VIN (Vehicle Identification Number) - Informatii utile
  • VIN Peugeot 508
    Salut stimati colegi,
    Ma poate ajuta cineva cu un VIN ? ...si dau un vin
    VF38E9HR8BL081765
    • Originally posted by Tyby1601 View Post
      VF34E9HP0ES041442
      Salutare.
      Apare pe undeva cat are volumul la portbagaj? Doar acesta ma intereseaza.
      Multumesc
      Sent from my Nexus 7 using Tapatalk
      Pe Service Box nu apare dar am gasit aici: http://masininisam.com/portbagaj/peugeot/308.html. Ar fi 584 de litri, banuiesc cu bancheta spate nerabatata.
      • Originally posted by licasica View Post
        Buna seara si bine v-am gasit , am intrat de cateva zile in posesia unui 307 sw motor de 2.0 hdi 90 cp si vreau sa aflu si eu mai multe detalii despre el deci daca ma poate ajuta cineva ,aceasta este seria vin- VF33hrhyb84000377 va multumesc
        Astea-s: "
        Caractéristiques du véhicule
        Ligne de produit 307
        N°APV/PR 10320 89 2 0169
        Date de Début de Garantie 30/03/2005
        NRE e2*98/14*0245*06
        Informations générales
        GENRE DE PRODUIT VEHICULE PARTICULIER
        MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
        LIGNE DE PRODUIT 307
        SILHOUETTE BREAK LOISIRS
        FINITION GRAND ANGLE 2
        MOTEUR DIESEL TURBO DW10TD
        TRANSMISSION BVM5
        TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
        COULEUR DE CAISSE EKQ - PEINTURE ROUGE LUCIFER
        TYPE D’HABILLAGE INTÉRIEUR CHAINE ET TRAME MINIKA + EKFA "NV"
        COULEUR DE GARNISSAGE "FX"
        BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
        MOTEUR (TYPE) MOTEUR TYPE EW/DW
        MONOGRAMME COMPLÉMENTAIRE, DIVERS HDI (I CHROME)
        MONOGRAMME SW
        Caractéristiques véhicule
        DIRECTION DIRECTION ASSISTEE VARIABLE
        Alimentation moteur
        DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
        CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE FONTE
        CARBURANT GAZOLE
        DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
        CATALYSEUR CATALYSEUR 2 COMPOSES FILTRES IMPR PLATINE
        REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
        RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
        AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
        DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
        DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
        FILTRE À PARTICULE SANS FILTRE A PARTICULES
        VENTILATEUR 1 VENTILATEUR 2 VITESSES 130WAERO
        RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUPERATION VAPEUR ESSENCE
        VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
        CHAINE DE TRACTION HYBRIDE SANS ALTERNO-DEMARREUR
        FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
        BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
        STOP AND START SANS STOP AND START
        Boîte de vitesses Transmission
        TRANSMISSION BVM5
        COUPLE RAPPORT CP 19 X 75
        STYLE ROUE ROUE ALLIAGE APOLLO 7 AJOURS 15 POUCES
        TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV BE4/5 L
        DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
        PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195X65X15 H
        ROUES MONTÉES ROUE 6 POUCES
        ROUE (TYPE) MONTAGE ROUE ALLIAGE
        BOITE DE VITESSES TYPE BVM BE4R
        Suspension Direction Freinage
        ANTIBLOCAGE ANTI-BLOCAGE ROUE
        BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 27
        ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 23
        FREIN TYPE DISQUES AV VENTILES/DISQUES AR
        SUSPENSION SUSPENSION NORMALE
        CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP
        VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 0
        PÉDALIER (TYPE) PEDALIER STANDARD
        Carrosserie Equipements
        ATTACHE-REMORQUE SANS ATTACHE REMORQUE
        AVERTISSEURS AVERTISSEUR STANDARD
        ANTENNE ANTENNE PAVILLON COURTE
        ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX COULEUR CAISSE
        ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX
        ENJOLIVEUR ROUE (STYLE) TYPE APOLLO
        FEU DE RECUL AVEC 1 FEU RECUL
        COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
        ETANCHÉITÉ AÉRODYNAMIQUE JOINT CAPOT AV
        FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE MANUEL
        ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT SANS ENJOLIVEUR SORTIE ECHAPPEMENT
        ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
        ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
        ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
        VITRE PAVILLON AVEC VITRE PAVILLON
        PARE-CHOCS PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
        PARE-BOUE (BAVETTE) SANS BAVETTES AR
        PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
        RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE ELECTRIQUE
        RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE ELECTRIQUE
        ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
        ACCESSOIRES EXTÉRIEURS POIGN EXT+ENJ VOLET ALU +RETRO EXT C CAISSE
        LAVE-VITRE ARRIÈRE LAVE VITRE ARRIERE
        TOIT OUVRANT TOIT FIXE
        ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
        VITRE (ASPECT) TEINTEE + SURTEINTEE
        VITRE CUSTODE (NATURE) VITRE CUSTODE FIXE
        VITRE (TYPE) PARE-BRISE ACOUSTIQUE SAUF SINGAPOUR
        PACK RADIO / INFORMATION / COMMUNICATION RADIO CD / INFO 2
        Equipement intérieur
        ALARME ANTIVOL SANS ALARME ANTIVOL
        APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
        APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
        ASSISE ARRIÈRE 3 SIEGES AR SEPARES (1 COULISSANT)
        ASSISE SUPPLÉMENTAIRE SANS ASSISE SUPPLEMENTAIRE
        ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
        BAGUETTE PLANCHER DE CHARGE AVEC BAGUETTE PLANCHER CHARGE
        CACHE-BAGAGES AVEC CACHE BAGAGES
        CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 5 ENROULEURS 3 PTS
        CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME
        CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
        GRADUATION VITESSES GRADUATION EN KM/H
        CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
        COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
        CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
        EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD STANDARD + FACADE ALU VIF ARGENT
        VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR VOLANT POMMEAU SOUFFLET CUIR
        HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
        COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
        ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
        REHAUSSE ASSISE AVANT PASSAGER REHAUSSE ASSISE AV PASSAGER REGLAGE PARALLELE
        RÉGLAGE ASSISE AVANT CONDUCTEUR SANS MAINTIENS LOMBAIRE ET LATERAL CONDUCTEUR
        RÉGLAGE ASSISE AVANT PASSAGER SANS MAINTIENS LOMBAIRE ET LATERAL PASSAGER
        RABATTEMENT ASSISE AVANT CONDUCTEUR SANS RABATTEMENT ASSISE AV CONDUCTEUR
        RABATTEMENT ASSISE AVANT PASSAGER SANS RABATTEMENT ASSISE AV PASSAGER
        ACCOUDOIR ASSISE AVANT ACCOUDOIRS AVANT CONDUCTEUR ET PASSAGER
        INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
        COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
        BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
        SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
        LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE ELECTRIQUE SEQUENTIELLE
        LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
        LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
        AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
        MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
        INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
        MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
        NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
        SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX + RIDEAU
        SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
        LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR + PASSAGERS AV/AR
        ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
        PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
        RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
        NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
        COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INT PORTE ASPECT VIF ARGENT
        PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
        RANGEMENT (POSTE CONDUITE) SANS RANGEMENT CONSOLE AV PAVILLON
        RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD3"
        RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
        RÉGULATEUR DE VITESSES REGULATION VITESSE
        REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
        RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
        SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
        RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
        TUNER-RADIO MONO TUNER RADIO
        DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE
        ADAPTATION GARNITURE POMMEAU LEVIER VITESSE+SOUFFLET CUIR
        SURTAPIS SANS SURTAPIS
        AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
        FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
        COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
        VOLANT VOLANT CUIR 3 BRAS
        SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
        Electricité
        ALTERNATEUR ALTERNATEUR CLASSE 15
        BATTERIE BATTERIE L2 400
        DÉMARREUR DEMARREUR CLASSE 6
        ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
        MULTIPLEXAGE MONTAGE MULTIPLEXE CAN VAN
        Marques d'équipements
        Divers
        CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION LCDV CREE POUR INIT VERSION16
        ATMOSPHÈRE ATMOSPHERE NORMALE
        PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES
        COTÉ CIRCULATION CIRCULATION A DROITE
        CHOCS LATÉRAUX PORTE NON RENFORCEE
        JEUX DE CLÉS 1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
        ADAPTATION PAYS SANS ADAPTATION PAYS
        EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS
        ROULAGE BONNE ROUTE
        SURVEILLANCE VITESSE SANS SURVEILLANCE VITESSE
        BOÎTIER SERVITUDE BSI LIGHT COM 2000."
        • Originally posted by electricserv View Post
          VF38E9HR8BL081765
          Astea-s: "
          Ligne de produit 508
          N°APV/PR 12742 CJ 1 0433
          Date de Début de Garantie 25/10/2011
          NRE e2*2007/46*0080*03
          P4A 9666506499
          LIGNE DE PRODUIT 508
          SILHOUETTE BREAK 5PTES
          FINITION HAUTE BASSE
          MOTEUR DIESEL TURBO DV6C
          TRANSMISSION BVM PILOTEE 6 RAPPORTS STT
          TYPE DE PEINTURE METALLISEE VERNIS
          COULEUR DE CAISSE KTV - PEINTURE NOIR PERLA NERA
          TYPE D’HABILLAGE INTÉRIEUR CUIR CLAUDIA "Q1"
          BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MCD
          DEFINITION A VENIR ANCIENNE GAMME
          MOTEUR (TYPE) MOTEUR TYPE DV
          MONOGRAMME COMPLÉMENTAIRE, DIVERS E-HDI
          Alimentation moteur
          CARBURANT GAZOLE QUALITE DA/DE/DE+
          DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 5(MOTEUR)
          ECHAPPEMENT SILENCIEUX AR LONGITUDINAL
          CYLINDRÉE 1600 CM3
          CATALYSEUR CATALYSEUR INF 10PPM
          REFROIDISSEMENT D’HUILE ECHANGEUR SUR MOTEUR ET BV
          RÉSERVOIR DE CARBURANT RESERVOIR CARBURANT AVEC DETROMPEUR
          VARIATION PUISSANCE (MOTEUR) PUISSANCE MOTEUR 82 KW - 270 NM
          DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 5
          FILTRE À PARTICULE FILTRE A PARTICULES
          VENTILATEUR 1 VENTILATEUR ELECTRONIQUE BI VIT 140W
          VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SIEMENS
          CHAINE DE TRACTION HYBRIDE SANS CHAINE TRACTION HYBRIDE
          STOP AND START AVEC STOP AND START
          COUPLE RAPPORT CP 19 X 77
          STYLE ROUE STYLE 04 17 POUCES
          EMBRAYAGE SANS EMBRAYAGE
          JANTE / PNEU DIMENSION MONTE PNEU 17 POUCES
          PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R17 94W NON RENFORCE
          ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
          INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
          BOITE DE VITESSES TYPE BVM MC
          BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 20
          CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
          VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1
          DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
          ATTACHE-REMORQUE ROTULE DEMONTABLE VERTICALE
          ENJOLIVEMENT LATÉRAL (ASPECT) SANS PROTECTEURS LATERAUX
          ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
          FEU D’ÉCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL AVANT
          ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) SANS ANNEAU ARRIMAGE EXTERIEUR RAPPORTE
          FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE SANS MEMOIRE
          OBTURATEUR FACE AVANT OBTURATEUR INFERIEUR FACE AV
          VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
          PARE-CHOCS PC AV/AR STANDARD COULEUR CAISSE + GRILLE CHROME
          PORTE-BAGAGES MONTAGE AVEC BARRES DE TOIT
          ROUE DE SECOURS SANS ROUE DE SECOURS
          ACCESSOIRES EXTÉRIEURS POIGNEE EXT COULEUR CAISSE+COULISSE ENJO CHROME
          RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
          ENJOLIVEMENT PARE-CHOCS P/C AVEC INSERT CHROME
          VITRE (ASPECT) VITRE TEINTEE
          VITRE (TYPE) P-B FEUILLETE ACCOUSTIQUE + AR TREMPE
          ACCÈS ET DÉMARRAGE MAINS LIBRES SANS ACCES ET DEMARRAGE MAINS LIBRES
          ASSISE ARRIÈRE BANQUETTE SEPAREE RABATTABLE
          DETECTION ANGLEMORT SANS SURVEILLANCE ANGLE MORT
          ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
          CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
          CLIMAT (TEMPERATURE AMBIANTE) PAYS TEMPERES
          CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
          EQUIPEMENT PLANCHE DE BORD DECOR SATIN ARGENTE
          FEUX INT. DIVERS LECTEUR CARTE AV + AR + LED AV
          GARNISSAGE VOLUME CHARGEMENT TAPIS COFFRE + COTES MOQUETTE
          COMBINÉ (CARACTÉRISTIQUES) GRADUATION 260 KM/H 160 M/H MATRICE MONOCHROME
          GARNISSAGE DE PORTE DECOR TEP
          HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 4 HP AR
          COMMANDE D’AUTORADIO COMMANDE AUTO-RADIO A DISTANCE STANDARD
          INSONORISATION HABITACLE INSONO TABLIER 4 KG
          REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE PARALLELE+AV
          COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV ELECT CONDUCTEUR
          COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV ELECT PASSAGER
          RÉGLAGE ASSISE AVANT CONDUCTEUR REGLAGE LOMBAIRE CONDUCTEUR
          RÉGLAGE ASSISE AVANT PASSAGER REGLAGE LOMBAIRE PASSAGER
          SYSTÈME DE NAVIGATION AVEC SYSTEME NAVIGATION ECRAN COULEUR
          LAMPES DE PROJECTEURS LAMPE HALOGENE
          LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECTRIQUE CDE SEQUENTIELLE
          AFFICHEUR AFFICHEUR DEV
          INDICATEUR D’HUILE RECEPTEUR TEMPORISE NIV + TEMP
          NAPPE CHAUFFANTE SIEGE CHAUFFANT
          ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
          PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
          PROJECTEUR CORRECTEUR ASSIETTE REGLAGE MANUEL A DISTANCE PROJECTEURS
          PROJECTEUR DIRECTIONNEL SANS PROJECTEUR DIRECTIONNEL
          RÉCEPTEUR RADIO RADIO TELEPHONE AFFICHAGE DEPORTE ’RT6’
          RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
          REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE ELECTRIQUE
          RÉGULATION CLIMATISATION / TEMPÉRATURE REFRIGERATION AUTOMATIQUE BI-ZONE
          TUNER-RADIO TRI TUNER RADIO
          DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AVANT ARRIERE
          STORES LATÉRAUX SANS STORES LATERAUX
          ADAPTATION GARNITURE POMMEAU CUIR RETRO ECLAIRE
          VOLANT VOLANT CROUTE CUIR 3 BRAS
          ECRAN VIDÉO ARRIÈRE SANS ECRAN VIDEO AR
          PRISE AUXILIAIRE PACK AUDIO 1 PRISE JACK + USB
          BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOME
          Electricité
          ALTERNATEUR ISTT50
          BATTERIE L3 760 VRLA1 EN AGM
          DÉMARREUR DEMARREUR CLASSE 5
          ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE + FEUX DIURNES AV
          FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
          ALLUMAGE FEUX ALLUMAGE FEUX MANUEL
          Divers
          CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION BUSINESS LINE
          ETIQUETTE SANS ETIQUETTE
          PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES QUADRUPLE
          EQUIPEMENT DE SECOURS KIT ANTI CREVAISON
          ROULAGE BONNE ROUTE
          BOÎTIER SERVITUDE BSI EVOLUTION
          TRIANGLE DE PRÉSIGNALISATION SANS TRIANGLE PRESIGNALISATION."
          • Multumesc mult Cristi . Stima !
            • Salut! Daca ma puteti ajuta cu decodarea VIN-ului: VF36D6FZB21073334 as fi mare recunoscator! Vreau sa aflu ce norma de poluare. Va multumesc anticipat!
              • Salutare. Ceva informatii despre un 508 cu VIN VF38DRHC8CL071595. Multumesc anticipat!.
                • Buna ziua, va rog mult pot afla si eu detalii despre VIN VF38D9HR8BL075374 ? Ma intereseaza sa am acces la echiparea autovehiculului, exact ca in raspunsurile de mai sus. Multumesc!
                  • Originally posted by Dinu Adrian View Post
                    Caracteristicile vehiculului
                    Linie de produs 407
                    Nr. APV/PR 10104 CJ 2 0835
                    Data de Inceput de Garantie 28.07.2004
                    NRE e2*2001/116*0292*00
                    Informatii generale
                    GEN DE PRODUS VEHICUL PARTICULAR
                    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
                    LINIE DE PRODUS 407
                    TIP CAROSERIE BERLINA 4 USI
                    NIVEL DE ECHIPARE AP1
                    MOTOR INJECTIE EW7J4
                    TRANSMISIE CUTIE DE VITEZE MANUALA5
                    TIP DE VOPSEA VOPSEA METALIZATA LACUITA
                    CULOAREA CAROSERIEI EZW - VOPSEA GRI FER
                    TIP ECHIPARE INTERIOARA TESATURA BAMBA "UD"
                    CULOARE GARNISAJ "FY"
                    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA BE4 V
                    MOTOR (TIP) MOTOR TIP EW/DW
                    Caracteristici vehicul
                    DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
                    Alimentare motor
                    DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
                    CARBURANT BENZINA FARA PLUMB
                    DEPOLUARE (MOTOR) DEPOLUARE CEE 2000 (MOTOR)
                    RECIRE ULEI FARA SCHIMBATOR APA/ULEI
                    INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
                    VARIATE DE PUTERE (MOTOR) PUTERE STANDARD
                    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
                    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
                    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL L4
                    FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
                    VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
                    VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SAGEM
                    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
                    MODUL CLAPETA (ADMISIE AER MOTOR) MODUL CLAPETA MOTORIZATA (ADMISIE AER MOTOR)
                    Cutie de viteze - Transmisie
                    CUPLU RAPORT CP 17 X 73
                    STIL ROATA (JANTA) ROATA CU JANTA DIN TABLA
                    AMBREIAJ AMBREIAJ HIDRAULIC
                    DIFERENTIAL (CUTIE) DIFERENTIAL 77
                    JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
                    PNEURI (DIMENSIUNI, TIP) PNEU 205/60 R16 92H FARA INTARIRE
                    ROATA (TIP) MONTARE ROATA CU JANTA DIN TABLA
                    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
                    CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
                    COLOANA DE DIRECTIE COLOANA DE DIRECTIE CU REGLARE MANUALA
                    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
                    CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 184
                    SUSPENSIE ACTIVA FARA SUSPENSIE VARIABILA
                    CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
                    DIRECTIE (FUNCTIONARE) SISTEM DE DIRECTIE MECANICA ASISTATA
                    Caroserie Echipamente
                    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
                    ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
                    ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE FINE
                    ORNAMENT DE ROATA (STIL) STIL NOVAE 7 FANTE 16 INCI
                    LUMINA DE PRAG FARA LUMINA DE PRAG
                    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
                    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
                    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
                    STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
                    STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
                    OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
                    GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
                    ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
                    ACCESORII EXTERIOARE MANERE EXTERIOARE NEUTRE + RETROVIZOARE EXTERIOARE IN CULOAREA CAROSERIEI
                    TRAPA DE PLAFON ACOPERIS FIX
                    ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
                    GEAM (ASPECT) GEAM FUMURIU
                    GEAM (TIP) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
                    ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
                    Echipament interior
                    ALARMA ANTIFURT FARA ALARMA ANTIFURT
                    COTIERA DE SCAUN SPATE FARA COTIERA SPATE
                    CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
                    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
                    SIGURANTA COPII SIGURANTA COPIL MANUALA USA SPATE
                    GRADARE VITEZE GRADATIE IN KM/H
                    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
                    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
                    ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD
                    TABLOU DE BORD (CARACTERISTICI) GRADAT 240 KM/H 150 M/H FUNDAL NEGRU
                    CAPITONAJ DE USA DECORATIUNE GRI METALIZAT
                    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
                    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
                    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANTE SPATE
                    INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
                    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
                    COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
                    REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
                    CD FARA MONTARE COMPACT DISC
                    SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
                    BECURI DE PROIECTOR LAMPA CU HALOGEN
                    ACTIONARE GEAM SPATE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
                    AFISAJ AFISAJ (RADIO + CEAS + SI SAU T°,CD)
                    OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
                    INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
                    FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
                    AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
                    ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
                    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
                    PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
                    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
                    RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
                    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
                    REGULATOR DE VITEZA FARA SISTEM DE REGULARIZARE VITEZA
                    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
                    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
                    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU O ZONA
                    TUNER-RADIO TUNER DUBLU RADIO
                    PROTECTIE INTERIOARA FARA PROTECTIE INTERIOARA
                    DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
                    STORURI LATERALE FARA TRANSPERANTE LATERALE
                    ADAPTARE GARNITURA MANER MANETA DE VITEZA CU INSERTIE CROMATA
                    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
                    FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
                    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
                    VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
                    AIRBAG DE GENUNCHI CONDUCATOR AIRBAG ZONA GENUNCHI CONDUCATOR
                    Electricitate
                    ALTERNATOR ALTERNATOR CLASA 9
                    BATERIE BATERIE L2 400
                    DEMAROR DEMAROR CLASA 3
                    ILUMINAT DEOSEBIT FARA ILUMINAT SPECIAL
                    Marci echipamente
                    Diverse
                    CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
                    ATMOSFERA ATMOSFERA NORMALA
                    RULARE DRUM CORECT
                    • Originally posted by RaduVali80 View Post
                      Linie de produs 508
                      Nr. APV/PR 13093 CJ 1 0461
                      Data de Inceput de Garantie 05.10.2012
                      NRE e2*2007/46*0080*11
                      P4A 9667228099
                      Informatii generale
                      LINIE DE PRODUS 508
                      NIVEL DE ECHIPARE INALTIME MEDIE PLUS
                      MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
                      TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
                      TIP DE VOPSEA METALIZATA LACUITA
                      CULOAREA CAROSERIEI KDM - VOPSEA CAFENIU INCHIS GUARANJA
                      TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
                      CULOARE GARNISAJ "FD"
                      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
                      EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
                      MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
                      DIRECTIE SISTEM DE DIRECTIE ASISTATA
                      Alimentare motor
                      CARBURANT MOTORINA CALITATE DA/DE/DE+
                      DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
                      ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
                      CILINDREE 2000 CM3
                      CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
                      RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
                      REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
                      DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
                      FILTRU DE PARTICULE FILTRU DE PARTICULE
                      VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
                      VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
                      LANT DE TRACTIUNE HIBRIDA LANT DE TRACTIUNE HIBRID
                      STOP AND START CU STOP AND START
                      CUPLU RAPORT RAPORT PUNTE 17 X 74
                      STIL ROATA (JANTA) STIL 05 17 INCI
                      AMBREIAJ FARA AMBREIAJ
                      DIFERENTIAL (CUTIE) DIFERENTIAL 86
                      JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
                      PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
                      ROATA (TIP) MONTARE ROATA ALIAJ 2
                      CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
                      BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
                      SUSPENSIE SUSPENSIE NORMALA
                      VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
                      DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
                      DISPOZITIV DE REMORCARE ARTICULATIE SFERICA VERTICALA DEMONTABILA
                      ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
                      ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
                      LUMINA DE PRAG LUMINI DE PRAG FATA
                      INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
                      FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
                      INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
                      STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
                      STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
                      OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
                      LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
                      BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
                      APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
                      PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
                      PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
                      ROATA DE REZERVA FARA ROATA DE REZERVA
                      ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
                      RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
                      ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
                      GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
                      ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
                      Echipament interior
                      SCAUN SPATE BANCHETA SEPARATA RABATABILA
                      DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
                      COTIERA DE SCAUN SPATE CU COTIERA SPATE
                      CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
                      ECHIPAMENT PLANSA DE BORD DECORATIUNE IMITATIE LEMN
                      LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
                      GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
                      TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
                      CAPITONAJ DE USA DECORATIUNE TEP
                      DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
                      COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
                      IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
                      INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
                      COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
                      COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
                      REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
                      REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
                      SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
                      BECURI DE PROIECTOR LAMPA CU DESCARCARE
                      ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
                      ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
                      AFISAJ AFISAJ DEV
                      OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
                      INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
                      FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
                      AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
                      ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
                      PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
                      PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
                      RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
                      REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
                      INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
                      RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
                      REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
                      DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
                      DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
                      STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
                      ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
                      AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
                      VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
                      AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
                      ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
                      PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
                      MODUL TELEMATIC MODUL TELEMATICA AUTONOM
                      Electricitate
                      ALTERNATOR ISTT6
                      BATERIE L3 800
                      DEMAROR DEMAROR CLASA 5
                      ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
                      FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
                      APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
                      Marci echipamente
                      Diverse
                      CRITERIU FACTORI, CLIENTELA CONCEPTIE CONSUM SCAZUT
                      ETICHETA FARA ETICHETA
                      CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
                      PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
                      SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
                      ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
                      RULARE DRUM CORECT
                      MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
                      TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
                      - - - Updated - - -
                      Linie de produs 508
                      Nr. APV/PR 12716 CJ 1 0219
                      Data de Inceput de Garantie 03.09.2011
                      P4A 9666506499
                      Informatii generale
                      LINIE DE PRODUS 508
                      MOTOR DIESEL TURBO DV6C
                      TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE STOP AND START
                      CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
                      CULOARE GARNISAJ "FX"
                      CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
                      MOTOR (TIP) MOTOR TIP DV
                      MONOGRAMA COMPLEMENTARA, DIVERSE E-HDI
                      Alimentare motor
                      CILINDREE 1600 CM3
                      VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
                      VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
                      LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
                      CUPLU RAPORT RAPORT PUNTE 19 X 77
                      STIL ROATA (JANTA) STIL 09 17 INCI
                      DIFERENTIAL (CUTIE) DIFERENTIAL 84
                      ROATA (TIP) MONTARE ROATA ALIAJ 3
                      ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
                      OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
                      ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
                      Echipament interior
                      ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
                      DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
                      INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
                      AFISAJ AFISAJ DEV
                      ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
                      Electricitate
                      ALTERNATOR ISTT50
                      BATERIE L3 760 VRLA1 EN AGM
                      Marci echipamente
                      Diverse
                      CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA FRANTA
                      ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
                      RULARE DRUM CORECT
                      • Multumesc!
                        • multumesc pentru datele oferite!.
                          • Buna ziua! Daca se poate, doresc si eu detalii despre VIN VF38D9HDBELO4I872 . Multumesc in avans!
                            • Buna ziua! As dori si eu informatii legate de VIN VF34E9HR8BS120847 . Multumesc anticipat!
                              • @claudiutergo
                                Linie de produs 308
                                Nr. APV/PR 12568 89 1 0335
                                Data de Inceput de Garantie 28.04.2011
                                NRE e2*2001/116*0362*31
                                P4A 9666545899
                                Informatii generale
                                LINIE DE PRODUS 308
                                TIP CAROSERIE BREAK 5 USI
                                NIVEL DE ECHIPARE INALTA MEDIE
                                TRANSMISIE CUTIE DE VITEZE MANUALA 6 TREPTE TIP STOP AND START
                                CULOAREA CAROSERIEI KTP - VOPSEA GRI SHARK
                                TIP ECHIPARE INTERIOARA TESATURA STARTING + OMNI "XW"
                                CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCE
                                EVOLUTIE DEFINITIE TEHNICA ANIMATIE GAMA
                                MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
                                Alimentare motor
                                ALIMENTARE INJECTIE TURBO DIRECTA CU SCHIMBATOR
                                CARBURANT MOTORINA
                                ESAPAMENT ESAPAMENT STANDARD
                                CILINDREE 1600 CM3
                                CATALIZATOR CATALIZATOR CU 3 COMPUSI IN FILTRE IMPREGNATE CU RODIU + PALADIU
                                MOTOR RACIRE RADIATOR GROSIME:27 - 21 DM2 ALUMINIU BRAZAT
                                INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
                                AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
                                VENTILATOR 1 VENTILATOR 2 TURATII 140W AERO FARA PRIZA DE AER
                                RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
                                CUPLU RAPORT RAPORT PUNTE 19 X 71
                                STIL ROATA (JANTA) ROATA MELBOURNE 2 DE 17 INCI
                                PNEURI (DIMENSIUNI, TIP) PNEU 225/45 R17 94W RANFORSAT
                                ROTI MONTATE ROATA 7 INCI 1/2
                                ROATA (TIP) MONTARE ROATA CU JANTA DIN ALIAJ
                                ANTIBLOCARE ANTIBLOCARE ROATA
                                BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 29
                                FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
                                DIRECTIE (FUNCTIONARE) SISTEM DE DIRECTIE ASISTATA ELECTROHIDRAULIC IN MOD STAND-BY
                                PEDALIER (TIP) PEDALIER STANDARD
                                AVERTIZOARE SISTEM DE AVERTIZARE STANDARD
                                ANTENA ANTENA SCURTA PAVILION
                                DEFLECTOR AERODINAMIC SPATE MONTARE FARA DEFLECTOR SPATE
                                ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
                                LUMINA DE MERS INAPOI CU 1 LUMINA PENTRU MERS INAPOI
                                LUMINA DE SEMNALIZARE SEMNATURA LUMINOASA
                                APARATOARE DE NOROI APARATOARE DE NOROI STANDARD
                                ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
                                INSONORIZARE PE MOTOR ELEMENT DE IZOLARE FONICA TABLIER + CAPOTA + GRUP MOTOPROPULSOR SCURT ALUMINIU
                                STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
                                STERGATOR DE LUNETA (FUNCTIONARE) STERGATOR DE LUNETA INTERMITENT CU FUNCTIONARE AUTOMATA LA MERSUL INAPOI
                                GEAM DE PAVILION CU GEAM DE PAVILION
                                BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE IN CULOAREA CAROSERIEI + GRILA PANA LA MOD2000
                                PLACA DE INMATRICULARE FARA PLACUTA DE INMATRICULARE
                                RETROVIZOR EXTERIOR (PARTEA CONDUCATORULUI) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
                                RETROVIZOR EXTERIOR (PARTEA PASAGERULUI) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
                                ACCESORII EXTERIOARE MANER EXTERIOR + SUPORT RETROVIZOR + RETROVIZOR CULOARE CAROSERIE
                                ORNAMENT DE BARA DE PROTECTIE BANDOU FATA NEGRU STRALUCITOR + SPATE CULOAREA CAROSERIEI
                                GEAM (ASPECT) FUMURIU + FUMURIU INCHIS
                                GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
                                GEAM (TIP) PARBRIZ DIN STICLA STRATIFICATA IZOLATA TERMIC + IZOLATA ACUSTIC + SPATE DIN STICLA SECURIZATA
                                Echipament interior
                                TETIERA SPATE TETIERA SPATE REGLABILA
                                SCAUN SUPLIMENTAR FARA PERNA DE SCAUN SUPLIMENTARA
                                MASCARE BAGAJE PANOU/MASUTA
                                CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
                                CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
                                SIGURANTA COPII SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
                                CONSOLA CONSOLA LUNGA + CONDUCTA AER SPATE
                                INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
                                ILUMINAT DE PORTBAGAJ VOLUM INCARCARE COMANDA AUTOMATA DE ILUMINAT PORTBAGAJ SI VOLUM DE INCARCARE
                                ECHIPAMENT PLANSA DE BORD PLANSA DE BORD SUPORT NEGRU SAU WARM SILVER
                                LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA + LED FATA + 2 SPOTURI SPATE
                                MASUTA DE LUCRU FARA MASUTA DE LUCRU
                                DEPOZITARE SUB SCAUN FARA COMPARTIMENT DE DEPOZITARE SUB SCAUN
                                TABLOU DE BORD (CARACTERISTICI) GRADAT 230 KM/H 140 M/H FUNDAL NEGRU CU CONTUR CROMAT
                                INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 13 KG
                                INALTARE SCAUN DE PASAGER FATA SISTEM DE INALTARE PERNA SCAUN PASAGER FATA REGLARE PARALELA
                                REGLARE PERNA DE SEZUT FATA CONDUCATOR SPATAR SCAUN CONDUCATOR CARE SE POATE INCLINA
                                RABATERE SCAUN FATA DE CONDUCATOR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
                                RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
                                COTIERA DE SCAUN FATA COTIERA CENTRALA PERNA FATA
                                INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
                                ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
                                CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
                                ACTIONARE GEAM DE CONDUCATOR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
                                AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
                                ACCESORII INT. DIVERSE FARA PLASA ANTI-DEPLASARE
                                SUPORT DE PICIOR SUPORT SPRIJINIRE PICIOR CONDUCATOR
                                PERNA DE SCAUN MATLASATA MATLASARE PERNA DE SEZUT FATA STANDARD
                                AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
                                PACHET ECHIPAMENT FARA PACHET ECHIPAMENT
                                RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
                                COMANDA INTERIOARA DE USA (ASPECT) PALETA USA ASPECT CROMAT + ORNAMENT COLORAT
                                PROTECTIE POST FATA FARA PROTECTIE POST FATA
                                PARASOLAR FATA PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
                                DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT PENTRU OCHELARI
                                RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
                                AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
                                TUNER-RADIO CU UN SINGUR TUNER RADIO
                                DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
                                ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN MATERIAL PLASTIC + PLACUTA CROMATA
                                COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
                                COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
                                PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB + BLUETOOTH
                                MODUL TELEMATIC FARA MODUL TELEMATIC
                                Electricitate
                                ALTERNATOR ISTT50
                                BATERIE BATERIE L3 760 ETANSA(L3 760 VRLA 760 EN AGM)
                                DEMAROR DEMAROR CLASA 6
                                ILUMINAT DEOSEBIT LUMINI DE ZI FATA
                                MASURA INCARCARII BATERIEI CU SISTEM DE MASURARE A NIVELULUI DE INCARCARE A BATERIEI
                                APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
                                Marci echipamente
                                Diverse
                                SOC LATERAL USA CARE NU ESTE INTARITA
                                SET DE CHEI 1 CHEIE TELECOMANDA DE INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
                                MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI COMM 2003
                                S-o stapanesti sanatos !!
