Regulament sectiune.
[306] Peugeot 306 Sedan D-turbo
  • #46
    Cam asa arata masina acuma. Astept 205-ul Dturbo sa-l studiez atent sa vad daca se pupa 1.8td-ul la prinderi.
    Peugeot 306 D-turbo PH1 XUD7TE - Racecar pe ulei vegetal.
    • #47
      A venit si donatorul. Astept sa intre bani sa ma pot apuca de swap. Daca intereseaza pe cineva restu masinii este de vanzare. Este un 205 d-turbo de la mama lui cu geamuri electrice, trapa mare, inchidere centralizata.
      • #48
        Imi cer scuze ca nu stau sa traduc tot postul insa l-am scris pt cei din Anglia si am pierdut cam jumatate de ora sa-l scriu.
        As i promised some pictures. Sorry for the delay.
        ENGINE BAY
        The fuel filter part from the 1.9 engine
        No more choke senzor + cable because it won't fit.
        Boost gauge
        Damn gearbox linkages + improv
        The Lucas. I hate it. It won't idle. Just hate it. No space to work on the boost compensator as you can see.
        Glory hole. There are some others as well.
        The remaining plugs. Please help me with these and tell me which is the rev counter one. Nr 4 is the cable from the 205 which is from the senzor on the fly wheel.
        Ok. I have some problems. Probably it's my boost gauge probably not. When the engine is cold it reads around 0.8-0.9bars on the clock. When it's hot it goes up only until 0.5-0.6bars. Is it because it's non-intercooled? It has an k14 turbo. Next week will try to put a stock 1.9td tmic if the vacuum pump will give enough room. If not i have the smaller vacuum pump from the 1.9 engine. Will make a vent in the bonnet to improve cooling for the intercooler. After i mount the intercooler will try to built up the boost to around 1.5bars and hopefully set up the Lucas as well. Again, i hate this pump.
        Oh yeah. I forgot. Bought new signal indicators and mounted a sport air filter.
        • #49
          N-am mai scris de mult pe aici.
          4.jpg2.jpg285243_251401338218624_100000462782011_1069184_4980893_n.jpgPicture 002.jpg
          Motorul a primit un intercooler de 1.9td top mount. Odata cu instalarea intercoolerului s-a marit si presiunea in turbina (de la 0.8 la 1.5 si 1.7 in overboost pe a5-a) si debit de motorina pe masura. Furtunul de la turbo la intercooler a pleznit pe drum spre casa la 160km/h. M-am speriat un pic insa am reusit sa ajung din Sibiu acasa cu furtunul crapat. Am schimbat furtunul cu altul care din pacate a fost pe un diametru mai mic. K14-le nu a rezistat prea mult iar acu 1 saptamana si-a dat duhul.
          Am achizitionat 2 turbine. Un T2 (de pe un 1.9td) si un T25 de pe un BMW 325 TDS. Am facut un hibrid din cele 2 cu partea calda de T2 (ca sa nu mai fac flansa pentru evacuare) si partea rece de T25. Este o diferenta semnificativa chiar si intre K14-T2 iar intre K14 si T25 nu mai vorbesc. Ca sa elemin toate eventualele cauze care ar putea defecta turbina o sa-mi cumpar un intercooler mai are care il voi monta frontal cu traseu din inox pe 60. Evacuarea este si ea gata. Am optat pentru eliminarea tuturor tobelor cu teava diametru 55 si iesire la prag usa stanga spate.
          Urmeaza sa achizitonez o pompa Bosch de motorina cu cap hidraulic 9-10mm. Lucasu actual cu cap de 8mm nu prea face fata peste 4000 rpm. Alta problema care s-ar putea sa mai apara va fi garnitura de chiuloasa care la 1.8 nu este si nici nu se gaseste de cumparat metalica. Voi fi nevoit sa fac pe comanda una, cand va plezni acuala.
          Mai am de schimbat bucsile la puntea spate pentru ca troncanitul imi sta de foarte mult timp pe creier. Sistemul de franare de asemenea trebe imbunatatit. Am vandut jantele albe pe 15'' iar acuma merg cu jante pe 13'' cu gume aproape noi 185/60. Demarajul este bun cu jantele astea insa pierd foarte mult la viteza de top.
          Sper ca luna viitoare sa termin si eu masina. Finantele nu prea ma ajuta dar ma descurc eu cumva.
          • #50
            Sincere felicitari pt ce ai facut. Nu stiu cati s-ar fi bagat la asta dupa ce a plesnit motorul.
            Low is a lifestyle.
            • #51
              Mersi.
              E un swap mai special pentru ca toti ar fi pus 1.9td. Eu tinand cont ca am luat 205-ul foarte ieftin m-am multumit cu 1.8. Este un motor foarte bun insa multi prefera sa plece cu 90 de cai de fabrica si de aceea prefera 1.9td care oricum s-a pus de fabrica pe 306. Eu cu modificarile mai sus mentionate sper catre un 150cp+, plecand de la 78.
              • #52
                Faorte tare evolutia masini !Te felicit !
                Un sfat sincer ,lasa proiectorul ala acolo,o face unica ! E prima masina la care vad un singur proiector ,imi place la nebunie ideea !!!!
                • #53
                  Mersi. Il las pentru ca si mie imi place Din pacate este deja al 2-lea si e spart si asta, datorita drumurilor noastre frumoase si curate... Dar punem altu nu-i problema
                  ps. Numarul pus la loc in fata (m-au oprit de cateva ori), semnalizari noi, evacuarea si priza pentru intercooler care in curand va avea efect doar sa scoata caldura de la motor...
                  • #54
                    N-am mai scris de ceva timp pe aici...
                    Masina e cam la fel cu putine modificari. Tot neagra dar lucioasa. Acelas 1.8TD pe ea. M-am cam plictisit sa mai bag bani in ea dar asta e... S-a rezovat tablaria, dupa care s-a vopsit. Praguri originale si bara modelul sport pentru care o sa trebuiasca niste proiectoare. Punte schimbata si coborata (tipic...) Pompa de 1.9td modificata, garnituri noi, cap hidraulic nou, lda pin modificat. Cutie de 1.9td (putin mai lunga decat cea de 1.8). Turbina este un k14 care merge la presiune stock deocamdata. Jante am ceva speedline-uri cu gume noi pirelli cinturato p6 doar ca trebe inca un set de distantiere pt spate (et 37 mdea...), volan sport (urmeaza sa-l schimb cu unu omp rally)... + multe altele.
                    Las pozele sa vorbeasca.
                    • #55
                      Frumos!!!
                      406 206 C4 508
                      • #56
                        Multumesc. Mai sunt multe de facut. Prea multe chiar.
                        • #57
                          Cand incepi , nu se mai termina niciodata
                          • #58
                            O am de 3 ani. A trecut prin diferite etape atat estetic cat si tehnic. Nu ma voi opri aici.
                            • #59
                              Tocmai d`asta zic...mereu se gaseste cate ceva
                              • #60
                                Cam asa suna masina la ora actuala.
                                http://www.youtube.com/watch?v=6m1L2GaptWg
