Rezistenta aia este prinsa in cutiuta unde este si releul, pe prima treapta trebuie sa plece cand dai drumul la AC.
Porneste ventilatorul mereu
Si eu l-am cautat dar nu am gasit nimic doar in furtunul care iese pe sus din radiator si intra la motor este un senzor cu niste fire. Din cate am inteles nu are o termocupla cum ma asteptam eu ci are un "captor de temperatura" care citeste temp. si prin soft e programat la o anumita temp. sa porneasca vent. Problema e ca poti prin diagnoza sa vezi daca ai probleme cu asa ceva?
Salut!
Ventilatorul porneste in tr.II-a si sta cca 6-7 minute pornit dupa oprirea motorului in cazul in care se face regenerarea FAP (e o masura de precautie sa nu ia foc motorul ptr. ca temperatura gazelor este f. mare ca sa arda particulele depuse in FAP). After market se poate schimba soft-ul pentru ca ventilatorul sa porneasca in tr.I-a sa nu mai faca asa zgomot. Iata ce am gasit pe net, fiind si eu preocupat de problema ventilatorului care este destul de enervanta:
The engine cooling fan continues to operate after the ignition has been switched off
1.6 HDi, 9HZ with particle filter (FAP).
FINDINGS
The engine cooling fan continues to operate or starts to operate after the ignition has been switched off . the fan may operate, at fast speed, for 10 minutes.
DIAGNOSIS
This function is specific to the 1.6 HDi version equipped with particle filter (FAP) . the rotation of the cooling fan serves to cool the engine compartment if the driver has switched off the ignition while a particle filter regeneration is taking place , whatever the engine temperature.
This rotation time is piloted by the engine ECU and the BSI and can be up to 10 minutes.
AFTER-SALES REMEDY
These operational details should be passed on without delay to all personnel in the New Vehicle Distributor and PSA Authorised Repairer who have contact with customers.
These facts should form part of the information given to the customer when he is taking delivery of his new vehicle.
From RPO 10535 , the fast speed function of the cooling fan is replaced by an increased slow speed operation.
Operating procedure:
Into the ECU, download the "Flash Eprom" software contained in the update CD-ROMs from CD 34.
The "Flash Eprom" software is available on the After-Sales download server.
After downloading , the software reference is 96 589 453 80.
The identification zone of the ECU after downloading is :
Supplier 03
System 2F
Application 01
Version 60
Edition 0400
Labour code 1612 6910.
Invoicing time 0.50 hr.
Eu am facut un drum lung in weekendu asta si apa a stat la 80 de grade(prima linie la stanga de cea de 90 de grade) iar cum mam intors in bucuresti cum a crescut apa la 90 peste.....spre 100, exact cum sa intamplat ultimele dati. Inseamna ca treapta 1 de la ventilator sa fie dusa? Sau cum pot verifica daca releele/sigurantele functioneaza?
Problema cu ventilatorul care porneste dupa oprirea motorului am avut-o de cand am cumparat masina de noua, si cu siguranta toti cei care au filtru de particule se confrunta cu aceasta situatie. Se face regenerarea la FAP, iar daca regenerarea nu se finalizeaza si se opreste motorul este necesar ca FAP-ul sa fie racit. Explicatia de mai sus in limba engleza postata de "Jho" este valabila dupa parerea mea pentru ca mie imi porneste si la 75 de grade pe sistemul de racire ventilatorul.
:shock4: :russianroulette: :rofl2:Originally posted by Johnnyboy View Post.... iar daca regenerarea nu se finalizeaza si se opreste motorul este necesar ca FAP-ul sa fie racit....
Ventilatorul radiatorului raceste esapamentul?
Ventilatorul este actionat independent de functionarea motorului.De ce se porneste ventilatorul dupa oprirea motorului?Deoarece odata oprit va creste temperatura in el ,lichidul de racire nemaicirculand ,lucru sesizat de senzorul de temperatura ce va actiona ventilatorul.Simplu.
Da,@turbojack chiar a zis una buna acum
Si eu am sesizat(ca proaspat posesor de 307) ca ventilatorul porneste foarte des in comparatie cu 206-ele,la 206 pornea doar cand ajungea apa spre 90 de grade in trafic greu si mers bara la bara..la 307 porneste si pe la 80.
Banuiesc totusi ca e un lucru destul de normal,la mai multe marci am auzit sub capota ventilatorul mergand dese ori,fara sa fi fost incinse tare...
De acord, ventilatorul raceste si lichidul de racire al motorului dar nu dupa ce se opreste motorul ci in timpul functionarii acestuia, atunci cand se circula in oras bara la bara cum spune si Taz, cand temperatura lichidului ajunge la 80-90gr.C, neavand debit de aer suficient pentru racire din exterior datorita vitezei mici , iar cu situatia pornirii ventilatorului dupa oprirea motorului se intalnesc cei care au motoarele echipate cu FAP, pentru ca FAP-ul se afla pe esaparea gazelor din motor in dreptul radiatorului de racire, respectiv a ventilatorului, avand loc ce am mai spus in postarea anterioara. Nu sunt mecanic auto dar cel putin la aceasta concluzie am ajuns de cand utilizez masina.
