peugeot 508 VIN
  • #61
    Originally posted by dinujr View Post
    salutare !
    un check de vin va rog frumos : vf38D4HLABL065187
    multumesc anticipat!
    Caracteristicile vehiculului
    Linie de produs 508
    Nr. APV/PR 12660 CJ 1 0239
    Data de Inceput de Garantie 23.08.2011
    Numar de Serie Motor 10 DZ86 4002257
    NRE e2*2007/46*0080*01
    P4A 9666987299
    Informatii generale
    GEN DE PRODUS VEHICUL PARTICULAR
    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
    LINIE DE PRODUS 508
    TIP CAROSERIE BERLINA 4 USI
    NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
    MOTOR DIESEL TURBO DW12C FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
    TIP DE VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
    TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE GT MARSTON "4Q"
    CULOARE GARNISAJ "FX"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
    EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
    MOTOR (TIP) MOTOR TIP EW/DW
    Caracteristici vehicul
    DIRECTIE SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT MOTORINA CALITATE DA/DE/DE+
    DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR SUPERIEUR L6 EURO 5
    ESAPAMENT TOBA DE ESAPAMENT TRANSVERSALA
    CILINDREE 2200 CM3
    CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
    RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRU DE PARTICULE CU FILTRU DE PARTICULE
    VENTILATOR 2 VENTILATOARE ELECTRONICE CU COMANDA INTEGRATA 300W
    VARIANTA SOCIATA INJECTIE MONTARE BOSCH
    LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
    STOP AND START FARA SISTEM STOP AND START
    Cutie de viteze - Transmisie
    CUPLU RAPORT RAPORT PUNTE 15 X 53
    STIL ROATA (JANTA) STIL 10 DE 18 INCI
    AMBREIAJ FARA AMBREIAJ
    DIFERENTIAL (CUTIE) DIFERENTIAL 86
    JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 235/45 R18 98W INTARIT
    ROATA (TIP) MONTARE ROATA ALIAJ 2
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
    CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24
    SUSPENSIE SUSPENSIE NORMALA
    CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
    VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
    DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
    ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
    LUMINA DE PRAG LUMINI DE PRAG FATA
    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
    OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
    GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
    LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA VOPSITA
    APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
    PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
    PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
    ROATA DE REZERVA ROATA TIP ROLA
    ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TRAPA DE PLAFON ACOPERIS FIX
    ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
    GEAM (ASPECT) GEAM FUMURIU
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
    Echipament interior
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    SCAUN SPATE BANCHETA SEPARATA RABATABILA
    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    COTIERA DE SCAUN SPATE CU COTIERA SPATE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA FOARTE RECE
    GRADARE VITEZE GRADATIE IN KM/H
    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
    ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL
    LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
    GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
    CAPITONAJ DE USA DECORATIUNE TEP
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
    INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
    COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
    REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
    SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    BECURI DE PROIECTOR LAMPA CU DESCARCARE
    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFISAJ AFISAJ DEV
    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
    AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
    PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
    RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
    DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
    TUNER-RADIO TRI TUNER RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
    STORURI LATERALE FARA TRANSPERANTE LATERALE
    ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
    FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
    AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
    MODUL TELEMATIC MODUL TELEMATICA AUTONOM
    Electricitate
    ALTERNATOR ALTERNATOR CLASA 18
    BATERIE L3 760 VRLA1 EN AGM
    DEMAROR DEMAROR CLASA 6+
    ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
    Marci echipamente
    Diverse
    CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
    ATMOSFERA ATMOSFERA NORMALA
    ETICHETA FARA ETICHETA
    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
    PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
    SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
    ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
    RULARE DRUM CORECT
    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
    TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
    Diagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
    • #62
      508 VIN
      caracteristici va rog pt masina cu seria VF38EAHRMFL011121 . Multumesc.
      Linie de produs 508
      P4A 9666987299
      Informatii generale
      LINIE DE PRODUS 508
      Alimentare motor
      CILINDREE 2200 CM3
      Echipament interior
      AFISAJ AFISAJ DEV
      Electricitate
      Marci echipamente
      Diverse
      RULARE DRUM CORECT
      • #63
        508 BREAK 5 USI 2.0 HDi 150 FAP (DW10FD) CUTIE DE VITEZE MANUALA 6 (Cu stop and start)
        Linie de produs 508
        Nr. APV/PR 13982 CJ 1 0266
        Data de Inceput de Garantie 25.03.2015
        Numar de Serie Motor 10 DYZH 4019740
        NRE e2*2007/46*0080*26
        P4A 9810108999
        Informatii generale
        LINIE DE PRODUS 508
        TIP CAROSERIE BREAK 5 USI
        NIVEL DE ECHIPARE INALTA JOASA
        MOTOR DIESEL DW10FD FAP 110KW
        TRANSMISIE CUTIE DE VITEZE MANUALA 6 TREPTE TIP STOP AND START
        CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
        TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
        EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
        MONOGRAMA COMPLEMENTARA, DIVERSE BLUE HDI
        Alimentare motor
        DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR EURO 6.1
        ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
        CILINDREE 2000 CM3
        DEPOLUARE TEHNICA VEHICUL DEPOLLUTION TECHNIQUE VEHICULE EURO 6.1
        VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
        VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
        STOP AND START STOP & START ALTERNO DEMAROR BOOST
        CUPLU RAPORT RAPORT PUNTE 19 X 70
        STIL ROATA (JANTA) STIL 02 16 INCI
        JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
        PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
        INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
        CUTIE DE VITEZE TIP ML6C
        BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
        ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
        CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
        DISPOZITIV DE REMORCARE ARTICULATIE SFERICA VERTICALA DEMONTABILA
        ANTENA ANTENA + GPS
        INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
        STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
        STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
        OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
        GEAM DE PAVILION CU GEAM DE PAVILION
        BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
        PORTBAGAJ MONTARE CU BARE DE ACOPERIS
        ROATA DE REZERVA FARA ROATA DE REZERVA
        ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
        ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
        Echipament interior
        DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
        CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
        CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
        COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
        ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
        LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
        TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
        CAPITONAJ DE USA DECOR TESATURA
        INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
        COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
        COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
        REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
        BECURI DE PROIECTOR LAMPA CU HALOGEN
        AFISAJ AFISAJ ECRAN DIGITAL TACTIL
        ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
        PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
        PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
        RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
        INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
        COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
        DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
        DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
        ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
        PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
        Electricitate
        ALTERNATOR ISTT53
        BATERIE L3 760 VRLA2 EN AGM
        APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
        Marci echipamente
        Diverse
        CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
        CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
        SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
        ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
        RULARE DRUM CORECT
        • #64
          Salut! Ceva info pentru VF38D9HR8BL082212 ?!? Multumesc!
          • #65
            Linie de produs 508
            Nr. APV/PR 12743 CJ 1 0121
            Data de Inceput de Garantie 30.11.2011
            Numar de Serie Motor 10 JBEG 3038528
            NRE e2*2007/46*0080*03
            P4A 9666506499
            Informatii generale
            LINIE DE PRODUS 508
            NIVEL DE ECHIPARE INALTIME MEDIE PLUS
            MOTOR DIESEL TURBO DV6C
            TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE STOP AND START
            CULOAREA CAROSERIEI KLX - VOPSEA ALBASTRU ISEO
            TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
            CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
            MOTOR (TIP) MOTOR TIP DV
            MONOGRAMA COMPLEMENTARA, DIVERSE E-HDI
            Alimentare motor
            CILINDREE 1600 CM3
            INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
            VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
            VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
            STOP AND START CU STOP AND START
            CUPLU RAPORT RAPORT PUNTE 19 X 77
            STIL ROATA (JANTA) STIL 09 17 INCI
            DIFERENTIAL (CUTIE) DIFERENTIAL 84
            JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
            PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
            ROATA (TIP) MONTARE ROATA ALIAJ 3
            INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
            CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
            ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
            OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
            PACHET ROTI MONTAJ PNEURI 17 INCI (DOL08) + MONTAJ JANTA ALIAJ 3 (DRP07) + FĂRĂ ROATĂ DE REZERVĂ (DRS00)
            Echipament interior
            CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
            ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
            IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
            COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
            AFISAJ AFISAJ DEV
            REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
            STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
            Electricitate
            ALTERNATOR ISTT50
            DEMAROR DEMAROR CLASA 5
            Marci echipamente
            Diverse
            CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA FRANTA
            RULARE DRUM CORECT
            • #66
              Multumesc!!
              • #67
                Buna ziua , doresc sa achizitionez un peugeot 508 second și as vrea sa stiu daca ma poate ajuta si pe mine cineva de pe grup cu verificarea vin-ului masinii : VF38DRHHACL053449 . Va mulțumesc !
                • #68
                  Originally posted by Gama View Post
                  Buna ziua , doresc verificarea vin-ului masinii : VF38DRHHACL053449 . Va mulțumesc !
                  Linie de produs 508
                  Nr. APV/PR 12996 CJ 1 0222
                  Data de Inceput de Garantie 22.06.2012
                  Numar de Serie Motor 10 DYZD 4024423
                  NRE e2*2007/46*0080*07
                  P4A 9802998799
                  Informatii generale
                  LINIE DE PRODUS 508
                  MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
                  CULOAREA CAROSERIEI KGN - VOPSEA BOURRASQUE
                  TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
                  MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
                  Alimentare motor
                  CILINDREE 2000 CM3
                  STIL ROATA (JANTA) STIL 05 17 INCI
                  ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
                  Echipament interior
                  AFISAJ AFISAJ DEV
                  FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
                  Electricitate
                  BATERIE L3 720 EF
                  Marci echipamente
                  Diverse
                  RULARE DRUM CORECT
                  Cu atat te pot ajuta .
                  Mai mult gasesti intr-un service autorizat cu conditia ca masina in cauza sa fi intrat doar in service-uri autorizate.
                  Succes !
                  • #69
                    Salutare grup ! Mă poate ajuta și pe mine cineva cu verificarea unui vin ? Doresc să cumpăr un peugeot 508 second și aș dori să știu mai multe despre mașină înainte să merg s-o văd . VF38DRHHACL053449 . Mulțumesc !
                    • #70
                      Mulțumesc mult Wildman !
                      • #71
                        Salut , mă poți ajuta cu verificarea unui VIN ? Ms !
                        • #72
                          VF38D9HD8EL015636 mi-am luat un 508 din 2014 acum o saptamana si as dori sa stiu cate ceva despre el dacă se poate . Mulțumesc anticipat !
                          • #73
                            VF38D9HD8EL015636
                            Linie de produs 508
                            Nr. APV/PR 13654 CJ 1 0200
                            Data de Inceput de Garantie 26.05.2014
                            Numar de Serie Motor 10 JBFT 0061563
                            NRE e2*2007/46*0080*13
                            P4A 9804886599
                            Informatii generale
                            LINIE DE PRODUS 508
                            CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCE
                            Alimentare motor
                            CILINDREE 1600 CM3
                            ANTENA ANTENA + GPS
                            Echipament interior
                            AFISAJ AFISAJ DEV
                            INDICATOR DE ULEI FARA INDICATOR DE NIVEL DE ULEI
                            Electricitate
                            ALTERNATOR ISTT51
                            Marci echipamente
                            Diverse
                            RULARE DRUM CORECT
                            • #74
                              Vă rog caracteristici pentru:
                              VF38DRHC8DL046337
                              https://www.viagrasansordonnancefr.c...ance-biogaran/
                              • #75
                                Linie de produs 508
                                Nr. APV/PR 13450 CJ 1 0351
                                Data de Inceput de Garantie 24.09.2013
                                Numar de Serie Motor 10 DYZC 4040616
                                NRE e2*2007/46*0080*16
                                P4A 9667228099
                                Informatii generale
                                LINIE DE PRODUS 508
                                TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
                                CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
                                MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
                                Alimentare motor
                                DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
                                CILINDREE 2000 CM3
                                CATALIZATOR CATALIZATOR CU COMPUSI IMPREGNATI PESTE 50 PPM
                                LANT DE TRACTIUNE HIBRIDA LANT DE TRACTIUNE HIBRID
                                CUPLU RAPORT RAPORT PUNTE 17 X 74
                                PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 98W RANFORSAT
                                ROATA (TIP) MONTARE ROATA ALIAJ 7
                                Echipament interior
                                AFISAJ AFISAJ DEV
                                DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
                                ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
                                Electricitate
                                ALTERNATOR ISTT6
                                BATERIE L3 800
                                Marci echipamente
                                Diverse
                                RULARE DRUM CORECT
                                Sanatate !!
