Buna ziua,informatii,va rog ...VIN VF38DAHWTFL049975 ,multumesc.
peugeot 508 VIN
Originally posted by Miodrag View Postsalut! ma ajutati si pe mine cu ceva informatii despre masina mea? VIN VF38D5FV8AL037564 multumesc mult!
Caracteristicile vehiculului
Linie de produs 508
Nr. APV/PR 12460 CJ 1 0252
Data de Inceput de Garantie 28.02.2011
Numar de Serie Motor 10 FJBH 1046896
NRE e2*2007/46*0080*00
P4A 9665953199
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
LINIE DE PRODUS 508
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE INALTA JOASA
MOTOR INJECTIE EP6CDT
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCC
EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
MOTOR (TIP) MOTOR TIP EP
Caracteristici vehicul
DIRECTIE SISTEM DE DIRECTIE ASISTATA
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT FARA PLUMB 95 CALITATE A/B/E/E+
DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE MONTARE BOSCH
LANT DE TRACTIUNE FARA LANT DE TRACTIUNE HIBRID
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze - Transmisie
CUPLU RAPORT RAPORT PUNTE 17 X 71
STIL ROATA (JANTA) STIL 09 17 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
ROATA (TIP) MONTARE ROATA ALIAJ 3
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
LUMINA DE PRAG LUMINI DE PRAG FATA
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
SCAUN SPATE BANCHETA SEPARATA RABATABILA
DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GRADARE VITEZE GRADATIE IN KM/H
COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
CAPITONAJ DE USA DECOR TESATURA
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFISAJ AFISAJ DEV
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TRI TUNER RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
MODUL TELEMATIC MODUL TELEMATICA AUTONOM
Electricitate
ALTERNATOR ALTERNATOR CLASA 12
BATERIE L2 640
DEMAROR DEMAROR CLASA 3
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA ETICHETA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANTDiagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
Ba se deschide . Incearca de pe alt dispozitiv .
Sau de aici
https://ibb.co/0cwX3Ky
https://ibb.co/V9Vkybf
https://ibb.co/MnGsW3s
https://ibb.co/df2dWYP
https://ibb.co/0Y1g47K
https://ibb.co/3vV5Ysc
Sau
Linie de produs 508
Nr. APV/PR 13399 CJ 1 0254
Data de Inceput de Garantie 20.08.2013
Numar de Serie Motor 10 DYZE 4092944
NRE e2*2007/46*0080*13
P4A 9800966599
Informatii generale
LINIE DE PRODUS 508
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE INALTIME MEDIE PLUS
MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
CULOAREA CAROSERIEI KCJ - VOPSEA SIWA
TIP ECHIPARE INTERIOARA PIELE NAPPA "4H"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
Alimentare motor
CARBURANT MOTORINA CALITATE DA/DE/DE+
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR CU COMPUSI IMPREGNATI PESTE 50 PPM
RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
FILTRU DE PARTICULE CU FILTRU DE PARTICULE
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
CUPLU RAPORT RAPORT PUNTE 6 X 65
STIL ROATA (JANTA) STIL 05 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 98W RANFORSAT
ROATA (TIP) MONTARE ROATA ALIAJ 2
CUTIE DE VITEZE TIP ML6C
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
GEAM DE PAVILION CU GEAM DE PAVILION
PORTBAGAJ MONTARE CU BARE DE ACOPERIS
ROATA DE REZERVA FARA ROATA DE REZERVA
ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
Echipament interior
ALARMA ANTIFURT CU ALARMA ANTIFURT
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
INCALZIRE ADITIONALA SISTEM DE INCALZIRE HABITACLU SUPLIMENTAR PROGRAMABIL
ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE PIELE CLUB
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN FATA CU MEMORIE + REGLARE PARTE SUPERIOARA DE PERNA
AFISAJ AFISAJ DEV
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
COMANDA DE BLOCARE BLOCARE PRIN SUPRA INCHIDERE
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE L3 720 EF
DEMAROR DEMAROR CLASA 6+
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
Marci echipamente
Diverse
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
RULARE DRUM CORECT
Linie de produs 508
Nr. APV/PR 13252 CJ 1 0596
Data de Inceput de Garantie 12.03.2013
Numar de Serie Motor 10 DYZD 4041295
NRE e2*2007/46*0080*12
P4A 9802998799
Informatii generale
LINIE DE PRODUS 508
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
Alimentare motor
CILINDREE 2000 CM3
CUPLU RAPORT RAPORT PUNTE 15 X 53
AMBREIAJ FARA AMBREIAJ
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
Echipament interior
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
CAPITONAJ DE USA DECORATIUNE TEP
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
AFISAJ AFISAJ DEV
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
Electricitate
BATERIE L3 720 EF
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA FRANTA
RULARE DRUM CORECT
