  • Multumesc de raspunsuri. M-a mai lasat bateria acum un an, dar nu a facut asa "urat". O sa incerc astazi sa scot bateria si sa o pun pe redresor. Va tin la curent cu ce am mai facut.
    Last edited by Cristi_M.; 20-03-2013, 06:19 PM. Reason: Problema ta se incadreaza la acest topic!
    • Salutare ,mi sa stins in mashina toti martorii + radioul ,,cred eu ca e un fusibil
      Cred ca am gasit cred eu ca e aceasta ...http://www.peugeotlogic.com/fuses/fuses307/307fuse1.htm
      F11 15 +BB-2 Radio RB, RD,RT
      Multifunction screen B
      CV 00
      Automatic transmission
      DAR ESTE SI ALTA
      F24 15A +BB-2 S VAN COMF instrument panel
      S VAN COMF radio (+tel)
      S VAN COMF display
      S VAN COMF air conditioning
      S VAN COMF parking aid
      EU revin cu raspuns ...era arsa asta de'' F24 15A'' sper ca am ajutat pe multi
      Eu le pun pe toate sper sa ajut si pe altii ,,
      BSI-1
      Fuses
      Rating
      Supply
      Application
      F1 10A +BB-1 Rear foglight
      F2 15A +BB-1 Rear wiper
      F3
      F4 15A +BB-2 +VAN BOD2 Front electric windows
      +VAN BOD2 Sunroof
      F5 15A 2100 Brake lights
      F7 20A +AA Rear roof light
      Front roof light, map reading light
      Front 12V socket
      Cigar lighter
      Glove box light
      F9 30A +BB-1 Sunroof, front electric window power
      F10 15A +BB-2 Diagnostic plug
      Rear 12V socket
      CV 00
      F12 10A +BB-2 Front right sidelight
      Rear right sidelight, number plate light, trailer
      Locking, alarm, ESP, hazard pushbutton
      AC controlpanel light
      Ashrtay light
      Seat pushbutton
      Automatic transmission pushbutton
      F14 30A +BB-1 Central locking control
      Dead locking control
      Central unlocking control
      F15 30A +BB-1 Rear electric windows (Version D and E)
      Brake lights input
      F16 5A +BB-2 +VAN BOD1 BM34
      +VAN BOD1 anti theft alarm
      +VAN BOD1 particle filter
      +VAN BOD1 CV00
      +VAN BOD1 airbag
      F17 10A 2100 Right brake light (including third brake light)
      F18 10A +CC Diagnostic plug
      CV00
      Brake light, clutch pedal switches
      Coolant level switch
      Brake switch (backup)
      F19 SH +BB-2 Park shunt
      F19A 30A +CC Park position
      F22 10A +BB-2 Front left sidelight
      Rear left sidelight, number plate light, trailer
      F23 15A +BB-2 Alarm siren
      Alarm volumetric control unit
      S VAN COMF display
      F26 30A +BB30 Heated rear screen
      Engine Fuse Module (BM34) Module-1
      Fuses
      Rating
      Supply
      Application
      MF1 40A +BB GMV 100/150 AND 300 Watt
      MF2 30A +BB ABS/ESP: pump
      MF3 30A +BB ABS/ESP: solenoid valves
      MF4 70A +BB BSI power supply +BB-1
      MF5 70A +BB BSI power supply +BB-2
      MF6 20A +BB Heated seats (ccs police)
      MF7 30A +BB Anti-theft power switch
      MF8 70A +BB Electric power steering. (GEP)
      Engine Fuse Module (BM34) Module-2
      Fuses
      Rating
      Supply
      Application
      F1 10A +CC Automatic transmission reverse lights
      Automatic transmission starter inhibitor relay
      Manual gearbox reverse lights
      Vehicle speed sensor (TU3/EW10)
      F2 15A + BB Canister solenoid valves (TU/EW)
      Fuel pump
      F3 10A +CC Power steering ECU
      ABS or ESP ECU
      F4 10A +CC Additional heating relay signal.
      Injection ECU
      Fan motor relay signal
      Automatic transmission ECU
      Shift lock relay singal
      Shift lock motor signal
      Automatic transmission push button signal
      F5 15A + BB PF ECU
      F6 15A + BB Both front foglights
      F7 20A + BB Head light washer pump
      F8 ----- FREE
      F9 15A + BB Left headlight low beam
      F10 15A + BB Right headlight low beam
      F11 10A + BB Right headlight high beam
      F12 10A + BB Left headlight high beam
      F13 15A + BB Low and high tone horn
      F14 10A + BB Washer pump, front and rear
      F15 30A + BB Ignition coil (TU/EW)
      Diesel heater (DW10TD)
      Diesel injection pump (DV4, DW10)
      EGR solenoid valve (EW10)
      RR oxygen sensor (TU/EW)
      Front oxygen sensor (TU/EW)
      ECU 1320 (DW10 Siemens)
      Injectors (TU/EW)
      Air flow meter (DW, DV4)
      Solenoid valve EGR+THR (DW10 TD)
      EGR solenoid valve (DW10TD)
      Coolant heat solenoid valve (DW1ATED)
      Turbo pressure control solenoid vlve (DW10ATED)
      F16 30A + BB Air pump
      F17 30A + BB Front wiper, slow and fast speed
      F18 40A + BB Air conditioning blower motor
      nicolai1905
      • Am patit ceva azi dimineata, aveam faza scurta pornita si am observat cum deodata se oprea faza scurta, intrau pozitiile, pornea faza scurta si tot asa de cateva ori. Mi-a facut de mai multe ori, cateodata o singura data, cateodata de 3-4 ori pana am oprit si repornit eu luminile. De ce poate fi ?
        • A incercat cineva sa desfaca maneta de lumini de pe blocul de lumini? Capacul a iesit usor cu o surubelnita mica (ca la maneta cealalta cu stergatoarele si cb) dar mai departe vine un plastic care se roteste putin stanga-dreapta dar nu iese afara. M-am chinuit putin dar am renuntat sa nu fac vreo bucurie.
          • Salut.Sper ca postez unde trebuie.
            Am gasit un cablu care avea protectia rupta si dadea la masa la un suport de injector, l-am izolat cu banda sa nu faca vreo surpriza.Cumva este de la bujii, ca este prins in dreptul fiecarui injector?Nu pot sa atasez pozele cu acel fir!!!!
            • Nasol si mie mi s a rupt una dar la mine a ramas doar varful nu si parte afiletata. Cred ca solutia ar fi schimbarea mai des.
              Sent from my GT-I9100 using Tapatalk 2
              Black Lion.
              • Salut astea sunt pozele cu acel fir cu protectia rupta si locul unde vine legat.De la ce este acest fir?
                • Lumini frana aprinse
                  Am observat urmatoarea problema: pedala de frana nu revine totdeauna sus de tot si luminile de frana raman aprinse. Insa nu simt ca masina ar ramane partial franata. Daca ridic pedala cu piciorul becurile se sting. Se poate regla ceva ca sa fac pedala sa revina sus de tot sau trebuie schimbat ceva?
                  • Bloc lumini
                    Salut, stie careva dintre voi ce tip de bloc de lumini am nevoie pentru 307, 1.4 hdi 8 HZ cu urmatoarele caracteristici: NU am CB, functie stergator parbriz,luneta, temporizator , functie intermitenta, faza scurta , lunga, pozitie, semnalizare stg.-dreapta,stropire parbriz,luneta, comutator ceata spate si cred ca atat.Am inteles ca este vorba de ceva pini cu care este dotat fiecare bloc de lumini.Vreau sa cumpar unul SH.dar pentru asta trebuie sa-l dau jos si sa merg cu el la dezmembrari dar nu pot sa fac acest lucru deoarece unde am gasit este in afara orasului si nu ma pot lipsi de masina. Multumesc.
                    • Poti incerca si asa, sa astepti un raspuns poti sa incerci si asa : 307, 1.4 Hdi 8 HZ are un VIN. Numarul acesta il introduci la Public Service Box, pentru a-ti afla referinta subansamblului.
                      Imprimi datele din PSB sa le iei cu tine si te duci cu foaia si cu masina deci si cu blocul de lumini montat, la acel sh. shop.
                      • Daca dai plasticele jos din jurul volanului, poti sa vezi ce tip de bloc de lumini ai.
                        Plus conteaza anul de fabricatie.
                        • Wow,multumesc H3llow33N,nu stiam chestia asta,credeam ca trebuie demontat tot sa vezi tipul blocului de lumini.Ma apuc de smuls plasticele alea de acolo ca imi scoate peri albi piesa cu pricina.
                          • Daca nu e mai noua de 2003-2004 atuncea ai nevoie de com2000 totusi de ce vrei sa l schimbi? Poti sa iei absolut orice model si cu cb si fara ca nu te incurca cu nimica.
                            Black Lion.
                            • Pai e fabricatie 06.2004 si vreau sa l schimb ca nu mi sta pe faza lunga,sare pe scurta si nici butonul pt cb nu mi functioneaza,si mai face si semnalizarea figuri))) cam multe probleme pt un bloc de lumini nu?
                              • Salut!De azi dupa un drum in oras,ajuns acasa am observat ca pozitia din far pe partea dreapta uitandu te la masina nu se stinge.Va rog daca puteti sa ma ajutati cu o idee.Multumesc anticipat!
