Salut! Am langa km un triunghi cu semnul exclamarii in el! E un semn de avertizare pentru ce?
Probleme Peugeot 308
Va salut ! Tyger , triunghiul cu semnul exclamarii in el ( asa scrie la mine in manualul de utilizare , si nu vad de ce la 307 ar fi altfel ) se numeste "Service Warning Light" si poate insemna :
" This is displayed for the following warnings:
- remote control battery flat, ( bateria telecomenzii s-a "fasait" ! )
- engine management system fault. ( sistemul de management al motorului are o buba ! ) - eu am avut asa ceva de la benzina proasta , poate o fi la fel si la tine - motorina "cu purici"
In the first case, replace the remote control battery.
In the second case, contact a PEUGEOT dealer as soon as possible. "
Sper si iti urez sa fie primul caz , ala cu bateria la telecomanda ! Bafta !
Aoleu , am mai gasit semnificatii ( tu n-ai manual de utilizare , ca e mai usor daca te uiti direct ) :
" When this is displayed for the following warnings, contact a PEUGEOT dealer:
- blown bulb,
- low wash-wipe fluid level,
- engine oil level,
- speed control system,
- automatic switching on of the lights system,
- obstacle proximity detection system,
- engine immobiliser system,
- automatic headlamp beam adjustment system fault,
- low diesel additive reservoir level,
- tyre under-inflation detection system fault.
When it is displayed continuously for the following warnings, contact a PEUGEOT dealer as soon as possible:
- tyre under-inflation,
- engine management system fault,
- particle emission filter saturation (Diesel engine),
- one or more doors open at a speed above 6 mph (10 kmh),
- low coolant level,
- brake pad wear. "
Atat !!!
Last edited by Cristi_M.; 17-02-2012, 07:17 PM.Nu uitam! Nu iertam! Ne vom razbuna in viata asta sau in urmatoarele! Noi suntem Europa!
Martor Service
Aprinderea sa indică apariţia unei probleme pe unul dintre sisteme care nu are un martor specific.
Pentru a-l identifica, consultaţi mesajul de pe ecranul multifuncţie.
După verificarea:
- închiderii portierelor, a portbagajului şi a capotei,
- nivelului de ulei motor,
- nivelului lichidului de spălare geamuri,
- bateriei telecomenzii,
- presiunii în pneuri,
- saturării filtrului cu particule (Diesel),
pentru celelalte cazuri, consultaţi un Centru Service PEUGEOT.
Pentru viitoare nelamuriri ai la dispozitie manualul de utilizare online aici
Poate cineva sa-mi spuna si mie cum se scoate fusta aia din imitatie de piele de la schimbatorul de viteze, as vrea sa o scot sa-i iau dimensiunile si sa fac una din piele, caci s-a rupt a doua oara (crapa la frig) mi-au schimbat-o odata in garantie, nu mai tin minte cum au scos-o caci parea complicat avand in vedere ca am cutie cu sase viteze?
@scoty
Daca-mi aduc bine aminte, trebuie sa tragi in sus de rama de plastic ce o inconjoara si iese cu tot cu acel burduf.Vand piese auto originale si aftermarket. Pentru cereri si oferte vezi sectiunea Vanzari Piese, Roti, Accesorii / [Vând] Piese Peugeot originale si producator (aftermarket)
Da , asta stiu , dar cum se scoate maciulia de la schimbator , caci aici este problema , se misca nu mai stiu cum , ca este si inelul de la marche-arierre in calcul !Last edited by Cristi_M.; 22-02-2012, 05:03 PM. Reason: Vezi mai jos ! Maciulia se misca fata-spate , stanga-dreapta si tras in sus !
Am achizitionat un 308 sw 1.6 hdi , 2009 , dar nu imi merge spalarea nici la parbriz , nici la luneta .
Ar fi doua variante , ori e stricat motorasul , ori a pus cineva apa in loc de lichid pt. parbriz si a inghetat . Stie cineva unde se afla motorasul acela ?Last edited by Cristi_M.; 22-02-2012, 05:08 PM. Reason: Atentie la redactare ! De obicei motorasul este chiar langa rezervorul de lichid !207 1.4 hdi 2009 308sw 1.6hdi 2009
Chiar daca stergatoarele merg?
Unde este tabloul de sigurante si care ar fi siguranta pt stergator?Last edited by bobovis; 22-02-2012, 04:46 PM.207 1.4 hdi 2009 308sw 1.6hdi 2009
Va salut ! Scoty , uite aici un topic folositor al colegului GGG ! Ai acolo si schita ansamblului schimbator ! E de la Peugeot 407 , dar cred ca si la 308 este la fel !Last edited by Cristi_M.; 22-02-2012, 08:07 PM.Nu uitam! Nu iertam! Ne vom razbuna in viata asta sau in urmatoarele! Noi suntem Europa!
Motorasul este in vas, vasul este undeva in spatele proiectorului din dreapta, cel putin asa este la 207.
Daca siguranta este arsa, se pune una noua, pentru a dezgheta apa, se completeaza cu apa fierbinte dupa care se treaga apa din vas, cu un furtun mai gros si mai moale. Si tot asa pana il golesti, daca ai posibilitatea sa pui cu un furtun apa fierbinte continuu atunci este si mai bine, daca nu, astepti pana la primavara
Tehnic sau sanitar este acelasi lucru, cel sanitar mai are ceva colorant si arome, in rest acelasi alcool.
