VIN (Vehicle Identification Number) - Informatii utile
  • Oare se mai poate o verificare service pentru
    VF38URHC8FL015109
    • Verificare Vin
      Buna ziua! Se poate verificarea unui Vin VF38D9HR8BL005211?
      Multumesc anticipat!
      • Vin VF38D9HR8BL005211
        Caracteristicile vehiculului
        Linie de produs 508
        Nr. APV/PR 12493 CJ 1 0220
        Data de Inceput de Garantie 28.06.2011
        NRE e2*2007/46*0080*00
        P4A 9666506499
        Informatii generale
        GEN DE PRODUS VEHICUL PARTICULAR
        MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
        LINIE DE PRODUS 508
        TIP CAROSERIE BERLINA 4 USI
        NIVEL DE ECHIPARE INALTIME MEDIE PLUS
        MOTOR DIESEL TURBO DV6C
        TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE STOP AND START
        TIP DE VOPSEA METALIZATA LACUITA
        CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
        TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
        CULOARE GARNISAJ "FX"
        CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
        EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
        MOTOR (TIP) MOTOR TIP DV
        Caracteristici vehicul
        DIRECTIE SISTEM DE DIRECTIE ASISTATA
        Alimentare motor
        DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
        CARBURANT MOTORINA CALITATE DA/DE/DE+
        DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
        ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
        CILINDREE 1600 CM3
        CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
        RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
        REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
        INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
        VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
        AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
        DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
        DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
        FILTRU DE PARTICULE FILTRU DE PARTICULE
        VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
        VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
        LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
        FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
        STOP AND START CU STOP AND START
        Cutie de viteze - Transmisie
        CUPLU RAPORT RAPORT PUNTE 19 X 77
        STIL ROATA (JANTA) STIL 09 17 INCI
        AMBREIAJ FARA AMBREIAJ
        DIFERENTIAL (CUTIE) DIFERENTIAL 84
        JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
        PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
        ROATA (TIP) MONTARE ROATA ALIAJ 3
        INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
        CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
        BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
        ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
        SUSPENSIE SUSPENSIE NORMALA
        CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
        VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
        DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
        Caroserie Echipamente
        DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
        ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
        ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
        LUMINA DE PRAG LUMINI DE PRAG FATA
        SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
        INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
        FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
        STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
        STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
        STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
        OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
        GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
        LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
        BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
        APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
        PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
        PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
        ROATA DE REZERVA FARA ROATA DE REZERVA
        ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
        RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
        TRAPA DE PLAFON ACOPERIS FIX
        ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
        GEAM (ASPECT) GEAM FUMURIU
        GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
        ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
        PACHET ROTI MONTAJ PNEURI 17 INCI (DOL08) + MONTAJ JANTA ALIAJ 3 (DRP07) + FĂRĂ ROATĂ DE REZERVĂ (DRS00)
        Echipament interior
        ALARMA ANTIFURT FARA ALARMA ANTIFURT
        SCAUN SPATE BANCHETA SEPARATA RABATABILA
        DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
        COTIERA DE SCAUN SPATE CU COTIERA SPATE
        CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
        CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
        GRADARE VITEZE GRADATIE IN KM/H
        PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
        INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
        ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
        LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
        GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
        TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
        CAPITONAJ DE USA DECORATIUNE TEP
        DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
        COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
        INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
        IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
        INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
        COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
        COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
        REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
        REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
        SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
        BECURI DE PROIECTOR LAMPA CU DESCARCARE
        ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
        ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
        AFISAJ AFISAJ DEV
        OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
        INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
        FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
        AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
        ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
        PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
        NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
        PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
        PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
        RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
        REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
        REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
        INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
        RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
        REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
        DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
        TUNER-RADIO TRI TUNER RADIO
        DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
        STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
        ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
        AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
        FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
        COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
        VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
        AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
        ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
        PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
        MODUL TELEMATIC MODUL TELEMATICA AUTONOM
        Electricitate
        ALTERNATOR ISTT50
        BATERIE L3 760 VRLA1 EN AGM
        DEMAROR DEMAROR CLASA 5
        ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
        FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
        APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
        Marci echipamente
        Diverse
        CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA FRANTA
        ATMOSFERA ATMOSFERA NORMALA
        ETICHETA FARA ETICHETA
        CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
        PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
        SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
        ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
        RULARE DRUM CORECT
        MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
        TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
        • Buna ziua, ma puteti ajuta cu verificarea service(verificare istoric) a unui ViN VF38UAHWTFL013501
          Multumesc anticipat.
          MACR82
          Vizitator
          • Istoric ? Nu. Caracteristici generale - da.
            • Multumesc mult si pentru alea
              • Atunci ia de citeste !
                Linie de produs 508
                Nr. APV/PR 13995 CJ 1 0224
                Data de Inceput de Garantie 23.04.2015
                NRE e2*2007/46*0080*29
                P4A 9802301499
                Informatii generale
                LINIE DE PRODUS 508
                TIP CAROSERIE BREAK RXH
                NIVEL DE ECHIPARE CU EXCEPTIA STANDARDULUI COBORAT
                MOTOR DIESEL DW10FC FAP 132KW
                TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE TIP STOP AND START
                TIP ECHIPARE INTERIOARA PIELE CLUB NAPPA "8B"
                CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
                EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
                MOTOR (TIP) MOTOR TIP EW/DW
                MONOGRAMA COMPLEMENTARA, DIVERSE BLUE HDI
                Alimentare motor
                DEPOLUARE (MOTOR) DEPOLUARE (MOTOR) EURO 6.1
                CILINDREE 2000 CM3
                INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
                DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA EURO6
                VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
                CUPLU RAPORT RAPORT PUNTE 15 X 53
                STIL ROATA (JANTA) ROATA CU JANTA DIN ALUMINIU STIL ARCHIPEL 18"
                DIFERENTIAL (CUTIE) DIFERENTIAL 86
                JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
                PNEURI (DIMENSIUNI, TIP) PNEU 245/45 R18 W FARA INTARIRE
                ROATA (TIP) MONTARE ROATA ALIAJ 4
                INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
                CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO6
                BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21,5
                ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
                CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
                ANTENA ANTENA + GPS
                FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
                INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
                STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
                OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
                GEAM DE PAVILION CU GEAM DE PAVILION
                PORTBAGAJ MONTARE CU BARE DE ACOPERIS
                PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
                GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
                Echipament interior
                DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
                CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
                CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
                ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU + DEGRADE
                CAPITONAJ DE USA DECORATIUNE PIELE CLUB
                DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
                IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
                COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN FATA CU MEMORIE + REGLARE PARTE SUPERIOARA DE PERNA
                COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
                BECURI DE PROIECTOR LAMPA CU LED
                AFISAJ AFISAJ ECRAN DIGITAL TACTIL
                PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
                RECEPTOR RADIO RECEPTOR RADIO SMEG DIGITAL
                COVORAS DE PODEA (ASPECT) COVORASE TRAMONTANE BRODERIE PIELE
                DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
                DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE
                STORURI LATERALE FARA TRANSPERANTE LATERALE
                AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
                PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
                Electricitate
                ALTERNATOR ISTT53
                BATERIE L3 760 VRLA2 EN AGM
                DEMAROR DEMAROR CLASA 6+
                Marci echipamente
                Diverse
                CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
                CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
                RULARE DRUM CORECT
                Sa o stapanesti sanatos !!
                • Multumesx frumos!
                  • Buna, as dori si eu mai multe informatii. Multumesc
                    VF38DRHF8BL096344
                    • VF38DRHF8BL096344
                      Trimite508 BERLINA 4 USI 2.0 HDi 138 FAP CUTIE DE VITEZE
                      Linie de produs 508
                      Nr. APV/PR 12785 CJ 1 0402
                      Data de Inceput de Garantie 30.03.2012
                      NRE e2*2007/46*0080*04
                      P4A 9691274299
                      Informatii generale
                      LINIE DE PRODUS 508
                      NIVEL DE ECHIPARE INALTA JOASA
                      MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
                      TRANSMISIE CUTIE DE VITEZE MANUALA6
                      CULOAREA CAROSERIEI KGN - VOPSEA BOURRASQUE
                      TIP ECHIPARE INTERIOARA TESATURA NERVURON "5L"
                      CULOARE GARNISAJ "FD"
                      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
                      MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
                      Alimentare motor
                      STOP AND START FARA SISTEM STOP AND START
                      DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR SUPERIEUR L6 EURO 5
                      CILINDREE 2000 CM3
                      FILTRU DE PARTICULE CU FILTRU DE PARTICULE
                      CUPLU RAPORT RAPORT PUNTE 6 X 65
                      STIL ROATA (JANTA) STIL 02 16 INCI
                      AMBREIAJ AMBREIAJ HIDRAULIC
                      JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
                      PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
                      ROATA (TIP) MONTARE ROATA ALIAJ 2
                      CUTIE DE VITEZE TIP ML6C
                      ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
                      ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
                      STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
                      ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
                      ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
                      Echipament interior
                      COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
                      ECHIPAMENT PLANSA DE BORD DECORATIUNE IMITATIE LEMN
                      LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
                      TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
                      CAPITONAJ DE USA DECOR TESATURA
                      INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
                      COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
                      COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
                      REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
                      BECURI DE PROIECTOR LAMPA CU HALOGEN
                      AFISAJ AFISAJ DEV
                      FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
                      ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
                      PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
                      INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
                      REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
                      ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
                      Electricitate
                      APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
                      ALTERNATOR ALTERNATOR CLASA 15
                      BATERIE L3 720 EF
                      Marci echipamente
                      Diverse
                      CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
                      SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
                      ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
                      RULARE DRUM CORECT
                      • salutare!se poate o verificare vin?: VF38D9HD8EL045942
                        orice fel de info este utila. multumesc anticipat.
                        • VF38D9HD8EL045942
                          Linie de produs 508
                          Nr. APV/PR 13911 CJ 1 0060
                          Data de Inceput de Garantie 22.12.2014
                          NRE e2*2007/46*0080*24
                          P4A 9803147699
                          Informatii generale
                          LINIE DE PRODUS 508
                          TIP ECHIPARE INTERIOARA TESATURA COCHER
                          CULOARE GARNISAJ "FR"
                          MONOGRAMA COMPLEMENTARA, DIVERSE E-HDI
                          Alimentare motor
                          CILINDREE 1600 CM3
                          ANTENA ANTENA + GPS
                          Echipament interior
                          ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
                          TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
                          INDICATOR DE ULEI FARA INDICATOR DE NIVEL DE ULEI
                          RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
                          COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
                          DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
                          Electricitate
                          ALTERNATOR ISTT51
                          Marci echipamente
                          Diverse
                          RULARE DRUM CORECT
                          • Va salut! se poate o verificare la acest VIN VF38D5FV8BL077860? Va multumesc anticipat.
                            • Salut !!! si La Multi Ani !!!
                              Va rog toate informatiile pentru seria
                              VF3WC9HXC34139966
                              I said BYE BYE BYE !!!!!
                              • VF32ABHZA47745416
                                Salutare tuturor si la multi ani!
                                Va rog, as vrea sa stiu istoricul unui 206 1.4 hdi.
                                Ieri am cumparat masina, adusa din Italia (in octombrie 2018).
                                M-ar ajuta mult sa stiu ce probleme a avut.
                                VIN VF32ABHZA47745416
                                Multumesc.
