Interfata diagnoza Peugeot
  • Originally posted by zaherr View Post
    Salut!
    Ma ajuta si pe mine cineva cu un soft (Diagbox sau PP200) ? am incercat link-urile postate aici dar nu mai sunt disponibile sau nu au virusi (asa spune antivirusul).
    Mersi!
    Diagbox updates from v8.20 to v8.26
    https://mega.nz/ #!kkNEmbpR!iTkm4OVDfgTDWRjg3c_ -TIWJQnr185jvzN2bML07tlU
    No need password!
    DiagBox from v7.82 to v7.83 (8.19)
    https://mega.nz/ #!IhNFmYrD!GLyERFpKftKAAaHN8mw AzI6p4mqMS9pVSw7EG1gCUM0
    Pass: Very Simple!
    Update DiagBox 7.76 vers 7.82 (8.18) English Version
    https://mega.nz/ #!h9kFlDrZ!DCpvnmCPB_NDm-wFrea 0mGiKDE5giM96-lSXXC1uSIg
    Pass : Maitresox01
    DiagBox software from 7.66 to 7.74 et 7.74 to 7.76
    https://mega.nz/ #!A4UgwKwK!hM_J6qXfB8bvq_P4Pa2 RF1wxneQJENvkT_jfYyw9ta8
    pass : Maitresox pour TLEMCEN TE-100%
    Lexia3 DiagBox from 7.62 to 7.66
    https://mega.nz/ #!15MnEQgR!GZyjMyrkZ1ZmBE_fX4P PM7AVKvSf8IKAbwoJNfkybYU
    pass :@-Maitresox-MHHAUTO
    DiagBox download from 7.58 to 7.62
    https://mega.nz/ #!gwMyzZxZ!A9XJwl8CgyliFjti6kn PhioDzQJPXieUtD1TJRnJG6Y
    DiagBox from 7.57 to 7.58
    https://mega.nz/ #!V8123SrK!w6OE4V15ABi8Ciolou_ zfEKbnPhNw4_ylxH3-yr3rmU
    PSA DiagBox from 7.01 to 7.57
    https://mega.nz/ #!xpdzRATA!uSUYxCEljCMC7z8aDWX b0izjcreCy-MTro80zAMeXxg
    Le instalezi in ordinea inversa fata de lista atasata, adica de la mic la mare.
    Arhivele au parolele atasate mai sus.
    Dupa fiecare update trebuie, de obicei, sa faci restart si sa pornesti aplicatia DiagBox. Abia atunci se va face efectiv update-ul.
    Nu mai tin minte la care update, oricum spre sfarsit-parca (ras)penultimul update, vei avea o eroare la lansarea aplicatiei. Problema se rezolva usor din proprietati->compatibilitate->run as admin pe scurtatura de pe desktop.
    In postul urmator iti trimit si likurile de descarcat aplicatia DiagBox.
    • Ai atasata aplicatia DiagBox vers 7.01 in format ISO intr-o arhiva multivolum. Iti trebuie winrar ca sa o recreezi. Sistemul poate fi Windows 7 pe 32bit.
      Prima data instalezi aplicatia (va dura ceva timp), o deschizi si ar trebui ca sus in dreapta sa iti arate 7.02 (!!!) si abia apoi pui toate update-urile de mai sus.
      Atentie: nu se poate instala decat daca o scrii pe un CD (evident ca imagine ISO) sau o deschizi printr-un program de virtualizare discuri (gen magicdisc, daemontools etc). Nu dezarvhiva imaginea ISO ca nu va functiona!
      Daca o instalezi intr-un sistem de operare virtual (gen Oracle vbox cu Windows 32 bit) trebuie ca drive-ul cu imaginea ISO sa fie montat ca un disc optic (cdrom/dvd) atlfel NU SE INSTALEAZA in virtualbox. Sistemul gazda poate fi si pe 64bit, doar cel virtual sa fie pe 32bit.
      Arhiva multivolum:
      • Buna ziua, se poate instala Diagbox pe tabletya cu win 8.1 32 bit? Si daca da, cum? Eu am incercat si la final cand sa deschida aplicatia, dupa ce introduc codul de validare "scary01" imi spune ca acesta nu este valid si-mi da eroare 0.
        • Ca sa poti sa instalezi DiagBox e musai ca aplicatia sa "vada" suportul de instalare ca un CDROM (virtual sau fizic). Probabil tu ai desfacut imaginea ISO si ai rulat setup de acolo...
          • Buna, am dezarhivat imaginea si am incercat sa o instalez dupa dezarhivare. Dar, dupa mesajul tau, am instalat ultraiso, si am instalat diagboxul conform instructajului pe care l-am primit cand am cumparat diagnoza. Tot degeaba, acelasi mesaj. Se deschide, apare in coltul din dreapta sus 7.01, imi apare mesajul cu activarea, ii dau clic pe activare manuala, introduc "scary01" (fara ghilimele), ii dau ok, astept si imi apare mesajul "actication failed (error 0)".
            • "error 0" e de la windows😉 daca era 11 ,aia e de la patch ul programului!
              Inviato da mTalk
              • Dar wi-fi este activat?
                • Am incercat si cu activa si inactiva si cu wifi oprit. Am citit pe un forum strain ca ar fi probleme de windows, in speta de facut update-uri in special la Net. nu mai stiu cum. Ma stradui sa vad daca iese ceva.
                  • Daca memoria permite....pune Diag ul pe VM cu XP si ai scapat de belele😉
                    Inviato da mTalk
                    • Nu permite. A instalat pe laptop cu win 8.1 dar pe tableta ar fi si mai usor de manevrat.
                      • Dupa instalare...incerca sa dai click dreapta pe icoana,si sa l setezi ca fiind compatibil cu sistemul instalat🤔sau il duci cu updat urile pana la versiunea 8+ si dupa incerci activarea😏
                        Inviato da mTalk
                        • Salut, pot instala PP2000 pe o mașină virtuală daca pe sistemul de operare al laptopului am instalat Diagbox fara să intre in conflict una cu cealaltă?
                          • Bineinteles.
                            • Salutare Salex,
                              Am si eu o intrebare: Care este diferenta dintre vesiunea Diag Box versiunea 7 si versiunea 8?
                              Eu am instalat pe XP Versiune 7.55 (Daca imi aduc aminte bine) iar pe W7 am 8.17. Acestea sint versiunile care sint in coltul din dreapta sus a DiagBoxului
                              La instalarea lui 8.17 am folosit informatia de aici LINK iar versiune 7.55 am primit-o o data cu interfata.
                              Daca ma uit bine 8.17 ar corespunde lui 7.81... Deci care este diferenta intre versiunile 7.XXX si 8.XXX aratate de aplicatie DIagBox in coltul din dreapta sus al ecranului?
                              • Salut,
                                Un raspuns de la o sursa sigura: https://www.cartechnology.co.uk/show...0148#pid190148
