VIN (Vehicle Identification Number) - Informatii utile
  • VIN (Vehicle Identification Number) - Informatii utile
    E si normal ca nu merge'el are 4 cifre legate in loc de 2cifre, LITERA si apoi cifra.in loc de 5 ii trebe litera.
    Sent from my BlackBerry 9520 using Tapatalk
    • Da era gresit, proprietarul a recunoscut asta. Asta este cel corect sper :VF32S8HZA47466492. Sanatate.
      • Asta a mers! Astea-s:
        " Caracteristicile vehiculului
        Linie de produs 206
        Nr. APV/PR 10686 81 2 0430
        Data de Inceput de Garantie 10.03.2006
        Informatii generale
        GENRE DE PRODUIT VEHICUL PARTICULAR
        MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
        LIGNE DE PRODUIT 206
        SILHOUETTE BERLINA COMERCIALA 3 USI
        FINITION NIVEL XR PREZENTA
        MOTEUR DIESEL TURBO DV4TD
        TRANSMISSION CUTIE DE VITEZE MANUALA5
        TYPE DE PEINTURE VOPSEA OPACA
        COULEUR DE CAISSE EWP - VOPSEA ALBA BANQUISE
        TYPE D’HABILLAGE INTÉRIEUR ACCESORIU PLASA TRAMI + SOFIS MONOTON "N5"
        COULEUR DE GARNISSAGE "FX"
        BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MA5 / O
        MOTEUR (TYPE) EV/DV
        MONOGRAMME COMPLÉMENTAIRE FARA MONOGRAMA SUPLIMENTARA
        MONOGRAMME FARA MONOGRAMA
        Caracteristici vehicul
        DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
        COUPLE TACHYMÈTRE RAPORT TRANSMISIE 21 X 18
        Alimentare motor
        BOUCHON DE REMPLISSAGE CARBURANT BUSON CARBURANT IN CULOAREA CAROSERIEI
        DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
        CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI ALUMINIU
        CARBURANT MOTORINA
        DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
        PRÉFILTRE ECHIPARE FARA PREGATIRE PENTRU FILTRU
        MOTEUR (TYPE) EV/DV
        CATALYSEUR CATALIZATOR 2 COMPUSI IMPREGNATI CU PLATINA SUB 50 PPM
        REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
        OPTIMISATION DE CONSOMMATION DU VÉHICULE FARA OPTIMIZARE DE CONSUM CARBURANT
        MOTEUR REFROIDISSEMENT RADIATOR EP:27 21 DM2 PAS 1,1 FARA SISTEM DE MONTARE/DEMONTARE RAPIDA
        RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
        COUPURE ALIMENTATION CARBURANT CU SISTEM DE INTRERUPERE A ALIMENTARII CU CARBURANT
        RHÉOSTAT CU REOSTAT
        AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" CU ACCELEROMETRU
        DISPOSITIF (ANTIPOLLUTION) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
        DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
        FILTRE À PARTICULE FARA FILTRU DE PARTICULE
        VENTILATEUR 1 VENTILATOR 2 TURATII 250W 70W AERO
        RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
        VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
        FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
        BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
        Cutie de viteze - Transmisie
        COUPLE RAPPORT RAPORT PUNTE 17 X 64
        STYLE ROUE ROATA DIN TABLA 14 INCI
        VERROUILLAGE SÉCURITÉ BOITE DE VITESSES FARA BLOCARE DE SIGURANTA BV
        TYPE DE BOITE DE VITESSES (HOMOLOGATION) CUTIE DE VITEZE TIP MA/5 O
        DIFFÉRENTIEL (BOITE) DIFERENTIAL 68
        PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 185X65X14 T
        ROUES MONTÉES ROATA 5 INCI 1/2
        ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
        BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA MA
        ANTIBLOCAGE ANTIBLOCARE ROATA
        BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 19
        ANTIVOL ANTIFURT STANDARD
        ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 20
        FREIN PRINCIPAL REPARTITIE ELECTRONICA DE FRANARE
        FREIN TYPE DISCURI FATA VENTILATE / TAMBURE SPATE
        SUSPENSION SUSPENSIE NORMALA
        CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
        VARIANTE ASSOCIÉE FREIN ABS TEVES MK70
        DIRECTION (FONCTIONNEMENT) SISTEM DE DIRECTIE MECANICA ASISTATA
        PÉDALIER (TYPE) PEDALIER STANDARD
        Caroserie Echipamente
        AVERTISSEURS SISTEM DE AVERTIZARE STANDARD
        ANTENNE ANTENA LUNGA DE PAVILION
        DÉCORATION (ADHÉSIVE) ORNAMENT SPATE DE INCADRARE NEGRU MAT
        ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
        ENJOLIVEUR ROUE (STYLE) STIL CUBA 8 FANTE 14 INCI
        COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
        FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
        ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
        INSONORISATION COTÉ MOTEUR ELEMENTE DE IZOLARE FONICA TABLIER + CAPOTA MOTOR + GRUP MOTOPROPULSOR
        ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
        ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
        ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
        OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
        VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
        PARE-CHOCS BARA DE PROTECTIE FATA STANDARD + SPATE SPORT CULOARE CAROSERIE
        PARE-BOUE (BAVETTE) APARATOARE DE NOROI IN FATA ROTII SPATE
        PORTE-BAGAGES MONTARE FARA BARE DE ACOPERIS LONGITUDINALE
        PROJECTEUR ANTIBROUILLARD FARA PROIECTOARE ANTICEATA
        PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROIECTOR CU PARABOLA DUBLA
        RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA MANUALA
        RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETROVIZOR EXTERIOR PASAGER CU COMANDA MANUALA
        ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
        ACCESSOIRES EXTÉRIEURS MANER EXTERIOR + RETROVIZOR EXTERIOR NEUTRE + ORNAMNT DE CAPAC VOPSIT
        RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA ASFERICA RETROVIZOR EXTERIOR
        TOIT OUVRANT ACOPERIS FIX
        ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
        VITRE ARRIÈRE (GENRE) LUNETA CU INCALZIRE
        VITRE (ASPECT) COLORATA
        VITRE CUSTODE (NATURE) GEAM LATERAL SPATE PIVOTANT
        VITRE (TYPE) PARBRIZ CARE NU ESTE IZOLAT TERMIC
        Echipament interior
        ALARME ANTIVOL FARA ALARMA ANTIFURT
        ALLUME-CIGARE BRICHETA FATA
        APPUI-TÊTE ARRIÈRE FARA TETIERA SPATE
        APPUI-TÊTE AVANT TETIERA FATA REGLABILA
        ASSISE ARRIÈRE FARA PERNA DE SEZUT SPATE
        CACHE-BAGAGES CU PANOU DE MASCARE BAGAJE
        CEINTURE DE SÉCURITÉ ARRIÈRE FARA CENTURA DE SIGURANTA SPATE
        CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
        CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
        GRADUATION VITESSES GRADATIE IN KM/H
        COMMODITÉS (POIGNÉES) MANERE FATA
        COMPTE-TOURS TUROMETRU CU AC
        CONDITIONNEMENT RADIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
        CONSOLE CONSOLA CU SISTEM DE INCALZIRE SPATE
        COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
        COMMANDE À DISTANCE MONTAJ COMANDA LA DISTANTA CU RAZA DE ACTIUNE IMBUNATATITA
        CHAUFFAGE ADDITIONNEL SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
        ECLAIRAGE RANGEMENT FARA ILUMINAT IN COMPARTIMENTUL DE DEPOZITARE
        ECLAIRAGE DE COFFRE VOLUME CHARGEMENT COMANDA AUTOMATA PENTRU ILUMINAT PORTBAGAJ SAU VOLUM DE INCARCARE
        EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD
        FEUX INT. DIVERS FARA LAMPA INTERIOARA DIVERSE
        COMBINÉ (CARACTÉRISTIQUES) GRADATIE 210 KM/H SAU 135 M/H FUNDAL NEGRU
        COMPTE-TOURS (PRISE INFORMATIONS) TUROMETRU INFO CALCULATOR
        ANCRAGE SIÈGE ENFANT FARA SISTEM DE ANCORARE SCAUNE COPII
        HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
        HOUSSE DE PROTECTION CU HUSA DE PROTECTIE BATERIE
        COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
        REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
        RÉGLAGE ASSISE AVANT CONDUCTEUR SUSTINERE LATERALA FIXA CONDUCATOR
        RÉGLAGE ASSISE AVANT PASSAGER SUPORT DE SUSTINERE LATERALA FIXA PENTRU PASAGER
        RABATTEMENT ASSISE AVANT CONDUCTEUR CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN CONDUCATOR
        RABATTEMENT ASSISE AVANT PASSAGER CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN PASAGER FATA
        INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATOR TEMPERATURA EXTERIOARA
        COMPACT DISQUE FARA MONTARE COMPACT DISC
        BOITE DE RANGEMENT FARA CONTAINER DE DEPOZITARE
        SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
        LÈVE-VITRE ARRIÈRE FARA MECANISM DE ACTIONARE GEAM SPATE
        LÈVE-VITRE AVANT CONDUCTEUR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA ELECTRICA
        LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA ELECTRICA
        AFFICHEUR AFISAJ (CEAS SI SAU T°)
        MONTRE FARA CEAS
        INDICATEUR D’HUILE SENZOR DE NIVEL DE ULEI
        NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
        SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL FATA SIMPLU
        SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
        ORDINATEUR DE BORD FARA CALCULATOR DE BORD
        PACK ÉQUIPEMENT FARA PACHET ECHIPAMENT
        RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU INCALZIRE
        NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
        COMMANDE INTÉRIEURE DE PORTE (ASPECT) PALETA USA NEUTRA + ORNAMENT NEUTRU
        PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
        PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
        PARE-SOLEIL AVANT PE PARTEA CONDUCATORULUI + PASAGERULUI (FARA INSCRIPTIONARE)
        RANGEMENT (POSTE CONDUITE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE + PALETA NEUTRA
        RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD3"
        RÉFRIGÉRATION SISTEM DE REFRIGERARE SIMPLA
        RÉGULATEUR DE VITESSES FARA SISTEM DE REGULARIZARE VITEZA
        REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
        RHÉOSTAT CU REOSTAT
        RANGEMENT (AUTRES) COMPARTIMENTE DEPOZITARE OBIECTE MARUNTE IN USILE FATA
        SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
        SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
        RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
        TAPIS MOCHETA TESUTA DILOUR F550
        TEMPORISATEUR D’ÉCLAIRAGE TEMPORIZATOR FIX
        CONTACT TRANSPONDER
        ADAPTATION GARNITURE MANER MANETA DE VITEZE DIN MATERIAL PLASTIC + PLACUTA CROMATA
        AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
        COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
        VOLANT VOLAN IMBRACAT CU SPUMA CU 3 BRATE
        VERROUILLAGE RANGEMENT COMPARTIMENT DEPOZITARE OBIECTE MARUNTE FARA SISTEM DE INCUIERE
        Electricitate
        ALTERNATEUR ALTERNATOR CLASA 15
        BATTERIE BATERIE L2 400
        DÉMARREUR DEMAROR CLASA 4
        ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
        MULTIPLEXAGE MONTARE MULTIPLEXATA
        Marci echipamente
        Diverse
        CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION PACK CLIMATIZARE 1
        ATMOSPHÈRE ATMOSFERA NORMALA
        BOITE DE PREMIERS SECOURS FARA TRUSA DE PRIM AJUTOR
        PRISE D’ÉCOUTE RADIO FARA PRIZA PENTRU ACCESORII
        CHOCS LATÉRAUX USA CARE NU ESTE INTARITA
        JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
        ROULAGE DRUM CORECT
        SURVEILLANCE VITESSE FARA SISTEM DE MONITORIZARE VITEZA
        TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT."
        • Salut,
          Am si eu o rugaminte pt VIN VF34A9HXCAY102322
          Merci mult!
            Vehicle characteristics
            Vehicle family 308
            Build code 12253 88 2 0265
            Warranty Start Date 25/06/2010
            BER e2*2001/116*0362*20
            General information
            PRODUCT TYPE CAR
            COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
            VEHICLE FAMILY 308
            SILHOUETTE FIRM 3 DOOR SALOON
            TRIM LEVEL LOW MEDIUM PLUS
            ENGINE DV6ATED4 TURBO DIESEL
            TRANSMISSION BVM5
            PAINT TYPE NON-METALLIC PAINT
            BODY COLOUR EWP - BANQUISE WHITE PAINT
            INTERIOR TRIM TYPE WARP&WEFT SIBAYAKF990+OMNI MONO F915 "4P"
            UPHOLSTERY COLOUR "FX"
            GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
            ENGINE (TYPE) EV/DV
            OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
            Fuel supply-Engine
            TANK FILTER RESERVOIR FILTER INTERIOR
            STOP AND START WITHOUT STOP AND START
            DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
            FUEL DIESEL FUEL
            EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
            EXHAUST STANDARD EXHAUST
            ENGINE (TYPE) EV/DV
            CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
            CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
            EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
            DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
            VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
            PARTICLE FILTER WITHOUT PARTICLE FILTER
            FAN 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
            FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
            INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
            Gearbox Transmission
            TRANSMISSION BVM5
            FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 72
            WHEEL STYLE 15 INCH STEEL WHEEL
            CLUTCH HYDRAULIC CLUTCH
            DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84
            RIM/TYRE SIZE 15 INCH TYRE FITMENT
            TYRE (SIZE, TYPE) 195X65X15 H TYRES
            WHEELS FITTED 6,5" RIM ROAD WHEELS
            WHEEL (TYPE) STEEL WHEELS
            INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
            GEARBOX TYPE GEARBOX BE4R
            Suspension-Steering-Brakes
            PEDAL BRACKET (TYPE) PEDAL STANDARD
            REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 28
            FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAMETER 22.5
            SUSPENSION NORMAL SUSPENSION
            DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
            BRAKE ASSOCIATED VARIANT 8 1 BOSCH ESP
            Body fittings
            TOWBAR WITHOUT TOWBAR
            HORNS HORN STANDARD
            AERIAL SHORT ROOF AERIAL
            REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
            SIDE MOULDINGS (TYPE) LATERAL PROTECTOR MASS TINTED
            SIDE MOULDINGS (DIMENSION) STANDARD LATERAL PROTECTORS
            WHEEL EMBELLISHER (STYLE) 15 INCH ATACAMA STYLE
            REVERSING LAMPS WITH 1 REVERSING LAMP
            SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
            ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
            EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
            SPLASH SHIELD STANDARD MUD GUARD
            EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
            ENGINE BAY SOUNDPROOFING UNDERBONNET + BULKHEAD SOUNDPROOFING
            WINDSCREEN WIPER INTERMITTENT WIPER 2 SPEED
            REAR SCREEN WIPER REAR SCREEN WIPER
            HEADLAMP WIPER W/O HEADLAMP WIPER
            FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
            ROOF GLASS WITHOUT ROOF WINDOW
            REAR TAILGATE GLASS FIXED TAILGATE WINDOW
            BUMPER FR BUMPER STBC TRIM+BRT CH+REAR STBC
            MUDFLAP WITHOUT REAR MUDGUARD
            NUMBER PLATE WITHOUT LICENCE PLATE
            FRONT FOGLAMP NO FRONT FOG LIGHTS
            EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
            EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
            SPARE WHEEL STEEL WHEEL + STANDARD TYRE
            EXTERIOR ACCESSORIES EXT HANDLE + NEUTRAL MIRROR BASE + MIRROR CC
            EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
            SUN ROOF FIXED ROOF
            BUMPER TRIM DYED BUMPER STRIP
            GLASS (APPEARANCE) TINTED
            REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
            WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
            Interior fittings
            DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
            AUDIO PACK AUXILIARY SOCKET WITHOUT AUDIO PACK AUXILIARY SOCKET
            ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
            REAR HEAD RESTRAINT WITHOUT REAR HEADREST
            REAR SEAT WITHOUT REAR SEAT POSITION
            SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
            REAR SEAT ARMREST WITHOUT REAR ARMREST
            LUGGAGE COVER SHELF + LUGGAGE COVER
            REAR SEATBELT WITHOUT REAR SAFETY BELT
            FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
            CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
            CHILD LOCK WITHOUT CHILD LOCK
            SPEED GRADUATIONS GRADUATION KMS/H
            CONSOLE LONG CONSOLE
            DRIVING POSITION LEFT HAND DRIVE
            ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
            BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT AND LOAD VOL SWITCH
            DASHBOARD EQUIPMENT FASCIA PANEL BASE WARM SILVER U BLACK
            MISC. INT. LAMPS MAP READING LAMP
            WORK TABLE WITHOUT WORK TABLE
            UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
            INSTRUMENT PANEL (CHARACTERISTICS) 230 KM/H 140 MPH GRAD BLACK BACKGND CHROME CIRCLE
            LOUDSPEAKER 4 FRONT SPEAKERS (2 TW + 2 FRONT)
            RADIO CONTROLS REMOTE RADIO CONTROL
            PASSENGER COMPARTMENT SOUNDPROOFING BULKHEAD SOUNDPROOFING 13 KG
            FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
            DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
            FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
            DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
            FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
            DRIVER’S SEAT FOLDING WITH FOLD DRIV FRONT SEATING
            FRONT PASSENGER SEAT FOLDING WITH FOLD PASS FRONT SEATING
            FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
            EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
            COMPACT DISC WITHOUT COMPACT DISC
            SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
            HEADLAMP BULBS HALOGEN BULB
            REAR WINDOW LIFT WITHOUT REAR GLASS LIFT
            TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
            DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
            PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
            DISPLAY DISPAY (RADIO+CLOCK+AND OR T°, CD) WITHOUT MEMORY
            MISC. INT. ACCESSORY WITHOUT WINDSTOP
            COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
            FOOTREST DRIVER’S FOOTREST
            CUSHION PADDING STANDARD FRONT SEAT CUSHION PADDING
            HEATING ELEMENT NON HEATED SEAT
            FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
            PASSENGER AIRBAG PASSENGER AIRBAG
            EQUIPMENT PACK W/O EQUIPMENT PACK
            EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
            AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
            INTERIOR DOOR CONTROL (APPEARANCE) CHROME EFFECT DOOR HANDLE + COLOURED TRIM
            HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
            DIRECTIONAL HEADLAMP WITHOUT DIRECTIONAL LIGHTS
            FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
            FRONT SUN VISOR DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION
            STORAGE (DRIVING POSITION) WITHOUT ROOF FRONT CONSOLE STORAGE
            RADIO RECEIVER "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
            REFRIGERATION SINGLE AIR CONDITIONING
            CRUISE CONTROL WITHOUT SPEED CONTROL
            INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
            DRIVER AIRBAG DRIVERS AIR BAG
            LOAD SPACE STORAGE W/O BOOT TIDY
            TUNER RADIO MONO RADIO TUNER
            OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
            LATERAL BLINDS WITHOUT SIDE BLINDS
            TRIM ADAPTATION GEAR LEVER KNOB PLASTIC+CHROME INSERT
            FLOOR MAT W/O CARPETMAT
            EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
            LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
            STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
            Electrical
            TELEMATIC UNIT WITHOUT TELEMATIC UNIT
            ALTERNATOR ALTERNATOR 150 AMP
            HORNS HORN STANDARD
            BATTERY BATTERY L2 400
            STARTER MOTOR STARTER MOTOR CL 4
            SPECIAL LIGHTING FRONT DAYTIME LIGHTS
            BATTERY CHARGE MEASUREMENT WITHOUT BATTERY CHARGE MEASUREMENT
            RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
            Component manufacturers
            Miscellaneous
            SPECIAL SPECIFICATION STANDARD
            ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
            SIDE IMPACTS DOOR WITH REINFORCEMENT
            EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
            SLAVE CONTROL UNIT BSI COMM 2003"
            • Ultima data va rog si pentru asta vf32s8hxf43527044.
              Multumesc si sarbatori fericite!
              • Originally posted by comarzan View Post
                Salut @comarzan,
                Sper sa te poti descurca cu datele de mai jos.
                Sarbatori fericite,
                Radu
                Vehicle family 206
                Build code 09829 81 2 0498
                Warranty Start Date 16/10/2003
                General information
                PRODUCT TYPE CAR
                VEHICLE FAMILY 206
                TRIM LEVEL LEVEL XR PRESENCE
                ENGINE DV4TD TURBO DIESEL
                TRANSMISSION BVM5
                INTERIOR TRIM TYPE COOLDOUCE WARP AND WEFT + EFKA "PF"
                UPHOLSTERY COLOUR "FY"
                GEARBOX (CHARACTERISTICS) BVM MA5 / O
                ENGINE (TYPE) EV/DV
                OTHER BADGE HDI
                BADGE WITHOUT BADGE
                STEERING UNVARIABLE POWER STEERING
                SPEEDOMETER DRIVE TACHO TORQUE 21X18
                Fuel supply-Engine
                FUEL FILLER CAP FUEL CAP WITHOUT LOCK
                CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
                FUEL DIESEL FUEL
                EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
                PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
                ENGINE (TYPE) EV/DV
                CATALYTIC CONVERTER 2-COMPONENT PLATINUM FILTER CATALYSER
                OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
                OPTIMISATION OF VEHICLE’S CONSUMPTION WITHOUT FUEL CONSUMPTION OPTIMISATION
                COOLING MOTOR RADIATOR TH: 27-21 DM2 THREAD 1,1 WITHOUT CLPIS IN
                FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
                RHEOSTAT RHEOSTAT
                EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER
                VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
                FAN 2 TWO-SPEED 250W FANS
                THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
                TRANSMISSION BVM5
                FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 64
                WHEEL STYLE 14 INCHES OPTIMIZED WHEEL
                GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
                GEARBOX TYPE (TYPE APPROVAL) GEARBOX MA/5 0
                DIFFERENTIAL (GEARBOX) DIFFERENTIAL 68
                TYRE (SIZE, TYPE) PNEU 175/65 R14 82T NON RENFORCE
                WHEELS FITTED 5,5" RIM ROAD WHEELS
                GEARBOX TYPE MA
                ABS WITH ABS BRAKES
                REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
                FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 20
                SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
                BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
                DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
                BRAKE ASSOCIATED VARIANT ABS TEVES MK70
                Body fittings
                HORNS HORN STANDARD
                AERIAL LONG FRONT AERIAL
                FINISHER (SELF-ADHESIVE) BLACK DOOR PILLAR WITHOUT DECORATIVE PATTERNS
                SIDE MOULDINGS (TYPE) DYED SIDELAMPS
                WHEEL EMBELLISHER (STYLE) CUBA STYLE 8 HOLES 14 INCHES
                ENGINE BAY SOUNDPROOFING BONNET+BULKHEAD+POWER TRAIN SOUNDPROOFING
                WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
                BUMPER STANDARD FRONT + BODY COLOUR SPORT REAR BUMPER
                MUDFLAP REAR WHEEL FRONT MUDFLAP
                LUGGAGE RACK MOUNTING WITHOUT ROOF BARS
                SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS
                EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
                EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO
                EXTERIOR ACCESSORIES NEUTRAL DOOR MIRRORS + HANDLES
                EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) EXT MIRROR ASPHERICAL GLASS
                SUN ROOF FIXED ROOF
                REAR WINDOW (TYPE) REAR GLASS HEATED
                REAR QUARTER WINDOW (TYPE) PIVOTING REAR QTR GLASS
                WINDOW (TYPE) ATHERMAL WINDSCREEN
                Interior fittings
                CIGAR LIGHTER FRONT CIGAR-LIGHTER
                FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
                LUGGAGE COVER WITH LUGGAGE COVER
                AIR CONDITIONING HEATER MATRIX WITH REAR HEATING
                GRAB HANDLES FRONT HANDLES
                TACHOMETER REV COUNTER WITH NEEDLE
                RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
                CONSOLE CONSOLE WITH REAR HEATING
                REMOTE CONTROL REMOTE CONTROL ASSEMBLY
                LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING
                BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
                DASHBOARD EQUIPMENT BLACK CENTRAL PANEL
                MISC. INT. LAMPS LESS INTERIOR LIGHT
                INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 210 KM/H 135 M/H BLACK LAND
                TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
                CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
                LOUDSPEAKER MOUNTING 2 LS FR + 2 TWEETERS + 2 LS RR
                RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
                DRIVER SEAT ADJUSTMENT DRIVERS FIXED LATERAL BEARING
                FRONT PASSENGER SEAT ADJUSTMENT PASSENG FIXED LATERAL BEARING
                STOWAGE BIN WITHOUT SETTING BOX
                DRIVER’S WINDOW LIFT ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER
                PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
                DISPLAY DISPLAY (CLOCK AND OR TEMP)
                CLOCK NUMERIC CLOCK
                OIL GAUGE STD OIL LEVEL INDICATOR
                ON-BOARD COMPUTER NO COMPUTER
                INTERIOR DOOR CONTROL (APPEARANCE) NEUTRAL FINISH INSIDE DOOR HANDLE
                FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
                RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
                DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
                RHEOSTAT RHEOSTAT
                STORAGE (OTHERS) STORAGE COMPARTMENT IN FR DOORS
                CARPET COVER W/O CARPETMAT
                CARPET F550 PILE CARPET
                LIGHTING TIMER NOT ADJUSTABLE TIMER
                SWITCH ELECTRONIC ANTI-THEFT KEY
                TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
                LOCKING CONTROL SIMPLE CENTRAL LOCKING
                STORAGE SPACE LOCKS GLOVE-BOX WITHOUT LOCKING
                Electrical
                HORNS HORN STANDARD
                BATTERY BATTERY L1 300
                SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
                MULTIPLEXING MULTIPLEXING ASSEMBLY
                Miscellaneous
                SPECIAL SPECIFICATION PACK AIR CONDITIONNING 1
                FIRST AID KIT WITHOUT FIRST AID BOX
                RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
                SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
                SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
                SURFACE CONDITIONS GOOD TERRAIN
                SPEED MONITORING WITHOUT SPEED CHECK
                EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
                • Va rog daca se poate un check la VF32CHFXF41229993
                  Multumesc anticipat.
                  • Astea-s:
                    Linie de produs 206
                    Nr. APV/PR 08740 83 1 0348
                    Data de Inceput de Garantie 14.11.2000
                    NRE e2*98/14*0212*00
                    Informatii generale
                    SILHOUETTE BERLINA 3 USI
                    FINITION NIVEL XR
                    MOTEUR SISTEM INJECTIE TU1JP
                    TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
                    COULEUR DE CAISSE EGE - VOPSEA ALBASTRU DE CHINA
                    TYPE D’HABILLAGE INTÉRIEUR TESATURA ADELIE "LB"
                    COULEUR DE GARNISSAGE "FY"
                    BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA MA INTARITA
                    MOTEUR (TYPE) MOTOR TIP TU
                    MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
                    FINITION NIVEL XR
                    COUPLE TACHYMÈTRE RAPORT TRANSMISIE 19 X 17
                    Alimentare motor
                    CARBURANT BENZINA FARA PLUMB
                    DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
                    CATALYSEUR CATALIZATOR CU 3 COMPUSI
                    REFROIDISSEMENT D’HUILE FARA SCHIMBATOR APA/ULEI
                    MOTEUR REFROIDISSEMENT RADIATOR EP:18 - 16 DM2
                    RHÉOSTAT FARA REOSTAT
                    DISPOSITIF (ANTIPOLLUTION) FARA DISPOZITIV ANTIPOLUARE
                    DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
                    RÉCUPÉRATION DES VAPEURS D’ESSENCE DISPOZITIV DE RECUPERARE VAPORI DE BENZINA PILOTAT
                    VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE MAGNETI MARELLI
                    COUPLE RAPPORT RAPORT PUNTE 14 X 60
                    STYLE ROUE ROATA OPTIMIZATA 14 INCI
                    TYPE DE BOITE DE VITESSES (HOMOLOGATION) CUTIE DE VITEZE TIP MA/5 N
                    DIFFÉRENTIEL (BOITE) DIFERENTIAL STANDARD
                    PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 175/65 R14 82T NON RENFORCE
                    BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 18
                    ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 18
                    FREIN TYPE DISCURI FATA CARE NU SUNT VENTILATE / TAMBURE SPATE
                    ANTENNE ANTENA SPATE SCURTA
                    DÉCORATION (ADHÉSIVE) MONTANT USA NEGRU FARA LINII DECORATIVE
                    ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE LATERALE DE PROTECTIE COLORATE IN MASA
                    ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE
                    ENJOLIVEUR ROUE (STYLE) STIL FLORIDA 6 FANTE 14 INCI
                    INSONORISATION COTÉ MOTEUR ELEMENT DE IZOLARE FONICA TABLIER PE PARTEA MOTORULUI
                    OBTURATEUR FACE AVANT CU OBTURATOR PANOU FATA
                    PARE-CHOCS BARA DE PROTECTIE CULOAREA CAROSERIEI INCEPAND CU MOD2000
                    PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROIECTOR CU PARABOLA SIMPLA
                    ACCESSOIRES EXTÉRIEURS RETROVIZOR EXTERIOR + MANERE EXTERIOARE NEUTRE
                    TOIT OUVRANT TRAPA DE PLAFON MANUALA SIMPLIFICATA
                    Echipament interior
                    APPUI-TÊTE AVANT TETIERA FATA ARTICULATA
                    ASSISE ARRIÈRE BANCHETA MONOBLOC RABATABILA
                    ALARME INTÉRIEURE FARA ALARMA INTERIOARA
                    CACHE-BAGAGES FARA PANOU DE MASCARE BAGAJE
                    CEINTURE DE SÉCURITÉ ARRIÈRE RETRACTOR CU BLOCARE CENTURA + RAMURA ABDOMINALA STATICA
                    CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA FARA ALARMA
                    CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA RECE
                    CLIMATISEUR AEROTERMA FARA INCALZIRE IN SPATE
                    COMMODITÉS (POIGNÉES) MANERE FATA + SPATE CU INCHIZATOARE
                    CONDITIONNEMENT RADIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA TWEETER
                    CONSOLE CONSOLA FARA INCALZIRE SPATE
                    COMMANDE À DISTANCE FARA COMANDA LA DISTANTA
                    CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
                    EQUIPEMENT PLANCHE DE BORD PANOU CENTRAL NEGRU
                    COMBINÉ (CARACTÉRISTIQUES) FUNDAL DE CADRAN NEGRU
                    HAUT-PARLEUR MONTARE 2 DIFUZOARE FATA + 2 TWEETERE
                    RÉGLAGE ASSISE AVANT CONDUCTEUR SPATAR SCAUN CONDUCATOR CARE SE POATE INCLINA
                    RÉGLAGE ASSISE AVANT PASSAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
                    INDICATEUR DE TEMPÉRATURE EXTÉRIEURE FARA INDICATOR DE TEMPERATURA EXTERIOARA
                    LÈVE-VITRE AVANT CONDUCTEUR MECANISM MANUAL ACTIONARE GEAM CONDUCATOR
                    LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA MANUALA
                    MONTRE CEAS DIGITAL
                    INDICATEUR D’HUILE FARA SENZOR DE NIVEL DE ULEI
                    SAC GONFLABLE LATÉRAL AVANT AIRBAG DUBLU LATERAL FATA
                    RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA INCALZIRE
                    COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA DE USA CU ASPECT NEUTRU
                    RÉCEPTEUR RADIO SISTEM AUDIO CU CASETA RDS "RB1"
                    RÉFRIGÉRATION FARA REFRIGERARE
                    REHAUSSE ASSISE AVANT CONDUCTEUR FARA SISTEM DE INALTARE PERNA SCAUN CONDUCATOR
                    RANGEMENT (AUTRES) COMPARTIMENTE DE DEPOZITARE OBIECTE MARUNTE IN USILE FATA
                    TAPIS MOCHETA TUFTEE RASEE F550
                    TEMPORISATEUR D’ÉCLAIRAGE FARA TEMPORIZATOR
                    CONTACT TRANSPONDER
                    ADAPTATION GARNITURE FARA ADAPTARE GARNITURA
                    COMMANDE VERROUILLAGE FARA INCHIDERE CENTRALIZATA
                    Electricitate
                    ALTERNATEUR ALTERNATOR CLASA 7
                    BATTERIE BATERIE L1 250
                    DÉMARREUR DEMAROR CLASA 1
                    MULTIPLEXAGE FARA MULTIPLEXARE
                    Marci echipamente
                    Diverse
                    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION SERIE SPECIALA GERMANIA
                    JEUX DE CLÉS 2 CHEI PRINCIPALE UNICA
                    ROULAGE DRUM CORECT
                    TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE."
                    • Salut
                      Daca se poate pentru VF32A8HXF43397630
                      • Astea-s:
                        Linie de produs 206
                        Nr. APV/PR 09738 81 2 0502
                        Data de Inceput de Garantie 14.10.2003
                        NRE e2*98/14*0250*02
                        Informatii generale
                        SILHOUETTE BERLINA CU 5 USI
                        FINITION MIDNIGHT
                        COULEUR DE CAISSE KKN - VOPSEA ROSU ADEN
                        TYPE D’HABILLAGE INTÉRIEUR TESATURA NATICE "RT"
                        COULEUR DE GARNISSAGE "FN"
                        MOTEUR (TYPE) EV/DV
                        MONOGRAMME COMPLÉMENTAIRE HDI
                        FINITION MIDNIGHT
                        Alimentare motor
                        DÉTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
                        CARBURANT MOTORINA
                        MOTEUR (TYPE) EV/DV
                        CATALYSEUR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
                        RHÉOSTAT CU REOSTAT
                        AUTODIAGNOSTIC EOBD FARA SISTEM DE AUTODIAGNOSTICARE "EOBD"
                        DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
                        VENTILATEUR 2 VENTILATOARE 2 TURATII 250W
                        PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 175/65 R14 82T NERANFORSAT
                        ANTIBLOCAGE FARA SISTEM ANTIBLOCARE ROATA
                        FREIN PRINCIPAL CU DISPOZITIV DE COMPENSARE CORELATA
                        VARIANTE ASSOCIÉE FREIN FARA ABS
                        ANTENNE ANTENA FATA LUNGA
                        INSONORISATION COTÉ MOTEUR ELEMENTE DE IZOLARE FONICA SUB CAPOTA + TABLIER + SUB GRUPUL MOTOPROPULSOR
                        PARE-CHOCS BARA DE PROTECTIE FATA + SPATE SPORT CULOARE CAROSERIE FARA CENTURA
                        PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
                        ACCESSOIRES EXTÉRIEURS RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI + MANERE EXTERIOARE NEUTRE
                        VITRE CUSTODE (NATURE) FARA GEAM FIX LATERAL SPATE
                        VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
                        Echipament interior
                        APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
                        ASSISE ARRIÈRE BANCHETA SEPARATA RABATABILA
                        CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
                        CLIMATISEUR AEROTERMA CU INCALZIRE SPATE
                        EQUIPEMENT PLANCHE DE BORD PANOU CENTRAL CU PAIETE + BUTON DIFUZOR NEGRU
                        HAUT-PARLEUR MONTARE 2 DIFUZOARE FATA + 2 TWWETERE + 2 DIFUZOARE SPATE
                        RABATTEMENT ASSISE AVANT CONDUCTEUR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
                        RABATTEMENT ASSISE AVANT PASSAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
                        LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
                        MONTRE CEAS DIGITAL
                        SAC GONFLABLE LATÉRAL AVANT FARA AIRBAG LATERAL FATA
                        RHÉOSTAT CU REOSTAT
                        RANGEMENT (AUTRES) COMPARTIMENT DE DEPOZITARE OBIECTE MARUNTE IN USILE FATA + SPATE
                        CONTACT TRANSPONDER
                        Electricitate
                        DÉMARREUR DEMAROR CLASA 5
                        Marci echipamente
                        Diverse
                        CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
                        ROULAGE DRUM CORECT
                        TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE"
                        • Buna.
                          Ma ajuti si pe mine?!
                          VF33H9HZC84092161
                          • Originally posted by vic80vic View Post
                            Buna.
                            VF33H9HZC84092161
                            Salut vic80vic,
                            Mai jos sunt detaliile cerute.
                            Spor si toate cele bune,
                            Radu
                            Caractéristiques du véhicule
                            Ligne de produit 307
                            N°APV/PR 10399 89 2 0473
                            Date de Début de Garantie 31/05/2005
                            NRE e2*2001/116*0287*02
                            Informations générales
                            GENRE DE PRODUIT VEHICULE PARTICULIER
                            LIGNE DE PRODUIT 307
                            SILHOUETTE BREAK LOISIRS
                            FINITION GRAND ANGLE 1
                            MOTEUR DIESEL TURBO DV6TED4 FAP
                            TRANSMISSION BVM5
                            TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
                            COULEUR DE CAISSE EZR - PEINTURE GRIS ALUMINIUM
                            TYPE D’HABILLAGE INTÉRIEUR DRAP SLATTER "GC"
                            BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
                            MOTEUR (TYPE) EV/DV
                            MONOGRAMME SW
                            Caractéristiques véhicule
                            DIRECTION DIRECTION ASSISTEE VARIABLE
                            Alimentation moteur
                            CHAINE DE TRACTION HYBRIDE SANS ALTERNO-DEMARREUR
                            FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
                            BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
                            DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
                            CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE ALUMINIUM
                            CARBURANT GAZOLE
                            DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
                            MOTEUR (TYPE) EV/DV
                            CATALYSEUR CATALYSEUR 2 COMPOSES FILTRES IMPR PLATINE
                            REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
                            RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
                            AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
                            DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
                            DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 4
                            FILTRE À PARTICULE FILTRE A PARTICULES
                            VENTILATEUR 1 VENTILATEUR 2 VITESSES 130WAERO
                            RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUPERATION VAPEUR ESSENCE
                            VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
                            Boîte de vitesses Transmission
                            TRANSMISSION BVM5
                            COUPLE RAPPORT CP 19 X 72
                            STYLE ROUE ROUE COTTYA 16 POUCES
                            TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV BE4/5 L
                            DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
                            PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R16 V NON RENFORCE
                            ROUES MONTÉES ROUE 6 POUCES 1/2
                            ROUE (TYPE) MONTAGE ROUE ALLIAGE
                            BOITE DE VITESSES TYPE BVM BE4R
                            Suspension Direction Freinage
                            PÉDALIER (TYPE) PEDALIER ALU
                            ANTIBLOCAGE ANTI-BLOCAGE ROUE
                            ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 23
                            FREIN TYPE DISQUES AV VENTILES/DISQUES AR
                            SUSPENSION SUSPENSION NORMALE
                            CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
                            VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 0
                            Carrosserie Equipements
                            ATTACHE-REMORQUE SANS ATTACHE REMORQUE
                            AVERTISSEURS AVERTISSEUR STANDARD
                            ANTENNE ANTENNE PAVILLON COURTE
                            ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX COULEUR CAISSE
                            ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX + BAS DE MARCHE
                            ENJOLIVEUR ROUE (STYLE) TYPE APOLLO
                            FEU DE RECUL AVEC 1 FEU RECUL
                            COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
                            ETANCHÉITÉ AÉRODYNAMIQUE SANS JOINT CAPOT AV
                            FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE MANUEL
                            ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT SANS ENJOLIVEUR SORTIE ECHAPPEMENT
                            ESSUIE-VITRE AVANT ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
                            ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
                            ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
                            OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
                            VITRE PAVILLON AVEC VITRE PAVILLON
                            PARE-CHOCS PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
                            PARE-BOUE (BAVETTE) SANS BAVETTES AR
                            PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
                            RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE ELECTRIQUE
                            RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE ELECTRIQUE
                            ROUE DE SECOURS ROUE TOLE REDUITE+PNEU NON STD
                            ACCESSOIRES EXTÉRIEURS POIGN EXT+ENJ VOLET ALU +RETRO EXT C CAISSE
                            LAVE-VITRE ARRIÈRE LAVE VITRE ARRIERE
                            TOIT OUVRANT TOIT FIXE
                            ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
                            VITRE (ASPECT) TEINTEE + SURTEINTEE
                            VITRE CUSTODE (NATURE) VITRE CUSTODE FIXE
                            VITRE (TYPE) P-B FEUILL ACOUST+ LAT & AR TREMPE
                            Equipement intérieur
                            SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
                            ALARME ANTIVOL SANS ALARME ANTIVOL
                            APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
                            APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
                            ASSISE ARRIÈRE 3 SIEGES AR SEPARES (1 COULISSANT)
                            ASSISE SUPPLÉMENTAIRE SANS ASSISE SUPPLEMENTAIRE
                            ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
                            BAGUETTE PLANCHER DE CHARGE AVEC BAGUETTE PLANCHER CHARGE
                            CACHE-BAGAGES AVEC CACHE BAGAGES
                            CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 5 ENROULEURS 3 PTS
                            CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME
                            CLIMAT (TEMPÉRATURE AMBIANTE) PAYS FROIDS
                            GRADUATION VITESSES GRADUATION EN KM/H
                            CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
                            COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
                            CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
                            EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD STANDARD + FACADE ALU VIF ARGENT
                            VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR VOLANT ET SOUFFLET CUIR + POMMEAU ALU
                            HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
                            COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
                            ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
                            REHAUSSE ASSISE AVANT PASSAGER REHAUSSE ASSISE AV PASSAGER REGLAGE PARALLELE
                            RÉGLAGE ASSISE AVANT CONDUCTEUR SANS MAINTIENS LOMBAIRE ET LATERAL CONDUCTEUR
                            RÉGLAGE ASSISE AVANT PASSAGER SANS MAINTIENS LOMBAIRE ET LATERAL PASSAGER
                            RABATTEMENT ASSISE AVANT CONDUCTEUR SANS RABATTEMENT ASSISE AV CONDUCTEUR
                            RABATTEMENT ASSISE AVANT PASSAGER SANS RABATTEMENT ASSISE AV PASSAGER
                            ACCOUDOIR ASSISE AVANT ACCOUDOIRS AVANT CONDUCTEUR ET PASSAGER
                            INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
                            COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
                            BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
                            SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
                            LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE ELECTRIQUE SEQUENTIELLE
                            LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
                            LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
                            AFFICHEUR AFFICHEUR (RADIO+MONTRE,T°,CD)
                            MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
                            INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
                            MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
                            NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
                            SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX + RIDEAU
                            SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
                            LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR + PASSAGERS AV/AR
                            ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
                            PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
                            RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
                            NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
                            COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INT PORTE ASPECT VIF ARGENT
                            PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
                            RANGEMENT (POSTE CONDUITE) SANS RANGEMENT CONSOLE AV PAVILLON
                            RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4"
                            RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
                            RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
                            REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
                            RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT
                            SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
                            RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
                            TUNER-RADIO MONO TUNER RADIO
                            DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
                            ADAPTATION GARNITURE POMMEAU LEVIER VITESSE ALU + SOUFFLET CUIR
                            SURTAPIS AVEC SURTAPIS
                            AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
                            COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
                            VOLANT VOLANT CUIR 3 BRAS
                            Electricité
                            ALTERNATEUR ALTERNATEUR CLASSE 15
                            BATTERIE BATTERIE L3 450
                            DÉMARREUR DEMARREUR CLASSE 6
                            ECLAIREMENT PARTICULIER SANS ECLAIRAGE PARTICULIER
                            MULTIPLEXAGE MONTAGE MULTIPLEXE CAN CAN
                            FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
                            Marques d'équipements
                            Divers
                            CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION QUIKSILVER C
                            ATMOSPHÈRE ATMOSPHERE NORMALE
                            PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES
                            COTÉ CIRCULATION CIRCULATION A DROITE
                            CHOCS LATÉRAUX PORTE NON RENFORCEE
                            JEUX DE CLÉS 1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
                            ADAPTATION PAYS SANS ADAPTATION PAYS
                            EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS
                            ROULAGE BONNE ROUTE
                            SURVEILLANCE VITESSE SANS SURVEILLANCE VITESSE
                            BOÎTIER SERVITUDE BSI COMM 2003
                            • Am si eu nevoie de 2 VIN-uri de pe un 307 cu motor RHS si RHZ.
                              • Salut daca se poate pentru
                                VF38ELFYE80336011
                                si pentru
                                VF38ERFNA81153334
                                Multumesc anticipat
