peugeot 508 VIN
  • VR3FBYHZRKY225463
    508 (R8) HATCHBACK 5 UTI 1.5 BlueHDi 130 (DV5RC Euro 6.2) 8 VITEZE AUTOMAT. TIP STT
    Campanii de revizuire
    JWX 3008(P84), 508(R8) Tren de fixare spate S.R. 18.02.2020 unsprezece
    JZV 208, 301, 308(T9), 508(R8), Rifter, Partner(K9) Motor moale RSU 12.05.2020 unsprezece
    JZD 508(R8) Etancheité CSN 30.08.2020 unsprezece
    KFX Toate tipurile Logiciel boitier telematique autonome CSN 25.05.2021 unsprezece
    KPL 508(R8) Barre de toit S.R. 16.07.2021 unsprezece
    Reparatie in garantie
    02.09.2021 027807F 03 XAEL69M01 00000000000KFXK LOGICIEL BOITIER TÉLÉMATIQUE KFX 52844 FR
    02.09.2021 027807F 03 XAEL69M02 00000000000KPLK BARRE DE TOIT KPL 52844 FR
    10.05.2021 006592G 01 XAEB66M01 00000000000JZDJ 508(R8) ETANCHEITE JZD 40403 FR
    24.06.2020 006592G 01 XADEI3S01 00000000000JZVJ TOUS TYPES SOFT MOTEUR JZV 8729 FR
    24.06.2020 006592G 01 XADEI3S02 00000000000161M TSB (LECTURE, CONTROLE, VIDANGE, TE 000 8729 FR
    05.03.2020 027807F 03 XAC7F2301 00000000000JWXJ FIXARE TREN ARRIČRE JWX 2118 FR
    Caracteristicile vehiculului
    Model 508 (R8)
    Nr. APV/PR 15732 88 1 0062
    Data īnceperii garanției 01.02.2020
    data fabricatiei 05.12.2019
    Numărul de serie al motorului 10 Q4DL 0074697
    NRE e2*2007/46*0628*06
    P4A 9835917699
    Informații generale
    FELUL PRODUSULUI O MAȘINĂ
    MARCA MARCA/TIP DE COMPONENT PEUGEOT
    LINEUPUL 508 (R8)
    CORP HATCHBACK 5 UȘI
    NIVEL DE FINISARE MARE MINUTĂ
    MOTOR DV5RC 96KW 1.5L DIESEL
    TRANSMITERE Transmisie automată cu 8 viteze. TIP STT
    TIP DE VOPSEA TIP EXTERN FINISAJE METALIZATE. LAC
    CULOAREA CORPULUI KTV - EMAL NEGRU PERLA NERA (PEARL NERA)
    TIP FINISAJ INTERIOR MISTRAL TREI MATERIALE "71"
    CULOARE TAPITERIE "FX"
    CUTIA DE VITERE (SPECIFICAȚII TEHNICE) ATNG8
    ORGANIZAREA CONVERSIEI FĂRĂ CONVERSIE
    FINISARE ĪN VINE GAMA ORIGINALA
    TIPUL MOTORULUI) TIP MOTOR DV
    ALTE AUTOCOLANTE, DIVERSE " FĂRĂ SUPLIMENTARE EMBLEME
    Sistem de alimentare cu combustibil
    SISTEM DE ALIMENTARE CON COMBUSTIBIL TURBO INJECTIE DIRECTA CU SCHIMBATOR DE CALDURA
    SENSOR DE APĂ ĪN FILTRUL DE CURĂȚARE COMBUSTIBIL DIESEL FĂRĂ FILTRU DE COMBUSTIBIL DIESEL SENSOR DE APA
    COMBUSTIBIL COMBUSTIBIL DIESEL DA/DE/DE+ CALITATE
    STANDARD DE EMISII DE GAZE DE ESAPAMENT (MOTOR) SISTEM DE REDUCERE A EMISIILOR DE MOTOR EURO 6.2
    SEMNALUL SENZORULUI DE VITEZA SENSOR PENTRU ROTI FATA FARA IDENTIFICARE, ROTI SPATE CU IDENTIFICARE.
    PUTERE 1500 CM3
    REZERVOR DE COMBUSTIBIL REZERVORUL DE COMBUSTIBIL NU ESTE SIGLAȘAT CU INSTALARE PIECI
    MOTOR DE RĂCIRE RADIATOR EP28 28DM2, ALUMINIU, CURU
    ĪNCĂLZIREA CALEI DE GAZ CARTER CU GAZ. CIRCUIT DE ĪNCĂLZIRE AL CLĂDIRII
    SUNET SPECIF AL UNITĂȚII DE PUTERE FĂRĂ IZOLAREA ACUSTICĂ A UNITĂȚII DE PUTERIE
    SISTEM DE AUTODIAGNOSTICĂ LA BORD EOBD CU DIAGNOSTICĂ AUTO LA BORD
    INSTRUMENTE TEHNICE PENTRU PROTECȚIA MEDIULUI SISTEM DE EMISII EURO 6.2
    FILTRUL DE PARTICULE CU FILTRU DE PARTICULE
    VENTILATOR VENTILATOR CU 2 VITEZE 140 W PANOU MOBIL AERO
    UNITATEA DE ALIMENTARE CIRCUIT DE TRACȚIUNE CU GHEAZĂ
    FILTRUL REZERVORULUI DE COMBUSTIBIL FILTRU REZERVOR EXTERIOR
    OPRIȚI ȘI PORNIȚI SISTEMUL CU SISTEM STOP AND START
    Cutie de viteze - Transmisie
    STILUL ROȚII DISC 17" DECO
    AMBREIAJ FĂRĂ AMBREIE
    DIMENSIUNEA PNEURI/ROȚI INSTALARE PNEURI DE 17 INCI
    PNEURI (TIP, DIMENSIUNE) ANVELOPE 215/55 R17 98W INFORTATA
    ROȚI MOTRICE 2 ROTI MOTRICE
    ROATA (TIP) ANSAMBLU ROȚE DE ALIAN 1
    INDICATOR DE PRESIUNE SCASA IN ANVELOPE DETECȚIA INDIRECTĂ A PIERDEREI DE PRESIUNE ĪN ANVELOPE FĂRĂ LOCALIZARE
    TIP CUTIE Cutie de viteze TIP ATN8
    Suspensie Direcție Sistem de frānare
    ROLL BAR STABILIZATOR SPATE STABILIZATOR SPATE 17.5MM DIAM
    DISPOZITIV ANTIFURT COMUTATOR ELECTRIC DE Aprindere
    ROLL BAR STABILIZATOR FATA FAȚĂ DURITATE STABILIZATOR 25000 N.M/RAD
    TIP DE FRANA DISCURI FATA/SPATE VENTILATE
    unghiul volanului CU SENSOR DE unghiul volanului
    SUSPENSIE SUSPENSIUNE CONVENȚIONALĂ
    SISTEM DE STABILITATE DINAMICĂ PROGRAM DE STABILIZARE ELECTRONICĂ
    DIRECȚIE (PRINCIPIU DE FUNCȚIONARE) SERVODIRECȚIE ELECTRICĂ DE PUTERE MICĂ CU DOUĂ TRIPATE
    SUPORT PEDALA (TIP) UNITATE DE PEDALA SIMPLU STANDARD
    Echipament de caroserie
    SISTEM DE REMORCARE DISPOZITIV DE REMORCARE DE DEPOZIT
    MULTURA LATERALĂ (DIMENSIUNI) FĂRĂ ELEMENTE DE PROTECȚIE ĪN PARTEA INFERIOR A CORPULUI
    ELEMENTE DECORATIVE ALE ROȚILOR (STYL) FĂRĂ CAPAC ROȚĂ
    ȚEAVĂ DE EȘAPAMENT FĂRĂ TUBA DE ESCAPAMENT
    SUB ECRAN DEFLECTOR FRONTAL INFERIOR
    LAMPĂ DE PRAG DE UȘĂ FĂRĂ ILUMINARE DE PRAG
    FUNCȚIA OGLINZĂ EXTERIORĂ Oglinda exterioara cu pliere electrica si LED
    SCUT DE PURZIUNE Căptușeală aripă față stānga. ACOUST PER. SPATE+FATA DREAPTA DESCHIS
    TIMITE TEVI DE ESCAPARE DIN DEC. DUZĂ ȚEVA DE EȘAPARE
    Izolarea fonica a compartimentului motor IZOLARE FONONIC COMPARTIMENT MOTOR + COMPARTIMENT + ISOVAC
    PARBRIZ (TIP) PARBRIZ STANDARD
    ȘTERGĂTOR DE PARBRIZ PERIE FRONTWISH DE LA DATA PLOIEI
    ȘTERGATOR SPATE (PRINCIPIU DE FUNCȚIONARE) ȘTERGĂTOR DE GEAM
    BASTĂ DE BAZĂ STANDARD BARĂ FAȚĂ/SPATE, CULOAREA CAROSERIEI
    ĪNMATRICULARE FĂRĂ NUMĂR DE STAT
    GRILĂ DE PORTBAGAI FĂRĂ SINE PENTRU BAGAJE PE ACOPEȘ
    SISTEM DE ASISTERE PANORAMICĂ CU SISTEM DE ASISTENȚĂ VIZUALĂ PANORAMICĂ SPATE VISIO PARK1
    ROATĂ DE REZERVĂ ROATA DE rezerve mai mica
    Oglinda retrovizoare exterioară (sticlă) Oglinda exterioara pictata pe sticla
    Oglinda retrovizoare exterioară (raza din partea șoferului) FĂRĂ CARACTERISTICI Oglinzile exterioare
    LUCA FĂRĂ VENTILAȚIE
    STICLA (ASPECT) STICLA TINATĂ
    FEREASTRĂ (TIP) PARBRIZ LAMINAT FONOABORBIANT + GEAM SPATE CALIT
    INTRAREA SI PORNIREA MOTORULUI FARA UTILIZAREA CHEIEI SISTEM DE PORNIRE A MOTORULUI FĂRĂ MĀINI
    Echipament intern
    COTIERA LATERALA (TIP) COTIERA LATERALA FATA SPATE TER
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    DETECȚIA PATELOR MOARTE FĂRĂ SISTEM DE MONITORIZAREA ANGULUI ORB
    COTIERA SCAZUL SPATE FĂRĂ COTIERE SCAUNEA SPATE
    HAPA BAGAJE (TIP) HAPA BAGAJ TARI
    CLIMA (TEMPERATURA AERULUI AMBIENT) ȚĂRI CU CLIME RECE
    APARAT DE AER CONDITIONAT CU ĪNCĂLZIRE+IEȘIRE SUPLIMENTARĂ
    BLOC DE SIGURANȚĂ PENTRU SIGURANȚA COPIILOR SIGURANTA COPII SPATE MANUALA
    GRADAȚIE PE VITOMETRO CALIBRAREA VITOMETORULUI ĪN KM/H
    MANETA SCHIMBĂTORULUI DE VITEZE TREBUIE TREBUIE PE POSEA SI PE VOLAN
    MĀNĂRI FĂRĂ MĀNERE
    CONSOLĂ DECOR CONSOLA NEGRU ĪNALTĂ+FLANȘĂ STANDARD
    POZIȚIE ĪN TIMP DE CONDUCERE CONDUCEREA STANGA
    Īncălzitor suplimentar FĂRĂ ĪNCĂLZIRE SUPLIMENTARĂ
    LINK OGLINDĂ CU FUNCȚIE MIRROR LINK
    ILUMINAT PLATFORMĂ DE MARFĂ FĂRĂ ILUMINARE COMPARTIMENTE DE DEPOZITARE CU EXCEPȚIA PORTAFEI
    ILUMINAT PORTBAGAJE ȘI MARFĂ PORNIREA AUTOMATĂ DE ILUMINARE LED PENTRU VOLUM PORTBAGAI + MARFĂ
    ECHIPAMENTE PANOUL DE INSTRUMENTE FINIS CARBON
    DIVERSE LĂMPURI DE ILUMINAT INTERIOARĂ LUMINI LED + LUMINI SPATE PERSONALIZATE
    FINISARE PLATFORMĂ DE MARFĂ INSTALARE COVORURI + MOCHETARE PARDOSULUI TRUNGIULUI
    TABLUL DE INSTRUMENTE (CARACTERISTICI) PANOU DE INSTRUMENTE DIGITAL CU 29 DE INDICATORI
    PANOU DE COPIE UȘI FINISARE USI CU FIBRA DE CARBON
    VORTORUL 4 VOLUM FAȚĂ (2 TWEETERE + 2 GR.) + 4 GR. SPATE
    FILTRU DE PRAF CU FILTRU + CARBON ACTIVAT
    IZOLAREA FONICĂ A INTERIORULUI INTERIOR FONOIZARE TAB/PLAV EDG/P. ABS ROATA SPATE
    REGLAREA ĪNĂLȚIMII SCAZULUI FAȚĂ PE LATEA PASagerului CONTROL DE TRAFIC Căptușeală pentru scaunul pasagerului
    COMUTATOR DE REGLARE A SCACULUI SOFERULUI RIDICAREA MANUALĂ A SCAUNULUI DE PASAJ + REGLAREA ĪNCLINAȚII PERNEI DE SCAZ
    COMUTATOR REGLARE SCAUN PASager REGLAREA MANUALĂ A PERNEI SCAZUL PASagerului FAȚĂ
    REGLAREA SCAUNULUI ȘOFERULUI SPATAR REGLABIL, SUPPORT LOMBAR PENTRU SCAZUL SOFERULUI
    REGLAREA SCAUNULUI PASagerului FAȚĂ REGLAREA PERNEI SCAZULUI PASagerului FAȚĂ, INCLINAREA SPĂTARULUI
    CD FĂRĂ CD
    SISTEM DE NAVIGAȚIE prin satelit CU NAVIGAȚIE. SISTEM - ECRAN CULOARE
    FAURI LAMPĂ CU HALOGEN
    SISTEMUL DE INFORMAȚII ȘOFERULUI DE TRAFIC AVERTISMENT+CORECȚIE+DETECȚIE BRUTARE
    AFIŞA DISPLAY DGT8C
    Oglinda PE PARASOARE KOZYR.SOFER.+CAMERA.TRESARE. FĂRĂ ILUMINĂ DE SPAZ
    UN ELEMENT DE ĪNCĂLZIRE SCAUN NEINCALZIT
    AIRBAG LATERAL FRONTAL SUBSIGURANȚĂ LATERALĂ SIGURANȚA TORAX + PERDEA
    ILUMINAT CAMERA DE PIEDERI FĂRĂ ILUMINARE INFERIORĂ
    PROTECTIE SCAUNEA SPATE FĂRĂ PROTECȚIE PASAGER SPATE
    SISTEM DE DEACTIVARE AIRBAG DECONECTARE MANUALĂ AIRBAG-UL
    SISTEM DE REGLARE FAURILOR REGLARE MANUALĂ A FAURILOR DE LA DISTANȚĂ
    WIFI Cu WIFI
    RADIO NAVIGAȚIE ANALOGĂ ATASATĂ
    SISTEM DE AER CONDITIONAT AER CONDITIONAT AUTOMAT
    CONTROL DE CRAZĂ CONTROL DE CRAZĂ PROGRAMABILE ȘI LIMITATOR DE VITEZĂ
    REGLAREA ĪNĂLŢIMII SCAUNULUI ŞOFERULUI REGLAREA ĪNĂLŢIMII PERNEA SCAZULUI ŞOFERUL MECANIC
    Oglinda retrovizoare interioara Oglinda retrovizoare interioara ELECTROCROMICA "ZI-NOAPTE"
    PARDOSELĂ FĂRĂ MAT
    PLATFORMĂ DE MARFĂ FĂRĂ PLASA DE PORTBAGAI
    TUNER RADIO TUNER RADIO DUAL
    SISTEM DE DETECȚIE A OBSTACULELOR DETECTOR DE OBSTACULE, RADAR FATA, SPATE
    ADAPTARE FINISARE FĂRĂ ADAPTATOR DE MULTARE
    EGALISATOR, AMPLIFICATOR FARA AMPLIFICATOR CU EGALISATOR
    FRECVENTA RADIO FRECVENȚA RADIO PENTRU EUROPA DE EST
    CONTROLUL SISTEMULUI DE BLOCARE BLOCARE SIMPLU + AUTOMAT
    VOLAN HUSĂ DE PIELE „FLEUR” PENTRU VOLAN
    OPȚIUNI DE LOCARE OPTIUNE CU SCAZ JOS
    CONECTOR SUPLIMENTAR PENTRU CONECTAREA DISPOZITIVELOR AUDIO 1 JACK + 2 USB
    UNITATEA DE TELECOMUNICATII UNITATEA DE TELEMATICA AUTONOMA 3S
    Echipament electric
    ALTERNATOR GENERATOR CLASA 18
    BATERIE BATERIE BATERIE L3 760 70AH EFR 760 EN EF
    INCEPATOR STARTER STTD
    FRECVENTA DE OPERARE A COMANDEI DE LA DISTANTA INCHISARE CENTRALIZATĂ FRECVENTA TELECOMANDA 433,92 MHz, LO
    COMUNICARE MULTIPLEX SISTEM ELECTRIC R3 ECO
    Aprinderea LUMINILE ILUMINAT AUTOMAT
    Marci de echipamente
    Diverse
    CARACTERISTICI SPECIALE STANDARD
    MODIFICĂRI FUCITE ĪN ANUL MODELULUI INDEX INFERIOR „00”
    CONDENSATOR (CARACTERISTICI) CONDENSATOR 19.3DM2 GROSIME 12
    VREME ATMOSFERĂ ORDINARĂ
    PLACA VIN PLACA TEHNICA UNIUNII EUROPENE + NRE
    STICKER FARA ETICHETA
    TUBATURA AER CONDITIONAT TUBATURA AER CONDIȚIONAT CU TEHNOLOGIA IHX
    CONECTOR PENTRU CONECTAREA CĂȘTILOR RADIOTELEFONICE PRISA TRIPLA PENTRU ECHIPAMENTE AUXILIARE
    GRAVE LATERALE PROTECTIE LATERALA INFORTATA
    SET DE CHEI SET CHEIE CU BLOCARE+CHEIE DE rezervă
    REFRIGERANT LICHID DE RĂCIRE ​​1234 YF
    ECHIPAMENTE DE URGENȚĂ FĂRĂ ECHIPAMENT DE BACKUP
    CONDIȚII Drumurilor Drum neted
    UNITATE DE CONTROL AUXILIAR BSI+COM 2008
    TRIUNGHI DE AVERTIZARE FĂRĂ SEMN STOP DE AVERTIZARE
    • Buna tuturor!
      ma poate ajuta cineva cu o decodare VIN pentru un 508? VIN VR3FCYHZTNY517888. Daca exista posibilitatea - sa fie in engleza va rog (traducerea in ro e maxima DDD)? Multumesc anticipat!
      D.
      • Buna seara, sunt nou posesor de peugeot 508 imi puteti spune si mie ce dotari are
        VN:VF38DBHZTHL063782
        Multumesc frumos,
        Cu stima,
