Display / Martori bord / Mesaje de eroare
  • Display / Martori bord / Mesaje de eroare
    Salut! Ieri dimineata cand am pornit masina mi-a aparut pe bord cand am dat la cheie un bec ca doua sarmulite ondulate una deasupra celeilalte, daca imi aduc bine aminte. Cele 2 sarmulite reprezinta ca au intrat in functiune bujiile incandescente? erau -9 grade. Semnalul luminos nu a persistat dupa ce am pornit masina s-a stins odata cu celelalte. Ce reprezinta semnalul luminos??
    Martorul de la bujiile incandescente e cel din dreapta jos din imagine:
      exact ala mi-a aparut! voua va aparut?
        Da, este normal, mie la 307 imi apare si cand e vara dar cei drept doar pentru 1 sec.
          Cand este frig afara, in special cu mult sub 0 grade, trebuie sa pui contactul si sa astepti ca acel martor sa se stinga. Altfel e posibil sa nu ti-o ia din prima.
            Codul de eroare P0409
            Astazi am avut si eu "placerea" sa primesc un ANTIPOLUTION FAULTY. Investigand mai in detaliu, codul de eroare P0409, am gasit urmatoarele explicatii (poate mai ajuta pe careva):
            Exhaust Gas Recirculation Sensor "A" Circuit
            What does this mean?
            OBD Code P0409refers to
            The optical sensor provides a high resolution signal to the Powertrain Control Module (PCM) by counting pulses on the sensor disk located in the injection pump. The high resolution is one of the most important inputs by the PCM for fuel control and timing. This test monitors the number of high resolution pulses which have been missed (not detected). It's based on a comparison between the number of pulses that were detected since the last pump cam pulse and the number of the pulses that should have occurred. There are approximately 64 high resolution pulses for every cam pulse.
            Possible sumptoms of OBD code P0409
            - Engine Light ON (or Service Engine Soon Warning Light)
            Possible causes of OBD code P0409
            - Open or short in the optical sensor circuit - Optical sensor connector - Damaged optical sensor - Damaged PCM or ECM The Error code is generally activated on detection of the following conditions: Some high resolution pulses are missing from the optical sensor to the PCM
            Possible Solutions
            - If damage, repair optical sensor circuit - Replaced optical sensor - Replaced PCM or ECM
            Momentan nu am identificat unde se afla senzorul asta. Daca nu dau de el, o sa fac o vizita pe la service
            Peugeot 308, 1.6HDI, 109HP
              Sensor "A" Circuit este in capul electrovanei EGR.Se repara prin inlocuire corp EGR.
              Uneori este defect cablajul sau ECU.
                Inca nu am reusit sa ajung la un service, dar dupa 50km pe autostrada cu motorul turat la 3500 - 4000, problema a disparut.
                EDIT:
                Distractia continua. Pe langa P0409, am mai primit si un P0489 (Exhaust Gas Recirculation Control Circuit Low). Se pare ca nu mai scap fara sa schimb EGR-ul.
                w0lfy
                Baby Lion
                  Eroare airbag centura
                  Azi am spalat masina si cand sa plec am pornit fara probleme si dupa vreo 10 secunde o bipaiala si semn cu.un om si airbag sarit in fata si pe cb scrie faulty airbag/seitbelt faulty ceva de genu de 2 ori si atat nu ramane nimic aprins. stiu ca sub scaunul sofer e un senzor.sau siguranta pt.airbaguri o fi atins cel.de.la.spalatorie cu aspiratorul de el?? Help
                    Da , cu siguranta sunt mufele de sub scaune atinse.De verificat.
                      M-am uitat la mufe, nu sunt electrician, am incercat sa le infig mai bine, maine vreau sa le scot pe toate si sa le bag la loc, e o solutie asta?
                        Inainte sa ma apuc sa scot mufele de sub scaun sofer m-am gandit ca ar fi bine sa scot bornele baterie sa nu ma trezesc cu vreun airbag sarit. Stiu ca se reseteaza casetofonul, stiti cumva care este codul? Nu stiu ce sa fac, mor de oftica dintr-o porcarie, si am vrut sa plec de la spalatoria aia si uite am ramas si m-am ales cu beleaua asta, crede-ti ca daca merg la un service si pune un aparat de masura pe mufe isi da seama ce are, sau un tester...help, nu am avut nici o problema cu masina in 2 ani si nu suport sa merg asa cu ea, imi bipaie la 10 secunde dupa ce dau la cheie si apoi nu mai zice nimic...help pls
                          Sa ai grija ca si dupa ce scoti bornele de la baterie airbag-ul se poate declansa (mai exista curent in circuit). Sa lasi 10-15 minute bateria deconectata si abia apoi sa te apuci de treaba.
                          Peugeot 205 XS 1.4l 80CP
                          NAV: DreimGO DG100 PNA
                          ICE: Kenwood KDC-F327
                          DRL: SMD3528 IP65
                            Da, asta am citit ca trebuie sa las masina 15 min neatinsa pana se "scurge" tot curentul din ea apoi ma apuc de treaba!
                              Salut , vezi sa nu fie contactele din mufa oxidate eu cand am spalat masina senzorul de usa deschisa pe stanga (cel de la sofer ) nu mai functiona dar mecanismul mergea . Rezolvare : 1 spray de contacte, data fata de usa jos, scos mufa din broasca, dat cu spray si bagata la loc merge fara probleme . Cazul meu este unul fericit pt ca nu am fost nevoit sa schimb broasca .
                              Acum nu stiu daca si la tine e vreun contact oxidat poate ai noroc si scapi asa . Si inca ceva nu sunt electrician deci nu stiu daca poti sa dai cu ceva pe contactele de la airbag deci mai bine daca e sa ma aprobe cineva care este in domeniu . Te salut
