Geamuri - Probleme, intretinere, modificari
  • Salut! La 407 trebuie reinitializare daca scoti borna de la baterie si ai geamul deschis, are o functie de protectie - sa nu se inchida geamul daca da de un obstacol - poate si la 307 este la fel! Uite textul din cartea lui 407, uita-te si la tine la 307:
    "REINITIALISATION OF THE WINDOWS: Following reconnection of the battery, the safety auto-reverse function must be reinitialised: the safety autoreverse function is not active during these operations.
    - lower the window completely, then raise it, it will rise in steps of a few centimetres each time the switch is pressed. Repeat the operation until the window closes completely;
    - continue to press the switch for at least one second after reaching this Safety auto-reverse position, window closed.
    Always remove the key from the ignition when leaving the vehicle, even for a short time. In the event of contact during operation of the windows, you must reverse the movement of the window. To do this, press the switch
    concerned.
    When the driver operates the passenger electric window switches, he must ensure that no one is preventing correct closing of the windows. The driver must ensure that the passengers use the electric windows correctly. Be aware of children when operating the windows."
    Efectiv mi-e lene sa traduc, dar simptomele descrise de tine, cu urcarea in trepte si urcarea si coborarea cu 3 cm, sunt similare! Bafta!
    Am mai gasit ceva:
    "When the window rises and meets an obstacle, it stops and immediately partially lowers again. In the event of unwanted opening of the window on closing, press the switch until the window opens completely, then pull the switch immediately until the window closes. Continue to hold the switch for approximately one second after the window has closed. The safety auto-reverse function is not active during this operation."
    Traducerea: "Cand geamul se ridica si intalneste un obstacol, se opreste si imediat coboara. In eventualitatea unei deschideri nedorite a geamului in cursul inchiderii, apasa comutatorul pana cand geamul se deschide complet, apoi apasati butonul imediat ce geamul s-a inchis. Tine apasat butonul pentru aproximativ 1 sec. dupa ce geamul s-a inchis. Functia de siguranta "auto-reverse" nu este activa in timpul acestei operatiuni."
    Asta-i! Hai c-am obosit !
    • Dap, si 307 face la fel. Trebuie reinitializate
      Pug 307SW T6 1.6HDI110 navi
      • Legat de un modul ridicare geamuri,, aveti idee cum trebuie montat??
        Imi cam da batai de cap schema electrica.
        • ]Detin un Peugeot 307 1.4 an 2006 si cam de jumatate de an geamul stanga fata a luat-o razna din comanda - coboara pana la jumatate, dupa care urca 3 cm si tot asa. Dupa ce am desfacut si curatat tot, incepand de la comanda pana la motoras, am verificat carbuni si altele, dupa montaj s-au inversat comenzile adica pentru ca sa coboare trebuie sa ridic de buton si ca sa urce trebuie sa apas pe buton, doar ca urca/coboara in trepte iar comanda de inchidere din cheie nu mai functioneaza deloc. Butoanele sunt in regula, din moment ce le-am dat jos si am facut un test cu joystick-ul direct pe comanda si face la fel. Are cineva vreo idee?
          Revin cu a mea problema!!!! inca nu s-a rezolvat.....intre timp am probat comanda(placuta)gemuri pe o alta masina si merge perfect.....am probat un alt motoras pe a mea masina si are aceleasi simptome.....mai mult am verificat cu un aparat de masura toate firele din legatura dintre usa si caroserie si is toate bune....ce mai ramane...?
          cineva zicea sa verific si modulul de confort.....daca mai are cineva si alta idee....mentionez ca am reinitializat .....am dat borna jos ....am pus si tester si nimic....are cineva vreo idee...?!
          • Cum ai reintializat?Ai dus geamul pana jos si apoi ai tinut 30 de secunde, apoi l-ai dus sus si ai tinut 30 de secunde?
            • Conteaza daca duc geamul prima data jos sau sus la reinitializare? La mine acum sunt comenzile inversate, cand ridic de buton gemul coboara in trepte si cand cobor de buton geamul se ridica tot in trepte....Nu mai stiu cum si ce sa mai incerc...
              • Salutare! am demontat consola cu comenzile pentru geamuri si oglinzi pentru a o curata (la geamul pasagerului face figuri butonasul) si nu pot sa o desfac. Are niste cleme pe margine care merg desfacute insa singura problema este butonul de pliere/selecare oglinzi (cel dreptunghiular, nu rotund) care este mai mare decat gaura de sub el si nu iese. Nu vreau sa trag de el ca sa nu raman cu el in mana...Vreun sfat? Multumesc anticipat
                • Se trage de el in sus si va iesi,l am scos de multe ori.
                  • Problema COMENZII gemurilor electrice - rezolvare
                    Problema COMENZII gemurilor electrice - rezolvare:
                    Am avut o problema cu butoanele geamurilor electrice: luau foarte greu comenzile si devenisera de-a dreptul enervante. M-am mai confruntat cu asta si in vara anului trecut si am rezolvat-o cu un Kit de reparatie pentru telecomenzi (niste capsule de cauciuc care se lipeau peste capsulele originale cu silicon cumparate de pe str. Maica Domnului) dar solutia asta nu a fost de durata pt ca dupa aprox 6 luni problema a revenit.
                    Rezolvarea:
                    In locul acelui "cauciuc" ce vine peste contactele de la placuta de comanda am lipit niste intrerupatoare mici - de aceeasi inaltime cu cauciucul (le-am luat de pe un MP3 player auto ce-l aveam prin debara si nu mai functiona).
                    Operatia am efectuat-o momentan numai pentru geamurile din fata. Am folosit 8 intrerupatoare - cate 4 pentru fiecare geam (sunt geamuri secventiale). Pentru cei cu comanda simpla treaba asta este mult mai usor de realizat (au numai doua butoane pt. fiecare geam).
                    Rezultatul este neasteptat de bun, comenzile sunt prompte, geamurile functionand acum PERFECT!
                    Pentru cei doritori sa incerce va stau la dispozitie cu sfaturi.
                    www.sub-capota.ro
                    • Salut. Am postat si in probleme electrice nevazand acest post abia dupa. Geamul de la sofer face figuri de 2 zile: la actionare se ridica/coboara cate 2 cm apoi se opreste pana este actionat din nou. Mentionez ca cel de la pasager functioneaza fara probleme. Culmea, problema a aparut cum am luat masina din service de la revizie :|
                      • N-ai citit manualul ....
                        Dupa deconectarea bateriei, in caz ca ai geamul lasat trebuie reinitializat:
                        -il ridici treptat pina sus
                        -la ultima ridicare mentii butonul ridicat inca 1..2 secunde (se si aude un click la capat de cursa)
                        -(re)initializarea e gata
                        • Mersi mult de tot, am rezolvat, cert e ca nu am crezut ca voi gasi asemenea detalii in manual..
                          • O problema asemanatoare am si eu. Masina este inca in service in lucru si am lasat geamurile fata jos( am doar pe fata electrice). Ieri mi-a spus mecanicul ca nu se mai inchid geamurile , pune contact si nimic nu se ridica. Nu l am mai intrebat daca a deconectat vreo borna de la baterie desi trebuie schimbata turbina , distributie etc...Mentionez ca a fost si conectata la un calculator ( laptop cu nu stiu ce program pt diagnoza ca nu stiam daca este turbina sau nu sa vedem ce probleme afiseaza) O sa-l mai sun azi pe mecanic sa l intreb exact , nu prea se pricepe pe partea de electrica doar mecanica. Daca stie cineva care ar putea fi problema sau solutia...?
                            • Spune-i sa porneasca motorul. Daca a intrat pe economy mode am impresia ca nu se mai ridica geamurile
                              Sent from my HTC One S using Tapatalk 2
                              • Acum nu poate ca nu mi a venit turbina noua si juma de motor este desfacut. Se mai schimba si altele. Da chiar a spus ca pe ecran ii apare economy mode. Sa inteleg ca atunci cand se porneste motorul iese automat din economy mode si geamurile isi revin?
                                Last edited by Cristi_M.; 07-03-2014, 07:29 PM. Reason: "k" nu este echivalent cu "ca"! Nu pe acest Forum!
