Valva EGR
    Originally posted by 406_silver View Post
    turbijak!turbina functioneaza mai bine fiindca intra in ea doar aer curat, nu gaza recirculate!nu mai sunt nici depuneri!
    Asa o mare ineptie nu am mai auzit de mult timp. Turbina se monteaza pe evacuare, nu pe admisie. Deci, nu are ce aer curat sa intre in ea.
    egr este o solutie tehnica pentru a reduce cantitatea de gaze emanate.in loc sa fie evacuate sunt reintroduse in motor prin acea valva egr.obturand valva, motorul trage numai aer curat, ca la motoarele mai vechi.renuntand la egr chiar protejati motorul.
    Uite o explicatie mult mai bine documentata:
    "Exhaust gas recirculation (EGR) systems were introduced in the early '70s to reduce an exhaust emission that was not being cleaned by the other smog controls. Oxides of nitrogen (NOx) are formed when temperatures in the combustion chamber get too hot. At 2500 degrees Fahrenheit or hotter, the nitrogen and oxygen in the combustion chamber can chemically combine to form nitrous oxides, which, when combined with hydrocarbons (HCs) and the presence of sunlight, produces an ugly haze in our skies known commonly as smog.
    How to reduce NOx NOx formation can be reduced by:
    - Enriching the air fuel (A/F) mixture to reduce combustion temperatures.
    However, this increases HC and carbon monoxide (CO) emissions.
    - Lowering the compression ratio and retarding ignition timing; but this leads to reduced performance and fuel economy.
    - Recirculating some exhaust gases.
    How EGR systems work:
    The EGR valve recirculates exhaust into the intake stream. Exhaust gases have already combusted, so they do not burn again when they are recirculated. These gases displace some of the normal intake charge. This chemically slows and cools the combustion process by several hundred degrees, thus reducing NOx formation.
    The design challenge The EGR system of today must precisely control the flow of recirculated exhaust. Too much flow will retard engine performance and cause a hesitation on acceleration. Too little flow will increase NOx and cause engine ping. A well-designed system will actually increase engine performance and economy. Why? As the combustion chamber temperature is reduced, engine detonation potential is also reduced. This factor enabled the software engineers to write a more aggressive timing advance curve into the spark timing program. If the EGR valve is not flowing, onboard diagnostics (OBD) systems will set a code and the power control module (PCM) will use a backup timing curve that has less advance to prevent engine ping. Less timing advance means less performance and economy. Do your customer a favor and fix those EGR codes that you may have previously deemed as unimportant.
    Concluzia: la un motor gandit sa functioneze cu valva EGR, a o intrerupe nu face altceva decat sa micsoreze avansul motorului, ceea ce determina performante diminuate si cresterea consumului.
      buuun!si atunci cum explici tu ca toata lumea care a obturat valva egr(si cunosc destui) zice ca masina trage mult mai bine si a scazut consumul? eu nu sunt de specialitate da e evident ca masina merge mult mai bine.iar cei care mi-au dat ideea crede-ma ca se pricep foarte bine si nu sunt mecanici de dacia reciclati si pusi sa repare masini straine!!!
        2 cuvinte am sa zic: "efectul placebo".
        Pe plan tehnic exista o explicatie: la cei care se minuneaza de cum trage masina dupa operatiunea "kill the EGR" cel mai probabil aceaa valva era super-super infundata/blocata/ne-functionala. In acel caz, masina era sub orice critica la performante, iar solutia corecta ar fi constat doar in curatarea cu simt de raspundere a acelei valve pentru re-aducerea la parametri. Se pare insa ca oamenii au preferat sa inlature acea valva din ecuatie, ne-cunoscand (dupa parerea mea, binenteles) implicatiile de ansamblu.
          Merite pt. altceva decât norme de poluare nu are decât pentru motoare cu aprindere prin scânteie. Textul spune chiar clar de fapt că e vorba de benzinare.
          La dizelare motorina arde mai mult sau mai puţin în timp ce e injectată datorită temperaturii aerului comprimat din cilindru iar amestecul este neomogen şi întotdeauna mult mai sărac fără nici o problemă, aprinderea nefiind prin scânteie.
          2 Întrebări. Mai treci ITP-ul la emisii NOx? Unde ai făcut obturarea valvei?
            4 mil si ceva + manopera ...m-a dus dus undeva la 6 mil. S-o schimb. Deci nu costa atat. Tipul de la serivice mi-a explicat ca au fost scumpe la inceput dar cum si-au dat seama ca multe masini au probleme ( era ceva din proiectare) au ieftinit-o pentru a o putea schimba toti cei care au probleme cu ea ( asta e explicata pe care am primit-o eu)...
            SOPO
            407 - 2.0 HDI
            Albastru
              pai explicatia asta am primit-o si eu pentru pretul enorm de la cerinul de regenerare fap.eu cre ca e pur si simplu o incercare de a ne prosti.daca merge bine, daca nu...baga explicatia de mai sus.
              cred ca iau itp-ul iar daca am probleme cu ei, pun egr provizoriu in functiune.da cum suntem in Rom, nu cred ca o sa am probleme.oricum mai am 2 ani pana atunci.nici nu stiu daca tin masina atat.
              lucrarea am facut-o la serviceul unui prieten.pt cei interesati pot sa-i ajut.
              si chiar nu e efectul placebo.masina merge mult mai bine si nu mai intrerupe in sarcina.
                Salut ptr. cine il intereseaza Vana EGR am eu 3 luate de la peugeot sunt noi. dar nustiu ptr. ce tipuri de motor sunt adica de 407 sunt sigur dar nustiu daca sunt de 1.6 sau 2.0 iar pretul uneia este de 5 mil.!
                Cine vrea da PM..
                PS:micone_16:Aceasta este vana EGR nu Valva EGR cum ai zis tu..!)
                Peugeot 407 SW,2.7HDi V6,204 CP,GRI,PANORAMIC,DUBLUCLIAMTRONIC,XENON
                Peugeot 206 RC,177 CP,jenti 16,piele,DVD,Climatronic,NEOANE ALBASTRE,Xenon doar pe scurta+proiectoare;)..curand si pe lunga!
                  Si se va aprinde martorul galben de la calculatorul motor,ca debitmetrul de aer furnizeaza in permanenta informatia ca EGR nu functioneaza.Daca ai soft vechi,te-ai scos,daca ai avut campanie de resoftare cu soft nou,mmmmmm...:naughty:
                    5 milioane jumate cu diagnosticare si manopera la Eurial.
                    • #25
                      Asa mi-au spus aia de la Peugeot ba vana ba valva.Dar mi se pare ciudat ca un mecanic mi-a spus ca vana egr este o chestie care se afla sub turbina ca o capsula si actioneaza o parghie care intra in turbina.La aceasta este un furtun actionat de un vacum.Nu stiu daca aia este Egr ptr ca dadea ipresia ca nu prea stie ce zice.Cine are 407 cu 1.6 hdi si stie unde este sa-mi spuna si mie.
                      • #26
                        nu stiu ce soft am, da pana acum nu am nici o problema.
                        nu stiu nici eu exact unde e valva egr. ce am vazut cand au lucrat la ea e o conducta groasa care porneste din stanga motorului (cum stai cu fata la el) de langa debitmetru si se duce pe sub filtrul de aer, undeva in jos. mie acolo mi l-au obturat. a trebuit sa scoata carcasa de la filtrul de aer.
                        • #27
                          conducta este din plastic sau din ce material este?
                          • #28
                            pare un fel de ebonita neagra
                            • #29
                              EGR lucreaza cu gaze de evacuare,care au sute de grade.Orice conexiune la EGR este metalica (de obicei cu burduf metalic),de aceea se exclud variante gen:cauciuc,plastic sau ebonita.
                              @406_silver,anularea EGR pe un dieselar,are ca prima consecinta vizibila,marirea fumozitatii,deci se incarca si turbina de funingine.
                              HDI are turbocharged,adica turbina antrenata de gazele de ardere,deci obligatoriu va avea doua camere turbionare,una pentru gazele de evacuare si o alta pentru aspiratie (aer curat ) .
                              A anula EGR pe un diesel cu FAP, este sinucidere financiara.
                              • #30
                                argumenteaza mai detaliat te rog.
                                eu am anulat egr-ul de 4000 de km si masina merge f bine. sigur, nu am scapat de mesajul depoulution faulty!!!am verificat masina pe tester sapt trecuta si gradul de incarcare a fap era de 44%.nu stiu cat de bine sau nu e!!!
