peugeot 508 VIN
  • peugeot 508 VIN
    Buna seara,
    sunt de 2 saptamani posesorul unui Peugeot 508 SW 2.0 140 CP.
    Ma poate ajuta cineva cu informatii despre VIN : VF38ERHF8BL025235?
    Salutari, si bine ai venit printre noi.
    Mai jos ai datele cerute:
    Code:
    Linie de produs	508
    Nr. APV/PR	12560 CJ 1 0555
    Data de Inceput de Garantie	29.06.2011
    NRE	e2*2007/46*0080*00
    Informatii generale
    GENRE DE PRODUIT	VEHICUL PARTICULAR
    MARQUE COMMERCIALE, TYPE ORGANE	PEUGEOT
    LIGNE DE PRODUIT	508
    SILHOUETTE	BREAK 5 USI
    FINITION	INALTIME MEDIE PLUS
    MOTEUR	DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
    TRANSMISSION	CUTIE DE VITEZE MANUALA6
    TYPE DE PEINTURE	METALIZATA LACUITA
    COULEUR DE CAISSE	KCJ - VOPSEA SIWA
    TYPE D’HABILLAGE INTÉRIEUR	PARTIAL DIN PIELE MARSTON "3F"
    COULEUR DE GARNISSAGE	"FX"
    BOITE DE VITESSES (CARACTÉRISTIQUES)	CUTIE DE VITEZE MANUALA ML6 CL
    MOTEUR (TYPE)	MOTOR TIP EW/DW
    Caracteristici vehicul
    DIRECTION	SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DÉTECTEUR D’EAU FILTRE À GAZOLE	FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT	MOTORINA CALITATE DA/DE/DE+
    DÉPOLLUTION (MOTEUR)	DEPOLUARE EURO5 (MOTOR)
    ECHAPPEMENT	TOBA DE ESAPAMENT LONGITUDINALA
    CYLINDRÉE	2000 CM3
    CATALYSEUR	CATALIZATOR IMPREGNAT SUB 10PPM
    REFROIDISSEMENT D’HUILE	SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT	REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    RÉCHAUFFAGE CIRCUIT GAZ CARTER	SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
    AUTODIAGNOSTIC EOBD	SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOSITIF (ANTIPOLLUTION)	RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DÉPOLLUTION TECHNIQUE VÉHICULE	DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRE À PARTICULE	FILTRU DE PARTICULE
    VENTILATEUR	1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
    VARIANTE ASSOCIÉE INJECTION	SISTEM DE INJECTIE DELPHI
    LANT DE TRACTIUNE HIBRIDA	FARA LANT DE TRACTIUNE HIBRID
    FILTRE RÉSERVOIR	FILTRU REZERVOR INTERIOR
    STOP AND START	FARA SISTEM STOP AND START
    Cutie de viteze - Transmisie
    COUPLE RAPPORT	RAPORT PUNTE 6 X 65
    STYLE ROUE	STIL 05 17 INCI
    EMBRAYAGE	AMBREIAJ HIDRAULIC
    DIFFÉRENTIEL (BOITE)	DIFERENTIAL 86
    JANTE / PNEU DIMENSION	ECHIPARE PNEU 17 INCI
    PNEUMATIQUE (DIMENSIONS, TYPE)	PNEU 215/55 R17 94W NERANFORSAT
    ROUE (TYPE)	MONTARE ROATA ALIAJ 2
    INDICATEUR DE PERTE DE PRESSION DE GONFLAGE	FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    BOITE DE VITESSES TYPE	ML6C
    BARRE ANTIDÉVERS ARRIÈRE	BARA ANTIRULIU SPATE DIAMETRU 20
    ANTIDÉVERS AVANT	BARA ANTIRULIU FATA DIAMETRU 23,5
    SUSPENSION	SUSPENSIE NORMALA
    CONTRÔLE DYNAMIQUE DE STABILITÉ	CU SISTEM ESP
    VARIANTE ASSOCIÉE FREIN	ESP BOSCH 8 1
    DIRECTION (FONCTIONNEMENT)	DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    ATTACHE-REMORQUE	FARA DISPOZITIV DE REMORCARE
    ENJOLIVEMENT LATÉRAL (ASPECT)	FARA ELEMENTE DE PROTECTIE LATERALE
    ENJOLIVEUR ROUE (STYLE)	FARA CAPAC DE ROATA
    FEU D’ÉCLAIRAGE DE SEUIL	LUMINI DE PRAG FATA
    COMPLÉMENT DE PROTECTION (SOUS MOTEUR)	FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ)	FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR	RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    ESSUIE-VITRE AVANT	MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    ESSUIE-VITRE ARRIÈRE	MECANISM DE STERGERE LUNETA
    ESSUIE-PROJECTEUR	MECANISM DE STERGERE PROIECTOR
    OBTURATEUR FACE AVANT	OBTURATOR INFERIOR PANOU FRONTAL
    VITRE PAVILLON	CU GEAM DE PAVILION
    VITRE VOLET ARRIÈRE	GEAM FIX DE CAPAC DE PORTBAGAJ
    PARE-CHOCS	BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
    PARE-BOUE (BAVETTE)	FARA APARATORI DE ROTI SPATE
    PORTE-BAGAGES	MONTARE CU BARE DE ACOPERIS
    PROJECTEUR ANTIBROUILLARD	PROIECTOARE ANTI-CEATA
    ROUE DE SECOURS	ROATA ALIAJ + PNEU STANDARD
    ACCESSOIRES EXTÉRIEURS	MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR)	OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TOIT OUVRANT	ACOPERIS FIX
    ENJOLIVEMENT PARE-CHOCS	BARA DE PROTECTIE CU INSERTIE CROMATA
    VITRE (ASPECT)	GEAM FUMURIU + FUMURIU INCHIS
    VITRE (TYPE)	PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCÈS ET DÉMARRAGE MAINS LIBRES	ACCES SI PORNIRE CU MAINI LIBERE
    Echipament interior
    ALARME ANTIVOL	FARA ALARMA ANTIFURT
    ASSISE ARRIÈRE	BANCHETA SEPARATA RABATABILA
    DETECTION ANGLEMORT	FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    ACCOUDOIR ASSISE ARRIÈRE	CU COTIERA SPATE
    CEINTURE DE SÉCURITÉ ARRIÈRE	CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CLIMAT (TEMPERATURE AMBIANTE)	TARI CU CLIMA RECE
    GRADUATION VITESSES	GRADATIE IN KM/H
    COMMANDE DE VITESSES	COMANDA DE VITEZE LA PODEA
    COTÉ DE CONDUITE (POSTE DE CONDUITE)	VOLAN PE STANGA
    CHAUFFAGE ADDITIONNEL	SISTEM DE INCALZIRE HABITACLU SUPLIMENTAR PROGRAMABIL
    EQUIPEMENT PLANCHE DE BORD	DECORATIUNE CUBIC CU OCHIURI MICI
    FEUX INT. DIVERS	CITITOR HARTA FATA + SPATE CU LED
    GARNISSAGE VOLUME CHARGEMENT	COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    COMBINÉ (CARACTÉRISTIQUES)	GRADATIE 260 KM/H 160 M/H MATRICE COLOR
    GARNISSAGE DE PORTE	DECOR TESATURA
    HAUT-PARLEUR	4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMMANDE D’AUTORADIO	COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    INSONORISATION HABITACLE	ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT)	FARA TRANSPERANT SPATE
    REHAUSSE ASSISE AVANT PASSAGER	DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
    COMMANDE ASSISE AVANT CONDUCTEUR	COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
    COMMANDE ASSISE AVANT PASSAGER	COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
    RÉGLAGE ASSISE AVANT CONDUCTEUR	SUPORT LOMBAR CU REGLARE CONDUCATOR
    RÉGLAGE ASSISE AVANT PASSAGER	REGLARE SUPORT LOMBAR PASAGER
    SYSTÈME DE NAVIGATION	CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    LAMPES DE PROJECTEURS	LAMPA CU DESCARCARE
    LÈVE-VITRE ARRIÈRE	MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    LÈVE-VITRE AVANT PASSAGER	MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFFICHEUR	AFISAJ DEV
    MIROIR DE COURTOISIE	OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATEUR D’HUILE	RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    NAPPE CHAUFFANTE	SCAUN CU INCALZIRE
    SAC GONFLABLE LATÉRAL AVANT	AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ECLAIRAGE BAS HABITACLE	ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROTECTION PASSAGER ARRIÈRE	CU PROTECTIE PASAGER SPATE
    NEUTRALISATION COUSSIN GONFLABLE	DEZACTIVARE MANUALA AIRBAG
    PROJECTEUR CORRECTEUR ASSIETTE	REGLARE AUTOMATA A PROIECTOARELOR
    PROJECTEUR DIRECTIONNEL	FARA PROIECTOR DIRECTIONAL
    RÉCEPTEUR RADIO	RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
    RÉFRIGÉRATION	SISTEM DE REFRIGERARE AUTOMATA
    RÉGULATEUR DE VITESSES	SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    REHAUSSE ASSISE AVANT CONDUCTEUR	SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
    RÉTROVISEUR INTÉRIEUR	RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    RÉGULATION CLIMATISATION / TEMPÉRATURE	SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
    RANGEMENT VOLUME CHARGEMENT	CU PLASA IN PORTBAGAJ
    TUNER-RADIO	TRI TUNER RADIO
    DÉTECTION D’OBSTACLE	SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
    STORES LATÉRAUX	TRANSPERANTE LATERALE "RAND 2"
    ADAPTATION GARNITURE	MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
    AMPLI-ÉQUALISEUR	FARA AMPLIFICATOR EGALIZATOR
    FRÉQUENCE RADIO	FRECVENTA RADIO EUROPA OCCIDENTALA
    COMMANDE VERROUILLAGE	BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT	VOLAN IMBRACAT IN PIELE CU 3 BRATE
    SAC GONFLABLE GENOUX CONDUCTEUR	FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDÉO ARRIÈRE	FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO	1 PRIZA JACK + USB
    BOITIER TELEMATIQUE	MODUL TELEMATICA AUTONOM
    Electricitate
    ALTERNATEUR	ALTERNATOR CLASA 18
    BATTERIE	L3 720 EF
    DÉMARREUR	DEMAROR CLASA 6+
    ECLAIREMENT PARTICULIER	APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION	FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    ALLUMAGE FEUX	APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
    Marci echipamente
    Diverse
    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION	STANDARD
    ATMOSPHÈRE	ATMOSFERA NORMALA
    ETIQUETTE	FARA ETICHETA
    PRISE D’ÉCOUTE RADIO	PRIZA CVADRUPLA DE ACCESORII
    COTÉ CIRCULATION	CIRCULARE PE DREAPTA
    JEUX DE CLÉS	2 CHEI TELECOMANDA DE INALTA FRECVENTA
    EQUIPEMENT DE SECOURS	FARA ECHIPARE DE REZERVA
    ROULAGE	DRUM CORECT
    BOÎTIER SERVITUDE	BSI EVOLUTION
    TRIANGLE DE PRÉSIGNALISATION	FARA TRIUNGHI REFLECTORIZANT
      va multumesc pentru promtitudinea raspunsului.
      date despre istoricul masinii de unde pot obtine?
      masina am cumparat-o din Germania.
      am fost la Eurial Cluj si mi-au spus ca ei nu pot accesa istoricul masinii, dar pot sa-mi faca o diagnoza cu testerul.
      am ramas destul de dezamagit referitor la faptul ca Eurialul nu poate accesa istoricul masinii.
        Unu: te-au mintit, daca exista inregistrari pe service in reteaua Peugeot ei le pot accesa; sfat: fiind proprietar ai tot dreptul sa le ceri asta, bate putin mai tare cu pumnul in tejgheaua lor, eventual pomeneste-le subtil de Protectia Consumatorului si vezi ce se intampla.
        Doi: de ce te interesezi acum de istoric si nu ai facut asta inainte de a o cumpara?
        Tigaia
          Omul de la care am cumparat masina mi-a spus mai multe lucruri despre masina, si am vrut doar sa verific, chiar daca omul a parut a fi sincer.
          nu aveam cum sa verific istoricul inainte de a cumpara masina, asa ca, acum fiind proprietar cu acte in regula am considerat ca as vrea sa stiu mai multe date din trecutul masinii.
          oricum am facut deja 2000 km cu masina si sunt foarte incantat de aceasta (motor, dotari, comportament pe sosea, confort, eleganta, etc.).
          consider ca este o masina buna!
            daca iei legatura cu vanzatorul si prezinti seriozitate, ai sanse mari ca Neamtul sa iti dea VINul, pentru a verifica masina.
              salut..
              Am achizitionat si eu un Peugeot 508 nou. ma poti ajuta si pe mine sa verific vin ce dotari am la el te rog frumos
              VIN : VF38ERHH8EL010673
              - - - Updated - - -
              salut..
              Am achizitionat si eu un Peugeot 508 nou. ma poti ajuta si pe mine sa verific VIN, ce dotari am la el te rog frumos
                Originally posted by danyratoiu87 View Post
                salut..
                - - - Updated - - -
                salut..
                Linie de produs 508
                Nr. APV/PR 13624 CJ 1 0351
                Data de Inceput de Garantie 29.01.2015
                NRE e2*2007/46*0080*15
                GEN DE PRODUS VEHICUL PARTICULAR
                MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
                LINIE DE PRODUS 508
                TIP CAROSERIE BREAK 5 USI
                NIVEL DE ECHIPARE INALTA JOASA
                MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
                TRANSMISIE CUTIE DE VITEZE MANUALA6
                TIP DE VOPSEA METALIZATA LACUITA
                CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
                TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
                CULOARE GARNISAJ "FX"
                CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
                EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
                MOTOR (TIP) MOTOR TIP EW/DW
                MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SU
                DIRECTIE SISTEM DE DIRECTIE ASISTATA
                Alimentare motor
                DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
                DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
                ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
                CILINDREE 2000 CM3
                RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
                INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
                AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
                DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
                DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
                FILTRU DE PARTICULE FILTRU DE PARTICULE
                VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
                VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
                FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
                CUPLU RAPORT RAPORT PUNTE 6 X 65
                STIL ROATA (JANTA) STIL 04 17 INCI
                AMBREIAJ AMBREIAJ HIDRAULIC
                DIFERENTIAL (CUTIE) DIFERENTIAL 86
                JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
                PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 98W RANFORSAT
                ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
                INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
                CUTIE DE VITEZE TIP ML6C
                BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
                ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
                SUSPENSIE SUSPENSIE NORMALA
                CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
                VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
                DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULI
                DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
                ANTENA ANTENA + GPS
                ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
                ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
                LUMINA DE PRAG LUMINI DE PRAG FATA
                SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
                INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
                FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
                INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
                STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
                STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
                STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
                OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
                GEAM DE PAVILION CU GEAM DE PAVILION
                LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
                BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
                APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
                PORTBAGAJ MONTARE CU BARE DE ACOPERIS
                PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
                ROATA DE REZERVA FARA ROATA DE REZERVA
                ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
                RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
                TRAPA DE PLAFON ACOPERIS FIX
                ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
                GEAM (ASPECT) GEAM FUMURIU
                GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
                ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
                ALARMA ANTIFURT FARA ALARMA ANTIFURT
                SCAUN SPATE BANCHETA SEPARATA RABATABILA
                DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
                COTIERA DE SCAUN SPATE CU COTIERA SPATE
                CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
                CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
                CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
                GRADARE VITEZE GRADATIE IN KM/H
                COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
                PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
                INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
                ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
                LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
                GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
                TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
                CAPITONAJ DE USA DECOR TESATURA
                DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
                COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
                IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
                INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
                COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
                COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
                REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
                REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
                SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
                BECURI DE PROIECTOR LAMPA CU HALOGEN
                ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
                ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
                AFISAJ AFISAJ DEV
                OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
                INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
                FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
                AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
                ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
                PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
                NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
                PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
                PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
                RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
                REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
                REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
                INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
                RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
                REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
                COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
                DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
                DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
                STORURI LATERALE FARA TRANSPERANTE LATERALE
                ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
                AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
                FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
                COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
                AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
                ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
                MODUL TELEMATIC MODUL TELEMATICA AUTONOM
                ALTERNATOR ALTERNATOR CLASA 18
                BATERIE L3 720 EF
                DEMAROR DEMAROR CLASA 6+
                ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
                FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
                APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
                CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
                ATMOSFERA ATMOSFERA NORMALA
                ETICHETA FARA ETICHETA
                CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
                PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
                SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
                ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
                RULARE DRUM CORECT
                MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
                TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
                  Multumesc frumos de raspuns.
                    Imi dati si mie ceva informati va rog? VIN:VF38DRHC8CL031340.
                      Linie de produs 508
                      Nr. APV/PR 12912 CJ 1 0273
                      Data de Inceput de Garantie 20.06.2012
                      NRE e2*2007/46*0080*06
                      Informatii generale
                      LINIE DE PRODUS 508
                      TIP CAROSERIE BERLINA 4 USI
                      NIVEL DE ECHIPARE INALTIME MEDIE PLUS
                      TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
                      CULOAREA CAROSERIEI KTH - VOPSEA GRI THORIUM
                      TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
                      CULOARE GARNISAJ "FD"
                      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
                      MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
                      Alimentare motor
                      CILINDREE 2000 CM3
                      CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
                      LANT DE TRACTIUNE HIBRIDA LANT DE TRACTIUNE HIBRID
                      STOP AND START CU STOP AND START
                      CUPLU RAPORT RAPORT PUNTE 17 X 74
                      STIL ROATA (JANTA) STIL 05 17 INCI
                      AMBREIAJ FARA AMBREIAJ
                      PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
                      ROATA (TIP) MONTARE ROATA ALIAJ 2
                      CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
                      CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
                      DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
                      STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
                      STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
                      GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
                      PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
                      ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
                      ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
                      Echipament interior
                      CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
                      ECHIPAMENT PLANSA DE BORD DECORATIUNE IMITATIE LEMN
                      LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
                      TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
                      CAPITONAJ DE USA DECORATIUNE TEP
                      DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
                      INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
                      IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
                      INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
                      COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
                      COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
                      REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
                      BECURI DE PROIECTOR LAMPA CU DESCARCARE
                      AFISAJ AFISAJ DEV
                      ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
                      PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
                      INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
                      REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
                      DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
                      DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
                      STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
                      ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
                      AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
                      Electricitate
                      ALTERNATOR ISTT6
                      BATERIE L3 800
                      DEMAROR DEMAROR CLASA 5
                      APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
                      Marci echipamente
                      Diverse
                      CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
                      CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
                      SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
                      RULARE DRUM CORECT
                        Ati dezgropat un thread vechi de 2 ani si nu isi are rostul. Exista thread pentru decodarea vin-ului pentru toate modelele. Nu e necesar sa continuam aici separat doar pt 508.
                          Multumesc "calinutz". "ionut159" poate ai dreptate, dar cei care nu stiu apeleaza aici👍.
                            O chestie ciudata insa🤔zice ca e noua,insa garantia pleaca in 2015 si noi suntem in 2017...sau ma insel🙄
                            Inviato da mTalk
                              Ma refeream la nenea @ratzoiu87😏 cu al lui 508 nou
                              Inviato da mTalk
