Mulțumesc =helios=
peugeot 508 VIN
Cred ca raspunsul e tardiv din pacate
VR3FHEHYRKY121159
508 (R8) HATCHBACK 5 UTI 2.0 HDI 163 (DW10FCC) 8 VITEZE AUTOMAT. TIP STT
Campanii de revizuireJTZ 308(T9), 3008(P84), 5008(P87), 508(R8) Logiciel Moteur CSN 04.02.2020 unsprezece KPL 508(R8) Portbagajul de acoperiș S.R. 20.07.2021 unsprezece K.W.J. Firmware ECU motor TT DW10F ER 07.11.2022 unsprezece KWL TT DW10F DPF ER 07.11.2022 unsprezece
Reparatie in garantie30.10.2023 1235002 01 2BQS83N01 00000000000KWLK FILTRE Ą PARTICULE SM KWL 164046 NL 05.12.2022 1235002 01 2BQRQ4K01 00000000000KPLK BARRE DE TOIT KPL 131685 NL 05.12.2022 1235002 01 2BQRQ4K02 00000000000KWJK FIRMWARE ECU MOTOR TT DW10F K.W.J. 131685 NL 21.09.2021 1235002 01 2BQQCCN01 9820632280 SUSPENSA SUTENIE D 61A 78624 NL 03.08.2021 1235002 01 2BQP6S401 000000000001612 CALCULATOR DE TELECHARCARE MOTEUR T 61A 73451 NL 12.05.2020 2243122 01 2BQN5Y001 00000000000JTZJ FIRMWARE ECU MOTOR JTZ 29023 NL 13.01.2020 2243122 01 2BQNM7M01 9821395680 MODUL 000 17916 NL 04.12.2019 2243122 01 2BQNGMI01 1616765780 ROTULE ATTELAGE RDSO 000 14192 NL
Caracteristicile vehiculului Model 508 (R8) Nr. APV/PR 15545 88 1 0247 Data īnceperii garanției 26.07.2019 data fabricatiei 01.06.2019 Numărul de serie al motorului 10 DY2T 4053892 NRE e2*2007/46*0628*02 P4A 9835724899 Informații generale FELUL PRODUSULUI O MAȘINĂ MARCA MARCA/TIP DE COMPONENT PEUGEOT LINEUPUL 508 (R8) CORP HATCHBACK 5 UȘI NIVEL DE FINISARE SUPER MEDIU MOTOR DW10FCC/UE62 2L DIESEL TRANSMITERE Transmisie automată cu 8 viteze. TIP STT TIP DE VOPSEA LAC METALIZ + CULOARE CULOAREA CORPULUI LQV - VOPSEA ROSIE ULTIMATE TIP FINISAJ INTERIOR COVORASE SUPERIOARE TEP PU FABRIC GT LINE "73" CULOARE TAPITERIE "FH" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) AMNG8 ORGANIZAREA CONVERSIEI FĂRĂ CONVERSIE FINISARE ĪN VINE GAMA ORIGINALA TIPUL MOTORULUI) EW/DW ALTE AUTOCOLANTE, DIVERSE " GT LINE Caracteristicile vehiculului NIVEL DE FINISARE SUPER MEDIU TIP DE VOPSEA LAC METALIZ + CULOARE CULOAREA CORPULUI LQV - VOPSEA ROSIE ULTIMATE TIP FINISAJ INTERIOR COVORASE SUPERIOARE TEP PU FABRIC GT LINE "73" CULOARE TAPITERIE "FH" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) AMNG8 Sistem de alimentare cu combustibil MOTOR DW10FCC/UE62 2L DIESEL SISTEM DE ALIMENTARE CON COMBUSTIBIL TURBO INJECTIE DIRECTA CU SCHIMBATOR DE CALDURA SENSOR DE APĂ ĪN FILTRUL DE CURĂȚARE COMBUSTIBIL DIESEL FĂRĂ FILTRU DE COMBUSTIBIL DIESEL SENSOR DE APA COMBUSTIBIL COMBUSTIBIL DIESEL DA/DE/DE+ CALITATE STANDARD DE EMISII DE GAZE DE ESAPAMENT (MOTOR) SISTEM DE REDUCERE A EMISIILOR DE MOTOR EURO 6.2 SEMNALUL SENZORULUI DE VITEZA SENSOR PENTRU ROTI FATA FARA IDENTIFICARE, ROTI SPATE CU IDENTIFICARE. TIPUL MOTORULUI) EW/DW PUTERE 2000CM3 REZERVOR DE COMBUSTIBIL REZERVORUL DE COMBUSTIBIL NU ESTE SIGLAȘAT CU INSTALARE PIECI MOTOR DE RĂCIRE RADIATOR EP28 28DM2, ALUMINIU, CURU ĪNCĂLZIREA CALEI DE GAZ CARTER CU GAZ. CIRCUIT DE ĪNCĂLZIRE AL CLĂDIRII SUNET SPECIF AL UNITĂȚII DE PUTERE GMP ACUSTICA ĪN DINAMICĂ SISTEM DE AUTODIAGNOSTICĂ LA BORD EOBD CU DIAGNOSTICĂ AUTO LA BORD INSTRUMENTE TEHNICE PENTRU PROTECȚIA MEDIULUI SISTEM DE EMISII EURO 6.2 FILTRUL DE PARTICULE CU FILTRU DE PARTICULE VENTILATOR 1 PANOU MOBIL AERO VENTILATOR 140 W 2 VITEZE RB45 UNITATEA DE ALIMENTARE CIRCUIT DE TRACȚIUNE CU GHEAZĂ FILTRUL REZERVORULUI DE COMBUSTIBIL FILTRU REZERVOR EXTERIOR OPRIȚI ȘI PORNIȚI SISTEMUL CU SISTEM STOP AND START SI ALTERNATOR-STARTER Cutie de viteze - Transmisie TRANSMITERE Transmisie automată cu 8 viteze. TIP STT CUTIA DE VITERE (SPECIFICAȚII TEHNICE) AMNG8 STILUL ROȚII DISC 17" DECO AMBREIAJ FĂRĂ AMBREIE DIMENSIUNEA PNEURI/ROȚI INSTALARE PNEURI DE 17 INCI PNEURI (TIP, DIMENSIUNE) ANVELOPE 215/55 R17 98W INFORTATA ROȚI MOTRICE 2 ROTI MOTRICE ROATA (TIP) ANSAMBLU ROȚE DE ALIAN 1 INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA INDIRECTĂ A PIERDEREI DE PRESIUNE ĪN ANVELOPE FĂRĂ LOCALIZARE TIP CUTIE CUTIE TIP AMN8 Suspensie Direcție Sistem de frānare ROLA DE STABILIZARE SPATE STABILIZATOR SPATE 18.5MM DIAM DISPOZITIV ANTIFURT COMUTATOR ELECTRIC DE Aprindere ROLL BAR STABILIZATOR FATA FAȚĂ DURITATE STABILIZATOR 25000 N.M/RAD TIP DE FRANA DISCURI FATA/SPATE VENTILATE unghiul volanului CU SENSOR DE unghiul volanului SUSPENSIE SUSPENSIUNE CONVENȚIONALĂ SISTEM DE STABILITATE DINAMICĂ PROGRAM DE STABILIZARE ELECTRONICĂ DIRECȚIE (PRINCIPIU DE FUNCȚIONARE) SERVODIRECȚIE ELECTRICĂ DE PUTERE MICĂ CU DOUĂ TRIPATE SUPORT PEDALA (TIP) BLOC PEDALA ALUMINIU Echipament de caroserie SISTEM DE REMORCARE FĂRĂ TURN MULTURA LATERALĂ (DIMENSIUNI) PROTECTIE LATERALA SUBTIRE + AMPRE PICIOARE PEUGEOT ELEMENTE DECORATIVE ALE ROȚILOR (STYL) FĂRĂ CAPAC ROȚĂ ȚEAVĂ DE EȘAPAMENT TUBA DE ESCAPARE CROMATA STANGA SUB ECRAN DEFLECTOR FRONTAL INFERIOR LAMPĂ DE PRAG DE UȘĂ FĂRĂ ILUMINARE DE PRAG FUNCȚIA OGLINZĂ EXTERIORĂ IN AFARA Oglinda CU ELECTRIC PLIERE CU MEMORIE SCUT DE MURDARIE Căptușeală aripă față stānga. ACOUST PER. SPATE+FATA DREAPTA DESCHIS TUBIERE DE ESCAPAR NU DEC. VARFURI TEVI DE ESCAPAMENT Izolarea fonica a compartimentului motor IZOLARE FONONIC COMPARTIMENT MOTOR + COMPARTIMENT + ISOVAC PARBRIZ (TIP) PARBRIZ STANDARD ȘTERGĂTOR DE PARBRIZ PERIE FRONTWISH DE LA DATA PLOIEI ȘTERGATORUL SPATE (PRINCIPIU DE FUNCȚIONARE) ȘTERGĂTOR DE GEAM BASTĂ DE BAZĂ BAMP. ANTERIOR POSTERIOR CULOARE CAROSERIE GRILĂ GTLINE+MODINE CROMĂ ĪNMATRICULARE FĂRĂ NUMĂR DE STAT GRILĂ DE PORTBAGAI FĂRĂ SINE PENTRU BAGAJE PE ACOPEȘ SISTEM DE ASISTERE PANORAMICĂ CU SISTEM DE ASISTENȚĂ VIZUALĂ PANORAMICĂ SPATE VISIO PARK1 ROATĂ DE REZERVĂ FARA ROATA DE rezerve Oglinda retrovizoare exterioară (sticlă) Oglinzi retrovizoare exterioare din sticlă cu acoperire cu electrocrom Oglinda retrovizoare exterioară (raza din partea șoferului) FĂRĂ CARACTERISTICI Oglinzile exterioare LUCA FĂRĂ VENTILAȚIE STICLA (ASPECT) STICLA NUAnțată + TENTAȚI GRELE FEREASTRĂ (TIP) PARBRIZ LAMINAT FONOABORBIANT + GEAM SPATE CALIT INTRAREA SI PORNIREA MOTORULUI FARA UTILIZAREA CHEIEI CU SISTEM DE ACCES/ PORNIRE FĂRĂ MĀINI Echipament intern TIP FINISAJ INTERIOR COVORASE SUPERIOARE TEP PU FABRIC GT LINE "73" COTIERA LATERALA (TIP) LATERAL FAŢĂ, COTIERE SPATE TEP PU+CUSĂTURĂ ALARMA ANTIFURT VOLUM + PERIMETRU + LIFT DETECȚIA PATELOR MOARTE MONITORIZAREA ACTIVĂ A PUNTURILOR MOARTE COTIERA SCANA SPATE CU COTIERA SCAUNA SPATE HAPA BAGAJE (TIP) HAPA BAGAJ TARI CLIMA (TEMPERATURA AERULUI AMBIENT) ȚĂRI CU CLIME RECE APARAT DE AER CONDITIONAT AER CONDIȚIONAT CU AERO+RECIRCULAT+IEȘIRE SUPLIMENTARĂ BLOC DE SIGURANȚĂ PENTRU SIGURANȚA COPIILOR SIGURANTA COPII, ELECTRICA SPATE. GRADAȚIE PE VITOMETRO CALIBRAREA VITOMETORULUI ĪN KM/H MANETA SCHIMBĂTORULUI DE VITEZE TREBUIE TREBUIE PE POSEA SI PE VOLAN MĀNĂRI FĂRĂ MĀNERE CONSOLĂ DECOR. CONSOLA LEMN+FLANSA COVOR POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA Īncălzitor suplimentar FĂRĂ ĪNCĂLZIRE SUPLIMENTARĂ LINK OGLINDĂ CU FUNCȚIE MIRROR LINK ILUMINAT PLATFORMĂ DE MARFĂ PORT PAGA LUMINA + USĂ + PU ILUMINAT PORTBAGAJE ȘI MARFĂ ILUMINARE AUTOMATĂ PORGAI + ILUMINARE MARFĂ 2 LED-uri ECHIPAMENTE PANOUL DE INSTRUMENTE FINISARE LEMN DESCHIS NATURAL DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LAMPĂ LED + ILUMINARE INTERIOARĂ + LAMPĂ INDIVIDUALĂ SPATE FINISARE PLATFORMĂ DE MARFĂ INSTALARE COVORURI + MOCHETARE PARDOSULUI TRUNGIULUI TABLUL DE INSTRUMENTE (CARACTERISTICI) PANOU DE INSTRUMENTE DIGITAL CU 29 DE INDICATORI PANOU DE COPIE UȘI LEMN DECORAT VORTORUL 5 PER. DINAM. +4 SPATE DINAM. +1 SUBWOOFER FILTRU DE PRAF FILTRU ANTIALERGEN IZOLAREA FONICĂ A INTERIORULUI FILA INTERIOR FONOIZ/PE POT HDG/P. ROATA DIN SPATE ISO REGLAREA ĪNĂLȚIMII SCAZULUI FAȚĂ PE LATEA PASagerului REGLAREA ELECTRICĂ A SCAZULUI PASAJUL, ĪNĂLȚIMIA ȘI NIVELUL PERNEI COMUTATOR DE REGLARE A SCACULUI SOFERULUI REGLAREA ELECTRICĂ A SCAUNULUI ȘOFER+REGLAREA CAPĂTULUI PERNEI COMUTATOR DE REGLARE A SCACULUI PASagerului PASARE FATA SCAUN ELECTRIC + REGLAREA PERNEI REGLAREA SCAUNULUI ȘOFERULUI SCAUN ELECTRIC ȘOFER AJUSTARE SUPORT LOMBAR REGLAREA SCAUNULUI PASagerului FAȚĂ SUPORT LOMBAR ELECTRONUMATIC PENTRU SCACUL PASagerului FAȚĂ CD FĂRĂ CD SISTEM DE NAVIGAȚIE prin satelit CU NAVIGAȚIE. SISTEM - ECRAN CULOARE FAURI LAMPA CU LED SISTEMUL DE INFORMAȚII ȘOFERULUI DE TRAFIC PREVENIREA DEVIERIEI + ȚINEREA PE TRAIECTOR APL AFIŞA DISPLAY FRONTAL ECRAN DIGITAL 10C HD Oglinda PE PARASOARE Oglinda Șofer + OGGLINDĂ PASager CU ILUMINARE LED UN ELEMENT DE ĪNCĂLZIRE SCAUNE ELECTRICE ĪNCĂLZITE ȘOFER ȘI PASAGER R1 AIRBAG LATERAL FRONTAL SUBSIGURANȚĂ LATERALĂ SIGURANȚA TORAX + PERDEA ILUMINAT CAMERA DE PIEDERI ILUMINAT PENTRU PICIOARE PENTRU ȘOFER + PASAGERI FAȚĂ ȘI SPATE PROTECTIE SCAUNEA SPATE FĂRĂ PROTECȚIE PASAGER SPATE SISTEM DE DEACTIVARE AIRBAG DECONECTARE MANUALĂ AIRBAG-UL SISTEM DE REGLARE FAURILOR REGLAREA AUTOMATĂ A FAURILOR WIFI Cu WIFI RADIO NAVIGARE DIGITALĂ ADAUGĂ SISTEM DE AER CONDITIONAT AER CONDITIONAT AUTOMAT CONTROL DE CRAZĂ CONTROL DE CRAZĂ ȘI LIMITATOR DE VITEZĂ ACC STOP AND GO REGLAREA ĪNĂLŢIMII SCAUNULUI ŞOFERULUI "RIDIC" SCAUNUL SOFER CU ELECTRICA AJUSTARE Oglinda retrovizoare interioara Oglinda retrovizoare interioara CU ACCESORII ELECTRO CROM FARA CADRU PARDOSELĂ COVOR NEGRU CU CUSCĂ DUBLĂ Oglinda retrovizoare exterioară (raza din partea șoferului) FĂRĂ CARACTERISTICI Oglinzile exterioare PLATFORMĂ DE MARFĂ FĂRĂ PLASA DE PORTBAGAI TUNER RADIO TUNER TRI-BAND SISTEM DE DETECȚIE A OBSTACULELOR DETECTOR DE OBSTACULE, RADAR FATA, SPATE INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA INDIRECTĂ A PIERDEREI DE PRESIUNE ĪN ANVELOPE FĂRĂ LOCALIZARE ADAPTARE FINISARE FĂRĂ ADAPTATOR DE MULTARE EGALISATOR, AMPLIFICATOR AMPLIFICATOR EGALIZATOR CU 12 CANALE FRECVENTA RADIO FRECVENȚA RADIO PENTRU EUROPA DE EST CONTROLUL SISTEMULUI DE BLOCARE BLOCARE SUPER BLOCARE + AUTOMAT FEREASTRĂ (TIP) PARBRIZ LAMINAT FONOABORBIANT + GEAM SPATE CALIT VOLAN VOLAN PLEINE FLEUR DIN PIELE PERFORATA CU INSERȚIE GTLINE VENTILATOR 1 PANOU MOBIL AERO VENTILATOR 140 W 2 VITEZE RB45 OPȚIUNI DE LOCARE OPTIUNE CU SCAZ JOS CONECTOR SUPLIMENTAR PENTRU CONECTAREA DISPOZITIVELOR AUDIO 1 JACK + 2 USB UNITATEA DE TELECOMUNICATII UNITATEA DE TELEMATICA AUTONOMA 3S Echipament electric ALTERNATOR GENERATOR ISTT53 BATERIE BATERIE BATERIE L3 760 70AH EFR 760 EN EF INCEPATOR CLASA DE STARTER 6+ ILUMINAT PLATFORMĂ DE MARFĂ PORT PAGA LUMINA + USĂ + PU ILUMINAT PORTBAGAJE ȘI MARFĂ ILUMINARE AUTOMATĂ PORGAI + ILUMINARE MARFĂ 2 LED-uri DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LAMPĂ LED + ILUMINARE INTERIOARĂ + LAMPĂ INDIVIDUALĂ SPATE LAMPĂ DE PRAG DE UȘĂ FĂRĂ ILUMINARE DE PRAG FUNCȚIA OGLINZĂ EXTERIORĂ IN AFARA Oglinda CU ELECTRIC PLIERE CU MEMORIE FRECVENTA DE OPERARE A COMANDEI DE LA DISTANTA INCHISARE CENTRALIZATĂ FRECVENTA TELECOMANDA 433,92 MHz, LO FAURI LAMPA CU LED COMUNICARE MULTIPLEX SISTEM ELECTRIC R3 ECO ILUMINAT CAMERA DE PIEDERI ILUMINAT PENTRU PICIOARE PENTRU ȘOFER + PASAGERI FAȚĂ ȘI SPATE SISTEM DE REGLARE FAURILOR REGLAREA AUTOMATĂ A FAURILOR Aprinderea LUMINILE PORNIRE AUTOMATĂ A LUMINII+COMUTARE AUTOMATĂ Marci de echipamente Diverse CARACTERISTICI SPECIALE STANDARD MODIFICĂRI FUCITE ĪN ANUL MODELULUI INDEX INFERIOR „00” CONDENSATOR (CARACTERISTICI) CONDENSATOR 19.3DM2 GROSIME 12 VREME ATMOSFERĂ ORDINARĂ POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA PLACA VIN PLACA TEHNICA UNIUNII EUROPENE + NRE STICKER FARA ETICHETA TUBATURA AER CONDITIONAT CONDUCTURI DE AER CONDIȚIONAT CU TEHNOLOGIA IHX CONECTOR PENTRU CONECTAREA CĂȘTILOR RADIOTELEFONICE PRISA DUBLA PENTRU ACCESORII GRAVE LATERALE PROTECTIE LATERALA INFORTATA SET DE CHEI SET CHEIE CU BLOCARE+CHEIE DE rezervă REFRIGERANT LICHID DE RĂCIRE 1234 YF ECHIPAMENTE DE URGENȚĂ KIT REPARARE ANVELOPE CONDIȚII Drumurilor Drum neted UNITATE DE CONTROL AUXILIAR BSI + COM 2008 + SON POLY + FINISAJ CROM TRIUNGHI DE AVERTIZARE FĂRĂ SEMN STOP DE AVERTIZARE
Pentru colegul Vlad
VR3FBYHZRKY115749
508 (R8) HATCHBACK 5 UTI 1.5 HDI 130 (DV5RC 96KW) 8 VITEZI AUTOMAT TIP STT
Campanii de revizuireJSZ TT Tuyau d'eau CSN 11.06.2020 unsprezece KPL 508(R8) Portbagajul de acoperiș S.R. 16.07.2021 unsprezece M.A.S. Tous tipuri de firmware ECU motor S.R. 26.07.2022 unsprezece
Reparatie in garantie16.01.2023 812308Q 95 XAFSFBO01 00000000000MASM FIRMWARE ECU MOTOR TOUS TYPES M.A.S. 168834 R.O. 23.11.2021 077001T 01 XAETBGL01 00000000000KPLK BARRE DE TOIT KPL 165517 Franţa 23.06.2021 077001T 01 XAEF1IS01 000000000001254 CLIMATIZAREA FCE 129643 Franţa 23.06.2021 077001T 01 XAEF1IS02 000000000009383 OPERATIONS SYSTEMATIQUES ENTRETIEN FCE 129643 Franţa 23.06.2021 077001T 01 XAEF1IS03 9823609180 BALAI PLAT G FCU 129643 Franţa 23.06.2021 077001T 01 XAEF1IS04 000000000009927 VEHICUL DE ASISTENȚĂ DE ĪNLOCUIRE F8R 129643 Franţa 25.01.2021 730304C 01 XAD1H2Z01 000000000009383 OPERATIONS SYSTEMATIQUES ENTRETIEN FCE 97834 Franţa 23.11.2020 730304C 01 XADUY6701 00004249K1 DISQUE VENTILE DIAM 304 E FCU 87069 Franţa 12.08.2020 077001T 01 XADKBGP01 000000000001254 CLIMATIZAREA FCE 66968 Franţa 12.08.2020 077001T 01 XADKBGP02 000000000009383 OPERATIONS SYSTEMATIQUES ENTRETIEN FCE 66968 Franţa 12.08.2020 077001T 01 XADKBGP03 9823609780 BALAI PLAT D FCU 66968 Franţa 12.08.2020 077001T 01 XADKBGP04 00000000000JSZJ TT TUYAU D'EAU JSZ 66968 Franţa 24.01.2020 730304C 01 XAC3X7G01 000000000009391 ENTRETIEN,SERVICE,ESSAI ANNUEL FCE 32942 Franţa
Caracteristicile vehiculului Model 508 (R8) Nr. APV/PR 15540 88 1 0848 Data īnceperii garanției 25.06.2019 data fabricatiei 27.05.2019 Numărul de serie al motorului 10 Q4DL 0010512 NRE e2*2007/46*0628*03 P4A 9835917699 Informații generale FELUL PRODUSULUI O MAȘINĂ MARCA MARCA/TIP DE COMPONENT PEUGEOT LINEUPUL 508 (R8) CORP HATCHBACK 5 UȘI NIVEL DE FINISARE MEDIE MARE PLUS MOTOR DV5RC 96KW 1.5L DIESEL TRANSMITERE Transmisie automată cu 8 viteze. TIP STT TIP DE VOPSEA TIP EXTERN FINISAJE METALIZATE. LAC CULOAREA CORPULUI KCA - VOPSEA GREY ARTENSE TIP FINISAJ INTERIOR TESTURĂ SEMI TEP +PU "72" CULOARE TAPITERIE "FX" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) ATNG8 ORGANIZAREA CONVERSIEI FĂRĂ CONVERSIE FINALIZARE ĪN VINE GAMA ORIGINALA TIPUL MOTORULUI) TIP MOTOR DV ALTE AUTOCOLANTE, DIVERSE " FĂRĂ SUPLIMENTARE EMBLEME Caracteristicile vehiculului NIVEL DE FINISARE MEDIE MARE PLUS TIP DE VOPSEA TIP EXTERN FINISAJE METALIZATE. LAC CULOAREA CORPULUI KCA - VOPSEA GREY ARTENSE TIP FINISAJ INTERIOR TESTURĂ SEMI TEP +PU "72" CULOARE TAPITERIE "FX" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) ATNG8 Sistem de alimentare cu combustibil MOTOR DV5RC 96KW 1.5L DIESEL SISTEM DE ALIMENTARE CON COMBUSTIBIL TURBO INJECTIE DIRECTA CU SCHIMBATOR DE CALDURA SENSOR DE APĂ ĪN FILTRUL DE CURĂȚARE COMBUSTIBIL DIESEL FĂRĂ FILTRU DE COMBUSTIBIL DIESEL SENSOR DE APA COMBUSTIBIL COMBUSTIBIL DIESEL DA/DE/DE+ CALITATE STANDARD DE EMISII DE GAZE DE ESAPAMENT (MOTOR) SISTEM DE REDUCERE A EMISIILOR DE MOTOR EURO 6.2 SEMNALUL SENZORULUI DE VITEZA SENSOR PENTRU ROTI FATA FARA IDENTIFICARE, ROTI SPATE CU IDENTIFICARE. TIPUL MOTORULUI) TIP MOTOR DV PUTERE 1500 CM3 REZERVOR DE COMBUSTIBIL REZERVORUL DE COMBUSTIBIL NU ESTE SIGLAȘAT CU INSTALARE PIECI MOTOR DE RĂCIRE RADIATOR EP28 28DM2, ALUMINIU, CURU ĪNCĂLZIREA CALEI DE GAZ CARTER CU GAZ. CIRCUIT DE ĪNCĂLZIRE A CLĂDIRII SUNET SPECIF AL UNITĂȚII DE PUTERE FĂRĂ IZOLAREA ACUSTICĂ A UNITĂȚII DE PUTERIE SISTEM DE AUTODIAGNOSTICĂ LA BORD EOBD CU DIAGNOSTICĂ AUTO LA BORD INSTRUMENTE TEHNICE PENTRU PROTECȚIA MEDIULUI SISTEM DE EMISII EURO 6.2 FILTRUL DE PARTICULE CU FILTRU DE PARTICULE VENTILATOR VENTILATOR CU 2 VITEZE 140 W PANOU MOBIL AERO UNITATEA DE ALIMENTARE CIRCUIT DE TRACȚIUNE CU GHEAZĂ FILTRUL REZERVORULUI DE COMBUSTIBIL FILTRU REZERVOR EXTERIOR OPRIȚI ȘI PORNIȚI SISTEMUL CU SISTEM STOP AND START Cutie de viteze - Transmisie TRANSMITERE Transmisie automată cu 8 viteze. TIP STT CUTIA DE VITERE (SPECIFICAȚII TEHNICE) ATNG8 STILUL ROȚII DISC 17" DECO AMBREIAJ FĂRĂ AMBREIE DIMENSIUNEA PNEURI/ROȚI INSTALARE PNEURI DE 17 INCI PNEURI (TIP, DIMENSIUNE) ANVELOPE 215/55 R17 98W INFORTATA ROȚI MOTRICE 2 ROTI MOTRICE ROATA (TIP) ANSAMBLU ROȚE DE ALIAN 1 INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA INDIRECTĂ A PIERDEREI DE PRESIUNE ĪN ANVELOPE FĂRĂ LOCALIZARE TIP CUTIE Cutie de viteze TIP ATN8 Suspensie Direcție Sistem de frānare ROLL BAR STABILIZATOR SPATE STABILIZATOR SPATE 17.5MM DIAM DISPOZITIV ANTIFURT COMUTATOR ELECTRIC DE Aprindere ROLL BAR STABILIZATOR FAȚĂ FAȚĂ DURITATE STABILIZATOR 25000 N.M/RAD TIP DE FRANA DISCURI FATA/SPATE VENTILATE unghiul volanului CU SENSOR DE unghiul volanului SUSPENSIE SUSPENSIUNE CONVENȚIONALĂ SISTEM DE STABILITATE DINAMICĂ PROGRAM DE STABILIZARE ELECTRONICĂ DIRECȚIE (PRINCIPIU DE FUNCȚIONARE) SERVODIRECȚIE ELECTRICĂ DE PUTERE MICĂ CU DOUĂ TRIPATE SUPORT PEDALA (TIP) UNITATE DE PEDALA SIMPLU STANDARD Echipament de caroserie SISTEM DE REMORCARE FĂRĂ TURN MULTURA LATERALĂ (DIMENSIUNI) FĂRĂ ELEMENTE DE PROTECȚIE ĪN PARTEA INFERIOR A CORPULUI ELEMENTE DECORATIVE ALE ROȚILOR (STYL) FĂRĂ CAPAC ROȚĂ ȚEAVĂ DE EȘAPAMENT FĂRĂ TUBA DE ESCAPAMENT SUB ECRAN DEFLECTOR FRONTAL INFERIOR LAMPĂ DE PRAG DE UȘĂ FĂRĂ ILUMINARE DE PRAG FUNCȚIA OGLINZĂ EXTERIORĂ Oglinda exterioara cu pliere electrica si LED SCUT DE PURZIUNE Căptușeală aripă față stānga. ACOUST PER. SPATE+FATA DREAPTA DESCHIS TIMITE TEVI DE ESCAPARE TUBA DE ESCAPARE CROMATA Izolarea fonica a compartimentului motor IZOLARE FONONIC COMPARTIMENT MOTOR + COMPARTIMENT + ISOVAC PARBRIZ (TIP) PARBRIZ STANDARD ȘTERGĂTOR DE PARBRIZ PERIE FRONTWISH DE LA DATA PLOIEI ȘTERGATORUL SPATE (PRINCIPIU DE FUNCȚIONARE) ȘTERGĂTOR DE GEAM BASTĂ DE BAZĂ STANDARD BARĂ FAȚĂ/SPATE, CULOAREA CAROSERIEI ĪNMATRICULARE FĂRĂ NUMĂR DE STAT GRILĂ DE PORTBAGAI FĂRĂ SINE PENTRU BAGAJE PE ACOPEȘ SISTEM DE ASISTERE PANORAMICĂ CU SISTEM DE ASISTENȚĂ VIZUALĂ PANORAMICĂ SPATE VISIO PARK1 ROATĂ DE REZERVĂ ROATA DE rezerve mai mica Oglinda retrovizoare exterioară (sticlă) Oglinda exterioara pictata pe sticla Oglinda retrovizoare exterioară (raza din partea șoferului) FĂRĂ CARACTERISTICI Oglinzile exterioare LUCA FĂRĂ VENTILAȚIE STICLA (ASPECT) STICLA NUAnțată + TENTAȚI GRELE FEREASTRĂ (TIP) PARBRIZ LAMINAT FONOABORBIANT + GEAM SPATE CALIT INTRAREA SI PORNIREA MOTORULUI FARA UTILIZAREA CHEIEI CU SISTEM DE ACCES/ PORNIRE FĂRĂ MĀINI Echipament intern TIP FINISAJ INTERIOR TESTURĂ SEMI TEP +PU "72" COTIERA LATERALA (TIP) COTIERA LATERALA FATA SPATE TER PU ALARMA ANTIFURT FARA ALARMA ANTIFURT DETECȚIA PATELOR MOARTE MONITORIZARE ACTIVĂ A PUNTURILOR MOARTE COTIERA SCANA SPATE CU COTIERA SCAUNA SPATE HAPA BAGAJE (TIP) HAPA BAGAJ TARI CLIMA (TEMPERATURA AERULUI AMBIENT) ȚĂRI CU CLIME RECE APARAT DE AER CONDITIONAT CU ĪNCĂLZIRE+IEȘIRE SUPLIMENTARĂ BLOC DE SIGURANȚĂ PENTRU SIGURANȚA COPIILOR SIGURANTA COPII SPATE MANUALA GRADAȚIE PE VITOMETRO CALIBRAREA VITOMETORULUI ĪN KM/H MANETA SCHIMBĂTORULUI DE VITEZE TREBUIE TREBUIE PE POSEA SI PE VOLAN māner FĂRĂ MĀNERE CONSOLĂ DECOR CONSOLA NEGRU ĪNALT+FLANȘĂ COVOR POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA Īncălzitor suplimentar FĂRĂ ĪNCĂLZIRE SUPLIMENTARĂ LINK OGLINDĂ CU FUNCȚIE MIRROR LINK ILUMINAT PLATFORMĂ DE MARFĂ CUTIE DE DEPOZITARE SUB RĀNDUL 1 COTIERA CENTRALĂ ILUMINAT PORTBAGAJE ȘI MARFĂ ILUMINARE AUTOMATĂ PORGAI + ILUMINARE MARFĂ 2 LED-uri ECHIPAMENTE PANOUL DE INSTRUMENTE FINIS CARBON DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LAMPĂ LED + ILUMINARE INTERIOARĂ + LAMPĂ INDIVIDUALĂ SPATE FINISARE PLATFORMĂ DE MARFĂ INSTALARE COVORURI + MOCHETARE PARDOSULUI TRUNGIULUI TABLUL DE INSTRUMENTE (CARACTERISTICI) PANOU DE INSTRUMENTE DIGITAL CU 29 DE INDICATORI PANOU DE COPIE UȘI FINISARE USI CU FIBRA DE CARBON VORTORUL 4 VOLUM FAȚĂ (2 TWEETERE + 2 GR.) + 4 GR. SPATE FILTRU DE PRAF CU FILTRU + CARBON ACTIVAT IZOLAREA FONICĂ A INTERIORULUI FILA INTERIOR FONOIZ/PE POT HDG/P. ROATA DIN SPATE ISO REGLAREA ĪNĂLȚIMII SCAZULUI FAȚĂ PE LATEA PASagerului CONTROL DE TRAFIC Căptușeală pentru scaunul pasagerului COMUTATOR DE REGLARE A SCACULUI SOFERULUI REGLAREA MANUALĂ A PERNEI ȘOFERULUI COMUTATOR REGLARE SCAUN PASager REGLAREA MANUALĂ A PERNEI SCAZUL PASagerului FAȚĂ REGLAREA SCAUNULUI ȘOFERULUI SPATAR REGLABIL, SUPPORT LOMBAR PENTRU SCAZUL SOFERULUI REGLAREA SCAUNULUI PASagerului FAȚĂ SPATAR REGLABIL SI SUPPORT LOMBAR PENTRU SCAUNUL PASager CD FĂRĂ CD SISTEM DE NAVIGAȚIE prin satelit CU NAVIGAȚIE. SISTEM - ECRAN CULOARE FAURI LAMPĂ CU HALOGEN SISTEMUL DE INFORMAȚII ȘOFERULUI DE TRAFIC AVERTISMENT+CORECȚIE+DETECȚIE BRUTARE AFIŞA DISPLAY FRONTAL ECRAN DIGITAL 10C HD Oglinda PE PARASOARE Oglinda Șofer + OGGLINDĂ PASager CU ILUMINARE LED UN ELEMENT DE ĪNCĂLZIRE SCAUN NEINCALZIT AIRBAG LATERAL FRONTAL SUBSIGURANȚĂ LATERALĂ SIGURANȚA TORAX + PERDEA ILUMINAT CAMERA DE PIEDERI ILUMINAT PENTRU PICIOARE PENTRU ȘOFER + PASAGERI FAȚĂ ȘI SPATE PROTECTIE SCAUNEA SPATE FĂRĂ PROTECȚIE PASAGER SPATE SISTEM DE DEACTIVARE AIRBAG DECONECTARE MANUALĂ AIRBAG-UL SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ WIFI Cu WIFI RADIO NAVIGAȚIE ANALOGĂ ATASATĂ SISTEM DE AER CONDITIONAT AER CONDITIONAT AUTOMAT CONTROL DE CRAZĂ CONTROL DE CRAZĂ PROGRAMABILE ȘI LIMITATOR DE VITEZĂ REGLAREA ĪNĂLŢIMII SCAUNULUI ŞOFERULUI REGLAREA MECANĂ A ĪNĂLŢIMII PERNEA SCAZULUI ŞOFER Oglinda retrovizoare interioara Oglinda retrovizoare interioara ELECTROCROMICA "ZI-NOAPTE" PARDOSELĂ COVOR NEGRU CU CUSCUT+PVC OTD Oglinda retrovizoare exterioară (raza din partea șoferului) FĂRĂ CARACTERISTICI Oglinzile exterioare PLATFORMĂ DE MARFĂ FĂRĂ PLASA DE PORTBAGAI TUNER RADIO TUNER RADIO DUAL SISTEM DE DETECȚIE A OBSTACULELOR DETECTOR DE OBSTACULE, RADAR FATA, SPATE INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA INDIRECTĂ A PIERDEREI DE PRESIUNE ĪN ANVELOPE FĂRĂ LOCALIZARE ADAPTARE FINISARE FARA ADAPTATOR DE MULTARE EGALISATOR, AMPLIFICATOR FARA AMPLIFICATOR CU EGALISATOR FRECVENTA RADIO FRECVENȚA RADIO PENTRU EUROPA DE EST CONTROLUL SISTEMULUI DE BLOCARE BLOCARE SIMPLU + AUTOMAT FEREASTRĂ (TIP) PARBRIZ LAMINAT FONOABORBIANT + GEAM SPATE CALIT VOLAN HUSĂ DE PIELE „FLEUR” PENTRU VOLAN VENTILATOR VENTILATOR CU 2 VITEZE 140 W PANOU MOBIL AERO OPȚIUNI DE LOCARE OPTIUNE CU SCAZ JOS CONECTOR SUPLIMENTAR PENTRU CONECTAREA DISPOZITIVELOR AUDIO 1 JACK + 2 USB UNITATEA DE TELECOMUNICAȚII UNITATEA DE TELEMATICA AUTONOMA 3S Echipament electric ALTERNATOR GENERATOR CLASA 18 BATERIE BATERIE BATERIE L3 760 70AH EFR 760 EN EF INCEPATOR STARTER STTD ILUMINAT PLATFORMĂ DE MARFĂ CUTIE DE DEPOZITARE SUB RĀNDUL 1 COTIERA CENTRALĂ ILUMINAT PORTBAGAJE ȘI MARFĂ ILUMINARE AUTOMATĂ PORGAI + ILUMINARE MARFĂ 2 LED-uri DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LAMPĂ LED + ILUMINARE INTERIOARĂ + LAMPĂ INDIVIDUALĂ SPATE LAMPĂ DE PRAG DE UȘĂ FĂRĂ ILUMINARE DE PRAG FUNCȚIA OGLINZĂ EXTERIORĂ Oglinda exterioara cu pliere electrica si LED FRECVENTA DE OPERARE A COMANDEI DE LA DISTANTA INCHISARE CENTRALIZATĂ FRECVENTA TELECOMANDA 433,92 MHz, LO FAURI LAMPĂ CU HALOGEN COMUNICARE MULTIPLEX SISTEM ELECTRIC R3 ECO ILUMINAT CAMERA DE PIEDERI ILUMINAT PENTRU PICIOARE PENTRU ȘOFER + PASAGERI FAȚĂ ȘI SPATE SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ Aprinderea LUMINILOR PORNIRE AUTOMATĂ A LUMINII+COMUTARE AUTOMATĂ Marci de echipamente Diverse CARACTERISTICI SPECIALE STANDARD CONDENSATOR (CARACTERISTICI) CONDENSATOR 19.3DM2 GROSIME 12 VREME ATMOSFERĂ ORDINARĂ POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA PLACA VIN PLACA TEHNICA UNIUNII EUROPENE + NRE STICKER FARA ETICHETA TUBATURA AER CONDITIONAT CONDUCTURI DE AER CONDIȚIONAT CU TEHNOLOGIA IHX CONECTOR PENTRU CONECTAREA CĂȘTILOR RADIOTELEFONICE PRISA DUBLA PENTRU ACCESORII GRAVE LATERALĂ PROTECTIE LATERALA INFORTATA SET DE CHEI SET CHEIE CU BLOCARE+CHEIE DE rezervă REFRIGERANT LICHID DE RĂCIRE 1234 YF ECHIPAMENTE DE URGENȚĂ FĂRĂ ECHIPAMENT DE BACKUP CONDIȚII Drumurilor Drum neted UNITATE DE CONTROL AUXILIAR BSI + COM 2008 + SON POLY + FINISAJ CROM TRIUNGHI DE AVERTIZARE FĂRĂ SEMN STOP DE AVERTIZARE
Originally posted by takle View PostSalutare!Cine poate sa ma ajute cu niste informatii despre nivelul de echipare pt masina mea peugeot 3008 1.2 130CP VF3MRHNYWJS047219.Multumesc!
VF3MRHNYWJS047219
3008 (P84E) CROSSOVER 5 UȘI 1.2 i THP 130 (EB2DTS) 6 VITEZI TRANSMISIE AUTOMATĂ TIP STT
Campanii de revizuireHZH 3008(P84),5008(P87): Soft BSI RSU 23.02.2018 unsprezece KGH Distribuția Tous tip Courroie S.R. 09.12.2022 unsprezece
Reparatie in garantie19.10.2023 3305004 01 4CESML801 9675350280 BOITIER PGA 61A 38118 FI 12.10.2023 3305004 01 4CESKNB01 00000000000KGHK DISTRIBUȚIE COURROIE KGH 38063 FI 22.11.2022 3305004 01 4CEP68N01 000000000009391 ENTRETIEN,SERVICE,ESSAI ANNUEL FCE 32915 FI 22.11.2022 3305004 01 4CEP68N02 1678168480 JEU 4 PLAQUETE FCU 32915 FI 13.07.2021 3305004 01 4CEMITH01 000000000009383 OPERATIONS SYSTEMATIQUES ENTRETIEN FCE 26375 FI 13.07.2020 3305004 01 4CEJJJH01 000000000009383 OPERATIONS SYSTEMATIQUES ENTRETIEN FCE 19931 FI 16.04.2019 3305004 01 4CEFSLH01 00000000000HZHH SOFT BSI HZH 11702 FI 16.04.2019 3305004 01 4CEFSLH02 000000000009391 ENTRETIEN,SERVICE,ESSAI ANNUEL FCE 11702 FI
Caracteristicile vehicululuiModel 3008 (P84E) Nr. APV/PR 15033 89 2 0852 Data īnceperii garanției 30.01.2018 data fabricatiei 01/05/2018 Numărul de serie al motorului 10 XTA4 0929532 NRE e2*2007/46*0534*04 P4A 9817422799 Informații generale FELUL PRODUSULUI O MAȘINĂ MARCA MARCA/TIP DE COMPONENT PEUGEOT LINEUPUL 3008 (P84E) CORP CROSSOVER 5 UȘI NIVEL DE FINISARE MEDIE MARE PLUS MOTOR INJECTIE EB2DTS 96KW TRANSMITERE 6-viteze TRANSMISIE AUTOMATĂ TIP STT TIP DE VOPSEA SMAL CU LAC CU METAL CULOAREA CORPULUI KCA - VOPSEA GREY ARTENSE TIP FINISAJ INTERIOR PIELE CLAUDIA MISTRAL L019 "QR" CULOARE TAPITERIE "FX" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) transmisie automată AT6 FINALIZARE ĪN VINE GAMA ORIGINALA TIPUL MOTORULUI) TIP MOTOR EB ACOPERIS (VEDERE EXTERIOR) CULOAREA CORPOIULUI ALTE AUTOCOLANTE FĂRĂ SUPLIMENTARE EMBLEME ALTE AUTOCOLANTE, DIVERSE " FĂRĂ SUPLIMENTARE EMBLEME EMBLEME FĂRĂ SUPLIMENTARE EMBLEME Caracteristicile vehiculului NIVEL DE FINISARE MEDIE MARE PLUS TIP DE VOPSEA SMAL CU LAC CU METAL CULOAREA CORPULUI KCA - VOPSEA GREY ARTENSE TIP FINISAJ INTERIOR PIELE CLAUDIA MISTRAL L019 "QR" CULOARE TAPITERIE "FX" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) transmisie automată AT6 ACOPERIS (VEDERE EXTERIOR) CULOAREA CORPOIULUI Sistem de alimentare cu combustibil MOTOR INJECTIE EB2DTS 96KW SISTEM DE ALIMENTARE CON COMBUSTIBIL TURBO INJECTIE DIRECTA CU SCHIMBATOR DE CALDURA SENSOR DE APĂ ĪN FILTRUL DE CURĂȚARE COMBUSTIBIL DIESEL FĂRĂ FILTRU DE COMBUSTIBIL DIESEL SENSOR DE APA COMBUSTIBIL BENZINA FĂRĂ PLUMB 95 CALITATE A/B/E/E+ STANDARD DE EMISII DE GAZE DE ESAPAMENT (MOTOR) SISTEM DE REDUCERE A EMISIILOR DE MOTOR EURO 6.1 SEMNALUL SENZORULUI DE VITEZA SENSOR PENTRU ROTI FATA FARA IDENTIFICARE, ROTI SPATE CU IDENTIFICARE. TIPUL MOTORULUI) TIP MOTOR EB PUTERE 1200 CM3 CONVERTOR CATALITIC CONVERTITOR CALITIC INFERIOR 50PPM REZERVOR DE COMBUSTIBIL REZERVOR DE COMBUSTIBIL FĂRĂ CHEIE MOTOR DE RĂCIRE RADIATOR 28DM2 18 ALUMINIU GRESO, LIPITURA PERFO ĪNCĂLZIREA CALEI DE GAZ CARTER FĂRĂ CIRCUIT DE GAZ ĪNCĂLZIRE CLĂDIR SUNET SPECIF AL UNITĂȚII DE PUTERE FĂRĂ IZOLAREA ACUSTICĂ A UNITĂȚII DE PUTERIE SISTEM DE AUTODIAGNOSTICĂ LA BORD EOBD CU DIAGNOSTICĂ AUTO LA BORD INSTRUMENTE TEHNICE PENTRU PROTECȚIA MEDIULUI VEHICUL CU EMISII EURO 6.1 FILTRUL DE PARTICULE FARA FILTRU DE PARTICULE VENTILATOR 1 VENTILATOR DYNAMIQUE AERO VOLET 95W CU 2 VITEZE OPȚIUNI DE CONFIGURARE A SISTEMULUI DE INJECȚIE SISTEM DE INJECȚIE VALEO UNITATEA DE ALIMENTARE CIRCUIT DE TRACȚIUNE CU GHEAZĂ FILTRUL REZERVORULUI DE COMBUSTIBIL FILTRU REZERVOR INTERN OPRIȚI ȘI PORNIȚI SISTEMUL CU SISTEM STOP AND START Cutie de viteze - Transmisie TRANSMITERE 6-viteze TRANSMISIE AUTOMATĂ TIP STT CUTIA DE VITERE (SPECIFICAȚII TEHNICE) transmisie automată AT6 RAPORTUL DE ACTIONARE FINAL PERECHE DE ACȚIUNI FINALE 15 X 61 STILUL ROȚII JANTE DE ALIE DETROIT ĪNALTE 18" 7.5 J18 CH 5-49 AMBREIAJ FĂRĂ AMBREIE PNEURI (TIP, DIMENSIUNE) ANVELOPE 225/55 R18 98 V NEARMATURA ROȚI MOTRICE 2 ROTI MOTRICE ROATA (TIP) ANSAMBLU ROȚE DE ALIAN 1 INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA PIERDERI DE PRESIUNE CU ANVELOPE CU LOCALIZAREA ROȚII TIP CUTIE AT6 3 CUTIE DE VITERE Suspensie Direcție Sistem de frānare ROLL BAR STABILIZATOR SPATE ROLL BAR STABILIZATOR SPATE CU RIGIDITATE 30000 N.M/RAD ROLL BAR STABILIZATOR FATA ROLL BAR STABILIZATOR FATA, RIGIDITATE 30000 N.M/RAD TIP DE FRANA DISCURI FATA/SPATE VENTILATE unghiul volanului CU SENSOR DE unghiul volanului SUSPENSIE SUSPENSIUNE CONVENȚIONALĂ SISTEM DE STABILITATE DINAMICĂ PROGRAM DE STABILIZARE ELECTRONICĂ DIRECȚIE (PRINCIPIU DE FUNCȚIONARE) SERVODIRECȚIE ELECTRICĂ CU O SINGURĂ PUTERE DE PUTERE MICĂ SUPORT PEDALA (TIP) UNITATE DE PEDALE STANDARD Echipament de caroserie SISTEM DE REMORCARE FĂRĂ TURN SEMNALE SUNETARE SEMNALE SUNETARE - MELODICE MULTURA LATERALĂ (TIP) MULTURI DE PROTECȚIE LATERALĂ CROMATE MULTURA LATERALĂ (DIMENSIUNI) FARA PROTECTII LATERALE+SUPPORT PLASTIC ȚEAVĂ DE EȘAPAMENT SISTEM SIMPLU DE EVACUARE SUB ECRAN DEFLECTOR FRONTAL INFERIOR ECRAN SUPLIMENTAR (SUB MOTOR) FARA PROTECTIE CARTER MOTOR REȚINERE PENTRU ASIGURAREA ĪNCĂRCĂRII ĪN EXTERIOR CAROSERIEI (ATCHES) FĂRĂ OCHIUL DE REMORCARE EXTERN FUNCȚIA OGLINZĂ EXTERIORĂ IN AFARA Oglinda CU ELECTRIC PLIERE CU MEMORIE Izolarea fonica a compartimentului motor SOUMOISOL. rafturi + hota + roata. ARKA + GMP ACOPERIS (VEDERE EXTERIOR) CULOAREA CORPOIULUI PARBRIZ (TIP) PARBRIZ STANDARD ȘTERGĂTOR DE PARBRIZ PERIE FRONTWISH DE LA DATA PLOIEI CURĂȚAT FAURI FĂRĂ ȘTERGĂTOR DE FAURI COMUTATOR PANOUL FRONTAL FĂRĂ BUCĂ BARĂ FAȚĂ STICLA TRAPA ACOPERȘ CULISANT DE STICLĂ ĪN PRIMIAL DESCHIS ANTI-PATCH BASTĂ DE BAZĂ BARĂ DE BĂRĂ CULOARE + GRILĂ CU 2 căptușeli cromate + CAPETE PLASTIC LAMPĂ DE CĂTĂ FAȚĂ LAMPURI DE CATA FATA SISTEM DE ASISTERE PANORAMICĂ FĂRĂ FUNCȚIE DE ASISTENȚĂ PANORAMICĂ ROATĂ DE REZERVĂ JANTE aliaj+STANDARD. OBOSI Oglinda retrovizoare exterioară (raza din partea șoferului) STICLA CONVEXA A OGLIZIEI EXTERIOARE STICLA (ASPECT) STICLA NUAnțată + TENTAȚI GRELE INTRAREA SI PORNIREA MOTORULUI FARA UTILIZAREA CHEIEI ACCES UȘĂ FAȚĂ + PORGAI + PORNIRE MĀINI LIBERE Echipament intern TIP FINISAJ INTERIOR PIELE CLAUDIA MISTRAL L019 "QR" COTIERA LATERALA (TIP) COTIERA LATERALA FATA SPATE TER ALARMA ANTIFURT FARA ALARMA ANTIFURT ABRICHETA FĂRĂ ABRICHETĂ DETECȚIA PATELOR MOARTE CU SISTEM DE MONITORIZAREA ANGULUI ORB HAPA BAGAJE RAFT REVISTA Centura de siguranta fata SIGURANȚA REPARAȚILOR CU PYROT.PRODENT. ȘI SEMNAL. CLIMA (TEMPERATURA AERULUI AMBIENT) ȚĂRI CU CLIME RECE APARAT DE AER CONDITIONAT CU RADIATOR DE ĪNCĂLZIRE ȘI SISTEM DE RECIRCULARE AUTO BLOC DE SIGURANȚĂ PENTRU SIGURANȚA COPIILOR SIGURANTA COPII SPATE MANUALA MANETA SCHIMBĂTORULUI DE VITEZE COMANDA SCHIMBĂTORULUI DE VIPTĂ PE POSA + VOLAN POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA Īncălzitor suplimentar FĂRĂ ĪNCĂLZIRE SUPLIMENTARĂ LINK OGLINDĂ CU FUNCȚIE MIRROR LINK ILUMINAT PLATFORMĂ DE MARFĂ ILUMINARE COMPARTIMENT DE DEPOZITARE * LUMINA CUTIIE DE TORPUP LED ILUMINAT PORTBAGAJE ȘI MARFĂ BAGAJE AUTO ILUMINAT. SAU PER. ĪNCĂRCĂRI ECHIPAMENTE PANOUL DE INSTRUMENTE ECHIPAMENT PANOUL DE COMANDĂ CU BORNIERE DIN TESSA DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ ILUMINARE INDIVIDUALĂ LED FAȚĂ/SPATE FĂRĂ ILUMINARE INTERIOARĂ LED CU ILUMINARE TABLUL DE INSTRUMENTE (CARACTERISTICI) PANOU DE INSTRUMENTE DIGITAL CU 29 DE INDICATORI PANOU DE COPIE UȘI GARNITURĂ UȘĂ CU ȚESATĂ PUNCTE DE ATASA SCAUN COPII FĂRĂ ISOFIX ĪN FAȚĂ. SI SCAUNEE SPATE VORTORUL 4 difuzoare frontale (2 TWITTERE + 2 difuzoare frontale) + 2 difuzoare spate VENTILATOR SUPLIMENTAR FĂRĂ SUPLIMENTARE PULS. IZOLAREA FONICĂ A INTERIORULUI IZOLARE FONICA PENTRU PANOUL FRONTAL INTERIOR 7 KG+APAC ROATA+TUNEL+PRIPA DE AER REGLAREA ĪNĂLȚIMII SCAZULUI FAȚĂ PE LATEA PASagerului REGLAREA PARALELA A RIDICATORULUI PERNELOR SCAZUL PASagerului din fata COMUTATOR DE REGLARE A SCACULUI SOFERULUI SCAUNUL ȘOFER REGLARE MANUALĂ DRIVE+RELAX COMUTATOR REGLARE SCAUN PASager SCAUN PASager FAȚĂ CU REGLARE MANUALĂ + RELAX REGLAREA SCAUNULUI ȘOFERULUI SPATAR REGLABIL, SUPPORT LOMBAR PENTRU SCAZUL SOFERULUI REGLAREA SCAUNULUI PASagerului FAȚĂ REGLAREA PERNEI SCAZULUI PASagerului FAȚĂ, INCLINAREA SPĂTARULUI SCAUN PASager FAȚĂ rabatabil PERNA SAC PASager FAȚĂ PLIABLE ELEMENTE DE TAPIERE TAPIERII INTERIOARE SALIN ACOPERIS+STOLPI DE PARBRIZ+PERET LATERAL COTIERA SCAUN FATA COTIERA CENTRALĂ FURRY + TER CD FĂRĂ CD SISTEM DE NAVIGAȚIE prin satelit CU NAVIGAȚIE. SISTEM - ECRAN CULOARE FAURI LAMPĂ CU HALOGEN SISTEMUL DE INFORMAȚII ȘOFERULUI DE TRAFIC PREVENIREA REMILOR + CORECTAREA TRAIECTORII LATERALE AFIŞA DISPLAY DIGITAL TOUCH Oglinda PE PARASOARE UNITĂȚI. + PASAJ RABAT. CU ILUMINARE INDICATOR NIVEL ULEI STANDARD INDICATOR NIVEL ULEI UN ELEMENT DE ĪNCĂLZIRE SCAUN NEINCALZIT AIRBAG LATERAL FRONTAL SUBSIGURANȚĂ LATERALĂ SIGURANȚA TORAX + PERDEA ILUMINAT CAMERA DE PIEDERI ILUMINARE LED PENTRU NISE DE PICIOARE PROTECTIE SCAUNEA SPATE FĂRĂ PROTECȚIE PASAGER SPATE SET DE ECHIPAMENTE FĂRĂ PACHET ECHIPAMENT SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ WIFI Cu WIFI DEPOZITARE MARFĂ (POZIȚIA ĪN CADRUL CONDUCEREI) PORTBAGAJE + TAVĂ CROMĂ RADIO NAVIGAȚIE DIGITALĂ ADAUGĂ SISTEM DE AER CONDITIONAT AER CONDITIONAT AUTOMAT CONTROL DE CRAZĂ CONTROL ȘI LIMITATOR DE VITEZĂ REGLAREA ĪNĂLŢIMII SCAUNULUI ŞOFERULUI CONTROL PARALEL ĪNĂLȚIMILE SCAUNULUI ȘOFER Oglinda retrovizoare interioara Oglinda retrovizoare interioara ELECTROCROMICA "ZI-NOAPTE" PARDOSELĂ Covoraș TUFT F470 Oglinda retrovizoare exterioară (raza din partea șoferului) STICLA CONVEXA A OGLIZIEI EXTERIOARE PLATFORMĂ DE MARFĂ COMPARTIMENT DE DEPOZITARE CU CAPAC ASCUNS SISTEM DE DETECȚIE A OBSTACULELOR DETECTOR DE OBSTACULE, RADAR FATA, SPATE INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA PIERDERI DE PRESIUNE CU ANVELOPE CU LOCALIZAREA ROȚII Covoraș Covorase fata si spate EGALISATOR, AMPLIFICATOR FARA AMPLIFICATOR CU EGALISATOR FRECVENTA RADIO FRECVENȚA RADIO PENTRU EUROPA DE EST CONTROLUL SISTEMULUI DE BLOCARE BLOCARE SIMPLU + AUTOMAT VOLAN PIELE CU INSERȚII DE SATIN VENTILATOR 1 VENTILATOR DYNAMIQUE AERO VOLET 95W CU 2 VITEZE CONECTOR SUPLIMENTAR PENTRU CONECTAREA DISPOZITIVELOR AUDIO 1 CONECTOR USB+CONECTOR VIDEO LVDS2 UNITATEA DE TELECOMUNICAȚII UNITATEA AUTONOMA DE TELEMATICA EVOLUTIA 2.0 Echipament electric ALTERNATOR GENERATOR 120 A SEMNALE SUNETARE SEMNALE SUNETARE - MELODICE BATERIE BATERIE BATERIE L3 760 70AH EFR 760 EN EF INCEPATOR STARTER STTD ILUMINAT PLATFORMĂ DE MARFĂ ILUMINARE COMPARTIMENT DE DEPOZITARE * LUMINA CUTIIE DE TORPUP LED ILUMINAT PORTBAGAJE ȘI MARFĂ BAGAJE AUTO ILUMINAT. SAU PER. ĪNCĂRCĂRI ILUMINAT SPECIAL LUMINILE DE RUNSAȚI FAȚĂ (DRL) DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ ILUMINARE INDIVIDUALĂ LED FAȚĂ/SPATE FĂRĂ ILUMINARE INTERIOARĂ LED CU ILUMINARE FUNCȚIA OGLINZĂ EXTERIORĂ IN AFARA Oglinda CU ELECTRIC PLIERE CU MEMORIE FRECVENTA DE OPERARE A COMANDEI DE LA DISTANTA INCHISARE CENTRALIZATĂ FRECVENTA TELECOMANDA 433,92 MHz, LO FAURI LAMPĂ CU HALOGEN ĪNCĂRCĂTOR DE BATERIE FĂRĂ ĪNCĂRCĂTOR INSTALAT COMUNICARE MULTIPLEX ARHITECTURA ELECTRICA COMPLETA ILUMINAT CAMERA DE PIEDERI ILUMINARE LED PENTRU NISE DE PICIOARE LAMPĂ DE CĂTĂ FAȚĂ LAMPURI DE CATA FATA SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ Aprinderea LUMINILOR PORNIRE AUTOMATĂ A LUMINII+COMUTARE AUTOMATĂ Marci de echipamente OPȚIUNI DE CONFIGURARE A SISTEMULUI DE INJECȚIE SISTEM DE INJECȚIE VALEO Diverse CARACTERISTICI SPECIALE STANDARD CONDENSATOR (CARACTERISTICI) CONDENSATOR 23,5DM2 GROSIME 12 POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA STICKER FARA ETICHETA TUBATURA AER CONDITIONAT CONDUCTURI DE AER CONDIȚIONAT CU TEHNOLOGIA IHX CONECTOR PENTRU CONECTAREA CĂȘTILOR RADIOTELEFONICE PRISA TRIPLA PENTRU ECHIPAMENTE AUXILIARE SET DE CHEI SET CHEIE CU BLOCARE+CHEIE DE rezervă GARNITURA UȘI GARNITURĂ UȘĂ FAȚĂ + INFERIOR FAȚĂ/SPATE. UȘI REFRIGERANT LICHID DE RĂCIRE 1234 YF ECHIPAMENTE DE URGENȚĂ FĂRĂ ECHIPAMENT DE BACKUP UNITATE DE CONTROL AUXILIAR BSI + COM 2008 + SON POLY + FINISAJ CROM
Toate drepturile rezervate. © PSA ServiceBox
- 1 like
Salutare colegi,
Doresc sa achiziționez un 508 II cadou personal de ziua mea
Vor o verificare VIN pentru următoarele serii daca se poate:
1: VR3FBYHZRKY129640
2: VR3FBYHZRKY048036
3: VR3FBYHZRJY171241
Ar fi prima masina cumparata de mine (sofer de 5 ani), ar fi folosita in special pt naveta tg jiu bucuresti, iar masina ar sta in parcare cam 3 saptamani pe luna datorita jobului de tehnician de service.
Daca se poate un ajutor la verificare si o sugestie pentru a alege modelul cel mai ok sunt recunoscator.
Multumesc
VF38DRHC8EL013399
508 SEDAN 4 PORTI 2.0 HDi 163 filtru de particule (DW10CTED4) transmisie manuala automatizata (BVMP) 6H
Nu există campanii de rechemare pentru acest VIN
Reparatie in garantie23.10.2018 019513J 01 XABVXHZ01 1611278480 KIT ACCESORIU 8P1 102211 Franţa 17.03.2016 186909L 03 X98ZJ2O01 00000000000ZZVZ TT DW10C RECHAUFFEUR GAZOL ZZV 11102 Franţa
Caracteristicile vehiculului Model 508 Nr. APV/PR 13646 CJ 1 0022 Data īnceperii garanției 27.03.2015 data fabricatiei 20.03.2014 Numărul de serie al motorului 10 DYZC 4049352 NRE e2*2007/46*0080*20 P4A 9809323199 Informații generale FELUL PRODUSULUI O MAȘINĂ MARCA MARCA/TIP DE COMPONENT PEUGEOT LINEUPUL 508 CORP BERLINĂ 4 UȘI NIVEL DE FINISARE MEDIE MARE PLUS MOTOR MOTOR DIESEL TURBO DW10CTED4 FAP TRANSMITERE TRANSMISIE MANUALĂ ROBOTICĂ CU 6 VELOZE PENTRU MOTOARE HIBRIDE TIP DE VOPSEA SMALȚ „METALIC” CU ĪNCĂȘTIRE PERLATĂ ĪN TREI STRATURILE CULOAREA CORPULUI KWE - ESMAL ALBA PERLA TIP FINISAJ INTERIOR TAPIERE COMBINATA PIELE "MARSTON" "3F" CULOARE TAPITERIE "FX" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) Cutie de viteze manuală MC6F FINISARE ĪN VINE GAMA ORIGINALA TIPUL MOTORULUI) EW/DW ALTE AUTOCOLANTE, DIVERSE " DRIVE HIBRID 4 Caracteristicile vehiculului NIVEL DE FINISARE MEDIE MARE PLUS TIP DE VOPSEA SMALȚ „METALIC” CU ĪNCĂȘTIRE PERLATĂ ĪN TREI STRATURILE CULOAREA CORPULUI KWE - ESMAL ALBA PERLA TIP FINISAJ INTERIOR TAPIERE COMBINATA PIELE "MARSTON" "3F" CULOARE TAPITERIE "FX" CUTIA DE VITERE (SPECIFICAȚII TEHNICE) Cutie de viteze manuală MC6F DIRECȚIE SERVODIRECȚIE Sistem de alimentare cu combustibil MOTOR MOTOR DIESEL TURBO DW10CTED4 FAP SENSOR DE APĂ ĪN FILTRUL DE CURĂȚARE COMBUSTIBIL DIESEL FĂRĂ FILTRU DE COMBUSTIBIL DIESEL SENSOR DE APA COMBUSTIBIL COMBUSTIBIL DIESEL DA/DE/DE+ CALITATE STANDARD DE EMISII DE GAZE DE ESAPAMENT (MOTOR) SISTEM DE CONTROL A EMISIILOR DE MOTOR DE LA L6 EURO 5 SISTEM DE EVACUARE EȘAPEP LONGITUDINAL SPATE TIPUL MOTORULUI) EW/DW PUTERE 2000CM3 RADIATOR DE ULEI UNITATE DE SCHIMB DE CALDURA PE DRIVE. SI COR.PER. REZERVOR DE COMBUSTIBIL REZERVOR DE CARBURANT CU CHEIE ĪNCĂLZIREA CALEI DE GAZ CARTER FĂRĂ CIRCUIT DE GAZ ĪNCĂLZIRE CLĂDIR SISTEM DE AUTODIAGNOSTICĂ LA BORD EOBD AUTODIAGNOSTICĂ „EOBD” DISPOZITIV SISTEM DE CONTROL A EMISIILOR RECIRCULARE GAZ DE ESCAPE "EGR" INSTRUMENTE TEHNICE PENTRU PROTECȚIA MEDIULUI SISTEM DE CONTROL AL EMISIILOR EURO 5 FILTRUL DE PARTICULE CU FILTRU DE PARTICULE VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUĂ VITEZE 140 W OPȚIUNI DE CONFIGURARE A SISTEMULUI DE INJECȚIE SISTEM DE INJECȚIE DELPHI UNITATEA DE ALIMENTARE LANȚ DE TRACȚIUNE HIBRID FILTRUL REZERVORULUI DE COMBUSTIBIL FILTRU INTERN REZERVOR OPRIȚI ȘI PORNIȚI SISTEMUL CU SISTEM STOP AND START Cutie de viteze - Transmisie TRANSMITERE TRANSMISIE MANUALĂ ROBOTICĂ CU 6 VELOZE PENTRU MOTOARE HIBRIDE CUTIA DE VITERE (SPECIFICAȚII TEHNICE) Cutie de viteze manuală MC6F RAPORTUL DE ACTIONARE FINAL CP 17 X 74 STILUL ROȚII STYLE 05 17 INCH AMBREIAJ FĂRĂ AMBREIE DIFERENȚIAL (CUTIE DE VITEZE) DIFERENȚIAL 86 DIMENSIUNEA PNEURI/ROȚI INSTALARE PNEURI DE 17 INCI PNEURI (TIP, DIMENSIUNE) ANVELOPE 215/55 R17 98W INFORTATA ROATA (TIP) JANTE din aliaj de aluminiu 7 INDICATOR DE PRESIUNE SCASA IN ANVELOPE INDICATOR DE PIERDERE DE PRESIUNE IN PNEURI CONFORM ECE 64.02 TIP CUTIE MCP MS Suspensie Direcție Sistem de frānare ROLL BAR STABILIZATOR SPATE STABILIZATOR SPATE TRANS.STABIL DIAM. 20 DIRECȚIE SERVODIRECȚIE ROLL BAR STABILIZATOR FAȚĂ TRANS.STABILIZAT FATA DIAM. 23 SUSPENSIE SUSPENSIUNE CONVENȚIONALĂ SISTEM DE STABILITATE DINAMICĂ CU SISTEM ESP OPȚIUNI DE CONFIGURARE FRĀNE SISTEMUL DE STABILIZARE DINAMICĂ BOSCH 8 1 DIRECȚIE (PRINCIPIU DE OPERARE) DIRECȚIE CU ELECTROHIDRAULIC AMPLIFICATOR Echipament de caroserie SISTEM DE REMORCARE FĂRĂ TURN ANTENĂ ANTENA + GPS CAPACITATE DE ĪNCĂRCARE CAPACITATE DE INCARCARE 815 KG MULTURA LATERALĂ (TIP) FĂRĂ PLACINE DE PROTECȚIE LATERALE ELEMENTE DECORATIVE ALE ROȚILOR (STYL) FARA CAPACE ROTI LAMPĂ DE PRAG DE UȘĂ ILUMINARE PRAG UȘĂ FAȚĂ ECRAN SUPLIMENTAR (SUB MOTOR) FARA PROTECTIE CARTER MOTOR REȚINERE PENTRU ASIGURAREA ĪNCĂRCĂRII ĪN EXTERIOR CAROSERIEI (ATCHES) FĂRĂ OCHIUL DE REMORCARE EXTERN FUNCȚIA OGLINZĂ EXTERIORĂ IN AFARA Oglinda CU ELECTRIC PLIERE FĂRĂ MEMORIE Izolarea fonica a compartimentului motor Izolarea fonica a hotei ȘTERGĂTOR DE PARBRIZ PERIE FRONTWISH DE LA DATA PLOIEI ȘTERGATOR SPATE FĂRĂ SPĂLARE/ȘTERGĂTOR LUNET CURĂȚAT FAURI FĂRĂ ȘTERGĂTOR DE FAURI COMUTATOR PANOUL FRONTAL CU BUPĂ PENTRU FATA MODULULUI DE ADMISIE AER STICLA TRAPA FĂRĂ LUNAR STICLA UȘĂ PORGAI STICLA FIXA UȘĂ PORGAI BASTĂ DE BAZĂ CULOARE CAROSERIE STANDARD BARA DE BARĂ FAȚĂ ȘI SPATE + GRILĂ CROMĂ Scut de murdărie (șorț) FĂRĂ NAVE SPATE GRILĂ DE PORTBAGAI FĂRĂ SINE PENTRU BAGAJE PE ACOPEȘ LAMPĂ DE CĂTĂ FAȚĂ LAMPURI DE CATA FATA ROATĂ DE REZERVĂ FARA ROATA DE rezerve ECHIPAMENT SUPLIMENTAR EXTERIOR MĀNERE EXTERIOARE ȘI ELEMENT DECORATIV CROM Oglinda retrovizoare exterioară (raza din partea șoferului) STICLA CONVEXA A OGLIZIEI EXTERIOARE LUCA ACOPERIS FIX GARNIERE DE BARĂ BARA DE BARĂ CU INSERȚIE CROMĂ STICLA (ASPECT) STICLA TINATĂ FEREASTRĂ (TIP) GEAM MULTIPLE ACUSTIC + GEAM SPATE CALIT INTRAREA SI PORNIREA MOTORULUI FARA UTILIZAREA CHEIEI SISTEM DE ACCES ȘI PORNIRE "MĀINI LIBERE" Echipament intern TIP FINISAJ INTERIOR TAPIERE COMBINATA PIELE "MARSTON" "3F" ALARMA ANTIFURT FARA ALARMA ANTIFURT LOCUL DIN SPATE DEPOZIT SEPARAT. LOCUL DIN SPATE DETECȚIA PATELOR MOARTE FĂRĂ SISTEM DE MONITORIZAREA ANGULUI ORB COTIERA SCAZUL SPATE CU COTIERA SCAUNA SPATE Centura de siguranta spate 3 CENTURI DE SIGURANȚĂ SPATE LED CU PIR. ANTERIOR + ALARMĂ. Centura de siguranta fata DOUĂ CENTURI FĂRĂ. CU PYROTECH. ANTERIOR SI ALARMA CLIMA (TEMPERATURA AERULUI AMBIENT) ȚĂRI CU CLIMA TEMPERATĂ GRADAȚIE PE VITOMETRO CALIBRAREA VITOMETORULUI ĪN KM/H POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA Īncălzitor suplimentar FĂRĂ ĪNCĂLZIRE SUPLIMENTARĂ ECHIPAMENTE PANOUL DE INSTRUMENTE DECORAT "CUBIC MINIMAILLE" DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LUMINA DE TENSIUNE FAȚĂ ȘI SPATE + LED FAȚĂ FINISARE PLATFORMĂ DE MARFĂ Covoraș pentru portbagaj + COVOARE LATERALE TABLUL DE INSTRUMENTE (CARACTERISTICI) GRAD LA 260 KM/H (160 MPH) CULOARE MATER PANOU DE COPIE UȘI TESTURĂ DECORATIVA VORTORUL 4 VOLUM FAȚĂ (2 TWEETERE + 2 GR.) + 4 GR. SPATE COMANDE RADIO CONTROL AUDIO STANDARD DE LA DISTANȚĂ PERDELE (PERDEA, PERDEA LATERALĂ, TRAPA) FARA PERDEA SPATE REGLAREA ĪNĂLȚIMII SCAZULUI FAȚĂ PE LATEA PASagerului CONTROL DE TRAFIC Căptușeală pentru scaunul pasagerului COMUTATOR DE REGLARE A SCACULUI SOFERULUI PE. UNITĂȚI. SCAUN CU MANUAL CONTROL COMUTATOR REGLARE SCAUN PASager Scaunul din față pentru pasager, reglabil manual REGLAREA SCAUNULUI ȘOFERULUI AJUSTARE CONDUCERE DE SUPPORT LOMBAR. LED REGLAREA SCAUNULUI PASagerului FAȚĂ PASARE ĪNAPOI. SCAUN. CU AJUSTARE ĪNCLINARE SISTEM DE NAVIGAȚIE prin satelit CU NAVIGAȚIE. SISTEM - ECRAN CULOARE FAURI LAMPĂ CU HALOGEN GEAMUL UȘII SPATE PICIOSA DE STICLA. GEAMUL SPATE CU CONTROL SECVENTIAL GEAMĂ UȘĂ LATEA PASagerului GEAMUL FAȚĂ PASager CU ULTIMUL CONTROL AFIŞA DISPLAY DEV Oglinda PE PARASOARE UNITĂȚI. + PASAJ RABAT. CU ILUMINARE INDICATOR NIVEL ULEI INDICATOR TEMPERATURA + NIVEL ULEI UN ELEMENT DE ĪNCĂLZIRE SCAUN NEINCALZIT AIRBAG LATERAL FRONTAL SUBSIGURANȚĂ LATERALĂ SIGURANȚA TORAX + PERDEA ILUMINAT CAMERA DE PIEDERI ILUMINAT PENTRU PICIOARELE ȘOFERULUI + PASAJ FAȚĂ ȘI SPATE PROTECTIE SCAUNEA SPATE FĂRĂ PROTECȚIE PASAGER SPATE SISTEM DE DEACTIVARE AIRBAG DECONECTARE MANUALĂ AIRBAG-UL SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ FAURI REGLABILE FARA FARU VARIABIL RADIO RADIOTELEFON CU DISPLAY DE LA DISTANȚĂ „RT6” SISTEM DE AER CONDITIONAT AER CONDITIONAT AUTOMAT CONTROL DE CRAZĂ CONTROL ȘI LIMITATOR DE VITEZĂ REGLAREA ĪNĂLŢIMII SCAUNULUI ŞOFERULUI SCAUNUL ȘOFER „LIFT” CU REGLARE MANUALĂ Oglinda retrovizoare interioara Oglinda retrovizoare interioara ELECTROCROMICA "ZI-NOAPTE" REGLAREA TEMPERATURII/CONTROLUL AER CONDIȚIONAT SISTEM DE CONTROL CLIMATICE DUAL ZONE PARDOSELĂ COVORAS TRAMONTANE Oglinda retrovizoare exterioară (raza din partea șoferului) STICLA CONVEXA A OGLIZIEI EXTERIOARE PLATFORMĂ DE MARFĂ FĂRĂ PLASA DE PORTBAGAI TUNER RADIO TUNER TRI-BAND SISTEM DE DETECȚIE A OBSTACULELOR SENSORI DE DETECȚIE OBSTACULE FAȚĂ SPATE MDP PERDELE LATERALE FARA PERDELE LATERALE INDICATOR DE PRESIUNE SCASA IN ANVELOPE INDICATOR DE PIERDERE DE PRESIUNE IN PNEURI CONFORM ECE 64.02 ADAPTARE FINISARE MĀNER DIN PIELE CU INSERȚIE CROMĂ EGALISATOR, AMPLIFICATOR FARA AMPLIFICATOR CU EGALISATOR FRECVENTA RADIO FRECVENȚA RADIO PENTRU EUROPA DE EST CONTROLUL SISTEMULUI DE BLOCARE INCHIDERE CENTRALA SIMPLA FEREASTRĂ (TIP) GEAM MULTIPLE ACUSTIC + GEAM SPATE CALIT VOLAN VOLANT DIN PIELE CU 3 spite VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUĂ VITEZE 140 W AIRBAG GENUNCHI ȘOFER FARA AIRBAG. PENTRU GENUNCHII ȘOFERULUI ECRAN VIDEO SPATE FĂRĂ ECRAN VIDEO SPATE CONECTOR SUPLIMENTAR PENTRU CONECTAREA DISPOZITIVELOR AUDIO 1 PRISA "JACK" + USB UNITATEA DE TELECOMUNICAȚII UNITATEA AUTONOMA DE SISTEM DE TELECOMUNICATII Echipament electric ALTERNATOR ISTT6 BATERIE L3 800 INCEPATOR STARTER CL 5 ILUMINAT SPECIAL AVT. PE ILUMINARE + FATA ZILNIC ILUMINAT DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LUMINA DE TENSIUNE FAȚĂ ȘI SPATE + LED FAȚĂ LAMPĂ DE PRAG DE UȘĂ ILUMINARE PRAG UȘĂ FAȚĂ FUNCȚIA OGLINZĂ EXTERIORĂ IN AFARA Oglinda CU ELECTRIC PLIERE FĂRĂ MEMORIE FRECVENTA DE OPERARE A COMANDEI DE LA DISTANTA INCHISARE CENTRALIZATĂ FRECVENTA TELECOMANDA 433,92 MHz, LO FAURI LAMPĂ CU HALOGEN ILUMINAT CAMERA DE PIEDERI ILUMINAT PENTRU PICIOARELE ȘOFERULUI + PASAJ FAȚĂ ȘI SPATE LAMPĂ DE CĂTĂ FAȚĂ LAMPURI DE CATA FATA SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ FAURI REGLABILE FARA FARU VARIABIL Aprinderea LUMINILOR ILUMINARE NEAUTOMATĂ PORNIRE Marci de echipamente OPȚIUNI DE CONFIGURARE FRĀNE SISTEMUL DE STABILIZARE DINAMICĂ BOSCH 8 1 OPȚIUNI DE CONFIGURARE A SISTEMULUI DE INJECȚIE SISTEM DE INJECȚIE DELPHI Diverse CARACTERISTICI SPECIALE STANDARD VREME ATMOSFERĂ ORDINARĂ POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA STICKER FARA ETICHETA CONECTOR PENTRU CONECTAREA CĂȘTILOR RADIOTELEFONICE PRISA TRIPLA PENTRU ECHIPAMENTE AUXILIARE PARTEA DE CONDUCERE Trafic pe dreapta SET DE CHEI 2 TASTE RF PLIP ECHIPAMENTE DE URGENȚĂ KIT REPARARE ANVELOPE CONDIȚII Drumurilor Drum neted ECHIPAMENT SUPLIMENTAR EXTERIOR MĀNERE EXTERIOARE ȘI ELEMENT DECORATIV CROM UNITATE DE CONTROL AUXILIAR BLOC COMUTATOR INTELIGENT SCHIMBAT TRIUNGHI DE AVERTIZARE FĂRĂ SEMN STOP DE AVERTIZARE
- 1 like
