VIN (Vehicle Identification Number) - Informatii utile
  • Info
    Va salut! Am si eu o rugaminte. Imi puteti decoda urmatorul VIN: VF3WE9HP0AW092834
    Vreau sa achizitionez masina si nu stiu prea multe despre ea. Multumesc!
    • Caracteristicile vehiculului
      Linie de produs 207
      Nr. APV/PR 12352 81 2 0216
      Data de Inceput de Garantie 30.09.2010
      Numar de Serie Motor 10 JBCL 3046879
      NRE e2*2001/116*0340*21
      P4A 9666152199
      Informatii generale
      GEN DE PRODUS VEHICUL PARTICULAR
      MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
      LINIE DE PRODUS 207
      TIP CAROSERIE BREAK 5 USI
      NIVEL DE ECHIPARE TRENDY A72
      MOTOR DIESEL TURBO DV6DTED
      TRANSMISIE CUTIE DE VITEZE MANUALA5
      TIP DE VOPSEA VOPSEA METALIZATA LACUITA
      CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
      TIP ECHIPARE INTERIOARA TESATURA CHILICO+MAILHORSPISTE+F915 "4D"
      CULOARE GARNISAJ "FX"
      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
      MOTOR (TIP) MOTOR TIP DV
      MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
      MONOGRAMA FARA MONOGRAMA
      Caracteristici vehicul
      CUPLU DE TAHOMETRU FARA C T
      Alimentare motor
      DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
      CARBURANT MOTORINA CALITATE DA/DE/DE+
      DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
      CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
      REZERVOR DE CARBURANT REZERVOR CARBURANT FARA ELEMENT DE INDEXARE
      OPTIMIZAREA CONSUMULUI VEHICULULUI CONSUM CARBURANT OPTIMIZARE
      MOTOR RACIRE RADIATOR EP:18 - 21 DM2 ALUMINIU BRAZAT
      INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
      AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
      DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
      DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
      FILTRU DE PARTICULE CU FILTRU DE PARTICULE
      VENTILATOR 1 VENTILATOR CU 2 TURATII 140W AERO CU PALETA
      RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
      VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
      FITRU DE REZERVOR FARA FILTRU REZERVOR
      STOP AND START FARA SISTEM STOP AND START
      Cutie de viteze - Transmisie
      CUPLU RAPORT RAPORT PUNTE 17 X 61
      STIL ROATA (JANTA) JANTA TABLA 6 J15 4-23
      DIFERENTIAL (CUTIE) DIFERENTIAL 84
      JANTA / PNEU DIMENSIUNI MONTAJ PNEU 15 INCI
      PNEURI (DIMENSIUNI, TIP) PNEU 185/65 R15 88H NERANFORSAT
      ROTI MONTATE ROATA 6 INCI
      ROATA (TIP) MONTARE ROATA CU JANTA DIN TABLA
      INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
      CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
      ANTIBLOCARE ANTIBLOCARE ROATA
      ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22
      FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
      CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 144
      SUSPENSIE SUSPENSIE NORMALA
      CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
      VARIANTA ASOCIATA FRANA ABS TEVES MK60 O
      PEDALIER (TIP) PEDALIER STANDARD
      Caroserie Echipamente
      AVERTIZOARE SISTEM DE AVERTIZARE STANDARD
      ANTENA ANTENA + GPS
      TRAPA DE PLAFON (ASPECT) FARA TRAPA DE PLAFON
      DECORATIUNE (ADEZIVA) ORNAMENT SPATE DE INCADRARE NEGRU MAT
      DEFLECTOR AERODINAMIC SPATE MONTARE FARA DEFLECTOR SPATE
      ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
      ORNAMENT LATERAL (DIMENSIUNE) FARA ELEMENTE DE PROTECTIE LATERALE
      ORNAMENT DE ROATA (STIL) TIP BRISBANE 15 INCI
      PROTECTIE SUB CAROSERIE ELEMENT DE PROTECTIE DIN MATERIAL PLASTIC + ELEMENT DIN SPUMA SUB MOTOR
      SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
      FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
      ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
      INSONORIZARE PE MOTOR ELEMENT DE IZOLARE CAPOTA + ELEMENT DE PROTECTIE TERMICA
      STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
      STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
      STERGATOR DE LUNETA (FUNCTIONARE) MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CU PORNIRE AUTOMATA
      OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
      GEAM DE PAVILION CU GEAM DE PAVILION
      LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
      SONDA DE TEMPERATURA EXTERIOARA CU SONDA DE TEMPERATURA EXTERIOARA
      BARA DE PROTECTIE BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
      PLACA DE INMATRICULARE FARA PLACUTA DE INMATRICULARE
      PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
      PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
      PROIECTOR SPECIAL (OPTICA DUBLA) PROIECTOR CU PARABOLA DUBLA
      RETROVIZOR EXTERIOR (PARTEA CONDUCATORULUI) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
      RETROVIZOR EXTERIOR (PARTEA PASAGERULUI) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
      ROATA DE REZERVA FARA ROATA DE REZERVA
      ACCESORII EXTERIOARE MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
      RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
      TRAPA DE PLAFON ACOPERIS FIX
      ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
      GEAM (ASPECT) COLORATA
      GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
      GEAM (TIP) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
      ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
      Echipament interior
      ALARMA ANTIFURT FARA ALARMA ANTIFURT
      TETIERA SPATE TETIERA SPATE REGLABILA
      TETIERA FATA TETIERA FATA REGLABILA
      SCAUN SPATE BANCHETA SEPARATA RABATABILA
      MASCARE BAGAJE RULOU
      CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
      CENTURA DE SIGURANTA FATA ALARMA CUPLARE CENTURA CONDUCATOR + PASAGER
      CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
      CLIMATIZOR SISTEM DE CLIMATIZARE CU INTRARE DE AER MOTORIZATA
      SIGURANTA COPII SIGURANTA COPIL MANUALA USA SPATE
      GRADARE VITEZE GRADATIE IN KM/H
      ACCESORII (MANERE) MANERE FATA + SPATE CU INCHIZATOARE
      AMBALARE SISTEM AUDIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
      PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
      COMANDA LA DISTANTA MONTAJ COMANDA LA DISTANTA
      ILUMINAT COMPARTIMENT DEPOZITARE FARA ILUMINAT IN COMPARTIMENTUL DE DEPOZITARE
      ECHIPAMENT PLANSA DE BORD PLANSA DE BORD SOFT DECORATIUNE GRI LION MISTRAL
      LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA
      TABLOU DE BORD (CARACTERISTICI) GRADATIE 220 KM/H 140 M/H FUNDAL CADRAN ALB
      DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
      COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
      INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 2,2KG
      INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
      COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
      COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
      REGLARE PERNA DE SEZUT FATA CONDUCATOR SPATAR SCAUN CONDUCATOR CARE SE POATE INCLINA
      REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
      COTIERA DE SCAUN FATA MONTARE FARA COTIERA FATA
      CONSOLA DE PLAFON CONSOLA PLAFON STANDARD
      CD FARA MONTARE COMPACT DISC
      SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
      BECURI DE PROIECTOR LAMPA CU HALOGEN
      ACTIONARE GEAM SPATE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
      ACTIONARE GEAM DE CONDUCATOR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
      ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA ELECTRICA
      AFISAJ AFISAJ DEV
      OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
      INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
      MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
      FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
      AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
      ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
      AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
      CALCULATOR DE BORD CU CALCULATOR DE BORD
      PACHET ECHIPAMENT FARA PACHET ECHIPAMENT
      RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
      NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
      COMANDA INTERIOARA DE USA (ASPECT) COMANDA INTERIOARA USA ASPECT GRI LION
      PLAFONIERA COMANDA LA DISTANTA USI + PLAFONIERE FATA SI SPATE
      PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
      PROTECTIE POST FATA FARA GRILA DE SEPARARE
      DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE INFERIOR FARA REFRIGERARE
      RECEPTOR RADIO SISTEM RADIONAVIGATIE CU MEMORIE FLASH "RNEG"
      REFRIGERARE SISTEM DE REFRIGERARE SIMPLA
      REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
      INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
      RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
      DEPOZITARE (ALTELE) FARA ALTE COMPARTIMENTE DE DEPOZITARE
      COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
      AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
      DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
      TUNER-RADIO CU UN SINGUR TUNER RADIO
      PROTECTIE INTERIOARA FARA PROTECTIE INTERIOARA
      INDICATOR DE TEMPERATURA EXTERIOARA (GRADARE) INDICATOR TEMPERATURA EXTERIOARA CELSIUS
      DETECTAREA OBSTACOLULUI DEPOLUARE TEHNICA VEHICUL L4 EURO 3
      ADAPTARE GARNITURA MANER MANETA DE VITEZA CU INSERTIE CROMATA
      COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
      AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
      FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
      COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
      VOLANT VOLAN IMBRACAT CU SPUMA
      INCUIERE COMPARTIMENT DEPOZITARE COMPARTIMENT DEPOZITARE OBIECTE MARUNTE FARA SISTEM DE INCUIERE
      PACHET AMBIANTA FARA PACHET AMBIANTA
      AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
      PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
      MODUL TELEMATIC FARA MODUL TELEMATIC
      Electricitate
      ALTERNATOR ALTERNATOR CLASA 15
      BATERIE BATERIE L2 640
      DEMAROR DEMAROR CLASA 6
      ILUMINAT DEOSEBIT FARA ILUMINAT SPECIAL
      FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
      MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN CAN
      MASURA INCARCARII BATERIEI CU SISTEM DE MASURARE A NIVELULUI DE INCARCARE A BATERIEI
      Marci echipamente
      Diverse
      CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
      ATMOSFERA ATMOSFERA NORMALA
      CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII FATA + SPATE 12V
      PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
      SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
      ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
      RULARE DRUM CORECT
      MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
      MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI + COM 2005 INEL CU 4 POZITII
      • Multumesc frumos pentru raspuns! Apreciez!
        • Ma poate ajuta cineva cu VF39URHRH92219827? Multumesc, o zi buna.
            Linie de produs 607 RESTYL
            Nr. APV/PR 10573 89 2 0698
            Data de Inceput de Garantie 23.02.2006
            Numar de Serie Motor 10 DYTU 4000398
            NRE e2*98/14*0199*11
            Informatii generale
            LINIE DE PRODUS 607 RESTYL
            TIP CAROSERIE BERLINA 4 USI
            NIVEL DE ECHIPARE NIVEL 1 ABANOS
            MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
            TRANSMISIE CUTIE DE VITEZE MANUALA6
            CULOAREA CAROSERIEI EXL - VOPSEA NEGRU OBSIDIAN
            TIP ECHIPARE INTERIOARA TESATURA PARSIFAL + EFKA "UC"
            CULOARE GARNISAJ "FT"
            CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
            MOTOR (TIP) MOTOR TIP EW/DW
            MONOGRAMA COMPLEMENTARA FARA MONOGRAMA SUPLIMENTARA
            DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
            Alimentare motor
            MODUL CLAPETA (ADMISIE AER MOTOR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
            DEPOLUARE (MOTOR) DEPOLUARE MOTOR EURO 4
            RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
            MOTOR RACIRE RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
            INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
            VARIATE DE PUTERE (MOTOR) PUTERE STANDARD
            AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
            DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
            VENTILATOR 1 VENTILATOR 1 TURATIE 150W AERO
            RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
            CUPLU RAPORT RAPORT PUNTE 16 X 69
            STIL ROATA (JANTA) ROATA ARCTIQUE 17 INCI
            PNEURI (DIMENSIUNI, TIP) PNEU 225/50 R17 98Y NERANFORSAT
            ROATA (TIP) MONTARE ROATA ALIAJ 2
            CUTIE DE VITEZE TIP ML6C
            DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
            BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 24
            ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 25
            SUSPENSIE ACTIVA FARA SUSPENSIE VARIABILA
            DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
            ANTENA ANTENA + GPS + GSM
            ORNAMENT DE ROATA (STIL) TIP APOLLO
            FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
            STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
            ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
            RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA RETROVIZOR EXTERIOR FUMURIE
            RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA RETROVIZOR EXTERIOR CONDUCATOR ASFERICA
            GEAM (TIP) PARBRIZ + LATERAL SPATE DIN STICLA SECURIZATA MAI PUTIN PENTRU SINGAPORE
            Echipament interior
            PACHET MODULARITATE / ERGONOMIE SCAUN FATA CU PACHET MODULARITATE ERGONOMIE PERNA DE SEZUT FATA
            ALARMA ANTIFURT PREGATIRE ELECTRICA ALARMA ANTIFURT
            BRICHETA BRICHETA FATA + SPATE
            CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
            CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
            TABLOU DE BORD (CARACTERISTICI) GRADATIE 250 KM/H SAU 150 M/H FUNDAL NEGRU
            ANCORARE SCAUN PENTRU COPII FARA ANCORARE SCAUNE DE COPII CU SISTEM ISO ARD
            DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
            IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT SPATE CU COMANDA ELECTRICA
            INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
            COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
            COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
            CD MONTARE COMPACT DISCURI
            BECURI DE PROIECTOR LAMPA CU DESCARCARE
            ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
            AFISAJ AFISAJ (ECRAN VIDEO 16/9 + RADIO + CEAS,T°,CD)
            AIRBAG LATERAL FATA AIRBAGURI LATERALE ZONA TORACE FATA + SPATE + AIRBAG CORTINA
            PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
            RECEPTOR RADIO SISTEM RADIOTELEFON "RT3"
            REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
            RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
            DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
            STORURI LATERALE FARA TRANSPERANTE LATERALE
            TETIERA FATA (FUNCTIONARE) TETIERA FATA CU COMANDA ELECTRICA
            VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
            Electricitate
            ALTERNATOR ALTERNATOR CLASA 18
            BATERIE BATERIE L5 600
            DEMAROR DEMAROR CLASA 6+
            ILUMINAT DEOSEBIT APRINDERE AUTOMATA A LUMINILOR
            Marci echipamente
            Diverse
            CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
            GRUPARE ECHIPARE ECHIPARE CU NUC + MICRO CARBON
            SOC LATERAL USA CARE NU ESTE INTARITA
            RULARE DRUM CORECT
            • Salut. Ma poate ajuta cineva cu vin VF33C9HYB84854342? Multumesc anticipat.
                Linie de produs 307 RESTYL
                Nr. APV/PR 10990 89 1 0096
                Data de Inceput de Garantie 31.01.2007
                Numar de Serie Motor 10 JB97 3001382
                NRE e2*2001/116*0299*02
                Informatii generale
                LINIE DE PRODUS 307 RESTYL
                TIP CAROSERIE BERLINA CU 5 USI
                NIVEL DE ECHIPARE INALTA MEDIE
                MOTOR DIESEL TURBO DV6TED4 FARA FILTRU DE PARTICULE
                TIP DE VOPSEA VOPSEA OPACA
                CULOAREA CAROSERIEI KTG - VOPSEA GRI HURRICANE
                TIP ECHIPARE INTERIOARA POSTAV IKHO "UO"
                MONOGRAMA HDI
                DIRECTIE SISTEM DE DIRECTIE VARIABILA ASISTATA
                CUPLU DE TAHOMETRU RAPORT TRANSMISIE 22 X NO
                Alimentare motor
                DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
                BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
                DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L4 EURO 2000
                DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL L4 EURO 3
                FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
                VENTILATOR 1 VENTILATOR 2 TURATII 130W AERO
                FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
                CUPLU RAPORT CP 19 X 72
                STIL ROATA (JANTA) ROATA CU JANTA DIN TABLA 16 INCI
                AMBREIAJ AMBREIAJ HIDRAULIC
                TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP BE4/5 L
                JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
                PNEURI (DIMENSIUNI, TIP) PNEU 205/55 R16 91V FARA INTARIRE
                ROTI MONTATE ROATA 6 INCI 1/2
                BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 29
                RACIRE ULEI DE POMPA DE DIRECTIE FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
                CONTROL DINAMIC AL STABILITATII FARA SISTEM ESP
                VARIANTA ASOCIATA FRANA ABS BOSCH 8 1
                AVERTIZOARE SISTEM DE AVERTIZARE ACORD
                ANTENA ANTENA SCURTA PAVILION
                ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
                ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE
                ORNAMENT DE ROATA (STIL) STIL JUPITER 8 FANTE 16 INCI
                LUMINA DE MERS INAPOI CU 1 LUMINA PENTRU MERS INAPOI
                INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
                STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
                STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
                GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
                BARA DE PROTECTIE BARA DE PROTECTIE FATA SPORT IN CULOAREA CAROSERIEI + INEL - SPATE STANDARD IN CULOAREA CAROSERIEI
                APARATOARE DE NOROI (BAVETA) CU APARATORI DE ROTI SPATE
                PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
                ROATA DE REZERVA ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
                ACCESORII EXTERIOARE MANER EXTERIOR + ORNAMENT CAPAC + RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI
                SPALARE LUNETA MECANISM DE SPALARE LUNETA
                ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
                GEAM LATERAL SPATE (NATURA) FARA GEAM FIX LATERAL SPATE
                GEAM (TIP) PARBRIZ CU IZOLARE ACUSTICA MAI PUTIN PENTRU SINGAPORE
                PACHET RADIO / INFORMATII / COMUNICARE RD4, FARA SISTEM DE NAVIGATIE, AFISAJ NIVEL B, FARA AMPLIFICATOR EGALIZATOR
                Echipament interior
                TETIERA FATA TETIERA FATA ARTICULATA
                SCAUN SUPLIMENTAR FARA PERNA DE SCAUN SUPLIMENTARA
                COTIERA DE SCAUN SPATE FARA COTIERA SPATE
                BAGHETA PLANSEU DE INCARCARE FARA BAGHETA PLANSEU DE INCARCARE
                MASCARE BAGAJE CU PANOU DE MASCARE BAGAJE
                INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
                ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + FATADA GRI LION
                VARIATIE DE ECHIPARE INTERIOARA VOLAN IMBRACAT IN PIELE PERFORATA + MANER MANETA IN PIELE
                DEPOZITARE SUB SCAUN FARA COMPARTIMENT DE DEPOZITARE SUB SCAUN
                TABLOU DE BORD (CARACTERISTICI) GRADATIE 220 KM/H 140 M/H FUNDAL NEGRU CU CONTUR CROMAT
                COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
                IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
                RABATERE SCAUN FATA DE CONDUCATOR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
                RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
                INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
                CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
                SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
                ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
                AFISAJ AFISAJ (RADIO + CEAS + SI SAU T°, CD) FARA MEMORIE
                OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR CU CAPAC + OGLINDA PARASOLAR PASAGER FARA CAPAC PARA LUMINA
                SUPORT DE PICIOR SUPORT SPRIJINIRE PICIOR CONDUCATOR
                FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
                ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
                PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
                PROTECTIE POST FATA FARA PROTECTIE POST FATA
                DEPOZITARE (POST DE CONDUCERE) FARA COMPARTIMENT DE DEPOZITARE IN CONSOLA FATA DE PAVILION
                RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
                REGULATOR DE VITEZA FARA SISTEM DE REGULARIZARE VITEZA
                DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
                DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
                ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
                FRECVENTA RADIO FRECVENTA RADIO ASIA
                VOLANT VOLAN IMBRACAT IN PIELE PERFORATA CU 3 BRATE
                Electricitate
                BATERIE BATERIE L2 400
                Marci echipamente
                Diverse
                CONECTOR DE ASCULTARE SISTEM AUDIO FARA PRIZA PENTRU ACCESORII
                RULARE DRUM CORECT
                • Buna. Ma poate ajuta cineva cu vin VF3LBBHZHFS168490? Multumesc anticipat
                    Linie de produs 308 (T9)
                    Nr. APV/PR 14099 89 1 0432
                    Data de Inceput de Garantie 30.06.2015
                    Numar de Serie Motor 10 JBGY 0008526
                    NRE e2*2007/46*0405*04
                    P4A 9806776799
                    Informatii generale
                    LINIE DE PRODUS 308 (T9)
                    NIVEL DE ECHIPARE ACTIV
                    MOTOR DIESEL TURBO DV6FC FAP 88KW
                    TRANSMISIE CUTIE DE VITEZE MANUALA 6 TREPTE TIP STOP AND START
                    CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
                    TIP ECHIPARE INTERIOARA TESATURA OXFORD"0I"
                    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6CV
                    EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
                    MONOGRAMA COMPLEMENTARA, DIVERSE BLUE HDI
                    CUPLU DE TAHOMETRU FARA RAPORT TAHOMETRU
                    Alimentare motor
                    ALIMENTARE INJECTIE TURBO DIRECTA CU SCHIMBATOR
                    DEPOLUARE (MOTOR) DEPOLUARE MOTOR EURO 6.1
                    PRIZA VITEZE (INFORMATII SENZOR) SENZOR ROTI FATA/SPATE NESEMNALIZAT
                    CILINDREE 1600 CM3
                    CATALIZATOR CATALIZATOR CU COMPUSI IMPREGNATI PESTE 50 PPM
                    REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
                    MOTOR RACIRE RADIATOR 28DM2-18F1
                    INCALZIRE CIRCUIT GAZE CARTER CU SISTEM DE INCALZIRE CIRCUIT DE GAZE DIN CARTER
                    SONORITATE GMP SPECIFICA FARA IZOLARE ACUSTICA GRUP MOTOPROPULSOR
                    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO 6.1
                    VENTILATOR 1 VENTILATOR 2 TREPTE DE TURATIE 95W AERO VOLET DYNAMIQUE
                    LANT DE TRACTIUNE LANT DE TRACTIUNE TERMICA
                    STOP AND START CU STOP AND START DEMAROR
                    CUPLU RAPORT CP 19 X 61
                    STIL ROATA (JANTA) JANTA QUARTZ 16"
                    ROTI MOTOARE 2 ROTI MOTOARE
                    ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
                    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE DETECTARE INDIRECTA DE PNEU DEZUMFLAT CU LOCALIZARE
                    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE CU RIGIDITATE 25000 NM/RAD
                    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22 TUBULARA
                    UNGHI VOLAN CU DISPOZITIV DE ESTIMARE UNGHI VOLAN ABSOLUT
                    SUSPENSIE (TIP ARHITECTURA) SUSPENSIE METALICA
                    DIRECTIE (FUNCTIONARE) DIRECTIE ELECTRICA ASISTATA PINION SIMPLU LOW POWER
                    PEDALIER (TIP) PEDALIER STANDARD SIMPLU
                    ANTENA ANTENA PAVILION SCURTA + INTEGRATA
                    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
                    PROTECTIE SUB CAROSERIE DEFLECTOR SUB PLANSEU FATA
                    LUMINA DE MERS INAPOI CU 2 LUMINI DE MERS INAPOI
                    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
                    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC + DIODA/LED
                    APARATOARE DE NOROI APARATOARE DE NOROI STANDARD CU SPUMA FATA
                    INSONORIZARE PE MOTOR ELEMENTE DE IZOLARE FONICA TABLIER + CAPOTA MOTOR + GRUP MOTOPROPULSOR
                    GEAM DE PARBRIZ (GEN) GEAM PARBRIZ STANDARD
                    STERGATOR DE LUNETA CU MECANISM DE STERGERE LUNETA
                    OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
                    GEAM DE PAVILION CU GEAM DE PAVILION FIX
                    BARA DE PROTECTIE BARA DE PROTECTIE FATA IN CULOAREA CAROSERIEI + INEL CROMAT SI BARA DE PROTECTIE SPATE IN CULOAREA CAROSERIEI
                    APARATOARE DE NOROI (BAVETA) APARATOARE DE NOROI FATA AERO
                    PORTBAGAJ MONTARE FARA BARE DE ACOPERIS LONGITUDINALE
                    ROATA DE REZERVA ROATA DE REZERVA TIP ROLA
                    ACCESORII EXTERIOARE MANER EXTERIOR CULOARE CORSERIE
                    GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS SPATE
                    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE ACUSTICA + LUNETA SECURIZATA
                    ACCES SI PORNIRE CU MAINI LIBERE FARA SISTEM ACCES/PORNIRE MAINI LIBERE
                    Echipament interior
                    BRICHETA FARA BROCHETA
                    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
                    COTIERA DE SCAUN SPATE CU COTIERA SPATE
                    FIXARE LA INTERIOR CU SISTEM DE ARIMARE INTERIOARA
                    MASCARE BAGAJE PANOU/MASUTA
                    CENTURA DE SIGURANTA FATA RETRACTOR CU ALARMA CUPLARE CENTURA CONDUCATOR + PASAGER
                    SCRUMIERA FARA SCRUMIERA
                    COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
                    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
                    VARIATIE DE ECHIPARE INTERIOARA MANER FRANA DE MANA IMBRACAT IN PIELE
                    LUMINI INTERIOARE DIVERSE LUMINI PENTRU CITIT HARTA FATA/SPATE CU LED-URI / FARA LED DE AMBIANTA FARA LUMINI PENTRU ILUMINAT AMBIENTAL
                    GARNISAJ SPATIU DE INCARCARE COVORAS + PODEA + MOCHETA PE LATERAL
                    TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD FARA MATRICE
                    CAPITONAJ DE USA TAPITERIE USA DECORATIUNE CROM SATINAT
                    ANCORARE SCAUN PENTRU COPII FARA SISTEM DE ANCORARE ISO PENTRU SCAUNE DE COPII SPATE
                    DIFUZOR 4 DIFUZOARE FATA (2 TWEETER + 2 FATA) + 2 DIFUZOARE SPATE
                    INSONORIZARE HABITACLU IZOLARE FONICA (HABITACLU) TABLIER 2,8 KG
                    REGLARE PERNA DE SEZUT FATA CONDUCATOR REGLARE MANUALA SUPORT LOMBAR CONDUCATOR
                    COTIERA DE SCAUN FATA COTIERA CENTRALA
                    SISTEM DE NAVIGATIE SISTEM DE NAVIGATIE 2 ECRANE COLOR
                    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
                    CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
                    AFISAJ ECRAN DIGITAL SENSIBIL LA ATINGERE
                    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
                    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
                    PLANSEU SPATE INCARCARE FARA PLANSEU SPATE DE INCARCARE
                    PARASOLAR FATA PE PARTEA CONDUCATORULUI + PASAGERULUI CU SUPORT HARTA + INSCRIPTIONARE
                    RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
                    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI LIMITARE VITEZA PROGRAMABIL
                    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR REGLAJ PARALEL + INAINTE
                    DEPOZITARE VOLUM DE INCARCARE CHINGA GARNITURA LATERALA PORTBAGAJ
                    TUNER-RADIO TUNER DUBLU RADIO
                    MARTOR DE NIVEL DE LICHID DE RACIRE FARA MARTOR LUMINOS PENTRU NIVEL LICHID DE RACIRE
                    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE
                    VOLANT VOLAN IMBRACAT IN PIELE DE CEA MAI BUNA CALITATE
                    VARIANTA ASOCIATA SCAUN JOASA
                    SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUPORT LOMBAR MANUAL
                    PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
                    MODUL TELEMATIC MODUL TELEMATIC AUTONOM
                    Electricitate
                    BATERIE BATERIE L3 760 VRLA2 EN AGM
                    DEMAROR DEMAROR STTD
                    ILUMINAT DEOSEBIT LUMINI DE ZI FATA
                    MULTIPLEXARE ARHITECTURA ELECTRICA ECONOMICA
                    APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
                    Marci echipamente
                    Diverse
                    CRITERIU FACTORI, CLIENTELA CONCEPTIE BAZA CONSO BUSINESS LINE
                    PLACUTA CONSTRUCTORULUI PLACUTA CONSTRUCTOR UNIUNEA EUROPEANA + NRE
                    ETICHETA FARA ETICHETA
                    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII SIMPLA
                    SET DE CHEI 1 CHEIE TELECOMANDA DE INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
                    GARNITURA ANTIMURDARIE GARNITURA ANTI-MURDARIRE IMBUNATATITA
                    LICHID REFRIGERANT LICHID DE REFRIGERARE 1234 YF
                    ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
                    RULARE DRUM CORECT
                    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI + COM 2008 + SUNET POLY
                    • Bună ziua! Ma puteți ajuta cu seria Vin VF33H9HZC84792319. MULTUMESC
                      • 307 RESTYL BREAK 1.6 HDi 110 FAP (DV6TED4) CUTIE DE VITEZE MANUALA 5
                        Nr. APV/PR 10928 89 2 0174
                        Data de Inceput de Garantie 01.12.2006
                        Numar de Serie Motor 10 JB89 3002551
                        NRE e2*2001/116*0287*03
                        Informatii generale
                        TIP CAROSERIE BREAK TIMP LIBER
                        NIVEL DE ECHIPARE MEDIE INALTA
                        MOTOR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
                        TIP ECHIPARE INTERIOARA ACCESORIU PLASA TURBINE F931+EFKA F604 "VR"
                        MONOGRAMA SW
                        Alimentare motor
                        STIL ROATA (JANTA) ROATA ECHINOCTIU 16 INCI
                        ROATA (TIP) MONTARE ROATA CU JANTA DIN ALIAJ
                        BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 30
                        ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
                        DECORATIUNE (ADEZIVA) ORNAMENT SPATE DE USA FATA + ORNAMENT FATA DE USA SPATE
                        APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
                        ACCESORII EXTERIOARE MANER EXTERIOR + ORNAMENT CAPAC ALUMINIU + RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI
                        Echipament interior
                        SCAUN SPATE 3 SCAUNE SPATE SEPARATE (1 CULISANT)
                        BAGHETA PLANSEU DE INCARCARE CU BAGHETA DE PLANSEU DE INCARCARE
                        CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE 5 RETRACTOARE IN 3 PUNCTE
                        CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
                        DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
                        TABLOU DE BORD (CARACTERISTICI) GRADATIE 250 KM/H 160 M/H FUNDAL ALB CONTUR CROMAT
                        INALTARE SCAUN DE PASAGER FATA SISTEM DE INALTARE PERNA SCAUN PASAGER FATA REGLARE PARALELA
                        COTIERA DE SCAUN FATA COTIERE FATA CONDUCATOR SI PASAGER
                        ACTIONARE GEAM SPATE MECANISM DE ACTIONARE GEAM SPATE SECVENTIAL CU COMANDA ELECTRICA
                        INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
                        ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
                        Electricitate
                        DEMAROR DEMAROR CLASA 5
                        Marci echipamente
                        Diverse
                        CRITERIU FACTORI, CLIENTELA CONCEPTIE OXYGO
                        RULARE DRUM CORECT
                        MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI COMM 2005
                        • Multumesc
                          • Cu drag !
                            • Salut ma pute-ți ajuta cu ceva istoric despre mașina asta reparații daune etc Dotari VF36D6FYC21562458
                              • Bună ziua!
                                Ma puteți ajuta cu seria VIN : VF3MRHNSUKS427616
                                Multumesc!
