VIN (Vehicle Identification Number) - Informatii utile
  • Originally posted by lucianian View Post
    Va salut.
    Daca se poate o decodare pt VIN: VF38DRHF8BL022101
    Multumesc
    Caracteristicile vehiculului
    Linie de produs 508
    Nr. APV/PR 12551 CJ 1 0731
    Data de Inceput de Garantie 02.08.2011
    NRE e2*2007/46*0080*00
    Informatii generale
    GEN DE PRODUS VEHICUL PARTICULAR
    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
    LINIE DE PRODUS 508
    TIP CAROSERIE BERLINA 4 USI
    NIVEL DE ECHIPARE INALTA JOASA
    MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE MANUALA6
    TIP DE VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
    TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
    CULOARE GARNISAJ "FX"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
    EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
    MOTOR (TIP) MOTOR TIP EW/DW
    Caracteristici vehicul
    DIRECTIE SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT MOTORINA CALITATE DA/DE/DE+
    DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
    ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
    CILINDREE 2000 CM3
    CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
    RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRU DE PARTICULE FILTRU DE PARTICULE
    VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
    VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
    LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
    STOP AND START FARA SISTEM STOP AND START
    Cutie de viteze - Transmisie
    CUPLU RAPORT RAPORT PUNTE 6 X 65
    STIL ROATA (JANTA) STIL 09 17 INCI
    AMBREIAJ AMBREIAJ HIDRAULIC
    DIFERENTIAL (CUTIE) DIFERENTIAL 86
    JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
    ROATA (TIP) MONTARE ROATA ALIAJ 3
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    CUTIE DE VITEZE TIP ML6C
    Suspensie - directie - Franare
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
    SUSPENSIE SUSPENSIE NORMALA
    CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
    VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
    DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
    ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
    LUMINA DE PRAG LUMINI DE PRAG FATA
    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
    OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
    GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
    LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
    APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
    PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
    PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
    ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
    ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
    RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TRAPA DE PLAFON ACOPERIS FIX
    ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
    GEAM (ASPECT) GEAM FUMURIU
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
    Echipament interior
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    SCAUN SPATE BANCHETA SEPARATA RABATABILA
    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    COTIERA DE SCAUN SPATE CU COTIERA SPATE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
    GRADARE VITEZE GRADATIE IN KM/H
    COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
    ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
    LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
    GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
    CAPITONAJ DE USA DECOR TESATURA
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
    INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
    COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
    REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
    SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
    BECURI DE PROIECTOR LAMPA CU HALOGEN
    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
    AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
    PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
    RECEPTOR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT
    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
    DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
    TUNER-RADIO TUNER DUBLU RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
    STORURI LATERALE FARA TRANSPERANTE LATERALE
    ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
    FRECVENTA RADIO FRECVENTA RADIO ARABIA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
    AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
    MODUL TELEMATIC FARA MODUL TELEMATIC
    Electricitate
    ALTERNATOR ALTERNATOR CLASA 18
    BATERIE L3 720 EF
    DEMAROR DEMAROR CLASA 6+
    ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
    Marci echipamente
    Diverse
    CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
    ATMOSFERA ATMOSFERA NORMALA
    ETICHETA FARA ETICHETA
    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
    PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
    SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
    ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
    RULARE DRUM CORECT
    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
    TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
    • Multumesc frumos
      • Salutare. Ma poate ajuta cineva cu un istoric de km, sau revizii pt un Ford Focus? VIN: wfolxxgcblca48335
        Multumesc anticipat
        Peugeot 406 2.0 hdi
        • Am gresit o litera, seria corecta este WF0LXXGCBLCA48335, cu zero in loc de "o"
          Peugeot 406 2.0 hdi
          • Incearca pe forumul monomarca , adica la ford nu la peugeot .
            • Am rezolvat...ramanem fidel marci pana la urma.
              Peugeot 406 2.0 hdi
              • Are cineva cont si pe Citroen...? Ca vad ca trebuie sa ma inregistrez cu firma...
                • Geo, daca ai nev. de caracteristici, da-mi seria si te ajut.
                  • Ceva caracteristici si pentru mine va rog ? Ma intereseaza in special daca are esp/asr .
                    VF32A8HXF43074792
                    Multumesc .
                    Peugeot 206 1.4 HDI 2003 - un lenes
                    • Originally posted by SoriNn View Post
                      daca are esp/asr
                      Cu ABS
                      Fara ESP
                      ANTIBLOCAGE ANTI-BLOCAGE ROUE
                      CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP
                      VARIANTE ASSOCIÉE FREIN ABS TEVES MK70
                      caracteristici VF32A8HXF43074792
                      Caractéristiques du véhicule
                      Ligne de produit 206
                      N°APV/PR 09613 81 2 0111
                      Date de Début de Garantie 09/04/2003
                      NRE e2*98/14*0250*02
                      Informations générales
                      GENRE DE PRODUIT VEHICULE PARTICULIER
                      MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
                      LIGNE DE PRODUIT 206
                      SILHOUETTE BERLINE 5PTES
                      FINITION X LINE
                      MOTEUR DIESEL TURBO DV4TD
                      TRANSMISSION BVM5
                      TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
                      COULEUR DE CAISSE EZR - PEINTURE GRIS ALUMINIUM
                      TYPE D’HABILLAGE INTÉRIEUR TISSU TRESSE ANDORRE + EFKA "PA"
                      COULEUR DE GARNISSAGE "FN"
                      BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MA5 / O
                      MOTEUR (TYPE) MOTEUR TYPE DV
                      MONOGRAMME COMPLÉMENTAIRE HDI
                      MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
                      MONOGRAMME SANS MONOGRAMME
                      Caractéristiques véhicule
                      FINITION X LINE
                      DIRECTION DIRECTION ASSISTANCE NON VARIABLE
                      COUPLE TACHYMÈTRE CT 21 X 18
                      Alimentation moteur
                      BOUCHON DE REMPLISSAGE CARBURANT BOUCHON CARBURANT COULEUR CAISSE
                      DÉTECTEUR D’EAU FILTRE À GAZOLE AVEC DETECTEUR EAU FILTRE GASOIL
                      CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE ALUMINIUM
                      CARBURANT GAZOLE
                      DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
                      PRÉFILTRE MONTAGE SANS PREFILTRE
                      CATALYSEUR CATALYSEUR 2 COMPOSES FILTRES IMPR PLATINE
                      REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
                      OPTIMISATION DE CONSOMMATION DU VÉHICULE SANS OPTIMISATION CONSOMMATION CARBURANT
                      MOTEUR REFROIDISSEMENT RADIATEUR EP:27 21 DM2 PAS 1,1 NON ENCLIQUETABLE
                      RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
                      COUPURE ALIMENTATION CARBURANT AVEC COUPURE ALIMENTATION CARBURANT
                      RHÉOSTAT AVEC RHEOSTAT
                      AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC "EOBD"
                      DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
                      DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
                      FILTRE À PARTICULE SANS FILTRE A PARTICULES
                      VENTILATEUR 2 VENTILATEURS 2 VITESSES 250W
                      RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUPERATION VAPEUR ESSENCE
                      VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
                      FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
                      BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
                      Boîte de vitesses Transmission
                      TRANSMISSION BVM5
                      COUPLE RAPPORT CP 17 X 64
                      STYLE ROUE ROUE BOHEME 2 14 POUCES
                      VERROUILLAGE SÉCURITÉ BOITE DE VITESSES SANS VERROUILLAGE SECURITE BV
                      TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV MA/5 O
                      DIFFÉRENTIEL (BOITE) DIFFERENTIEL RENFORCE
                      PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 175/65 R14 82T NON RENFORCE
                      ROUES MONTÉES ROUE 5 POUCES 1/2
                      ROUE (TYPE) MONTAGE ROUE ALLIAGE
                      BOITE DE VITESSES TYPE BVM MA
                      Suspension Direction Freinage
                      BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 19
                      ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 20
                      FREIN PRINCIPAL REPARTITION ELECTRONIQUE FREINAGE
                      FREIN TYPE DISQUES AV VENTILES/TAMBOURS AR
                      SUSPENSION SUSPENSION NORMALE
                      PÉDALIER (TYPE) PEDALIER STANDARD
                      Carrosserie Equipements
                      AVERTISSEURS AVERTISSEUR STANDARD
                      ANTENNE ANTENNE AV LONGUE
                      DÉCORATION (ADHÉSIVE) MONTANT PORTE NOIR SANS FILETS DECORATIFS
                      ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTES MASSE
                      ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX
                      ENJOLIVEUR ROUE (STYLE) CABOCHON ALU BOHEME
                      COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
                      FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE MANUEL
                      ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT SANS ENJOLIVEUR SORTIE ECHAPPEMENT
                      INSONORISATION COTÉ MOTEUR INSONO SOUS CAPOT + TABLIER +SOUS GMP
                      ESSUIE-VITRE AVANT ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
                      ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
                      ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
                      OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
                      VITRE PAVILLON SANS VITRE PAVILLON
                      PARE-CHOCS P/C COULEUR CAISSE DEPUIS MOD2000
                      PARE-BOUE (BAVETTE) PARE BOUE AV DE ROUE AR
                      PORTE-BAGAGES MONTAGE SANS BARRES DE TOIT LONGITUDINALES
                      PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
                      PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROJECTEUR SIMPLE PARABOLE
                      RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE MANUELLE
                      RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE MANUELLE
                      ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
                      ACCESSOIRES EXTÉRIEURS RETRO EXT ET POIGNEES EXT COULEUR CAISSE
                      RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) MIROIR ASPHERIQUE RETRO EXT
                      TOIT OUVRANT TOIT FIXE
                      ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
                      VITRE ARRIÈRE (GENRE) VITRE AR CHAUFFANTE
                      VITRE (ASPECT) TEINTEE
                      VITRE CUSTODE (NATURE) SANS VITRE CUSTODE
                      VITRE (TYPE) PARE-BRISE ATHERMIQUE
                      Equipement intérieur
                      ALARME ANTIVOL SANS ALARME ANTIVOL
                      ALLUME-CIGARE ALLUME CIGARE AVANT
                      APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
                      APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
                      ASSISE ARRIÈRE BANQUETTE SEPAREE RABATTABLE
                      ALARME INTÉRIEURE ALERTE PORTE OUVERTE(CLIGNOTTEMENT PLAFONNIER)
                      CACHE-BAGAGES SANS CACHE BAGAGES
                      CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS
                      CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE SANS ALARME
                      CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
                      CLIMATISEUR AEROTHERME AVEC CHAUFFAGE AR
                      GRADUATION VITESSES GRADUATION EN KM/H
                      COMMODITÉS (POIGNÉES) POIGNEES AV + AR AVEC CROCHETS
                      COMPTE-TOURS COMPTE-TOURS A AIGUILLE
                      CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV TWEETER
                      CONSOLE CONSOLE AVEC CHAUFFAGE AR
                      COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
                      COMMANDE À DISTANCE MONTAGE CDE A DISTANCE
                      CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
                      ECLAIRAGE RANGEMENT SANS ECLAIRAGE DE RANGEMENT
                      ECLAIRAGE DE COFFRE VOLUME CHARGEMENT CDE AUTO ECLAIRAGE COFFRE OU VOL CHARGEMENT
                      EQUIPEMENT PLANCHE DE BORD FACADE CENTRALE PAILLETEE + BOUTON DIFFUSEUR NOIR
                      FEUX INT. DIVERS SANS FEU INTERIEUR DIVERS
                      COMBINÉ (CARACTÉRISTIQUES) FOND CADRAN METAL
                      COMPTE-TOURS (PRISE INFORMATIONS) COMPTE-TOURS INFO CALCULATEUR
                      ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS
                      HAUT-PARLEUR MONTAGE 2 HP AV + 2 TWEETERS
                      COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
                      REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE ASSISE AV PASSAGER
                      RÉGLAGE ASSISE AVANT CONDUCTEUR MAINTIEN LAT FIXE CONDUCTEUR
                      RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LAT FIXE PASSAGER
                      RABATTEMENT ASSISE AVANT CONDUCTEUR SANS RABATTEMENT ASSISE AV CONDUCTEUR
                      RABATTEMENT ASSISE AVANT PASSAGER SANS RABATTEMENT ASSISE AV PASSAGER
                      INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
                      COMPACT DISQUE MONTAGE COMPACT DISQUES
                      BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
                      SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
                      LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE MANUELLE
                      LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE ELECTRIQUE
                      LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE ELECTRIQUE
                      AFFICHEUR AFFICHEUR (MONTRE ET OU T°)
                      MONTRE MONTRE NUMERIQUE
                      INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
                      NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
                      SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV DOUBLE
                      SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
                      ORDINATEUR DE BORD SANS ORDINATEUR DE BORD
                      PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
                      RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
                      NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
                      COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INTERIEURE PORTE ASPECT NEUTRE
                      PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
                      PARE-SOLEIL AVANT COTE COND+PASS (SANS INSCRIPT)
                      RÉCEPTEUR RADIO SYSTEME AUDIO CASSETTE RDS "RB3"
                      RÉFRIGÉRATION REFRIGERATION SIMPLE
                      RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
                      REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
                      RANGEMENT (AUTRES) VIDE-POCHES PORTES AV + AR + AUMONIERE
                      SURTAPIS (ASPECT) SANS SURTAPIS
                      SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
                      RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
                      TAPIS MOQUETTE TUFTEE RASEE F550
                      TEMPORISATEUR D’ÉCLAIRAGE TEMPORISATEUR FIXE
                      CONTACT TRANSPONDEUR
                      ADAPTATION GARNITURE POMMEAU LEVIER VITESSE PLASTIQUE+ PASTILLE CHROME
                      AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
                      COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
                      VOLANT VOLANT MOUSSE 3 BRAS
                      VERROUILLAGE RANGEMENT VIDE-POCHES SANS VERROUILLAGE
                      Electricité
                      ALTERNATEUR ALTERNATEUR CLASSE 15
                      BATTERIE BATTERIE L2 400
                      DÉMARREUR DEMARREUR CLASSE 5
                      ECLAIREMENT PARTICULIER SANS ECLAIRAGE PARTICULIER
                      MULTIPLEXAGE MONTAGE MULTIPLEXE
                      Marques d'équipements
                      Divers
                      CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION PACK CLIM
                      ATMOSPHÈRE ATMOSPHERE NORMALE
                      BOITE DE PREMIERS SECOURS SANS BOITE PREMIER SECOURS
                      PRISE D’ÉCOUTE RADIO SANS PRISE ACCESSOIRES
                      CHOCS LATÉRAUX PORTE NON RENFORCEE
                      JEUX DE CLÉS 1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
                      ROULAGE BONNE ROUTE
                      SURVEILLANCE VITESSE SANS SURVEILLANCE VITESSE
                      TRIANGLE DE PRÉSIGNALISATION CONDITIONNEMENT TRIANGLE PRESIGNALISATION
                      • Salut! Imi poate face cineva o verificare?
                        VF38D9HD8CL061293
                        Vanzatorul spune ca are cutie automata, mie pe un site (autoDNA) mi-a aparut cutie manuala.
                        Multumesc mult!
                        calinutz
                        • Originally posted by calinutz View Post
                          VF38D9HD8CL061293
                          Multumesc mult!
                          508 BERLINA 4 USI 1.6 HDI 115 (DV6C) CUTIE DE VITEZE MANUALA PILOTATA (Cu stop and start)
                          • Originally posted by bragelone View Post
                            Multumesc!
                              VF38D9HD8CL061293
                              Multumesc mult!
                              AutoDNA-ul ala e gaselnita a unor tipi care de multe ori fac bani frumosi pe nimic. Exemplu concret: masina pusa la vanzare de mine cu 0 inregistrari in istoric la reprezentanta. Masina cumparata de la privat din FR si servisata din 15 in 15k km la garaj(service auto privat - omul lucra la receptie service acolo) cu toate facturile doveditoare de la 0 km pana la zi. Daca faceai verificare la autodna, iti zicea cum ca masina respectiva are 1 inregistrare legata de nr de km in istoric. Clientul s-a pus si a cumparat ceva raport de vreo 80 si ceva de lei(din ce am inteles sunt si mai ieftine), tentat de faptul ca ii spunea ca are 1 inregistrare. Cand a primit raportul surpriza: inregistrarea arata asa - data x(data la care am publicat eu anuntul pe autovit) - nr km Y(nr de km pe care i-am trecut eu in anunt). Mi-a aratat clientul raportul de la autodna dupa ce a verificat masina si am facut tranzactia, spunandu-mi "uite pe ce am aruncat 80 si ceva de lei".
                              Acum strict legat de masina cu vin-ul postat de tine, uita-te foarte atent la poze si o sa observi niste probleme. Nu e topic-ul indicat pt a discuta despre asta, dar am discutat fix despre masina asta in privat cu un alt coleg care fusese interesat de ea.
                              • Salut! M-am decis sa cumpar un Peugeot 308 si ma intereseaza si pe mine echiparea pe seria de sasiu VF34C9HXC55316042 cu cat mai multe detalii daca e posibil.
                                Aparent nu e foarte echipat dar m-ar ajuta o descriere detaliata.
                                Dau berica
                                Multumesc!
