La tine nu merge graphic parameter measurement?
2.0 HDI - Erori / probleme / rezolvari
Bun, revin cu noi date. Doua masini la fel, aceeasi motorizare, una are turbina noua recent, si a mea. Cea cu turbina noua are niste valori cu 0.3-0.4 bari peste referinta, si parca si un zvac mai sesizabil. A mea in schimb undeva intre 0.2-0.3 bari in jos, si trage "normal". La o limita de accelerare, presiunile se echilibreaza, de la 1800 pana la 2300 mbari, referinta cu masuratul bat pe acolo, la ambele masini. Nici o eroare pe nici una din ele, referitoare la diferentele astea.
Sa trec o revizie la turbina pe wishlist ?
Azi am facut un drum afara si dupa cativa km pe tempomat, dau talpa si imi apare depolution faulty. Pun mana pe telefon si fac o diagnoza cu elm si imi da eroarea P1166 ceva de 02 heater. SI daca ma uit pe parametri in timpul functionarii motorului imi apare ceva cu rosu tot legat de 02 sensor. Stie ceineva care e problema?
L.E. Am gasit in documentatie ceva explicatii:
Request for Delayed Engine Stop
Deactivation of the pilot and post-injection injections
Deactivation of the detection of loop difference on the fuel flow rate regulator
Limitation of performanceP1166 - Deactivation of the vehicle speed limiter
- Deactivating the cruise control
- The engine ECU cuts the checking of the EGR system
- Cutting of the "exhaust heat recovery" function
- Switching off : Kick downFuel system : Maximum fuel injection common rail pressure exceeded Fault code P1166 After sales description of the fault code High pressure fuel regulation : Measured rail pressure higher than the maximum pressure Description of the diagnostics The rail pressure measured by the ECU exceeds the maximum threshold of 1800 bars for 6 seconds Conditions of activation of the diagnostics Consult the associated contexts for the Pcode forwarding conditions Conditions of disappearance of the fault Driving for 5 min with several full load accelerations for 10 seconds Down-grade modes if fault present Deactivation of the speed limiter Deactivation speed limiter until the next time the ignition is switched on Deactivation of the cruise control Deactivation cruise control until the next time the ignition is switched on Request for Delayed Engine Stop The ECU limits the fuel flow Switching on of the warning light and/or warning message Warning lamp MIL Main customer complaints likely Lack of power Engine hesitating, cutting out Suspect areas Electrical harness Connectors High pressure fuel pump Engine management ECU Fuel high pressure sensor
Intr-adevar si tempomatul a intrat in eroare. Ceva sfaturi?Last edited by adrian ghiurau; 06-01-2014, 10:54 PM.
La fel patesc si eu cand o accelerez brusc. Se dezactiveaza CC, intra in avarie, se aprinde check engine, depollution faulty si toate cele.
dispare dupa cateva porniri.
Am intrebat pe la baietii care mai stiu si am primit vre-o 3 pareri:
1. furtunase vacuum crapate;
2. regulator presiune care nu mai lucreaza in parametri;
3. probleme din softul masinii, daca nu e facuta bine remaparea e posibil sa apara astfel de manifestari. - asta vreau sa o cam exclud, cred ca @Doc stie ce a facut pe acolo
Cum vremea nu e tocmai potrivita, voi amana pana spre primavara verificarea/inlocuirea furtunaselor de vacuum. Mie mi-a dat o eroare legata de over-boost,de aia merg pe varianta vacumurilor.Peugeot 407 SW 2.0HDI 163 HP si in continuare fan 205 GTI
Aceasta eroare apare doar in momentul in care accelerez mai brusc. Dupa cum arata si pe diagnoza, eram la 97 km/h si am calcat-o mai tare sa intru intr-o depasire. Atunci a aparut pe bord Check engine, deppolution faulty si toate cele. Masina nu a intrat in limp, a functionat normal in continuare. Lipsa semnal de la ce poate fi? daca era un contact imperfect intr-o mufa, aparea tot timpul, nu doar in accelerari bruste. Presiunea e mai mare probabil din cauza remaparii.Peugeot 407 SW 2.0HDI 163 HP si in continuare fan 205 GTI
Ieri am observat un zgomot pe partea dreapta. Pare a fi din zona distributiei, desi nu se aude foarte bine cu capota ridicata, il acopera usor zgomotul de diesel. Cel mai bine se aude din exterior, pe partea dreapta a masinii, sau din habitaclu cu geamul dreapta deschis, de unde l-am si inregistrat. https://www.youtube.com/watch?v=qpwU...ature=youtu.be
M-am gandit initial la pompa de apa, desi distributia a fost facuta la 90 000, acum 3 ani, si a fost si pompa schimbata. Acum are 135 000.307 SW T5 2.0HDi FAP OFF 136cp
[QUOTE=adrian . Citeam undeva pe forum, nu stiu daca e adevarat, era vorba de RHR, ca apasarea la fund a pedalei, genereaza un plus de 20Nm.?[/QUOTE]
Si io stiam asta,insa Doar o parte poate au asa ceva;spre exemplu,aia ce merg eu Sa o vad in cāteva zile are tot RHR si nu are surplusu ala de putere in caz ca vrei o depasire la limita si ai nevoie de un cuplu mai mare(asa zice Service box.In schimb alte case tip Jaguar au asa ceva de serie.
Sent from my RM-885_eu_italy_278 using Tapatalk''ex 607 2.2 hdi''-''new 607 2.0 hdi''both made by Peugeot
Un aspect ciudat am remarcat de cateva zile.
Intr-a I-a cand plec de pe loc la 1500 - 2000 ture, inainte sa eliberez pedala de ambreiaj de tot, simt ca ar scapa ambreiajul. Masina nu smuceste, nu se simte cu nimic diferit, doar ca simt un hop, ca si cum ar scapa cativa cm si apoi ar cupla perfect. La plecarea de pe loc motorul nu are tendinta sa se tureze in gol, nici in depasiri sau in trepte mari de viteza.
Se simte doar uneori si imi este greu sa cred ca s-a uzat deja discul. Are abia 40-50.000 km.
Eu ma mai gandesc si la amortizoarele fata sau ceva din articulatii.
Simptomul a aparut de Paste cand am facut un drum de 700 km pe A2.
