Originally posted by vis-a-vis
View Post
VIN (Vehicle Identification Number) - Informatii utile
Salutare😏 as avea nevoie de ceva info,asta daca nu cer sau deranjez prea mult😂mai pe scurt,as lua o cutie de viteza pe 407le asta VF36DRHRH21379550 si s-o pun pe 607le meu VF39URHRH92220346 insa as vrea sa ma asigur ca are aceleasi caracteristici😉 ma intereseaza codul la cutia de viteze si raportul de transmisie,si daca FAP-ul e 1si acelasi ca la a mea-ma refer la prindere,lungime si diametru tub?!?!va multumesc
Inviato tramite Tapatalk per Windows Phone''ex 607 2.2 hdi''-''new 607 2.0 hdi''both made by Peugeot
Salutare @giorgio_24,
Admir perseverenta ta
In ServiceBox am gasit detaliile insirate mai jos pentru fiecare masina in parte.
Doar imi dau si eu cu parerea, STRICT pe baza codurilor de piese gasite.
Referitor la cutia de viteze as zice ca nu merge transplantul (difera raportul de cuplu, acel CP(16x69)).
Insa partea buna e ca FAP-ul este la fel pe cele 2 masini.
Spor la munca si drumuri bune,
Radu
Cutia de viteze:Originally posted by giorgio_24 View Post
... 407le asta VF36DRHRH21379550 ...
2231 Y3
BOITE-PONT MECANIQUE NEUVE
CP(17X71)
REPERE MB28 (MB28)
2232 Z3
BOITE_PONT MECANIQUE EST
CP(17X71)
REPERE MBK2 MB02 (MBK2) (MBB8) MB28 MBB3 (MBB3)
2222 YW
CP (17X71)
REPERE MB02 (MB02) MB17 (MB17)
- BERCEAU ACIER AVEC CADRE
2232 55
CP (17X71)
REPERE MB17 MBA7 (MBA7)
2223 QA / RP 2232 Z3
CP (17X71)
FAP:
1731 GJ
FILTRE PARTICULES OCTO SQUARE
TR PSA F015
1740 22
FAP OCTO SQUARE EST
TR PSA F015
16 113 227 80
EM:FAP OCTO SQUARE PSA
- ET ĀGE >= 3
... 607le meu VF39URHRH92220346 ...
Cutia de viteze:
2232 06 / RP 2232 91
CP(16X69)
REPERE MB11 (MBA1)
2222 YZ
CP (16X69)
REPERE (MB20) (MB11) MB11 MB20
2232 91
CP (16X69)
REPERE (MBB0) MB25 (MBN5) MB11 MB20 (MBA1)
FAP:
1731 GJ
TR PSA F015
1740 22
FAP OCTO SQUARE EST
TR PSA F015
16 113 227 80
- ET ĀGE >= 3
VF36DRHRH21379550 - are cutie MB17Originally posted by giorgio_24 View PostSalutare😏 as avea nevoie de ceva info,asta daca nu cer sau deranjez prea mult😂mai pe scurt,as lua o cutie de viteza pe 407le asta VF36DRHRH21379550 si s-o pun pe 607le meu VF39URHRH92220346 insa as vrea sa ma asigur ca are aceleasi caracteristici😉 ma intereseaza codul la cutia de viteze si raportul de transmisie,si daca FAP-ul e 1si acelasi ca la a mea-ma refer la prindere,lungime si diametru tub?!?!va multumesc
Si rapoartele astea:
VF39URHRH92220346 - are cutie MB11 / MB20 (acelasi drac)
Chiar daca dpvd. al montarii, cutiile sunt identice, inauntru nu sunt.Diagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
Salut tuturor.
Detin un 407 sw 1.6 hdi cu fap , īnsă despre mașină nu stiu mai nimic. Ma poate ajuta si pe mine cineva sa īmi spună dotările mașinii ? Vin ul esteVf36e9hzc21440581 . Pe lāngă dotări m-ar interesa si codurile, part no pentru kit ambreiaj complet , volantă si kit de distribuție. Mașina o am de ceva vreme dar īncă nu am apucat sa o văd live ...
Va mulțumesc anticipat.
P.s : eventual un site , verificat unde as putea afla toată istoria mașinii , nu contează dacă este contra cost doar sa fiu sigur ca voi primii informațiile cerute , nu am chef sa mai plătesc pentru tzepe online. Mulțumesc anticipat
Salut tot ce ai nevoie gasesti pe :
http://public.servicebox.peugeot.com dar ai nevoie de cont! Este gratuitBlack Lion.
Salut. Este si nu este chiar asa gratuit.Originally posted by kdyalex View PostSalut tot ce ai nevoie gasesti pe :
Am avut un cont mai demult, am incercat sa-l accesez si nu era buna parola. Am trimis resend password, am primit si cand am vrut sa-l accesez imi spunea ca nu este valabila locatia de unde am facut contul initial. Probabil verifica tara si IP. Am facut operatiunea asta din Franta. Am schimbat IP cu unul de RO si imi dadea aceiasi eroare. Am incercat sa fac un alt cont, dar imi spune ca ei nu fac conturi personale, cu toate ca exista acea optiune, dar daca o bifezi pe aceea, iti spune ca ei (servicebox.peugeot) nu fac conturi personale.
Noroc cu colegii si prietenii de aici care m-au ajutat si au putut ei/el sa verifice ce aveam nevoie. Merci...
Voi cum ati rezolvat problema asta cu inregistrarea uunui cont personal? Tin minte ca initial facusem un cont pe firma.... parca... a fost cu mult timp in urma. Multumesc.
