VIN (Vehicle Identification Number) - Informatii utile
  • Data inceperii garantiei: 08.11.2000 - care poate sa nu fie chiar data fabricatiei!
    DÉPOLLUTION TECHNIQUE VÉHICUL - DEPOLUARE TEHNICA VEHICUL L3 - dupa cate stiu eu este Euro 2. Si mai scrie:
    DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 95 (MOTOR) - asta nu stiu ce inseamna!!!
    • http://www.peugeotclubromania.ro/for...l=1#post381008
      • VF33E9HZC84910270 - am rugamintea sa-mi spuneti ce gasiti despre aceasta masina.Multumesc anticipat.
        • Caracteristicile vehiculului
          Linie de produs 307 RESTYL
          Nr. APV/PR 11054 89 2 0077
          Data de Inceput de Garantie 07.03.2007
          NRE e2*2001/116*0287*03
          Informatii generale
          GENRE DE PRODUIT VEHICUL PARTICULAR
          MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
          LIGNE DE PRODUIT 307 RESTILIZAT
          SILHOUETTE BREAK 5 USI
          FINITION INALTA MEDIE
          MOTEUR DIESEL TURBO DV6TED4 110 CV FAP
          TRANSMISSION CUTIE DE VITEZE MANUALA5
          TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
          COULEUR DE CAISSE EZW - VOPSEA GRI FER
          TYPE D’HABILLAGE INTÉRIEUR ACCESORIU PLASA TURBINE F931+EFKA F604 "VR"
          COULEUR DE GARNISSAGE "FT"
          BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
          MOTEUR (TYPE) EV/DV
          MONOGRAMME COMPLÉMENTAIRE, DIVERS OXYGO
          MONOGRAMME HDI
          Caracteristici vehicul
          DIRECTION SISTEM DE DIRECTIE VARIABILA ASISTATA
          COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
          Alimentare motor
          DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
          CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI ALUMINIU
          CARBURANT MOTORINA
          DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
          MOTEUR (TYPE) EV/DV
          CATALYSEUR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
          REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
          RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
          AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
          DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
          FILTRE À PARTICULE FILTRU DE PARTICULE
          VENTILATEUR 1 VENTILATOR 2 TURATII 130W AERO
          RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
          VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
          FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
          Cutie de viteze - Transmisie
          COUPLE RAPPORT CP 19 X 72
          STYLE ROUE ROATA ECHINOCTIU 16 INCI
          EMBRAYAGE AMBREIAJ HIDRAULIC
          TYPE DE BOITE DE VITESSES (HOMOLOGATION) CUTIE DE VITEZE TIP BE4/5 L
          DIFFÉRENTIEL (BOITE) DIFERENTIAL 84
          JANTE / PNEU DIMENSION MONTAJ PNEU 16 INCI
          PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R16 V CARE NU ESTE INTARIT
          ROUES MONTÉES ROATA 6 INCI 1/2
          ROUE (TYPE) MONTARE ROATA CU JANTA DIN ALIAJ
          INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
          BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
          BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 30
          ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 23
          REFROIDISSEMENT D’HUILE POMPE DE DIRECTION FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
          SUSPENSION SUSPENSIE NORMALA
          CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
          VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 1
          DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
          PÉDALIER (TYPE) PEDALIER STANDARD
          Caroserie Echipamente
          ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
          AVERTISSEURS SISTEM DE AVERTIZARE ACORD
          ANTENNE ANTENA SCURTA PAVILION
          DÉCORATION (ADHÉSIVE) ORNAMENT SPATE DE USA FATA + ORNAMENT FATA DE USA SPATE
          DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTARE FARA DEFLECTOR SPATE
          ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
          ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE
          ENJOLIVEUR ROUE (STYLE) TIP APOLLO
          FEU DE RECUL CU 1 LUMINA PENTRU MERS INAPOI
          COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
          FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
          ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
          INSONORISATION COTÉ MOTEUR IZOLARE FONICA LA CAPOTA
          ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
          ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
          ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
          OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
          VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
          PARE-CHOCS BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
          PARE-BOUE (BAVETTE) FARA APARATORI DE ROTI SPATE
          PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
          RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
          RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
          ROUE DE SECOURS ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
          ACCESSOIRES EXTÉRIEURS MANER EXTERIOR + ORNAMENT CAPAC + RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI
          LAVE-VITRE ARRIÈRE MECANISM DE SPALARE LUNETA
          TOIT OUVRANT ACOPERIS FIX
          ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
          VITRE (ASPECT) COLORATA
          VITRE CUSTODE (NATURE) GEAM LATERAL SPATE FIX
          VITRE (TYPE) PARBRIZ CU IZOLARE ACUSTICA MAI PUTIN PENTRU SINGAPORE
          Echipament interior
          ALARME ANTIVOL FARA ALARMA ANTIFURT
          APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
          APPUI-TÊTE AVANT TETIERA FATA ARTICULATA
          ASSISE ARRIÈRE BANCHETA SEPARATA RABATABILA
          ASSISE SUPPLÉMENTAIRE FARA PERNA DE SCAUN SUPLIMENTARA
          ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
          BAGUETTE PLANCHER DE CHARGE CU BAGHETA DE PLANSEU DE INCARCARE
          CACHE-BAGAGES CU PANOU DE MASCARE BAGAJE
          CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
          CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
          CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
          GRADUATION VITESSES GRADATIE IN KM/H
          CONDITIONNEMENT RADIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
          COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
          CHAUFFAGE ADDITIONNEL SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
          EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD + FATADA GRI LION
          VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR VOLAN IMBRACAT IN PIELE PERFORATA + MANER MANETA IN PIELE
          RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
          COMBINÉ (CARACTÉRISTIQUES) GRADATIE 250 KM/H 160 M/H FUNDAL ALB CONTUR CROMAT
          HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
          COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
          ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
          REHAUSSE ASSISE AVANT PASSAGER SISTEM DE INALTARE PERNA SCAUN PASAGER FATA REGLARE PARALELA
          COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
          RABATTEMENT ASSISE AVANT CONDUCTEUR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
          RABATTEMENT ASSISE AVANT PASSAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
          ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
          INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATOR TEMPERATURA EXTERIOARA
          COMPACT DISQUE FARA MONTARE COMPACT DISC
          BOITE DE RANGEMENT CU COMPARTIMENT DE DEPOZITARE
          SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
          LAMPES DE PROJECTEURS LAMPA CU HALOGEN
          LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
          LÈVE-VITRE AVANT CONDUCTEUR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
          LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
          AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°, CD) FARA MEMORIE
          MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
          REPOSE-PIED SUPORT SPRIJINIRE PICIOR CONDUCATOR
          INDICATEUR D’HUILE RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
          MONTAGE APPUI-TÊTE ARRIÈRE MONTARE 3 TETIERE SPATE
          NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
          SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
          SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
          LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
          ORDINATEUR DE BORD CU CALCULATOR DE BORD
          PACK ÉQUIPEMENT FARA PACHET ECHIPAMENT
          RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU INCALZIRE
          NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
          COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA USA ASPECT GRI LION
          PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
          PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
          RANGEMENT (POSTE CONDUITE) COMPARTIMENT DE DEPOZITARE IN CONSOLA FATA PAVILION
          RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
          RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
          RÉGULATEUR DE VITESSES FARA SISTEM DE REGULARIZARE VITEZA
          REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
          RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
          SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
          SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
          RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
          TUNER-RADIO CU UN SINGUR TUNER RADIO
          DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
          ADAPTATION GARNITURE MANER LEVIER DE VITEZE + BURDUF PIELE
          SURTAPIS FARA COVORAS SUPLIMENTAR
          AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
          COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
          VOLANT VOLAN IMBRACAT IN PIELE PERFORATA CU 3 BRATE
          PACK RADIO / INFORMATION / COMMUNICATION RD4, FARA SISTEM DE NAVIGATIE, AFISAJ NIVEL B, FARA AMPLIFICATOR EGALIZATOR
          SAC GONFLABLE GENOUX CONDUCTEUR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
          Electricitate
          ALTERNATEUR ALTERNATOR CLASA 15
          BATTERIE BATERIE L2 400
          DÉMARREUR DEMAROR CLASA 5
          ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
          MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
          FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
          Marci echipamente
          Diverse
          ATMOSPHÈRE ATMOSFERA NORMALA
          PRISE D’ÉCOUTE RADIO PRIZA ACCESORII
          COTÉ CIRCULATION CIRCULARE PE DREAPTA
          CHOCS LATÉRAUX USA CARE NU ESTE INTARITA
          JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
          ROULAGE DRUM CORECT
          SURVEILLANCE VITESSE FARA SISTEM DE MONITORIZARE VITEZA
          BOÎTIER SERVITUDE BSI COMM 2005
          Peugeot 307 T6 1.6 HDi 109 CP - no FAP
          • Ma poate ajuta si pe mine cineva ?
            VIN : VF39D3FZB92008861
            • Astea-s:
              " Caracteristicile vehiculului
              Linie de produs 607
              Nr. APV/PR 08632 89 2 0633
              Data de Inceput de Garantie 14.09.2000
              NRE e2*98/14*0199*02
              Informatii generale
              LIGNE DE PRODUIT 607
              SILHOUETTE BERLINA 4 USI
              FINITION LUX INTR-UN SINGUR TON
              MOTEUR INJECTIE EW12J4
              COULEUR DE CAISSE KMP - VOPSEA ALBASTRU DE RODOS
              TYPE D’HABILLAGE INTÉRIEUR PIELE L005 + TEP ARGALI V145 "C9"
              COULEUR DE GARNISSAGE "FL"
              BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML5T
              MOTEUR (TYPE) MOTOR TIP EW/DW
              MONOGRAMME COMPLÉMENTAIRE FARA MONOGRAMA SUPLIMENTARA
              DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
              COUPLE TACHYMÈTRE RAPORT TRANSMISIE 27 X 21
              Alimentare motor
              CARBURANT BENZINA FARA PLUMB RON 95
              DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
              PRÉFILTRE ECHIPARE FARA PREGATIRE PENTRU FILTRU
              CATALYSEUR CATALIZATOR CU 3 COMPUSI
              RÉCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
              DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
              FILTRE À PARTICULE FARA FILTRU DE PARTICULE
              COUPLE RAPPORT RAPORT PUNTE 15 X 67
              STYLE ROUE ROATA ALIAJ MARGUERITE 16 INCI
              ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
              INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
              BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA ML
              ANTIBLOCAGE ANTIBLOCARE ROATA
              BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 25
              ANTIVOL ANTIFURT STANDARD
              COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
              SUSPENSION ACTIVE FARA SUSPENSIE VARIABILA
              VARIANTE ASSOCIÉE FREIN ABS5-3
              ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
              FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
              OBTURATEUR FACE AVANT OBTURATOR BARA DE PROTECTIE FATA LATERAL DREAPTA
              RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETROVIZOR EXTERIOR CONDUCATOR, CU INCALZIRE COMANDA ELECTRICA
              RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETROVIZOR EXTERIOR PASAGER, CU INCALZIRE SI COMANDA ELECTRICA
              ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
              RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) OGLINDA RETROVIZOR EXTERIOR FUMURIE
              RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR DE PE PARTEA CONDUCATORULUI
              TOIT OUVRANT TRAPA DE PLAFON COMANDA ASISTATA SECVENTIALA
              VITRE (TYPE) PARBRIZ + GEAM LATERAL STRATIFICAT GEAM SPATE SECURIZATE MAI PUTIN PENTRU SINGAPORE
              Echipament interior
              ALARME ANTIVOL CU ALARMA ANTIFURT
              ASSISE ARRIÈRE BANCHETA SPATE CU PERNA MONOBLOC SPATARE SEPARATE
              CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA RECE
              COMBINÉ (CARACTÉRISTIQUES) FUNDAL DE CADRAN NEGRU
              COMPTE-TOURS (PRISE INFORMATIONS) TUROMETRU INFO CALCULATOR
              ANCRAGE SIÈGE ENFANT FARA SISTEM DE ANCORARE SCAUNE COPII
              HAUT-PARLEUR DIFUZOARE PE PANOUL MASCARE BAGAJE
              FILTRE À POLLEN CU FILTRU DE POLEN
              ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT SPATE CU COMANDA ELECTRICA
              REHAUSSE ASSISE AVANT PASSAGER DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
              COMMANDE ASSISE AVANT CONDUCTEUR COMANDA SCAUN CU MEMORIE CONDUCATOR
              COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
              RÉGLAGE ASSISE AVANT PASSAGER REGLARE SUPORT LOMBAR PASAGER
              COMPACT DISQUE MONTARE COMPACT DISCURI
              LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE GEAM SPATE SECVENTIAL CU COMANDA ELECTRICA
              AFFICHEUR AFISAJ (RADIO + CEAS, T°,CD)
              FERMETURE VITRE PAR COMMANDE À DISTANCE INCHIDERE GEAMURI CU COMANDA LA DISTANTA
              LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
              RÉCEPTEUR RADIO SISTEM RADIOTELEFON "RT2"
              RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE VITEZA
              REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR REGLAJ PARALEL + INAINTE
              SURTAPIS (ASPECT) CU COVORAS SUPLIMENTAR
              TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT FARA MARTOR LUMINOS PENTRU NIVEL LICHID DE RACIRE
              TÉMOIN D’ANOMALIES ANTIPOLLUTION AVERTIZARE FUNCTIONARE NECORESPUNZATOARE A SISTEMULUI ANTIPOLUARE
              DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE
              STORES LATÉRAUX FARA TRANSPERANTE LATERALE
              APPUI-TÊTE AVANT (FONCTIONNEMENT) TETIERA FATA CU COMANDA ELECTRICA
              SURTAPIS CU COVORAS SUPLIMENTAR
              TYPE GARNISSAGE PORTE ET BRISEMENT CU INSERTIE PIELE
              AMPLI-ÉQUALISEUR CU AMPLIFICATOR EGALIZATOR
              COMMANDE VERROUILLAGE BLOCARE PRIN SUPRA INCHIDERE
              VOLANT VOLAN IMBRACAT IN PIELE NETEDA 4 BRATE
              PACK MODULARITÉ / ERGONOMIE ASSISE AVANT PACHET MODULARITATE/ERGONOMIE PERNA DE SEZUT FATA ERGO 2
              Electricitate
              ALTERNATEUR ALTERNATOR CLASA 12
              DÉMARREUR DEMAROR CLASA 4
              ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
              BATTERIE (SERVICE) FARA BATERIE SERVICE
              Marci echipamente
              Diverse
              CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
              REGROUPEMENT ÉQUIPEMENT ECHIPAMENT BOURGEOIS
              ROULAGE DRUM CORECT."
              • Multumesc !!
                • @YuLee - multumesc frumos
                  La reprezentanta se poate afla cati km reali are masina, dupa VIN? La ce pret ?
                  • Depinde daca vor sa iti spuna in functie de istoricul masinii. Real nu are cum sa iti spuna nimeni, ci doar cu aproximatie.
                    • Daca ar fi fost ''mertzane'' masinile noastre,de mult ca erau vandute(in sensul ca la ei,poti afla cu exactitate din cate am inteles,cati km are masina),in schimb la Pejo,doar daca a facut tot in reprezentanta.
                      • Salut, cine ma poate ajuta cu niste informatii "VF33A9HZC83554719"
                        Multumesc!
                        • Ligne de produit 307
                          N°APV/PR 10011 88 1 0833
                          Date de Début de Garantie 01/07/2004
                          NRE e2*2001/116*0287*00
                          Informations générales
                          GENRE DE PRODUIT VEHICULE PARTICULIER
                          SILHOUETTE BERLINE 3PTES
                          FINITION XS PACK
                          MOTEUR DIESEL TURBO DV6TED4 FAP
                          TRANSMISSION BVM5
                          TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
                          COULEUR DE CAISSE EZA - PEINTURE GRIS SIDOBRE
                          TYPE D’HABILLAGE INTÉRIEUR CHAINE ET TRAME PALASSARI + EKFA "MU"
                          COULEUR DE GARNISSAGE "FX"
                          BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
                          MOTEUR (TYPE) EV/DV
                          MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
                          MONOGRAMME HDI
                          Caractéristiques véhicule
                          FINITION XS PACK
                          DIRECTION DIRECTION ASSISTEE VARIABLE
                          Alimentation moteur
                          DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
                          CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE ALUMINIUM
                          CARBURANT GAZOLE
                          DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
                          MOTEUR (TYPE) EV/DV
                          CATALYSEUR CATALYSEUR 2 COMPOSES FILTRES IMPR PLATINE
                          REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
                          RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
                          AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
                          DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
                          DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 4
                          FILTRE À PARTICULE FILTRE A PARTICULES
                          VENTILATEUR 1 VENTILATEUR 2 VITESSES 130WAERO
                          RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUPERATION VAPEUR ESSENCE
                          VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
                          CHAINE DE TRACTION HYBRIDE SANS ALTERNO-DEMARREUR
                          FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
                          BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
                          Boîte de vitesses Transmission
                          TRANSMISSION BVM5
                          STYLE ROUE ROUE ALLIAGE CHALLENGER 5 AJOURS 17 POUCES
                          TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV BE4/5 L
                          DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
                          PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205X50X17 W
                          ROUES MONTÉES ROUE 6 POUCES 1/2
                          ROUE (TYPE) MONTAGE ROUE ALLIAGE
                          BOITE DE VITESSES TYPE BVM BE4R
                          Suspension Direction Freinage
                          ANTIBLOCAGE ANTI-BLOCAGE ROUE
                          BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 26
                          ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 22
                          FREIN TYPE DISQUES AV VENTILES/DISQUES AR
                          SUSPENSION SUSPENSION NORMALE
                          CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
                          VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 0
                          Carrosserie Equipements
                          ATTACHE-REMORQUE SANS ATTACHE REMORQUE
                          AVERTISSEURS AVERTISSEUR ACCORDE
                          ANTENNE ANTENNE PAVILLON COURTE
                          ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX COULEUR CAISSE
                          ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX
                          ENJOLIVEUR ROUE (STYLE) TYPE APOLLO
                          FEU DE RECUL AVEC 1 FEU RECUL
                          COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
                          ETANCHÉITÉ AÉRODYNAMIQUE SANS JOINT CAPOT AV
                          FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE MANUEL
                          ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT SANS ENJOLIVEUR SORTIE ECHAPPEMENT
                          ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
                          ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
                          ESSUIE-PROJECTEUR ESSUIE-PROJECTEUR
                          OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
                          VITRE PAVILLON SANS VITRE PAVILLON
                          PARE-CHOCS PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
                          PARE-BOUE (BAVETTE) SANS BAVETTES AR
                          PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
                          RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE ELECTRIQUE
                          RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE ELECTRIQUE
                          ACCESSOIRES EXTÉRIEURS POIGN EXT+ENJ VOLET+RETRO EXT C CAISSE
                          LAVE-VITRE ARRIÈRE LAVE VITRE ARRIERE
                          TOIT OUVRANT TOIT FIXE
                          ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
                          VITRE (ASPECT) TEINTEE
                          VITRE CUSTODE (NATURE) VITRE CUSTODE PIVOTANTE
                          VITRE (TYPE) PARE-BRISE ACOUSTIQUE SAUF SINGAPOUR
                          Equipement intérieur
                          ALARME ANTIVOL SANS ALARME ANTIVOL
                          APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
                          APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
                          ASSISE ARRIÈRE BANQUETTE SEPAREE RABATTABLE
                          ASSISE SUPPLÉMENTAIRE SANS ASSISE SUPPLEMENTAIRE
                          ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
                          BAGUETTE PLANCHER DE CHARGE SANS BAGUETTE PLANCHER CHARGE
                          CACHE-BAGAGES AVEC CACHE BAGAGES
                          CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS
                          CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME
                          CLIMAT (TEMPÉRATURE AMBIANTE) PAYS FROIDS
                          GRADUATION VITESSES GRADUATION EN KM/H
                          CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
                          COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
                          CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
                          EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD STANDARD + FACADE ALU VIF ARGENT
                          VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR VOLANT POMMEAU SOUFFLET CUIR
                          HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
                          COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
                          ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
                          REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE ASSISE AV PASSAGER
                          RÉGLAGE ASSISE AVANT CONDUCTEUR SANS MAINTIENS LOMBAIRE ET LATERAL CONDUCTEUR
                          RÉGLAGE ASSISE AVANT PASSAGER SANS MAINTIENS LOMBAIRE ET LATERAL PASSAGER
                          RABATTEMENT ASSISE AVANT CONDUCTEUR AVEC RABATTEMENT ASSISE AV CONDUCTEUR
                          RABATTEMENT ASSISE AVANT PASSAGER AVEC RABATTEMENT ASSISE AV PASSAGER
                          ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
                          INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
                          COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
                          BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
                          SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
                          LÈVE-VITRE ARRIÈRE SANS LEVE VITRE AR
                          LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
                          LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
                          AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
                          MIROIR DE COURTOISIE CONDUCT OCCULT+PASSAG NON OCCULT SANS ECLAIRAGE
                          INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
                          MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
                          NAPPE CHAUFFANTE SIEGE CHAUFFANT
                          SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX + RIDEAU
                          SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
                          LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR + PASSAGER
                          ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
                          PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
                          RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
                          NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
                          COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INT PORTE ASPECT VIF ARGENT
                          PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
                          RANGEMENT (POSTE CONDUITE) SANS RANGEMENT CONSOLE AV PAVILLON
                          RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD3"
                          RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
                          RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
                          REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
                          RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
                          SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
                          RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
                          TUNER-RADIO MONO TUNER RADIO
                          DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
                          ADAPTATION GARNITURE POMMEAU LEVIER VITESSE+SOUFFLET CUIR
                          SURTAPIS SANS SURTAPIS
                          AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
                          COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
                          VOLANT VOLANT CUIR 3 BRAS
                          PACK RADIO / INFORMATION / COMMUNICATION RADIO CD / INFO 2
                          SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
                          Electricité
                          ALTERNATEUR ALTERNATEUR CLASSE 15
                          BATTERIE BATTERIE L2 400
                          DÉMARREUR DEMARREUR CLASSE 5
                          ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
                          MULTIPLEXAGE MONTAGE MULTIPLEXE CAN VAN
                          FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
                          Marques d'équipements
                          Divers
                          CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION LOOK
                          ATMOSPHÈRE ATMOSPHERE NORMALE
                          PRISE D’ÉCOUTE RADIO SANS PRISE ACCESSOIRES
                          COTÉ CIRCULATION CIRCULATION A DROITE
                          CHOCS LATÉRAUX PORTE NON RENFORCEE
                          JEUX DE CLÉS 1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
                          ADAPTATION PAYS SANS ADAPTATION PAYS
                          EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS
                          ROULAGE BONNE ROUTE
                          SURVEILLANCE VITESSE SANS SURVEILLANCE VITESSE
                          BOÎTIER SERVITUDE BSI LIGHT COM 2000
                          Peugeot 308
                          • Pentru Florinn: 1) In Servicebox nu-ti ofera numarul de km ai masinii;
                            2)Informatiile:
                            "Caracteristicile vehiculului
                            Linie de produs 308
                            Nr. APV/PR 11783 89 1 0213
                            Data de Inceput de Garantie 01.03.2009
                            NRE e2*2001/116*0362*10
                            Informatii generale
                            LIGNE DE PRODUIT 308
                            SILHOUETTE BERLINA CU 5 USI
                            FINITION SUPERIOARA INALTA PLUS
                            MOTEUR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
                            TRANSMISSION CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE
                            COULEUR DE CAISSE KTV - VOPSEA NEGRU PERLA NERA
                            TYPE D’HABILLAGE INTÉRIEUR ACCESORIU PLASA + CLAUDIA "XD"
                            BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA MCD
                            MOTEUR (TYPE) MOTOR TIP EV/DV
                            MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
                            Alimentare motor
                            STOP AND START FARA SISTEM STOP AND START
                            CARBURANT MOTORINA
                            CATALYSEUR CATALIZATOR IMPREGNAT SUB 10PPM
                            DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
                            VENTILATEUR 1 VENTILATOR 2 TURATII 140W AERO FARA PRIZA DE AER
                            RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
                            COUPLE RAPPORT RAPORT PUNTE 19 X 71
                            STYLE ROUE ROATA SANTIAGUITO 16 INCI
                            EMBRAYAGE FARA AMBREIAJ
                            DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
                            ROUES MONTÉES ROATA 7 INCI
                            BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA MC
                            BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 27
                            ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22,5
                            CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
                            VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1
                            ANTENNE ANTENA + GPS
                            ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE + TREAPTA
                            FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA
                            PARE-BOUE APARATOARE DE NOROI CU SPUMA
                            INSONORISATION COTÉ MOTEUR ELEMENTE DE IZOLARE SUB CAPOTA MOTOR + TABLIER + PARTE INFERIOARA DE CAROSERIE
                            VITRE PAVILLON CU GEAM DE PAVILION
                            VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
                            PARE-CHOCS BARA DE PROTECTIE FATA STANDARD CULOAREA CAROSERIEI GRILA PT ALUMINIU + SPATE SPOILER CULOAREA CAROSERIEI
                            PLAQUE POLICE FARA PLACUTA DE INMATRICULARE
                            ROUE DE SECOURS ROATA TIP ROLA
                            ACCESSOIRES EXTÉRIEURS MANER EXTERIOR + SUPORT RETROVIZOR + RETROVIZOR CULOARE CAROSERIE
                            VITRE CUSTODE (NATURE) FARA GEAM FIX LATERAL SPATE
                            VITRE (TYPE) PARBRIZ DIN STICLA STRATIFICATA IZOLATA TERMIC + IZOLATA ACUSTIC + SPATE DIN STICLA SECURIZATA
                            Echipament interior
                            SAC GONFLABLE GENOUX CONDUCTEUR AIRBAG ZONA GENUNCHI CONDUCATOR
                            PRIZA AUXILIARA PACK AUDIO FARA PRIZA AUXILIARA PACHET AUDIO
                            CACHE-BAGAGES MASUTA MATISSE
                            CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
                            CONDAMNATION ENFANT SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
                            ECLAIRAGE DE COFFRE VOLUME CHARGEMENT COMANDA AUTOMATA DE ILUMINAT PORTBAGAJ SI VOLUM DE INCARCARE
                            EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD SUPORT NEGRU SAU ALUMINIU PERIAT/MAT
                            FEUX INT. DIVERS LAMPA DE CITIT HARTA + LED FATA + 2 SPOTURI SPATE
                            TABLETTE DE TRAVAIL FARA MASUTA DE LUCRU
                            RANGEMENT SOUS SIÈGE 1 SERTAR DE DEPOZITARE SUB SCAUN
                            COMBINÉ (CARACTÉRISTIQUES) GRADAT 230 KM/H 140 M/H FUNDAL ALB/ALBASTRU CONTUR CROMAT + MATRICE
                            INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 13 KG + SUB SCAUNELE SPATE
                            COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
                            RÉGLAGE ASSISE AVANT CONDUCTEUR SUPORTURI LOMBAR + LATERALE FIXE CONDUCATOR
                            RÉGLAGE ASSISE AVANT PASSAGER SPRIJIN LOMBAR SI LATERALE FIXE SCAUN PASAGER
                            ACCOUDOIR ASSISE AVANT COTIERA CENTRALA PERNA FATA
                            SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
                            LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
                            LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
                            AFFICHEUR AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
                            ACCESSOIRES INT. DIVERS FARA PLASA ANTI-DEPLASARE
                            MATELASSURE COUSSIN MATLASARE PERNA DE SEZUT FATA SPORT
                            COMMANDE INTÉRIEURE DE PORTE (ASPECT) PALETA USA ASPECT CROMAT + ORNAMENT COLORAT
                            PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
                            PARE-SOLEIL AVANT PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
                            RANGEMENT (POSTE CONDUITE) COMPARTIMENT PENTRU OCHELARI
                            RÉCEPTEUR RADIO SISTEM RADIONAVIGATIE CU MEMORIE FLASH "RNEG"
                            RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
                            TUNER-RADIO TUNER DUBLU RADIO
                            DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
                            ADAPTATION GARNITURE MANER MANETA DE VITEZA CU INSERTIE CROMATA
                            VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
                            Electricitate
                            BOITIER TELEMATIQUE FARA MODUL TELEMATIC
                            ECLAIREMENT PARTICULIER LUMINI DE ZI FATA
                            MESURE CHARGE BATTERIE FARA MASURARE NIVEL DE INCARCARE BATERIE
                            Marci echipamente
                            Diverse
                            CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STIMULARE FISCALA DEPOLUARE L5
                            EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
                            BOÎTIER SERVITUDE BSI EVOLUTION".
                            Asta-i !
                            • Ma mai puteti ajuta si pe mine va rog frumos cu caracteristicile acestei masini: VF36D9HZC21127862?
                              Multumesc mult.
                              • Salut @octavianpascu,
                                Gasesti mai jos detaliile cerute.
                                Spor.
                                Caractéristiques du véhicule
                                Ligne de produit 407
                                N°APV/PR 10207 CJ 2 0324
                                Date de Début de Garantie 30/11/2004
                                NRE e2*2001/116*0296*01
                                LIGNE DE PRODUIT 407
                                SILHOUETTE BERLINE 4PTES
                                FINITION AA
                                TRANSMISSION BVM5
                                COULEUR DE CAISSE KQM - PEINTURE VERT INTENSIVE
                                TYPE D’HABILLAGE INTÉRIEUR TRESSE ANDORRE + TISSU SOFIS "RR"
                                MOTEUR (TYPE) MOTEUR TYPE EV/DV
                                FINITION AA
                                DIRECTION DIRECTION ASSISTANCE NON VARIABLE
                                Alimentation moteur
                                CARBURANT GAZOLE
                                VARIATION PUISSANCE (MOTEUR) PUISSANCE STANDARD
                                VENTILATEUR 1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 150W
                                FILTRE RÉSERVOIR SANS FILTRE RESERVOIR
                                BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) BOITIER PAPILLON MOTORISE(ADMISSION AIR MOTEUR)
                                TRANSMISSION BVM5
                                COUPLE RAPPORT CP 17 X 71
                                STYLE ROUE ROUE UNIVERS 16 POUCES
                                EMBRAYAGE EMBRAYAGE HYDRAULIQUE
                                JANTE / PNEU DIMENSION MONTE PNEU 16 POUCES
                                PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205X60X16 H
                                ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
                                INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATEUR PERTE PRESSION GONFLAGE
                                COLONNE DIRECTION COLONNE DE DIRECTION REGLAGE MANUEL
                                ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 24
                                COURSE MÉCANISME DE DIRECTION COURSE MECANISME DIRECTION 184
                                SUSPENSION ACTIVE SANS SUSPENSION VARIABLE
                                DIRECTION (FONCTIONNEMENT) DIRECTION MECANIQUE ASSISTEE
                                ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE + CHROME
                                ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX + BAS DE MARCHE
                                ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
                                FEU D’ÉCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL
                                FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE SANS MEMOIRE
                                ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
                                ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
                                ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
                                ACCESSOIRES EXTÉRIEURS POIGNEES EXT + RETRO EXT COULEUR CAISSE
                                ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE + ENJOL INOX
                                VITRE (ASPECT) VITRE TEINTEE
                                VITRE (TYPE) P-B FEUILL + LAT ET AR TREMPE
                                ACCÈS ET DÉMARRAGE MAINS LIBRES SANS ACCES ET DEMARRAGE MAINS LIBRES
                                ALARME ANTIVOL ALARME VOLUME+PERIMET-STANDARD
                                ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
                                CLIMAT (TEMPÉRATURE AMBIANTE) PAYS TEMPERES
                                CONDAMNATION ENFANT CONDAMNATION ENFANT ELECTRIQUE AR
                                GRADUATION VITESSES GRADUATION EN MPH
                                COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A DROITE
                                CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
                                COMBINÉ (CARACTÉRISTIQUES) GRADUATION 260 KM/H 160 M/H FOND CLAIR
                                GARNISSAGE DE PORTE DECOR GEOMETRIQUE
                                ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORES ARRIERES
                                REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE AVANT
                                COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
                                COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
                                RÉGLAGE ASSISE AVANT PASSAGER REGLAGE LOMBAIRE PASSAGER
                                LAMPES DE PROJECTEURS LAMPE HALOGENE
                                LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
                                MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
                                INDICATEUR D’HUILE RECEPTEUR DOUBLE FONCTION NIVEAU+TEMPERATURE HUILE
                                NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
                                SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX AV + RIDEAU
                                ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
                                PROJECTEUR CORRECTEUR ASSIETTE REGLAGE MANUEL A DISTANCE PROJECTEURS
                                PROJECTEUR DIRECTIONNEL SANS PROJECTEUR DIRECTIONNEL
                                RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4"
                                REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE MANUEL
                                RÉGULATION CLIMATISATION / TEMPÉRATURE REFRIGERATION AUTOMATIQUE BI-ZONE
                                TUNER-RADIO BI TUNER RADIO
                                PROTECTION INTÉRIEURE SANS PROTECTION INTERIEURE
                                STORES LATÉRAUX SANS STORES LATERAUX
                                ADAPTATION GARNITURE POMMEAU LEVIER VITESSE CUIR
                                COMMANDE VERROUILLAGE VERROUILLAGE SUPER CONDAMNATION
                                SAC GONFLABLE GENOUX CONDUCTEUR SAC GONFLABLE GENOUX CONDUCTEUR
                                Electricité
                                Divers
                                ROULAGE BONNE ROUTE
