VIN (Vehicle Identification Number) - Informatii utile
  • 1.Reprezentanta.2.Incearca un pm la ionut159 daca mai poate oferi.
    • Salut.
      De astazi sunt proprietarului unui 307 1.6 hdi diesel 2005.
      Va rog, daca cineva ma poate ajuta cu informatii legate de aceasta masina.
      VIN : VF33C9HXC84430365
      Multumesc.
      • De ce s-a redeschis acest topic daca Ionut nu mai posteaza?
        406 206 C4 508
        • @alynu.Probabil ca a cerut cineva informatii despre un vin pe sectiunea 307 si a fost mutat topicul aici. Eu cred ca nu strica topicul deschis decat sa tot apara topicuri pe tema asta. Ok nu se mai pot oferi informatii despre masini istoricul masinii dar pentru caracteristicile generale cred ca se poate lasa topicul. Din ce vad primul post pe tema asta a fost, descifrarea vinului si aflarea detaliilor despre masina.
          @jturos
          Vehicle characteristics
          Vehicle family 307 RESTYLING
          Build code 10565 88 2 0125
          Warranty Start Date 27/10/2005
          BER e2*2001/116*0301*01
          General information
          PRODUCT TYPE CAR
          COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
          VEHICLE FAMILY 307 RESTYLING
          SILHOUETTE 5 DOOR SALOON
          TRIM LEVEL LOW MEDIUM PLUS
          ENGINE DV6ATED4 TURBO DIESEL
          TRANSMISSION BVM5
          PAINT TYPE NON-METALLIC PAINT
          BODY COLOUR EWP - BANQUISE WHITE PAINT
          INTERIOR TRIM TYPE TRIM DESET "UM"
          UPHOLSTERY COLOUR "FZ"
          GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
          ENGINE (TYPE) EV/DV
          OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
          BADGE HDI
          STEERING VARIABLE POWER STEERING
          SPEEDOMETER DRIVE CT 22 X NO
          Fuel supply-Engine
          DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
          CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
          FUEL DIESEL FUEL
          EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
          ENGINE (TYPE) EV/DV
          CATALYTIC CONVERTER 2-COMPONENT PLATINUM FILTER CATALYSER
          OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
          CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
          EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
          VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
          PARTICLE FILTER WITHOUT PARTICLE FILTER
          FAN 2 FANS , 2 RATES , IMPROVED 130WAERO
          FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
          INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
          TANK FILTER RESERVOIR FILTER INTERIOR
          Gearbox Transmission
          TRANSMISSION BVM5
          FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 72
          WHEEL STYLE 15 INCH STEEL WHEEL
          CLUTCH HYDRAULIC CLUTCH
          GEARBOX TYPE (TYPE APPROVAL) GEARBOX BE4/5 L TYPE
          DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84
          RIM/TYRE SIZE 15 INCH TYRE FITMENT
          TYRE (SIZE, TYPE) 195X65X15 H TYRES
          WHEELS FITTED 6" RIM ROAD WHEELS
          WHEEL (TYPE) STEEL WHEELS
          INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
          GEARBOX TYPE GEARBOX BE4R
          Suspension-Steering-Brakes
          REAR ANTI-ROLL BAR REAR ANTI ROLL BAR DIAM 27
          FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
          POWER STEERING FLUID COOLING SYSTEM WITHOUT POWER STEERING OIL COOLING
          SUSPENSION NORMAL SUSPENSION
          DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
          BRAKE ASSOCIATED VARIANT BOSCH ABS 8 0
          STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
          PEDAL BRACKET (TYPE) PEDAL STANDARD
          Body fittings
          TOWBAR WITHOUT TOWBAR
          HORNS HORN STANDARD
          AERIAL SHORT ROOF AERIAL
          FINISHER (SELF-ADHESIVE) FRONT DOOR REAR TRIM+REAR DOOR FRONT TRIM
          SIDE MOULDINGS (TYPE) LATERAL PROTECTOR MASS TINTED
          SIDE MOULDINGS (DIMENSION) STANDARD LATERAL PROTECTORS
          WHEEL EMBELLISHER (STYLE) COLUMBIA STYLE 8 HOLES 15 INCHES
          REVERSING LAMPS WITH 1 REVERSING LAMP
          ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
          EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
          EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
          ENGINE BAY SOUNDPROOFING BONNET SOUNDPROOFING
          WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
          REAR SCREEN WIPER REAR SCREEN WIPER
          HEADLAMP WIPER W/O HEADLAMP WIPER
          FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
          ROOF GLASS WITHOUT ROOF WINDOW
          BUMPER BODY COLOUR STANDARD FRONT/REAR BUMPER
          MUDFLAP WITHOUT REAR MUDGUARD
          FRONT FOGLAMP NO FRONT FOG LIGHTS
          EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
          EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO
          SPARE WHEEL STEEL WHEEL + STANDARD TYRE
          EXTERIOR ACCESSORIES NEUTRAL EXT HANDLE+FLAP TRIM+EXT RR VIEW MIRROR
          REAR SCREEN WASH REAR SCREEN WASH
          SUN ROOF FIXED ROOF
          BUMPER TRIM DYED BUMPER STRIP
          GLASS (APPEARANCE) TINTED
          REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
          WINDOW (TYPE) ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR
          Interior fittings
          ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
          REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
          FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
          REAR SEAT SEPARATE FOLD BACK BENCH SEAT
          SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
          REAR SEAT ARMREST WITHOUT REAR ARMREST
          LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
          LUGGAGE COVER WITH LUGGAGE COVER
          REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
          FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
          CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
          SPEED GRADUATIONS GRADUATION KMS/H
          RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
          DRIVING POSITION LEFT HAND DRIVE
          ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
          DASHBOARD EQUIPMENT DASHBOARD STANDARD + FACADE GREY LION
          INT. TRIM AND EQUIPMENT VARIATION STANDARD INTERIOR EQUIPMENT DRESSING
          UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
          INSTRUMENT PANEL (CHARACTERISTICS) GRAD 220 KM/H 140 MPH BLACK BACKGND CHROME CIRCLE
          LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
          RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
          SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
          FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
          DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
          DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
          FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
          FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
          EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
          COMPACT DISC WITHOUT COMPACT DISC
          STOWAGE BIN WITHOUT SETTING BOX
          SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
          HEADLAMP BULBS HALOGEN BULB
          REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
          DRIVER’S WINDOW LIFT NON SEQUENTIAL DRIVER’S ELECTRIC WINDOW
          PASSENGER’S WINDOW LIFT NON SEQUENTIAL FRONT PASSENGER’S ELECTRIC WINDOW
          DISPLAY DISPAY (RADIO+CLOCK+AND OR T°, CD) WITHOUT MEMORY
          COURTESY MIRROR DRIVER’S CONCEALABLE+PASS NON CONCEALABLE NO LIGHT
          FOOTREST DRIVER’S FOOTREST
          OIL GAUGE STD OIL LEVEL INDICATOR
          FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
          HEATING ELEMENT NON HEATED SEAT
          FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
          PASSENGER AIRBAG PASSENGER AIRBAG
          ELECTRIC WINDOW (OPERATION) WITHOUT AUTO STOP ELECTRIC WINDOWS
          ON-BOARD COMPUTER COMPUTER
          EQUIPMENT PACK W/O EQUIPMENT PACK
          EXTERIOR REAR VIEW MIRROR (HEATED) NON HEATED DOOR MIRROR
          AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
          INTERIOR DOOR CONTROL (APPEARANCE) BLACK EFFECT INTERIOR DOOR HANDLE
          HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
          FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
          STORAGE (DRIVING POSITION) WITHOUT ROOF FRONT CONSOLE STORAGE
          RADIO RECEIVER "RD4" RDS COMPACT DISC AUDIO SYSTEM
          REFRIGERATION SINGLE AIR CONDITIONING
          CRUISE CONTROL WITHOUT SPEED CONTROL
          DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
          INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
          CARPET COVER W/O CARPETMAT
          DRIVER AIRBAG DRIVERS AIR BAG
          LOAD SPACE STORAGE W/O BOOT TIDY
          TUNER RADIO MONO RADIO TUNER
          OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
          TRIM ADAPTATION GEAR LEVER KNOB CHROME INSERT
          FLOOR MAT W/O CARPETMAT
          EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
          LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
          STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
          RADIO-INFORMATION-COMMUNICATION PACK RD4 NO NAV,LEV BDISP,NO AMPLI-EQUALIZER
          DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
          Electrical
          ALTERNATOR ALTERNATOR 150 AMP
          HORNS HORN STANDARD
          BATTERY BATTERY L2 400
          STARTER MOTOR STARTER MOTOR CL 5
          SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
          MULTIPLEXING MULTIPLEXING ASSEMBLY CAN CAN
          RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
          Component manufacturers
          Miscellaneous
          SPECIAL SPECIFICATION L5 DEPOLLUTION TAX INCENTIVE
          ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
          RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
          TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
          SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
          SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
          SURFACE CONDITIONS GOOD TERRAIN
          SPEED MONITORING WITHOUT SPEED CHECK
          SLAVE CONTROL UNIT BSI COMM 2003
          • @bighi89 multumesc mult.
            • Salut!
              Asta e primul meu post pe siteul felinelor pe 4 roti. Dar va citesc de ceva vreme deja. desi nu-s inca posesoare de leut, m-am inscris deja fiindca as avea nevoie de ajutorul vostru.
              Doresc sa-mi iau un peugeot 308, am vazut unul SH si as vrea sa verific daca are ESP pe el si-n general ce dotari are din fabrica pe el. E un coupe din 2008, 1.6 HDI 66kW 92 CP.
              VIN VF34A9HXC55287437
              Multumesc mult!
              • Nu are esp. Nu stiu ce are de nu imi mai incadreaza totul in tabel. Sper sa intelegi.
                Vehicle family 308
                Build code 11565 88 2 0456
                Warranty Start Date 08/08/2008
                BER e2*2001/116*0362*04
                General information
                PRODUCT TYPE CAR
                VEHICLE FAMILY 308
                SILHOUETTE FIRM 3 DOOR SALOON
                TRANSMISSION BVM5
                BODY COLOUR KTG - HURRICANE GREY PAINT
                INTERIOR TRIM TYPE SIBAYAK CLOTH + OMNI TWO-TONE "TQ"
                UPHOLSTERY COLOUR "FX"
                ENGINE (TYPE) EV/DV
                Fuel supply-Engine
                DIESEL FILTER WATER DETECTOR WITH DIESEL FILTER WATER DETECTOR
                FUEL DIESEL FUEL
                ENGINE (TYPE) EV/DV
                DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
                FAN 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
                TRANSMISSION BVM5
                WHEELS FITTED 6,5" RIM ROAD WHEELS
                REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 28
                FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAMETER 22.5
                BRAKE ASSOCIATED VARIANT 8 1 BOSCH ABS
                Body fittings
                HORNS HORN STANDARD
                REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
                WHEEL EMBELLISHER (STYLE) 15 INCH ATACAMA STYLE
                SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
                SPLASH SHIELD STANDARD MUD GUARD
                ENGINE BAY SOUNDPROOFING UNDERBONNET + BULKHEAD SOUNDPROOFING
                WINDSCREEN WIPER INTERMITTENT WIPER 2 SPEED
                REAR TAILGATE GLASS FIXED TAILGATE WINDOW
                BUMPER FR BUMPER STBC TRIM+BRT CH+REAR STBC
                NUMBER PLATE WITHOUT LICENCE PLATE
                FRONT FOGLAMP FRONT FOG LIGHTS
                EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
                EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
                EXTERIOR ACCESSORIES EXT HANDLE + NEUTRAL MIRROR BASE + MIRROR CC
                EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
                SUN ROOF FIXED ROOF
                REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
                WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
                Interior fittings
                REAR HEAD RESTRAINT WITHOUT REAR HEADREST
                REAR SEAT WITHOUT REAR SEAT POSITION
                LUGGAGE COVER SHELF + LUGGAGE COVER
                REAR SEATBELT WITHOUT REAR SAFETY BELT
                FRONT SEATBELT FR PRETEN INERT REEL + DRIVER FASTENING ALARM
                CHILD LOCK WITHOUT CHILD LOCK
                BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT AND LOAD VOL SWITCH
                DASHBOARD EQUIPMENT FASCIA PANEL BASE WARM SILVER U BLACK
                MISC. INT. LAMPS MAP READING LAMP
                WORK TABLE WITHOUT WORK TABLE
                INSTRUMENT PANEL (CHARACTERISTICS) 230 KM/H 140 MPH GRAD BLACK BACKGND CHROME CIRCLE
                PASSENGER COMPARTMENT SOUNDPROOFING BULKHEAD SOUNDPROOFING 13 KG
                FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
                DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
                FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
                DRIVER’S SEAT FOLDING WITH FOLD DRIV FRONT SEATING
                FRONT PASSENGER SEAT FOLDING WITH FOLD PASS FRONT SEATING
                REAR WINDOW LIFT WITHOUT REAR GLASS LIFT
                TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
                DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
                PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
                MISC. INT. ACCESSORY WITHOUT WINDSTOP
                COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
                CUSHION PADDING STANDARD FRONT SEAT CUSHION PADDING
                FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
                EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
                INTERIOR DOOR CONTROL (APPEARANCE) CHROME EFFECT DOOR HANDLE + COLOURED TRIM
                DIRECTIONAL HEADLAMP WITHOUT DIRECTIONAL LIGHTS
                FRONT SUN VISOR DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION
                STORAGE (DRIVING POSITION) GLASSES CASE
                LATERAL BLINDS WITHOUT SIDE BLINDS
                TRIM ADAPTATION GEAR LEVER KNOB PLASTIC+CHROME INSERT
                AUDIO PACK AUXILIARY SOCKET WITHOUT AUDIO PACK AUXILIARY SOCKET
                Electrical
                HORNS HORN STANDARD
                STARTER MOTOR STARTER MOTOR CL 4
                SPECIAL LIGHTING FRONT DAYTIME LIGHTS
                Miscellaneous
                RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET
                EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
                SLAVE CONTROL UNIT BSI EVOLUTION
                • Salut! Vreau sa-mi achizitionez un peugeot, oscilez intre 307 si 308. Am in vedere deja 2 masinute, diferenta intre ele fiind de 1000 de euro in favoarea lui 307 care e si mai dotat... asa zice proprietarul. Am VIN de la Peugeotu 307: VF33A9HXC84934628.
                  Daca ma poate ajuta cineva cu un listing cu tot ce e pe masina si daca se poate afla unde a fost fabricata ...
                  Stiu ca urmatoarea intrebare e cam offtopic, din ce am citit 307 e mai prost decat 308, dar cat de prost ca sa nu merite achizitionat? Ma intereseaza fiabilitate pe diesel.
                  Multumesc!
                  • Salut,
                    Pentru VIN-ul VF33A9HXC84934628 gasesti detaliile mai jos.
                    Poti afla locatia fabricii unde a fost produsa prin decodarea codului "N°APV/PR 11071 89 1 0416". Gasesti pe forum cum se face.
                    Cat despre celelalte intrebari, las colegii mai priceputi sa-si spuna parerea
                    Toate cele bune,
                    Radu
                    307 RESTYL BERLINE ENTREPRISE 3PTES 1.6 HDi 92 (DV6ATED4) BVM 5
                    Caractéristiques du véhicule
                    Ligne de produit 307 RESTYL
                    Date de Début de Garantie 13/05/2007
                    NRE e2*2001/116*0301*01
                    Informations générales
                    GENRE DE PRODUIT VEHICULE PARTICULIER
                    MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
                    LIGNE DE PRODUIT 307 RESTYL
                    SILHOUETTE BERLINE ENTREPRISE 3PTES
                    FINITION BASSE MOYENNE PLUS
                    MOTEUR DIESEL TURBO DV6ATED4
                    TRANSMISSION BVM5
                    TYPE DE PEINTURE PEINTURE OPAQUE
                    COULEUR DE CAISSE EWP - PEINTURE BLANC BANQUISE
                    TYPE D’HABILLAGE INTÉRIEUR CT STARTING 2 F933+EFKA F604 "WM"
                    COULEUR DE GARNISSAGE "FX"
                    BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
                    MOTEUR (TYPE) EV/DV
                    MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
                    MONOGRAMME HDI
                    Caractéristiques véhicule
                    DIRECTION DIRECTION ASSISTEE VARIABLE
                    COUPLE TACHYMÈTRE CT 22 X NO
                    Alimentation moteur
                    DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
                    CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE ALUMINIUM
                    CARBURANT GAZOLE
                    DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
                    MOTEUR (TYPE) EV/DV
                    CATALYSEUR CATALYSEUR 2 COMPOSES IMPR PLATINE INF 50PPM
                    REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
                    RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
                    AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
                    DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 4
                    FILTRE À PARTICULE SANS FILTRE A PARTICULES
                    VENTILATEUR 1 VENTILATEUR 2 VITESSES 130WAERO
                    RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUPERATION VAPEUR ESSENCE
                    VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
                    FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
                    Boîte de vitesses Transmission
                    TRANSMISSION BVM5
                    COUPLE RAPPORT CP 19 X 72
                    STYLE ROUE ROUE TOLE 15 POUCES
                    EMBRAYAGE EMBRAYAGE HYDRAULIQUE
                    TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV BE4/5 L
                    DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
                    JANTE / PNEU DIMENSION MONTE PNEU 15 POUCES
                    PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195X65X15 H
                    ROUES MONTÉES ROUE 6 POUCES
                    ROUE (TYPE) MONTAGE ROUE TOLE
                    INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
                    BOITE DE VITESSES TYPE BVM BE4R
                    Suspension Direction Freinage
                    BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 27
                    ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 22
                    REFROIDISSEMENT D’HUILE POMPE DE DIRECTION SANS REFROIDISSEMENT HUILE POMPE DIRECTION
                    SUSPENSION SUSPENSION NORMALE
                    CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP
                    VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 1
                    DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
                    PÉDALIER (TYPE) PEDALIER STANDARD
                    Carrosserie Equipements
                    ATTACHE-REMORQUE SANS ATTACHE REMORQUE
                    AVERTISSEURS AVERTISSEUR ACCORDE
                    ANTENNE ANTENNE PAVILLON COURTE
                    DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTAGE SANS DEFLECTEUR AR
                    ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE
                    ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX
                    ENJOLIVEUR ROUE (STYLE) STYLE COLUMBIA 8 AJOURS 15 POUCES
                    FEU DE RECUL AVEC 1 FEU RECUL
                    COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
                    FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE MANUEL
                    ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT SANS ENJOLIVEUR SORTIE ECHAPPEMENT
                    INSONORISATION COTÉ MOTEUR INSONO CAPOT
                    ESSUIE-VITRE AVANT ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
                    ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
                    ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
                    OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
                    VITRE PAVILLON SANS VITRE PAVILLON
                    PARE-CHOCS PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
                    PARE-BOUE (BAVETTE) SANS BAVETTES AR
                    PROJECTEUR ANTIBROUILLARD SANS PROJECTEURS ANTI-BROUILLARD
                    RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE ELECTRIQUE
                    RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE ELECTRIQUE
                    ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
                    ACCESSOIRES EXTÉRIEURS POIGN EXT+ENJ VOLET+RETRO EXT NEUTRES
                    LAVE-VITRE ARRIÈRE LAVE VITRE ARRIERE
                    TOIT OUVRANT TOIT FIXE
                    ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
                    VITRE (ASPECT) TEINTEE
                    VITRE CUSTODE (NATURE) VITRE CUSTODE PIVOTANTE
                    VITRE (TYPE) P-B FEUILL ACOUST+ LAT & AR TREMPE
                    Equipement intérieur
                    ALARME ANTIVOL SANS ALARME ANTIVOL
                    APPUI-TÊTE ARRIÈRE SANS APPUI TETE AR
                    APPUI-TÊTE AVANT APPUI-TETE AV REGLABLE
                    ASSISE ARRIÈRE SANS ASSISE AR
                    ASSISE SUPPLÉMENTAIRE SANS ASSISE SUPPLEMENTAIRE
                    ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
                    BAGUETTE PLANCHER DE CHARGE SANS BAGUETTE PLANCHER CHARGE
                    CACHE-BAGAGES TABLETTE + CACHE BAGAGES + TENDELET
                    CEINTURE DE SÉCURITÉ ARRIÈRE SANS CEINTURE DE SECURITE AR
                    CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME
                    CLIMAT (TEMPÉRATURE AMBIANTE) PAYS TEMPERES
                    GRADUATION VITESSES GRADUATION EN KM/H
                    CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
                    COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
                    CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
                    EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD STANDARD + FACADE GRIS LION
                    VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR HABILLAGE EQUIPEMENT INTERIEUR STANDARD
                    RANGEMENT SOUS SIÈGE SANS RANGEMENT SOUS SIEGE
                    COMBINÉ (CARACTÉRISTIQUES) GRADUATION 220 KM/H 140 M/H FOND NOIR CERCL CHROM
                    HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
                    COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
                    ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
                    REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE ASSISE AV PASSAGER
                    COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
                    RABATTEMENT ASSISE AVANT CONDUCTEUR AVEC RABATTEMENT ASSISE AV CONDUCTEUR
                    RABATTEMENT ASSISE AVANT PASSAGER AVEC RABATTEMENT ASSISE AV PASSAGER
                    ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
                    INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
                    COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
                    BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
                    SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
                    LAMPES DE PROJECTEURS LAMPE HALOGENE
                    LÈVE-VITRE ARRIÈRE SANS LEVE VITRE AR
                    LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
                    LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
                    AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD) SANS MEMOIRE
                    MIROIR DE COURTOISIE CONDUCT OCCULT+PASSAG NON OCCULT SANS ECLAIRAGE
                    REPOSE-PIED REPOSE PIED CONDUCTEUR
                    INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
                    MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE SANS APPUI-TETE AR
                    NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
                    SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX + RIDEAU
                    SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
                    LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR + PASSAGER
                    ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
                    PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
                    RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
                    NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
                    COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INT PORTE ASPECT NOIR
                    PROJECTEUR CORRECTEUR ASSIETTE REGLAGE MANUEL A DISTANCE PROJECTEURS
                    PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
                    RANGEMENT (POSTE CONDUITE) SANS RANGEMENT CONSOLE AV PAVILLON
                    RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4"
                    RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
                    RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
                    REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
                    RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT
                    SURTAPIS (ASPECT) SANS SURTAPIS
                    SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
                    RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
                    TUNER-RADIO MONO TUNER RADIO
                    DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
                    ADAPTATION GARNITURE POMMEAU LEVIER VITESSE INSERT CHROME
                    SURTAPIS SANS SURTAPIS
                    AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
                    COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
                    VOLANT VOLANT MOUSSE 3 BRAS
                    PACK RADIO / INFORMATION / COMMUNICATION RD4,SANS NAV,AFFICH NIV B,SS AMPLI EQUAL
                    SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
                    Electricité
                    ALTERNATEUR ALTERNATEUR CLASSE 15
                    BATTERIE BATTERIE L2 400
                    DÉMARREUR DEMARREUR CLASSE 4
                    ECLAIREMENT PARTICULIER SANS ECLAIRAGE PARTICULIER
                    MULTIPLEXAGE MONTAGE MULTIPLEXE CAN CAN
                    FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
                    Marques d'équipements
                    Divers
                    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION PACK CONFORT
                    ATMOSPHÈRE ATMOSPHERE NORMALE
                    PRISE D’ÉCOUTE RADIO SANS PRISE ACCESSOIRES
                    COTÉ CIRCULATION CIRCULATION A DROITE
                    CHOCS LATÉRAUX PORTE NON RENFORCEE
                    JEUX DE CLÉS 1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
                    ROULAGE BONNE ROUTE
                    SURVEILLANCE VITESSE SANS SURVEILLANCE VITESSE
                    BOÎTIER SERVITUDE BSI COMM 2005
                    • Salut am achizitionat un 107, va rog cateva informatii pentru VIN VF3PNCFAC88209567
                      Multumesc!!!
                      • Salut Alex,
                        Gasesti mai jos detaliile de pe ServiceBox pt VIN VF3PNCFAC88209567:
                        Ligne de produit 107
                        N°APV/PR 11336 UT 1 0259
                        Date de Début de Garantie 08/08/2008
                        NRE e11*2001/116*0237*04
                        LIGNE DE PRODUIT 107
                        SILHOUETTE BERLINE 5PTES
                        FINITION MOYENNE HAUTE
                        MOTEUR INJECTION 384F EURO4
                        TRANSMISSION BVM5
                        TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
                        COULEUR DE CAISSE KNR - PEINTURE BLEU 8M6
                        TYPE D’HABILLAGE INTÉRIEUR TISSU TRANSCODAGE "HI"
                        COULEUR DE GARNISSAGE "FZ"
                        Alimentation moteur
                        CARBURANT ESSENCE SANS PLOMB
                        BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) BOITIER PAPILLON MECANIQUE(ADMISSION AIR MOTEUR)
                        TRANSMISSION BVM5
                        COUPLE RAPPORT CP 20 X 71
                        STYLE ROUE ROUE TOLE 14 POUCES
                        TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV C550
                        PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 155X65X14 T
                        ROUES MONTÉES ROUE 4 POUCES 1/2
                        BOITE DE VITESSES TYPE BVM C550
                        PROTECTION SOUS CAISSE SANS PROTECTION SOUS CAISSE
                        ESSUIE-VITRE AVANT ESSUIE-VITRE AV 2 VITESSES
                        ACCESSOIRES EXTÉRIEURS POIGNEES EXT + RETRO EXT COULEUR CAISSE
                        APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
                        ASSISE ARRIÈRE BANQUETTE AR COUSSIN MONOBLOC DOSSIERS SEPARES
                        CLIMAT (TEMPÉRATURE AMBIANTE) PAYS FROIDS
                        COMPTE-TOURS COMPTE-TOURS A AIGUILLE
                        COMMANDE À DISTANCE MONTAGE CDE A DISTANCE
                        COMMANDE D’AUTORADIO SANS CDE AUTO-RADIO A DISTANCE
                        LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE ELECTRIQUE
                        SAC GONFLABLE LATÉRAL AVANT SANS SAC GONFLABLE LATERAL AV
                        RÉCEPTEUR RADIO CONDITIONNEMENT RADIO
                        RÉFRIGÉRATION REFRIGERATION SIMPLE
                        Electricité
                        ALTERNATEUR ALTERNATEUR CLASSE 8
                        BATTERIE BATTERIE L0 390
                        DÉMARREUR DEMARREUR CLASSE 3
                        Divers
                        CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
                        Toate cele bune,
                        Radu
                        • Cineva a papat posturi din acest topic. Aveam si eu un istoric la masinii in acest topic si nu il mai gasesc.
                          • SALUT.
                            Ma poate ajuta si pe mine cineva cu verificarea a doua masini ?
                            VIN-ul este:Wfonxxgcdn2u26595 - focus
                            Wvwzzz1kz6m799346 - Jetta
                            M-ar interesa nr. km, revizii, etc.
                            multumesc mult!
                            307, 2.0 HDI, 90 CP
                            gropile sunt facute ca sa fie luate :nhl:
                            • Incearca pe forumurile marcilor respective. Aici nu prea cred ca iti va oferi cineva ceva informatii despre ele.
                              • aaa, deci aici doar la marca peugeot se poate afla ?
                                307, 2.0 HDI, 90 CP
