peugeot 508 VIN
  • #31
    Multumesc!
    • #32
      Multumesc
      • #33
        Detalii vin
        Pot afla detalii despre Vin VF38DRHC8DL032883 ? Multumesc
        • #34
          Caracteristicile vehiculului
          Linie de produs 508
          Nr. APV/PR 13356 CJ 1 0586
          Data de Inceput de Garantie 21.06.2013
          NRE e2*2007/46*0080*12
          P4A 9667228099
          Informatii generale
          GEN DE PRODUS VEHICUL PARTICULAR
          MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
          LINIE DE PRODUS 508
          TIP CAROSERIE BERLINA 4 USI
          NIVEL DE ECHIPARE INALTIME MEDIE PLUS
          MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
          TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
          TIP DE VOPSEA METALIZATA LACUITA
          CULOAREA CAROSERIEI KTH - VOPSEA GRI THORIUM
          TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
          CULOARE GARNISAJ "FX"
          CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
          EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
          MOTOR (TIP) MOTOR TIP EW/DW
          MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
          Caracteristici vehicul
          DIRECTIE SISTEM DE DIRECTIE ASISTATA
          Alimentare motor
          DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
          CARBURANT MOTORINA CALITATE DA/DE/DE+
          DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
          ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
          CILINDREE 2000 CM3
          CATALIZATOR CATALIZATOR CU COMPUSI IMPREGNATI PESTE 50 PPM
          RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
          REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
          INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
          AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
          DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
          DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
          FILTRU DE PARTICULE FILTRU DE PARTICULE
          VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
          VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
          LANT DE TRACTIUNE HIBRIDA LANT DE TRACTIUNE HIBRID
          FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
          STOP AND START CU STOP AND START
          Cutie de viteze - Transmisie
          CUPLU RAPORT RAPORT PUNTE 17 X 74
          STIL ROATA (JANTA) STIL 05 17 INCI
          AMBREIAJ FARA AMBREIAJ
          DIFERENTIAL (CUTIE) DIFERENTIAL 86
          JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
          PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 98W RANFORSAT
          ROATA (TIP) MONTARE ROATA ALIAJ 7
          INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
          CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
          BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
          ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
          SUSPENSIE SUSPENSIE NORMALA
          CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
          VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
          DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
          Caroserie Echipamente
          DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
          ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
          ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
          LUMINA DE PRAG LUMINI DE PRAG FATA
          SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
          INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
          FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
          INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
          STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
          STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
          STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
          OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
          GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
          LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
          BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
          APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
          PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
          PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
          ROATA DE REZERVA FARA ROATA DE REZERVA
          ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
          RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
          TRAPA DE PLAFON ACOPERIS FIX
          ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
          GEAM (ASPECT) GEAM FUMURIU
          GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
          ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
          Echipament interior
          ALARMA ANTIFURT FARA ALARMA ANTIFURT
          SCAUN SPATE BANCHETA SEPARATA RABATABILA
          DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
          COTIERA DE SCAUN SPATE CU COTIERA SPATE
          CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
          CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
          CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
          GRADARE VITEZE GRADATIE IN KM/H
          PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
          INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
          ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
          LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
          GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
          TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
          CAPITONAJ DE USA DECORATIUNE TEP
          DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
          COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
          IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
          INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
          COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
          COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
          REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
          REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
          SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
          BECURI DE PROIECTOR LAMPA CU DESCARCARE
          ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
          ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
          AFISAJ AFISAJ DEV
          OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
          INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
          FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
          AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
          ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
          PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
          NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
          PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
          PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
          RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
          REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
          REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
          INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
          RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
          REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
          DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
          TUNER-RADIO TRI TUNER RADIO
          DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
          STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
          ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
          AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
          FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
          COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
          VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
          AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
          ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
          PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
          MODUL TELEMATIC MODUL TELEMATICA AUTONOM
          Electricitate
          ALTERNATOR ISTT6
          BATERIE L3 800
          DEMAROR DEMAROR CLASA 5
          ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
          FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
          APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
          Marci echipamente
          Diverse
          CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
          ATMOSFERA ATMOSFERA NORMALA
          ETICHETA FARA ETICHETA
          CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
          PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
          SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
          ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
          RULARE DRUM CORECT
          MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
          TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
          • #35
            Salut! Daca se poate afla detalii despre VF38DRHH8BL073508 as fi recunoscator! Multumesc anticipat!
            • #36
              Linie de produs 508
              Nr. APV/PR 12713 CJ 1 0240
              Data de Inceput de Garantie 07.11.2011
              NRE e2*2007/46*0080*03
              P4A 9800966599
              Informatii generale
              LINIE DE PRODUS 508
              TRANSMISIE CUTIE DE VITEZE MANUALA6
              CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
              Alimentare motor
              CILINDREE 2000 CM3
              CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
              INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
              LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
              STOP AND START FARA SISTEM STOP AND START
              CUPLU RAPORT RAPORT PUNTE 6 X 65
              STIL ROATA (JANTA) STIL 09 17 INCI
              AMBREIAJ AMBREIAJ HIDRAULIC
              PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
              ROATA (TIP) MONTARE ROATA ALIAJ 3
              CUTIE DE VITEZE TIP ML6C
              OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
              PACHET ROTI MONTAJ PNEURI 17 INCI (DOL08) + MONTAJ JANTA ALIAJ 3 (DRP07) + FĂRĂ ROATĂ DE REZERVĂ (DRS00)
              Echipament interior
              COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
              DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
              INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
              COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
              AFISAJ AFISAJ DEV
              ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
              AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
              Electricitate
              ALTERNATOR ALTERNATOR CLASA 15
              BATERIE L3 720 EF
              Marci echipamente
              Diverse
              CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA FRANTA
              RULARE DRUM CORECT
              • #37
                Buna ziua, va rog mult pot afla si eu detalii despre VIN VF38D9HR8BL075374 ? Ma intereseaza sa am acces la echiparea autovehiculului, exact ca in raspunsurile de mai sus. Multumesc!
                • #38
                  Buna ziua! Daca se poate, doresc si eu detalii despre VIN VF38D9HDBELO4I872 . Multumesc in avans!
                  • #39
                    @ razomir
                    Mai degraba mai tarziu decat deloc
                    Linie de produs 508
                    Nr. APV/PR 12716 CJ 1 0219
                    Data de Inceput de Garantie 03.09.2011
                    P4A 9666506499
                    Informatii generale
                    LINIE DE PRODUS 508
                    MOTOR DIESEL TURBO DV6C
                    TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE STOP AND START
                    CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
                    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
                    MOTOR (TIP) MOTOR TIP DV
                    MONOGRAMA COMPLEMENTARA, DIVERSE E-HDI
                    Alimentare motor
                    CILINDREE 1600 CM3
                    VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
                    VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
                    CUPLU RAPORT RAPORT PUNTE 19 X 77
                    DIFERENTIAL (CUTIE) DIFERENTIAL 84
                    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
                    OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
                    ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
                    Echipament interior
                    AFISAJ AFISAJ DEV
                    ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
                    Electricitate
                    ALTERNATOR ISTT50
                    BATERIE L3 760 VRLA1 EN AGM
                    Marci echipamente
                    Diverse
                    ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
                    RULARE DRUM CORECT
                    • #40
                      Buna ! As dori si eu detalii despre VF38DRHH8DL021472 Multumesc frumos !
                      • #41
                        @ vmtopan
                        VIN eronat - vehiculul nu exista ; Ai scris litere in loc de cifre . Le-am inlocuit dar tot nu merge . Mai incearca o data poate dai un VIN corect .
                        • #42
                          @emcretu90
                          Linie de produs 508
                          Nr. APV/PR 13294 CJ 1 0184
                          Data de Inceput de Garantie 30.04.2013
                          NRE e2*2007/46*0080*13
                          P4A 9800966599
                          Informatii generale
                          LINIE DE PRODUS 508
                          CULOAREA CAROSERIEI KDM - VOPSEA CAFENIU INCHIS GUARANJA
                          TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
                          MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
                          Alimentare motor
                          DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
                          CILINDREE 2000 CM3
                          ROATA (TIP) MONTARE ROATA ALIAJ 2
                          CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
                          ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
                          Echipament interior
                          CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
                          CAPITONAJ DE USA DECOR TESATURA
                          IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
                          INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
                          COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
                          COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
                          REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
                          SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
                          AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
                          RECEPTOR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT
                          INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
                          REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
                          TUNER-RADIO TUNER DUBLU RADIO
                          DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
                          STORURI LATERALE FARA TRANSPERANTE LATERALE
                          FRECVENTA RADIO FRECVENTA RADIO ASIA
                          MODUL TELEMATIC FARA MODUL TELEMATIC
                          Electricitate
                          ALTERNATOR ALTERNATOR CLASA 18
                          BATERIE L3 720 EF
                          DEMAROR DEMAROR CLASA 6+
                          Marci echipamente
                          Diverse
                          RULARE DRUM CORECT
                          • #43
                            Multumesc !
                            • #44
                              Originally posted by wildman View Post
                              @ vmtopan
                              ai dreptate, l-am scris gresit. Am corectat acum: VF38D9HD8EL041872
                              • #45
                                Sa o stapanesti sanatos !!!
                                Linie de produs 508
                                Nr. APV/PR 13863 CJ 1 0191
                                Data de Inceput de Garantie 14.01.2015
                                NRE e2*2007/46*0080*24
                                P4A 9803147699
                                Informatii generale
                                LINIE DE PRODUS 508
                                NIVEL DE ECHIPARE MEDIE COBORATA
                                TIP DE VOPSEA VOPSEA OPACA
                                CULOAREA CAROSERIEI EWP - VOPSEA ALBA BANQUISE
                                TIP ECHIPARE INTERIOARA TESATURA SI URZEALA DROP "3B"
                                EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
                                Alimentare motor
                                CILINDREE 1600 CM3
                                STIL ROATA (JANTA) STIL 01 16 INCI
                                JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
                                PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
                                ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
                                INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
                                ANTENA ANTENA INTEGRATA
                                DECORATIUNE (ADEZIVA) ORNAMENT SPATE DE USA FATA + ORNAMENT FATA DE USA SPATE NEGRU MAT
                                LUMINA DE PRAG FARA LUMINA DE PRAG
                                FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
                                STERGATOR PARBRIZ INTERMITENTA REGLABILA
                                STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
                                PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
                                ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA NEUTRA
                                ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
                                Echipament interior
                                COTIERA DE SCAUN SPATE FARA COTIERA SPATE
                                ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
                                LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
                                TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
                                DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
                                INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 3 KG
                                BECURI DE PROIECTOR LAMPA CU HALOGEN
                                AFISAJ AFISAJ ECRAN DIGITAL TACTIL
                                OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
                                INDICATOR DE ULEI FARA INDICATOR DE NIVEL DE ULEI
                                ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
                                PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
                                RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
                                RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
                                COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
                                Electricitate
                                ALTERNATOR ISTT51
                                ILUMINAT DEOSEBIT LUMINI DE ZI FATA
                                APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
                                Marci echipamente
                                Diverse
                                CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII SIMPLA
                                SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
                                RULARE DRUM CORECT
