Revizie Peugeot 407
  • MANN-FILTER CUK 2742 - Product Details Activated charcoal filter
    MANN-FILTER FP 2742 nu are carbune activ.
    Sunt aceeasi marime.
    Carbon Cabin Air Filters
    Carbon cabin air filters work very similarly to normal cabin air filters. The only major difference is that, along with the thin layers of paper in the filter, they also contain a thin layer of activated charcoal (carbon) somewhere in filter. Due to its extremely porous nature, activated charcoal has the ability to absorb offensive odors. This is why it is used in many filtration systems for water and air, along with applications such as shoe inserts. In a cabin air filter, the activated charcoal absorbs any offensive odors, making the air that is introduced into the vehicle more pleasant.
    • Primul are carbon activ si totusi al 2 lea e mai scump.
      Care o fi explicatia?
      • Si al doilea are carbon activ.E mai scump pentru ca are ceva in plus.In descrierea lui pe un site am gasit asa:
        FP2742-Filtru carbune activ cu polifenol,cu efect antibacterian,cu efect fungicid,Filtru praf fin(Pm 2.5)
        • Cati litri de ulei se pun intr-un motor de Peugeot 407 1.6 HDI la schimbul de ulei? Am cautat pe forum dar nu am gasit decat la motoarele 2.0 HDI. Multumesc.
          • 3.8lt😉
            Inviato da mTalk
            • Pentru motorul 9HZC - 1,6 litri HDI 16V, manualul zice ca ar intra 3.5L.
              Peugeot 407, 2008, 1.8L / 16V, 125 cp
              • 3.5daca nu schimbi filtru imaginez🤔Oricum....pune 3.5 si dupa ii faci nivelul dupa joja😉daca stai la 3.8 dai o bere😁
                Inviato da mTalk
                • Multumesc.
                  Sent from my iPhone using Tapatalk
                  • Salutare,
                    La mine in SB apare si un cod cu E148139 la filtru de motorina iar la descriere "Filtre gazole PSA".
                    L-am comandat,pretul a fost foarte OK,iar cand mi-a venit pe cutie apare EUROREPAR si codul solicitat.
                    N-am mai auzit de aceasta marca de filtre.Sunt OK?
                    • PSA sa alaturat astora si le furnizeaza materiale de "prima mana"(doar piese de schimb)---echivalentu la alea cu care iese masina pe poarta uzinei insa la un pret net inferior de cca 30%...sursa internet😁
                      Inviato da mTalk
                      • Originally posted by giorgio_24 View Post
                        Inviato da mTalk
                        Salut.
                        Am pus 3,6 litrii de ulei si nivelul arata cam asa:
                        Oare e bine?
                        Intreb asta pentru ca am schimbat ieri uleiul, filtre etc. Am mers ieri cu masina, am pornit-o, am oprit-o etc.
                        Azi dimineata cand am pornit-o, mi-a aparut martorul de motor in bord, "Engine antipollution ceva".
                        Am pornit-o de cateva ori, nimic, aparea eroarea incontinuu.
                        M-am dus si am facut plinul. Am mai pornit-o de doua ori si s-a stins martorul.
                        Ce sa fie oare?
                          Inviato da mTalk
                          Mersi,
                          Ma gandeam si eu ca fiind codurile in SB nu pot fi cele mai proaste.
                          Intre timp mi-au venit si celelalte(ulei,polen,aer) si sunt tot asa.Le schimb saptamana viitoare si revin cu noi informatii.
                          Toate bune,
                          • Originally posted by bogdan_vbm View Post
                            Salut.
                            [ATTACH]91371[/ATTACH]
                            Oare e bine?
                            Ce sa fie oare?
                            Uleiul pare peste nivel🤔cat priveste eroarea nu intra cu uleiul😉 mai degraba ceva pe injectie daca zici ca ai alimentat si a disparut!
                            Inviato da mTalk
                            • La schimbarea fitrului de motorina a fost bine umplut filtrul cel nou inainte de pornire?Eu asa am patit la 206 dupa schimbarea filtrului.S-a grabit un pic baiatul care mi-a schimbat filtrul si a dat doar de cateva ori la pompa de amorsare.La prima cheie a pornit si s-a oprit.Dupa aceea a pornit foarte greu dupa N incercari si martorul motor a ramas aprins.I-am pus a doua zi testerul si aveam o eroare legata de presiunea din rampa.Banuiesc ca din cauza ca a primit aer pompa.Am sters-o si de atunci n-a mai aparut.Ar fi necesar sa-i faci totusi o diagnoza.Chiar daca nu-ti mai apare eroarea a ramas memorata.
                                Inviato da mTalk
                                Asta zic si eu. Uleiul este putin peste nivel. Ideea in sine e ca nu in toate motoarele intra la fel. Probabil sunt mai multe versiuni.
                                In ceea ce priveste eroarea, sigur are legatura cu schimbul de ulei. Nu s-a mai aprins niciodata in 2 ani de zile. E coincidenta prea mare... Dar momentan s-a stins deci e bine.
