regenerare in "suturi"
  • #31
    @Corde Varianta scurta
    With the direct-injection common rail technology, the level of particle emissions from the HDi engine was already particularly low. With the PF, it drops still further to a level that is barely measurable. In this way, the engine goes well beyond the future environmental standards of the European Union.
    The PF traps the particles on a filter and burns them at regular intervals.
    The particles burn naturally at around 550 °C, but the initial temperature of the exhaust gases The PF modifies these two parameters through:
    * a post-injection of fuel in the expansion phase, which generates post-combustion in the cylinder and raises the temperature of the gases by 200 °C to 250 °C, to around 350°C to 400 °C.
    * additional post-combustion generated by an oxidation catalyser placed upstream of the filter, which treats the unburned hydrocarbons from the post-injection phase. The temperature may increase by a further 100 °C, up to 450°C or 500 °C.
    * the fuel additive Eolys fuel additive. This additive lowers the natural particle combustion temperature to 450 °C.
    FAP is the abbreviation for the French "Filtre à particules", i.e. particle filter, and FAP is registered as a proprietary name for PSA's DPFS.
    Deci s-a mai discutat exact cum functioneaza intreg procesul, aditivul nu este pentru mersul in oras asa cum crezi tu.
    • #32
      Nici nu am sustinut ca ar fi pentru mersul in oras, ci doar ca in afara orasului se poate si fara aditiv, ca si la alte marci cu DPF fara intretinere (aditiv).
      Pana la urma conteaza un sfat bun pentru a scapa de mersul in "suturi". Personal am ales demontarea FAP de pe masina.
      Sarbatori fericite tuturor, iar masinile sa ne duca pe fiecare la destinatie intr-un mod placut!
      • #33
        Originally posted by jeffe View Post
        Va salut , si masina mea , DOAR cand sunt la drum lung si merg cu ea la turatie mare si constanta , dupa cateva minute incepe sa mearga "intepata" , la Mine sigur FAP e infundat , nu am nici lichid . Si in oras se mai inteapa(cand fac multi km in oras fara drum lung) si stiu sigur ca este de la FAP infundat . Deci sigur eu zic ca e legeat de FAP problema mersului intrerupt. Daca el e infundat , la un nivel constant de gaze , el va intrerupe mersul lin al masinii .
        Masina are vlaga , se comporta normal .
        Ai incercat , in timp de merge intrerupt , sa o calci sa vezi daca mai merge asa ? Eu cand apasa pedale mai mult nu mai merge intrerupt , doar la turatie constanta face asa
        Da, atunci cand calc acceleratia merge mai bine,
        • #34
          regenararile dese si in " suturi" pot fi de la egr defect...cel putin asa am patit eu, am schimbat egr-ul si pt moment totul pare a fii in regula, plus ca acum si consul e normal.
          am uitat sa spun ca am un peugeot 407 ,2.0 hdi, 136 cp. salutari...
          • #35
            Heeelp!
            Salut. Am vazut ca ai postat in 2015 ca nu ai mai avut probleme cu regenerarile in suturi dupa ce ai schimbat egr-ul. Voiam sa te intreb daca de atunci e totul in ordine sau daca ti-a mai reaparut problema? Am acelasi simptome si nu stiu de unde sa ma apuc de treaba, ca efectiv nu o mai suport. Sper intr-un raspuns de la tine cat mai curand.
            🚘 Peugeot 407 2.0 hdi 136 CP FAP; ex. Peugeot 206 1.4 benzina🚘
            • #36
              Incearca sa iei legatura cu Turbojack (Viorel) din Cluj pentru o diagnoza. Mersul in suturi poate fi de la egr defect sau filtru de particule plin.
              • #37
                Am corespondat cu dansul si incerc sa ajung la Cluj zilele astea. Multumesc mult.
                • #38
                  Sa ne spui ce ati descoperit.
                  • #39
                    Ok, miercuri merg la Turbojack si v-oi reveni cu amanunte.
                    • #40
                      De ce nu indica martorul in bord ca este infundat filtrul ?
                      • #41
                        La regenerari care dureaza mai mult, s-a aprins depolution system faulty. Nu se aprinde intotdeauna, insa regenerarea porneste impreuna cu ,, suturile" respective, mult fum negru si sunet ciudat ca si cum ar bate injectoarele rau de tot. Limitare de putere nu are, pt ca daca ii dau ,, jar", fuge bine. Am un deal renumit ca si lungime in apropiere, Dăbăgau se numeste. Dupa o tura, doua in sus pe el la turatie de 3500 plus, masina isi revine pentru vreo doua saptamani.
                        • #42
                          Daca stii ca ar fi probleme cu filtrul de particule si a depasit termenul cand trebuia inlocuit, ar fii bine sa nu o mai arsi in sarcina maxima. O sa ajungi sa spui pe forum ca Peugeot-ul tau este cea mai proasta masina.
                          • #43
                            Tocmai ce am facut testele pe Lexia la Turbojack. Filtrul are grad de incarcare de 53% si in rest toate bune cu exceptia EGR-ului care nu functioneaza cum trebuie si de acolo si problemele semnalate. Acum vrem sa i-l schimbam. Va tin la curent cu amanunte.
                            • #44
                              Luni sau marti speram sa-l putem schimba si am sa postez primele impresii dupa aceasta operatiune.
                              • #45
                                Revin cu primele impresii dupa schimbarea EGR-ului la Turbojack: motorul urca in ture mult mai usor, a disparut problema cresterii turatiei peste 3000 de ture cand e cuplata clima si intreruperile intermitente de putere, raspunsul acceleratiei cand dau sprituri este mult mai prompt si nu mai ,, da motorul inapoi" de parca avea contragreutate cand scadea turatia, pornirea motorului este mult mai ,, aerisita" si eleganta. Urmăresc acum consumul si eventualele smucituri daca v-or mai fi, dar la cum se prezinta acum motorul, nu cred ca v-or mai aparea. Motorul merge si trage bine, chiar daca am o problema sesizata pe Lexia cu privire la presiunea la turbina care e numai de 1.8, lucru de care ma v-oi ocupa pe viitor impreuna cu Turbojack. Mentionez ca EGR-ul a fost pusa piesa noua si originala si sunt multumit de rezultate.
