Si greutatea in plus carata permanent? Aia cum se reflecta in consum? Si curentul electric bagat in baterii de unde vine? E 100% din soare si vant si valuri? La ora actuala, cand pretul carburantilor a scazut, nu are nimeni interes sa faca baterii eficiente si de folosinta indelungata. Masina electrica e inca moft ecologist.
sfat achizitie 508
^ Yep! + 1
) Totusi. La o masina cu 120.000 km, uzura bateriei era de doar 5%. Ori... nu e chiar rau, dar tot mi se pare aberant pretul unei baterii vs. consum si/alte beneficii. Cu toate acesta, impozitul e de vreo 0.70 RON cica
)) iar motorul ala electric in 4wd, face ceva minuni, nimic de zis, insa inca e un moft ecologist, cum ai zis tu, Cristi.
Diagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
Code:Caracteristicile vehiculului Linie de produs 508 Nr. APV/PR 12734 CJ 1 0641 Data de Inceput de Garantie 18.03.2013 NRE e2*2007/46*0080*03 Informatii generale GENRE DE PRODUIT VEHICUL PARTICULAR MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT LIGNE DE PRODUIT 508 SILHOUETTE BREAK 5 USI FINITION INALTA JOASA MOTEUR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE TRANSMISSION CUTIE DE VITEZE MANUALA6 TYPE DE PEINTURE METALIZATA LACUITA COULEUR DE CAISSE KDM - VOPSEA CAFENIU INCHIS GUARANJA TYPE D’HABILLAGE INTÉRIEUR TESATURA NERVURON "5L" COULEUR DE GARNISSAGE "FD" BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL MOTEUR (TYPE) MOTOR TIP EW/DW MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA Caracteristici vehicul FINITION INALTA JOASA TYPE DE PEINTURE METALIZATA LACUITA COULEUR DE CAISSE KDM - VOPSEA CAFENIU INCHIS GUARANJA TYPE D’HABILLAGE INTÉRIEUR TESATURA NERVURON "5L" COULEUR DE GARNISSAGE "FD" BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL DIRECTION SISTEM DE DIRECTIE ASISTATA Alimentare motor VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE DELPHI LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR STOP AND START FARA SISTEM STOP AND START MOTEUR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE DÉTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA CARBURANT MOTORINA CALITATE DA/DE/DE+ DÉPOLLUTION (MOTEUR) DEPOLUARE EURO5 (MOTOR) ECHAPPEMENT TOBA DE ESAPAMENT LONGITUDINALA MOTEUR (TYPE) MOTOR TIP EW/DW CYLINDRÉE 2000 CM3 CATALYSEUR CATALIZATOR IMPREGNAT SUB 10PPM REFROIDISSEMENT D’HUILE SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE RÉCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD" DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR" DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO5 FILTRE À PARTICULE FILTRU DE PARTICULE VENTILATEUR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W Cutie de viteze - Transmisie TRANSMISSION CUTIE DE VITEZE MANUALA6 BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL COUPLE RAPPORT RAPORT PUNTE 6 X 65 STYLE ROUE STIL 02 16 INCI EMBRAYAGE AMBREIAJ HIDRAULIC DIFFÉRENTIEL (BOITE) DIFERENTIAL 86 JANTE / PNEU DIMENSION MONTAJ PNEU 16 INCI PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/60 R16 95V NERANFORSAT ROUE (TYPE) MONTARE ROATA ALIAJ 2 INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI BOITE DE VITESSES TYPE ML6C Suspensie - directie - Franare VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1 DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 20 DIRECTION SISTEM DE DIRECTIE ASISTATA ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 23,5 SUSPENSION SUSPENSIE NORMALA CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP Caroserie Echipamente ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE ENJOLIVEMENT LATÉRAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA VITRE PAVILLON CU GEAM DE PAVILION VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ PARE-CHOCS BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA PARE-BOUE (BAVETTE) FARA APARATORI DE ROTI SPATE PORTE-BAGAGES MONTARE CU BARE DE ACOPERIS PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD ACCESSOIRES EXTÉRIEURS MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR TOIT OUVRANT ACOPERIS FIX ENJOLIVEMENT PARE-CHOCS BARA DE PROTECTIE CU INSERTIE CROMATA VITRE (ASPECT) GEAM FUMURIU VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT Echipament interior SAC GONFLABLE GENOUX CONDUCTEUR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR ECRAN VIDÉO ARRIÈRE FARA ECRAN VIDEO IN SPATE PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB BOITIER TELEMATIQUE FARA MODUL TELEMATIC TYPE D’HABILLAGE INTÉRIEUR TESATURA NERVURON "5L" ALARME ANTIVOL FARA ALARMA ANTIFURT ASSISE ARRIÈRE BANCHETA SEPARATA RABATABILA DETECTION ANGLEMORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA RECE GRADUATION VITESSES GRADATIE IN KM/H COMMANDE DE VITESSES COMANDA DE VITEZE LA PODEA COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR EQUIPEMENT PLANCHE DE BORD DECORATIUNE IMITATIE LEMN FEUX INT. DIVERS LAMPA DE CITIT HARTA FATA + SPATE + LED FATA GARNISSAGE VOLUME CHARGEMENT COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA GARNISSAGE DE PORTE DECOR TESATURA HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 4 KG ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA RÉGLAGE ASSISE AVANT CONDUCTEUR SUPORT LOMBAR CU REGLARE CONDUCATOR RÉGLAGE ASSISE AVANT PASSAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE LAMPES DE PROJECTEURS LAMPA CU HALOGEN LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA AFFICHEUR AFISAJ NIVEL C ECRAN MONOCROM MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC INDICATEUR D’HUILE RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA NAPPE CHAUFFANTE SCAUN FARA INCALZIRE SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL RÉCEPTEUR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ TUNER-RADIO TUNER DUBLU RADIO DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE STORES LATÉRAUX FARA TRANSPERANTE LATERALE INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI ADAPTATION GARNITURE MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR FRÉQUENCE RADIO FRECVENTA RADIO ASIA COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE VENTILATEUR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W Electricitate ALLUMAGE FEUX APRINDERE LUMINI MANUALA ALTERNATEUR ALTERNATOR CLASA 18 BATTERIE L3 720 EF DÉMARREUR DEMAROR CLASA 6+ ECLAIREMENT PARTICULIER APRINDERE AUTOMATA + LUMINI DIURNE COMPLET FEUX INT. DIVERS LAMPA DE CITIT HARTA FATA + SPATE + LED FATA FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA LAMPES DE PROJECTEURS LAMPA CU HALOGEN ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL Marci echipamente VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1 VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE DELPHI Diverse CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD ATMOSPHÈRE ATMOSFERA NORMALA COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA ETIQUETTE FARA ETICHETA PRISE D’ÉCOUTE RADIO PRIZA CVADRUPLA DE ACCESORII COTÉ CIRCULATION CIRCULARE PE DREAPTA JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA ROULAGE DRUM CORECT ACCESSOIRES EXTÉRIEURS MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT BOÎTIER SERVITUDE BSI EVOLUTION TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
intrebarea nu e deloc aiurea: bateriile se consuma, pot sa te tina 6-8-10 ani nu se stie exact
din ce am mai citit si eu pe forum si am intrebat la reprez galati: masina nu functioneaza daca bateria e dusa!
pretul pentru baterie noua dat de service: approx 36000 ron(da 360 milioane lei vechi!)
si eu ma uitam dupa un hibrid, dupa ce am aflat ce am scris mai sus m-am linistit instant si am luat una diesel simpla!
deci eu nu pot sa bag mana in foc ca daca se consuma nu merge masina, doar asta mi-a spus cel cu testerul de la reprez.
dar chiar si asa cu bateriile descarcate ce sens are sa cari dupa tine sute de kg in plus??
referitor la mondeo - 508, pretul la mondeo e mult mai mare, la sh, fata de un echivalent 508 asa ca...
