peugeot 508 VIN
  • #76
    Multumesc mult.
    Numai bine.
    https://www.viagrasansordonnancefr.c...ance-biogaran/
    • #77
      Salut detalii despre Vin-ul asta.?
      VF38D9HR8AL035233(01)
      • #78
        vin invalid
        citeste mai cu atentie
        • #79
          Salut
          Salut va rog detalii despre vin VF38DRHF8DL030712.Merci mult.
          • #80
            Caracteristicile vehiculului
            Linie de produs 508
            Nr. APV/PR 13349 CJ 1 0310
            Data de Inceput de Garantie 10.05.2014
            Numar de Serie Motor 10 DYZA 4038691
            NRE e2*2007/46*0080*13
            P4A 9691274299
            Informatii generale
            GEN DE PRODUS VEHICUL PARTICULAR
            MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
            LINIE DE PRODUS 508
            TIP CAROSERIE BERLINA 4 USI
            NIVEL DE ECHIPARE INALTA JOASA
            MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
            TRANSMISIE CUTIE DE VITEZE MANUALA6
            TIP DE VOPSEA VOPSEA OPACA
            CULOAREA CAROSERIEI EWP - VOPSEA ALBA BANQUISE
            TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
            CULOARE GARNISAJ "FX"
            CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
            EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
            MOTOR (TIP) MOTOR TIP EW/DW
            MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
            Caracteristici vehicul
            DIRECTIE SISTEM DE DIRECTIE ASISTATA
            Alimentare motor
            DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
            CARBURANT MOTORINA CALITATE DA/DE/DE+
            DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
            ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
            CILINDREE 2000 CM3
            CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
            RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
            REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
            INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
            AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
            DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
            DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
            FILTRU DE PARTICULE CU FILTRU DE PARTICULE
            VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
            VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
            LANT DE TRACTIUNE FARA LANT DE TRACTIUNE HIBRID
            FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
            STOP AND START FARA SISTEM STOP AND START
            Cutie de viteze - Transmisie
            CUPLU RAPORT RAPORT PUNTE 6 X 65
            STIL ROATA (JANTA) STIL 02 16 INCI
            AMBREIAJ AMBREIAJ HIDRAULIC
            DIFERENTIAL (CUTIE) DIFERENTIAL 86
            JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
            PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
            ROATA (TIP) MONTARE ROATA ALIAJ 2
            INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
            CUTIE DE VITEZE TIP ML6C
            BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
            ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
            SUSPENSIE SUSPENSIE NORMALA
            CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
            VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
            DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
            Caroserie Echipamente
            DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
            ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
            ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
            LUMINA DE PRAG LUMINI DE PRAG FATA
            SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
            INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
            FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
            INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
            STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
            STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
            STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
            OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
            GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
            LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
            BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
            APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
            PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
            PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
            ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
            ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
            RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
            TRAPA DE PLAFON ACOPERIS FIX
            ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
            GEAM (ASPECT) GEAM FUMURIU
            GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
            ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
            Echipament interior
            ALARMA ANTIFURT FARA ALARMA ANTIFURT
            SCAUN SPATE BANCHETA SEPARATA RABATABILA
            DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
            COTIERA DE SCAUN SPATE CU COTIERA SPATE
            CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
            CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
            CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
            GRADARE VITEZE GRADATIE IN KM/H
            COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
            PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
            INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
            ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
            LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
            GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
            TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
            CAPITONAJ DE USA DECOR TESATURA
            DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
            COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
            IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
            INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
            COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
            COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
            REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
            REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
            SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
            BECURI DE PROIECTOR LAMPA CU HALOGEN
            ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
            ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
            AFISAJ AFISAJ DEV
            OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
            INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
            FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
            AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
            ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
            PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
            NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
            PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
            PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
            RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
            REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
            REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
            INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
            RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
            REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
            DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
            TUNER-RADIO TRI TUNER RADIO
            DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
            STORURI LATERALE FARA TRANSPERANTE LATERALE
            ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
            AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
            FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
            COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
            VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
            AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
            ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
            PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
            MODUL TELEMATIC MODUL TELEMATICA AUTONOM
            Electricitate
            ALTERNATOR ALTERNATOR CLASA 15
            BATERIE L3 720 EF
            DEMAROR DEMAROR CLASA 5
            ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
            FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
            APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
            Marci echipamente
            Diverse
            CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
            ATMOSFERA ATMOSFERA NORMALA
            ETICHETA FARA ETICHETA
            CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
            PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
            SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
            ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
            RULARE DRUM CORECT
            MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
            TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
            • #81
              Merci mult.
              PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE asta înseamnă că nu are airbaguri pt cei din spate ?
              • #82
                VF38DRHC8CL066418
                Ma poate ajuta cineva si pe mine cu acest VIN?
                Multumesc
                • #83
                  Linie de produs 508
                  Nr. APV/PR 13043 CJ 1 0578
                  Data de Inceput de Garantie 12.10.2012
                  Numar de Serie Motor 10 DYZC 4016184
                  NRE e2*2007/46*0080*11
                  P4A 9667228099
                  Informatii generale
                  LINIE DE PRODUS 508
                  NIVEL DE ECHIPARE INALTIME MEDIE PLUS
                  MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
                  TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
                  TIP DE VOPSEA METALIZATA LACUITA
                  CULOAREA CAROSERIEI KLX - VOPSEA ALBASTRU ISEO
                  TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
                  CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
                  MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
                  Alimentare motor
                  CILINDREE 2000 CM3
                  LANT DE TRACTIUNE LANT DE TRACTIUNE HIBRID
                  STOP AND START CU STOP AND START
                  CUPLU RAPORT RAPORT PUNTE 17 X 74
                  STIL ROATA (JANTA) STIL 05 17 INCI
                  AMBREIAJ FARA AMBREIAJ
                  JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
                  PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
                  CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
                  CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
                  DISPOZITIV DE REMORCARE ARTICULATIE SFERICA VERTICALA DEMONTABILA
                  STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
                  ROATA DE REZERVA FARA ROATA DE REZERVA
                  ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
                  ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
                  Echipament interior
                  ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
                  LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
                  TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
                  CAPITONAJ DE USA DECORATIUNE TEP
                  DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
                  IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
                  INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
                  COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
                  COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
                  REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
                  BECURI DE PROIECTOR LAMPA CU DESCARCARE
                  AFISAJ AFISAJ DEV
                  FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
                  ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
                  PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
                  INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
                  REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
                  DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
                  STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
                  ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
                  AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
                  Electricitate
                  ALTERNATOR ISTT6
                  BATERIE L3 800
                  APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
                  Marci echipamente
                  Diverse
                  CRITERIU FACTORI, CLIENTELA CONCEPTIE CONSUM SCAZUT
                  SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
                  ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
                  RULARE DRUM CORECT
                  • #84
                    decodare vin
                    Bună seara!
                    Sunt posesorul unui 508 de câteva zile. Ma puteți ajuta cu ceva informații? VF38ERHHABL077893
                    • #85
                      Linie de produs 508
                      Nr. APV/PR 12733 CJ 1 0783
                      Data de Inceput de Garantie 27.01.2012
                      Numar de Serie Motor 10 DYYG 4030705
                      NRE e2*2007/46*0080*01
                      P4A 9666395299
                      Informatii generale
                      CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
                      TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
                      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
                      Alimentare motor
                      CILINDREE 2000 CM3
                      INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
                      TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
                      CUPLU RAPORT RAPORT PUNTE 15 X 53
                      PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95V NERANFORSAT
                      CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
                      ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
                      STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
                      OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
                      GEAM DE PAVILION CU GEAM DE PAVILION
                      PORTBAGAJ MONTARE CU BARE DE ACOPERIS
                      Echipament interior
                      CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
                      INCALZIRE ADITIONALA SISTEM DE INCALZIRE HABITACLU SUPLIMENTAR PROGRAMABIL
                      INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
                      COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
                      COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
                      AFISAJ AFISAJ DEV
                      REGULATOR SE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
                      DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
                      DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
                      ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
                      Electricitate
                      ALTERNATOR ALTERNATOR CLASA 18
                      BATERIE L3 720 EF
                      DEMAROR DEMAROR CLASA 6+
                      Marci echipamente
                      Diverse
                      CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
                      RULARE DRUM CORECT
                      • #86
                        Mulțumesc frumos!
                        • #87
                          Sa o stapanesti sanatos si la cat mai multi km fara evenimente neplacute !
                          Ti-as fi oferit datele mai devreme , insa am intampinat probleme in accesarea forumului mai multe zile la rand
                          A mai patit cineva la fel ?
                          • #88
                            Verificare vin
                            Salutare, ma puteti ajuta cu seria urmatoare?
                            VF38URHC8FL008861
                            • #89
                              Linie de produs 508
                              Nr. APV/PR 13973 CJ 1 0177
                              Data de Inceput de Garantie 16.03.2015
                              Numar de Serie Motor 10 DYZC 4058507
                              NRE e2*2007/46*0080*24
                              P4A 9667227999
                              Informatii generale
                              LINIE DE PRODUS 508
                              TIP CAROSERIE BREAK RXH
                              NIVEL DE ECHIPARE CU EXCEPTIA STANDARDULUI COBORAT
                              TIP ECHIPARE INTERIOARA PIELE CLUB NAPPA "8B"
                              EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
                              Alimentare motor
                              CILINDREE 2000 CM3
                              STIL ROATA (JANTA) ROATA ALIAJ STIL GRAND ANGLE 18"
                              JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
                              PNEURI (DIMENSIUNI, TIP) PNEU 245/45 R18 W FARA INTARIRE
                              ROATA (TIP) ECHIPARE CU ROATA CU JANTA DIN ALIAJ 5
                              INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
                              BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21,5
                              ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
                              ANTENA ANTENA + GPS
                              FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
                              PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
                              GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
                              Echipament interior
                              DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
                              ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU + DEGRADE
                              CAPITONAJ DE USA DECORATIUNE PIELE CLUB
                              COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN FATA CU MEMORIE + REGLARE PARTE SUPERIOARA DE PERNA
                              BECURI DE PROIECTOR LAMPA CU LED
                              AFISAJ AFISAJ ECRAN DIGITAL TACTIL
                              RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
                              COVORAS DE PODEA (ASPECT) COVORASE TRAMONTANE BRODERIE PIELE
                              DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE
                              PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
                              Electricitate
                              ALTERNATOR ISTT6
                              BATERIE L3 800
                              Marci echipamente
                              Diverse
                              CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
                              RULARE DRUM CORECT
                              • #90
                                Multumesc,
                                Data de intrare in garantie reprezinta data cand a fost cumparata sau data productiei?
                                Ce semnifica L6 de la norma de poluare?
