peugeot 508 VIN
  • Caracteristicile vehiculului : VF38ERHHAEL044497
    Linie de produs 508
    Nr. APV/PR 13898 CJ 1 0080
    Data de Inceput de Garantie 20.02.2015
    Numar de Serie Motor 10 DYZD 4073154
    NRE e2*2007/46*0080*24
    P4A 9802998799
    Informatii generale
    GEN DE PRODUS VEHICUL PARTICULAR
    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
    LINIE DE PRODUS 508
    TIP CAROSERIE BREAK 5 USI
    NIVEL DE ECHIPARE INALTIME MEDIE PLUS
    MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
    TIP DE VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
    TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
    CULOARE GARNISAJ "FX"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
    EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
    MOTOR (TIP) MOTOR TIP EW/DW
    MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
    Caracteristici vehicul
    DIRECTIE SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT MOTORINA CALITATE DA/DE/DE+
    DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
    ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
    CILINDREE 2000 CM3
    RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRU DE PARTICULE CU FILTRU DE PARTICULE
    VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
    VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
    LANT DE TRACTIUNE FARA LANT DE TRACTIUNE HIBRID
    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
    STOP AND START FARA SISTEM STOP AND START
    Cutie de viteze - Transmisie
    CUPLU RAPORT RAPORT PUNTE 15 X 53
    STIL ROATA (JANTA) STIL 05 17 INCI
    AMBREIAJ FARA AMBREIAJ
    DIFERENTIAL (CUTIE) DIFERENTIAL 86
    JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 98W RANFORSAT
    ROATA (TIP) MONTARE ROATA ALIAJ 2
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
    CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
    SUSPENSIE SUSPENSIE NORMALA
    CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
    VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
    DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
    ANTENA ANTENA + GPS
    ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
    LUMINA DE PRAG LUMINI DE PRAG FATA
    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
    OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
    GEAM DE PAVILION CU GEAM DE PAVILION
    LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
    APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
    PORTBAGAJ MONTARE CU BARE DE ACOPERIS
    PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
    ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
    ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TRAPA DE PLAFON ACOPERIS FIX
    ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
    GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
    Echipament interior
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    SCAUN SPATE BANCHETA SEPARATA RABATABILA
    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    COTIERA DE SCAUN SPATE CU COTIERA SPATE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
    GRADARE VITEZE GRADATIE IN KM/H
    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
    ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
    LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
    GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
    CAPITONAJ DE USA DECOR TESATURA
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
    INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
    COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
    REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
    SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    BECURI DE PROIECTOR LAMPA CU HALOGEN
    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFISAJ AFISAJ ECRAN DIGITAL TACTIL
    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
    AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
    PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
    RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
    COVORAS DE PODEA (ASPECT) COVORASE TRAMONTANE
    DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
    TUNER-RADIO TRI TUNER RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
    STORURI LATERALE FARA TRANSPERANTE LATERALE
    ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
    FRECVENTA RADIO FRECVENTA RADIO ASIA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
    AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
    MODUL TELEMATIC FARA MODUL TELEMATIC
    Electricitate
    ALTERNATOR ALTERNATOR CLASA 18
    BATERIE L3 720 EF
    DEMAROR DEMAROR CLASA 6+
    ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
    Marci echipamente
    Diverse
    CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
    ATMOSFERA ATMOSFERA NORMALA
    ETICHETA FARA ETICHETA
    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
    PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
    SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
    ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
    RULARE DRUM CORECT
    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
    TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
    • Respectele mele.
      Pentru VIN VF38DRHC8DL019214, m-ar putea ajuta cineva sa aflu mai multe detalii?
      Multumesc anticipat.
        Linie de produs 508
        Nr. APV/PR 13279 CJ 1 0633
        Data de Inceput de Garantie 21.06.2013
        Numar de Serie Motor 10 DYZC 4030827
        NRE e2*2007/46*0080*12
        P4A 9667228099
        Informatii generale
        LINIE DE PRODUS 508
        TIP CAROSERIE BERLINA 4 USI
        TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
        TIP DE VOPSEA VOPSEA METALIZATA TREI STRATURI DE LAC
        CULOAREA CAROSERIEI KWE - VOPSEA ALB SIDEFAT
        CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
        EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
        MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
        Alimentare motor
        LANT DE TRACTIUNE LANT DE TRACTIUNE HIBRID
        STOP AND START CU STOP AND START
        DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
        CILINDREE 2000 CM3
        CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
        CUPLU RAPORT RAPORT PUNTE 17 X 74
        ROATA (TIP) MONTARE ROATA ALIAJ 7
        INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
        CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
        CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
        STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
        STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
        GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
        PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
        ROATA DE REZERVA FARA ROATA DE REZERVA
        Echipament interior
        PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
        MODUL TELEMATIC MODUL TELEMATICA AUTONOM
        CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
        TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
        IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
        BECURI DE PROIECTOR LAMPA CU DESCARCARE
        AFISAJ AFISAJ DEV
        FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
        PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
        RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
        REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
        DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
        DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
        STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
        ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
        FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
        Electricitate
        APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
        ALTERNATOR ISTT6
        BATERIE L3 800
        DEMAROR DEMAROR CLASA 5
        Marci echipamente
        Diverse
        CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
        ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
        RULARE DRUM CORECT
        • Multumesc mult, Wildman.
          • Salut,
            Ma pueti ajuta cu o verificare? Cred ca nu este ce spune.
            https://www.autovit.ro/anunt/peugeot-508-ID7GyZoM.html
            VIN VF38DRHC8DL059217
              Linie de produs 508
              Nr. APV/PR 13546 CJ 1 0045
              Data de Inceput de Garantie 16.09.2014
              Numar de Serie Motor 10 DYZC 4044591
              NRE e2*2007/46*0080*20
              P4A 9809323199
              Informatii generale
              LINIE DE PRODUS 508
              CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
              TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
              CULOARE GARNISAJ "FD"
              Alimentare motor
              CILINDREE 2000 CM3
              CATALIZATOR CATALIZATOR CU COMPUSI IMPREGNATI PESTE 50 PPM
              Echipament interior
              ECHIPAMENT PLANSA DE BORD DECORATIUNE IMITATIE LEMN
              CAPITONAJ DE USA DECORATIUNE TEP
              DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
              INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
              COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
              COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
              REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
              AFISAJ AFISAJ DEV
              INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
              AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
              Electricitate
              ALTERNATOR ISTT6
              BATERIE L3 800
              Marci echipamente
              Diverse
              RULARE DRUM CORECT
              Aceste informații sunt gratuite .
              La reprezentanță contra cost este posibil să obții mai multe , dacă mașina a avut intervenții în unități service autorizate .
              • Multumesc.
                • VF38D9HL0CL064300
                  Linie de produs 508
                  Nr. APV/PR 13038 CJ 1 0281
                  Data de Inceput de Garantie 03.10.2012
                  Numar de Serie Motor 10 JBEU 3031493
                  NRE e2*2007/46*0080*08
                  P4A 9803284499
                  Informatii generale
                  LINIE DE PRODUS 508
                  NIVEL DE ECHIPARE INALTA JOASA
                  MOTOR DIESEL TURBO DV6C
                  TRANSMISIE CUTIE DE VITEZE MANUALA5
                  CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
                  TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
                  CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
                  MOTOR (TIP) MOTOR TIP DV
                  Alimentare motor
                  CILINDREE 1600 CM3
                  RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
                  VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
                  CUPLU RAPORT RAPORT PUNTE 17 X 71
                  STIL ROATA (JANTA) STIL 02 16 INCI
                  AMBREIAJ AMBREIAJ HIDRAULIC
                  DIFERENTIAL (CUTIE) DIFERENTIAL 84
                  JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
                  PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
                  CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
                  ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
                  OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
                  ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
                  ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
                  Echipament interior
                  COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
                  ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
                  LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
                  TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
                  AFISAJ AFISAJ DEV
                  ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
                  ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
                  Electricitate
                  ALTERNATOR ALTERNATOR CLASA 15
                  BATERIE L2 640 EF
                  Marci echipamente
                  Diverse
                  SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
                  RULARE DRUM CORECT
                  • Buna ziua, imi puteti verifica va rog frumos VIN-ul VF38DRHH8EL026476
                    Multumesc mult!
                      Linie de produs 508
                      Nr. APV/PR 13748 CJ 1 0242
                      Data de Inceput de Garantie 30.01.2015
                      Numar de Serie Motor 10 DYZE 4120413
                      NRE e2*2007/46*0080*15
                      P4A 9806932799
                      Informatii generale
                      LINIE DE PRODUS 508
                      TRANSMISIE CUTIE DE VITEZE MANUALA6
                      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
                      Alimentare motor
                      CILINDREE 2000 CM3
                      CUPLU RAPORT RAPORT PUNTE 6 X 65
                      STIL ROATA (JANTA) STIL 09 17 INCI
                      ROATA (TIP) MONTARE ROATA ALIAJ 3
                      CUTIE DE VITEZE TIP ML6C
                      ANTENA ANTENA INTEGRATA
                      Echipament interior
                      SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
                      AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
                      RECEPTOR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT
                      COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
                      TUNER-RADIO TUNER DUBLU RADIO
                      Electricitate
                      BATERIE L3 720 EF
                      Marci echipamente
                      Diverse
                      RULARE DRUM CORECT
                      • Buna ziua.
                        Sunt nou pe forum și proaspăt posesor al unui 508, cu seria de șasiu VF38EAHWTFL020510.
                        V-as ruga și eu, dacă se pote, o fisa cu informații despre vehicul.
                        Va mulțumesc anticipat.
                        • Poftim , Balanel !
                          Linie de produs 508
                          Nr. APV/PR 14037 CJ 1 0012
                          Data de Inceput de Garantie 30.04.2015
                          Numar de Serie Motor 10 DYZL 4022933
                          NRE e2*2007/46*0080*28
                          P4A 9802301499
                          Informatii generale
                          LINIE DE PRODUS 508
                          MOTOR DIESEL DW10FC FAP 132KW
                          TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE TIP STOP AND START
                          MONOGRAMA COMPLEMENTARA, DIVERSE BLUE HDI
                          Alimentare motor
                          DEPOLUARE (MOTOR) DEPOLUARE MOTOR EURO 6.1
                          CILINDREE 2000 CM3
                          DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO 6.1
                          STIL ROATA (JANTA) ROATA LED ZEP DE 17" INCI
                          ROATA (TIP) MONTAJ ROATA ALIAJ 9
                          CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO6
                          ANTENA ANTENA + GPS
                          ROATA DE REZERVA ROATA TIP ROLA
                          Echipament interior
                          DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
                          DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE
                          Electricitate
                          ALTERNATOR ISTT53
                          BATERIE L3 760 VRLA2 EN AGM
                          Marci echipamente
                          Diverse
                          RULARE DRUM CORECT
                          E posibil ca pozele sa nu poata fi accesate de pe telefon
                          Sa fii sanatos si sa stapanesti masina fara evenimente neplacute !
                          • Salutare!
                            Se poate o decodare vin pentru VF38URHC8CL037022?
                            Multumesc!
                              Linie de produs 508
                              Nr. APV/PR 12926 CJ 1 0516
                              Data de Inceput de Garantie 20.04.2012
                              Numar de Serie Motor 10 DYZC 4006384
                              NRE e2*2007/46*0080*06
                              P4A 9667227999
                              Informatii generale
                              LINIE DE PRODUS 508
                              TIP CAROSERIE BREAK RXH
                              NIVEL DE ECHIPARE CU EXCEPTIA STANDARDULUI COBORAT
                              TIP ECHIPARE INTERIOARA PIELE CLUB NAPPA "8B"
                              Alimentare motor
                              CILINDREE 2000 CM3
                              STIL ROATA (JANTA) ROATA ALIAJ STIL GRAND ANGLE 18"
                              JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
                              PNEURI (DIMENSIUNI, TIP) PNEU 245/45 R18 W FARA INTARIRE
                              ROATA (TIP) ECHIPARE CU ROATA CU JANTA DIN ALIAJ 5
                              BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21,5
                              ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
                              FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
                              PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
                              Echipament interior
                              ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU + DEGRADE
                              CAPITONAJ DE USA DECORATIUNE PIELE CLUB
                              INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
                              COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN FATA CU MEMORIE + REGLARE PARTE SUPERIOARA DE PERNA
                              AFISAJ AFISAJ DEV
                              PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
                              Electricitate
                              ALTERNATOR ISTT6
                              BATERIE L3 800
                              Marci echipamente
                              Diverse
                              RULARE DRUM CORECT
                              • Multumesc!
