VIN (Vehicle Identification Number) - Informatii utile
  • Salutare colegi, sunt nou pe acest forum si proaspat posesor de peugeot. Mai exact un 407. Ma ajutati va rog cu o decodare a VIN ului:
    Vf36drhrh21026179
    Mulțumesc anticipat!
    • Originally posted by CiprianMN View Post
      Vf36drhrh21026179
      Caracteristicile vehiculului
      Linie de produs 407
      Nr. APV/PR 10020 CJ 2 0568
      Data de Inceput de Garantie 17.05.2004
      NRE e2*2001/116*0297*00
      Informatii generale
      GEN DE PRODUS VEHICUL PARTICULAR
      MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
      LINIE DE PRODUS 407
      TIP CAROSERIE BERLINA 4 USI
      NIVEL DE ECHIPARE AA
      MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
      TRANSMISIE CUTIE DE VITEZE MANUALA6
      TIP DE VOPSEA VOPSEA METALIZATA LACUITA
      CULOAREA CAROSERIEI EGE - VOPSEA ALBASTRU DE CHINA
      TIP ECHIPARE INTERIOARA IMPLETITURA ANDORRA + TESATURA SOFIS "RR"
      CULOARE GARNISAJ "FT"
      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
      MOTOR (TIP) MOTOR TIP EW/DW
      Caracteristici vehicul
      DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
      Alimentare motor
      VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
      FITRU DE REZERVOR FARA FILTRU REZERVOR
      MODUL CLAPETA (ADMISIE AER MOTOR) MODUL CLAPETA MOTORIZATA (ADMISIE AER MOTOR)
      DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
      CARBURANT MOTORINA
      DEPOLUARE (MOTOR) DEPOLUARE EURO 4 (MOTOR)
      RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
      INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
      VARIATE DE PUTERE (MOTOR) PUTERE STANDARD
      AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
      DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
      DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
      FILTRU DE PARTICULE FILTRU DE PARTICULE
      VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
      Cutie de viteze - Transmisie
      CUPLU RAPORT RAPORT PUNTE 17 X 71
      STIL ROATA (JANTA) ROATA COSMOS 17 INCI
      AMBREIAJ AMBREIAJ HIDRAULIC
      DIFERENTIAL (CUTIE) DIFERENTIAL 86
      JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
      PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
      ROATA (TIP) MONTARE ROATA ALIAJ 3
      INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
      CUTIE DE VITEZE TIP ML6C
      DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
      COLOANA DE DIRECTIE COLOANA DE DIRECTIE CU REGLARE MANUALA
      ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24
      CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 174
      SUSPENSIE ACTIVA FARA SUSPENSIE VARIABILA
      CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
      Caroserie Echipamente
      ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
      DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
      ORNAMENT LATERAL (ASPECT) ELEMENTE PROTECTIE LATERALA VOPSITE IN MASA + CROMATE
      ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE + TREAPTA
      ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
      LUMINA DE PRAG LUMINA PENTRU PRAG
      SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
      FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
      STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
      STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
      STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
      OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
      GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
      ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
      ACCESORII EXTERIOARE MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
      TRAPA DE PLAFON ACOPERIS FIX
      ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE COLORAT IN MASA + ORNAMENT INOX
      GEAM (ASPECT) GEAM FUMURIU
      GEAM (TIP) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
      Echipament interior
      AIRBAG DE GENUNCHI CONDUCATOR AIRBAG ZONA GENUNCHI CONDUCATOR
      ALARMA ANTIFURT ALARMA PENTRU VOLUM + PERMETRU - STANDARD
      COTIERA DE SCAUN SPATE CU COTIERA SPATE
      CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
      CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
      SIGURANTA COPII SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
      GRADARE VITEZE GRADATIE IN MPH
      PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE PARTEA DREAPTA
      INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
      ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + FATADA ALUMINIU ARGINT VIU
      DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
      COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
      IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANTE SPATE
      INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
      COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
      COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
      REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
      CD FARA MONTARE COMPACT DISC
      SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
      BECURI DE PROIECTOR LAMPA CU HALOGEN
      ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
      AFISAJ AFISAJ (RADIO + CEAS + SI SAU T°,CD)
      OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
      INDICATOR DE ULEI SENZOR CU FUNCTIE DUBLA NIVEL + TEMPERATURA ULEI
      FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
      AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
      ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
      NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
      PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
      PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
      RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
      REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
      REGULATOR DE VITEZA FARA SISTEM DE REGULARIZARE VITEZA
      INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
      RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
      REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
      TUNER-RADIO TUNER DUBLU RADIO
      PROTECTIE INTERIOARA FARA PROTECTIE INTERIOARA
      DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
      STORURI LATERALE FARA TRANSPERANTE LATERALE
      ADAPTARE GARNITURA MANER MANETA DE VITEZE PIELE
      AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
      FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
      COMANDA DE BLOCARE BLOCARE PRIN SUPRA INCHIDERE
      VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
      Electricitate
      ALTERNATOR ALTERNATOR CLASA 18
      BATERIE BATERIE L2 400
      DEMAROR DEMAROR CLASA 6+
      ILUMINAT DEOSEBIT APRINDERE AUTOMATA A LUMINILOR
      Marci echipamente
      Diverse
      CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
      ATMOSFERA ATMOSFERA NORMALA
      RULARE DRUM CORECT
      Diagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
      • Salut! Daca ma poate ajuta cu decodarea VIN-ului: VF38DRHF8BL019249 . Va multumesc anticipat!
        • Originally posted by Dorin1996 View Post
          Linie de produs 508
          Nr. APV/PR 12546 CJ 1 0169
          Data de Inceput de Garantie 29.07.2011
          NRE e2*2007/46*0080*00
          P4A 9666543599
          Informatii generale
          LINIE DE PRODUS 508
          NIVEL DE ECHIPARE INALTA JOASA
          TIP DE VOPSEA METALIZATA LACUITA
          CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
          TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
          CULOARE GARNISAJ "FX"
          EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
          DIRECTIE SISTEM DE DIRECTIE ASISTATA
          Alimentare motor
          CARBURANT MOTORINA CALITATE DA/DE/DE+
          DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
          ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
          CILINDREE 2000 CM3
          CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
          RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
          REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
          INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
          DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
          VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
          VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
          LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
          FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
          STOP AND START FARA SISTEM STOP AND START
          CUPLU RAPORT RAPORT PUNTE 6 X 65
          STIL ROATA (JANTA) STIL 02 16 INCI
          JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
          PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
          ROATA (TIP) MONTARE ROATA ALIAJ 2
          INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
          BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
          ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
          SUSPENSIE SUSPENSIE NORMALA
          VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
          ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
          LUMINA DE PRAG LUMINI DE PRAG FATA
          INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
          OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
          LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
          BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
          APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
          PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
          PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
          ROATA DE REZERVA FARA ROATA DE REZERVA
          ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
          RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
          ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
          GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
          Echipament interior
          ALARMA ANTIFURT FARA ALARMA ANTIFURT
          SCAUN SPATE BANCHETA SEPARATA RABATABILA
          DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
          CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
          CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
          GRADARE VITEZE GRADATIE IN KM/H
          COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
          PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
          ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
          LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
          GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
          TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
          CAPITONAJ DE USA DECOR TESATURA
          DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
          COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
          INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
          IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
          INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
          COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
          COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
          REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
          SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
          ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
          ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
          AFISAJ AFISAJ DEV
          INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
          FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
          AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
          PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
          RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
          REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
          INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
          DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
          TUNER-RADIO TRI TUNER RADIO
          DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
          ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
          COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
          AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
          ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
          PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
          MODUL TELEMATIC MODUL TELEMATICA AUTONOM
          Electricitate
          BATERIE L3 720 EF
          ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
          FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
          APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
          Marci echipamente
          Diverse
          ETICHETA FARA ETICHETA
          CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
          PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
          SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
          ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
          RULARE DRUM CORECT
          MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
          TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
          • Salut! Daca ma puteti ajuta cu decodarea VIN-ului: VF38D9HD8EL042143 as fi mare recunoscator! . Va multumesc anticipat!
            • Caracteristicile vehiculului
              Linie de produs 508
              Nr. APV/PR 13874 CJ 1 0242
              Data de Inceput de Garantie 27.11.2014
              NRE e2*2007/46*0080*24
              P4A 9804886599
              Informatii generale
              LINIE DE PRODUS 508
              MOTOR DIESEL TURBO DV6C
              TRANSMISIE CUTIE DE VITEZE MANUALA 6 TREPTE TIP STOP AND START
              TIP DE VOPSEA VOPSEA OPACA
              CULOAREA CAROSERIEI EWP - VOPSEA ALBA BANQUISE
              TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
              CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCE
              EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
              MOTOR (TIP) MOTOR TIP DV
              MONOGRAMA COMPLEMENTARA, DIVERSE E-HDI
              Alimentare motor
              CILINDREE 1600 CM3
              STOP AND START CU STOP AND START
              CUPLU RAPORT RAPORT PUNTE 19 X 77
              AMBREIAJ FARA AMBREIAJ
              DIFERENTIAL (CUTIE) DIFERENTIAL 84
              ROATA (TIP) MONTARE ROATA ALIAJ 4
              INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
              CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
              ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
              CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
              ANTENA ANTENA INTEGRATA
              INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
              OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
              PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
              Echipament interior
              CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
              TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
              REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
              AFISAJ AFISAJ ECRAN DIGITAL TACTIL
              INDICATOR DE ULEI FARA INDICATOR DE NIVEL DE ULEI
              RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
              COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
              DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
              MODUL TELEMATIC FARA MODUL TELEMATIC
              Electricitate
              ALTERNATOR ISTT51
              BATERIE L3 760 VRLA1 EN AGM
              DEMAROR DEMAROR CLASA 5
              Marci echipamente
              Diverse
              ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
              RULARE DRUM CORECT
              • Salut,
                Cum pot afla si eu ce dotari din fabrica a avut masina mea, VIN: VF33H9HZC84765022 ? Ma intereseaza in mod special ce tip de ambreiaj a avut din fabrica , SACHS sau VALEO, volanta cu masa dubla sau simpla. Multumesc.
                  Linie de produs 307 RESTYL
                  Nr. APV/PR 10902 89 2 0271
                  Data de Inceput de Garantie 01.11.2006
                  NRE e2*2001/116*0287*03
                  Informatii generale
                  LINIE DE PRODUS 307 RESTYL
                  TIP CAROSERIE BREAK TIMP LIBER
                  MOTOR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
                  TRANSMISIE CUTIE DE VITEZE MANUALA5
                  CULOAREA CAROSERIEI EZW - VOPSEA GRI FER
                  TIP ECHIPARE INTERIOARA ACCESORIU PLASA PERLO F935+EFKA F604 "VU"
                  CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
                  MONOGRAMA COMPLEMENTARA, DIVERSE HDI (I CROM)
                  MONOGRAMA SW
                  DIRECTIE SISTEM DE DIRECTIE VARIABILA ASISTATA
                  CUPLU DE TAHOMETRU RAPORT TRANSMISIE 22 X NO
                  Alimentare motor
                  BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
                  CARBURANT MOTORINA
                  CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
                  AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
                  VENTILATOR 1 VENTILATOR 2 TURATII 130W AERO
                  RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
                  VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
                  CUPLU RAPORT CP 19 X 72
                  STIL ROATA (JANTA) ROATA ECHINOCTIU 16 INCI
                  TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP BE4/5 L
                  PNEURI (DIMENSIUNI, TIP) PNEU 205/55 R16 91V FARA INTARIRE
                  ROTI MONTATE ROATA 6 INCI 1/2
                  ROATA (TIP) MONTARE ROATA CU JANTA DIN ALIAJ
                  CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
                  BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 30
                  RACIRE ULEI DE POMPA DE DIRECTIE FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
                  CONTROL DINAMIC AL STABILITATII FARA SISTEM ESP
                  VARIANTA ASOCIATA FRANA ABS BOSCH 8 0
                  PEDALIER (TIP) PEDALIER STANDARD
                  AVERTIZOARE SISTEM DE AVERTIZARE ACORD
                  ANTENA ANTENA SCURTA PAVILION
                  DECORATIUNE (ADEZIVA) ORNAMENT SPATE DE USA FATA + ORNAMENT FATA DE USA SPATE
                  ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
                  ORNAMENT DE ROATA (STIL) TIP APOLLO
                  LUMINA DE MERS INAPOI CU 1 LUMINA PENTRU MERS INAPOI
                  FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
                  ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
                  STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
                  GEAM DE PAVILION CU GEAM DE PAVILION
                  BARA DE PROTECTIE BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
                  RETROVIZOR EXTERIOR (PARTEA CONDUCATORULUI) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
                  RETROVIZOR EXTERIOR (PARTEA PASAGERULUI) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
                  ROATA DE REZERVA ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
                  ACCESORII EXTERIOARE MANER EXTERIOR + ORNAMENT CAPAC ALUMINIU + RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI
                  SPALARE LUNETA MECANISM DE SPALARE LUNETA
                  ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
                  GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS SPATE
                  GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
                  GEAM (TIP) PARBRIZ CU IZOLARE ACUSTICA MAI PUTIN PENTRU SINGAPORE
                  PACHET RADIO / INFORMATII / COMUNICARE RD4, FARA NAVIGATIE, AFISAJ NIVEL C, FARA AMPLIFICATOR EGALIZATOR
                  Echipament interior
                  TETIERA SPATE TETIERA SPATE REGLABILA
                  TETIERA FATA TETIERA FATA ARTICULATA
                  SCAUN SPATE 3 SCAUNE SPATE SEPARATE (1 CULISANT)
                  SCAUN SUPLIMENTAR FARA PERNA DE SCAUN SUPLIMENTARA
                  COTIERA DE SCAUN SPATE FARA COTIERA SPATE
                  BAGHETA PLANSEU DE INCARCARE CU BAGHETA DE PLANSEU DE INCARCARE
                  MASCARE BAGAJE CU PANOU DE MASCARE BAGAJE
                  CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE 5 RETRACTOARE IN 3 PUNCTE
                  CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
                  AMBALARE SISTEM AUDIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
                  INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
                  ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + FATADA GRI LION
                  VARIATIE DE ECHIPARE INTERIOARA VOLAN MANER BURDUF PIELE
                  DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
                  TABLOU DE BORD (CARACTERISTICI) GRADATIE 220 KM/H 140 M/H FUNDAL NEGRU CU CONTUR CROMAT
                  COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
                  INALTARE SCAUN DE PASAGER FATA SISTEM DE INALTARE PERNA SCAUN PASAGER FATA REGLARE PARALELA
                  RABATERE SCAUN FATA DE CONDUCATOR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
                  RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
                  COTIERA DE SCAUN FATA COTIERE FATA CONDUCATOR SI PASAGER
                  INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
                  CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
                  ACTIONARE GEAM SPATE MECANISM DE ACTIONARE GEAM SPATE SECVENTIAL CU COMANDA ELECTRICA
                  ACTIONARE GEAM DE CONDUCATOR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
                  AFISAJ AFISAJ (RADIO + CEAS, T°,CD)
                  SUPORT DE PICIOR SUPORT SPRIJINIRE PICIOR CONDUCATOR
                  INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
                  MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
                  AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
                  ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
                  CALCULATOR DE BORD CU CALCULATOR DE BORD
                  PACHET ECHIPAMENT FARA PACHET ECHIPAMENT
                  RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
                  COMANDA INTERIOARA DE USA (ASPECT) COMANDA INTERIOARA USA ASPECT GRI LION
                  PROTECTIE POST FATA FARA PROTECTIE POST FATA
                  DEPOZITARE (POST DE CONDUCERE) FARA COMPARTIMENT DE DEPOZITARE IN CONSOLA FATA DE PAVILION
                  INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
                  AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
                  DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
                  TUNER-RADIO CU UN SINGUR TUNER RADIO
                  ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
                  COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
                  COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
                  Electricitate
                  ALTERNATOR ALTERNATOR CLASA 15
                  MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN CAN
                  Marci echipamente
                  Diverse
                  CRITERIU FACTORI, CLIENTELA CONCEPTIE STIMULARE FISCALA DEPOLUARE L5
                  SOC LATERAL USA CARE NU ESTE INTARITA
                  RULARE DRUM CORECT
                  MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
                  MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI COMM 2003
                  • Salut! Careva ma poate ajuta cineva cu un VIN: VF38DRHF8BL107333 . Va multumesc!
                    • Va salut!
                      Ma puteti ajuta cu o decodare VIN VF38ERHH8BL062177. Multumesc anticipat!
                        Linie de produs 508
                        Nr. APV/PR 12813 CJ 1 0884
                        Data de Inceput de Garantie 30.12.2011
                        NRE e2*2007/46*0080*07
                        P4A 9691274299
                        Informatii generale
                        LINIE DE PRODUS 508
                        NIVEL DE ECHIPARE INALTIME MEDIE PLUS
                        MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
                        Alimentare motor
                        CILINDREE 2000 CM3
                        STIL ROATA (JANTA) STIL 05 17 INCI
                        ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
                        STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
                        ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
                        ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
                        Echipament interior
                        ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
                        LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
                        TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
                        BECURI DE PROIECTOR LAMPA CU DESCARCARE
                        AFISAJ AFISAJ DEV
                        ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
                        PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
                        DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
                        Electricitate
                        APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
                        BATERIE L3 720 EF
                        Marci echipamente
                        Diverse
                        SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
                        RULARE DRUM CORECT
                        • Originally posted by florin g View Post
                          Va salut!
                          Linie de produs 508
                          Nr. APV/PR 12656 CJ 1 0229
                          Data de Inceput de Garantie 13.12.2012
                          NRE e2*2007/46*0080*03
                          P4A 9800966599
                          Informatii generale
                          LINIE DE PRODUS 508
                          TIP CAROSERIE BREAK 5 USI
                          MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
                          CULOAREA CAROSERIEI KDM - VOPSEA CAFENIU INCHIS GUARANJA
                          Alimentare motor
                          DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
                          CILINDREE 2000 CM3
                          PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95V NERANFORSAT
                          ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
                          PORTBAGAJ MONTARE CU BARE DE ACOPERIS
                          Echipament interior
                          AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
                          RECEPTOR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT
                          FRECVENTA RADIO FRECVENTA RADIO ARABIA
                          Electricitate
                          BATERIE L3 720 EF
                          ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE COMPLET
                          Marci echipamente
                          Diverse
                          CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
                          RULARE DRUM CORECT
                          • Multumesc frumos!
                            • VF34E9HP0ES041442
                              Salutare.
                              Apare pe undeva cat are volumul la portbagaj? Doar acesta ma intereseaza.
                              Multumesc
                              Sent from my Nexus 7 using Tapatalk
                              Peugeot 308 /SW/ 1.6HDI 9HX/ 90HP/ 2010/ Euro4/ fara FAP.
                              • Buna seara si bine v-am gasit , am intrat de cateva zile in posesia unui 307 sw motor de 2.0 hdi 90 cp si vreau sa aflu si eu mai multe detalii despre el deci daca ma poate ajuta cineva ,aceasta este seria vin- VF33hrhyb84000377 va multumesc
