Astea-s:
"Linie de produs 607 RESTYL
Nr. APV/PR 10831 89 2 0002
Data de Inceput de Garantie 26.07.2006
NRE e2*98/14*0199*12
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
LIGNE DE PRODUIT 607 RESTILIZAT
SILHOUETTE BERLINA 4 USI
FINITION NIVEL 1 ABANOS
MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EXL - VOPSEA NEGRU OBSIDIAN
TYPE D’HABILLAGE INTÉRIEUR VELUR OTELLO + MENPHIS "RL"
COULEUR DE GARNISSAGE "FD"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE FARA MONOGRAMA SUPLIMENTARA
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 1 TURATIE 150W AERO
RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
Cutie de viteze - Transmisie
COUPLE RAPPORT RAPORT PUNTE 16 X 69
STYLE ROUE ROATA ARCTIQUE 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225X50X17 Y
ROUE (TYPE) MONTARE ROATA ALIAJ 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
BOITE DE VITESSES TYPE ML6C
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 24
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 25
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE FARA SUSPENSIE VARIABILA
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
ANTENNE ANTENA + GPS + GSM
ENJOLIVEUR ROUE (STYLE) TIP APOLLO
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) OGLINDA RETROVIZOR EXTERIOR FUMURIE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA RETROVIZOR EXTERIOR CONDUCATOR ASFERICA
TOIT OUVRANT ACOPERIS FIX
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA + IZOLARE FONICA + STRAT REFLECTORIZANT + GEAMURI LATERLAE & SPATE SECURIZATE
Echipament interior
ALARME ANTIVOL PREGATIRE ELECTRICA ALARMA ANTIFURT
ALLUME-CIGARE BRICHETA FATA + SPATE
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 250 KM/H SAU 150 M/H FUNDAL NEGRU
ANCRAGE SIÈGE ENFANT FARA ANCORARE SCAUNE DE COPII CU SISTEM ISO ARD
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
REHAUSSE ASSISE AVANT PASSAGER DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA ELECTRICA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COMPACT DISQUE MONTARE COMPACT DISCURI
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
AFFICHEUR AFISAJ (ECRAN VIDEO 16/9 + RADIO + CEAS,T°,CD)
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAGURI LATERALE ZONA TORACE FATA + SPATE + AIRBAG CORTINA
SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
RÉCEPTEUR RADIO SISTEM RADIOTELEFON "RT3"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
STORES LATÉRAUX FARA TRANSPERANTE LATERALE
APPUI-TÊTE AVANT (FONCTIONNEMENT) TETIERA FATA CU COMANDA ELECTRICA
SURTAPIS FARA COVORAS SUPLIMENTAR
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
PACK MODULARITÉ / ERGONOMIE ASSISE AVANT FARA PACHET MODULARITATE ERGONOMIE PERNA DE SEZUT FATA
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L5 600
DÉMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
REGROUPEMENT ÉQUIPEMENT ECHIPARE CU NUC + MICRO CARBON
CHOCS LATÉRAUX USA CARE NU ESTE INTARITA
ROULAGE DRUM CORECT ".
Informatii generale
Alimentare motor
CARBURANT MOTORINA
Echipament interior
Electricitate
Marci echipamente
Diverse
