VIN (Vehicle Identification Number) - Informatii utile
Salutare. Ma poate ajuta cineva cu un istoric de km, sau revizii pt un Ford Focus? VIN: wfolxxgcblca48335
Multumesc anticipat
Leave a comment:
Originally posted by lucianian View PostVa salut.
Daca se poate o decodare pt VIN: VF38DRHF8BL022101
Multumesc
Caracteristicile vehiculului
Linie de produs 508
Nr. APV/PR 12551 CJ 1 0731
Data de Inceput de Garantie 02.08.2011
NRE e2*2007/46*0080*00
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
LINIE DE PRODUS 508
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE INALTA JOASA
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
MOTOR (TIP) MOTOR TIP EW/DW
Caracteristici vehicul
DIRECTIE SISTEM DE DIRECTIE ASISTATA
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA CALITATE DA/DE/DE+
DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze - Transmisie
CUPLU RAPORT RAPORT PUNTE 6 X 65
STIL ROATA (JANTA) STIL 09 17 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
ROATA (TIP) MONTARE ROATA ALIAJ 3
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP ML6C
Suspensie - directie - Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
LUMINA DE PRAG LUMINI DE PRAG FATA
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
SCAUN SPATE BANCHETA SEPARATA RABATABILA
DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GRADARE VITEZE GRADATIE IN KM/H
COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
CAPITONAJ DE USA DECOR TESATURA
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
BECURI DE PROIECTOR LAMPA CU HALOGEN
ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
RECEPTOR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO ARABIA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
MODUL TELEMATIC FARA MODUL TELEMATIC
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE L3 720 EF
DEMAROR DEMAROR CLASA 6+
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA ETICHETA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
Leave a comment:
Va salut.
Multumesc
Leave a comment:
Originally posted by ili85 View PostSalut,daca ma poate ajuta cineva cu o decodare vin,multumesc anticipat! vin: VF33E9HYB84050868.
Linie de produs 307
Nr. APV/PR 10368 89 1 0795
Data de Inceput de Garantie 06.05.2005
NRE e2*2001/116*0299*01
Informatii generale
LINIE DE PRODUS 307
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE XR
MOTOR DIESEL TURBO DV6TED4 FARA FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA5
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EZA - VOPSEA GRI SIDOBRE
TIP ECHIPARE INTERIOARA TESATURA NATICE "UR"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
MONOGRAMA HDI
DIRECTIE SISTEM DE DIRECTIE VARIABILA ASISTATA
Alimentare motor
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
LANT DE TRACTIUNE HIBRIDA FARA ALTERNATOR DEMAROR
MODUL CLAPETA (ADMISIE AER MOTOR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE CEE 2000 (MOTOR)
CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL L4
FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 2 TURATII 130W AERO
RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
CUPLU RAPORT CP 19 X 72
STIL ROATA (JANTA) ROATA DIN TABLA 15 INCI
TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP BE4/5 L
DIFERENTIAL (CUTIE) DIFERENTIAL 84
PNEURI (DIMENSIUNI, TIP) PNEU 195X65X15 H
ROTI MONTATE ROATA 6 INCI
ROATA (TIP) MONTARE ROATA CU JANTA DIN TABLA
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
VARIANTA ASOCIATA FRANA ABS BOSCH 8 0
PEDALIER (TIP) PEDALIER STANDARD
ANTIBLOCARE ANTIBLOCARE ROATA
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 27
FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
CONTROL DINAMIC AL STABILITATII FARA SISTEM ESP
AVERTIZOARE SISTEM DE AVERTIZARE STANDARD
ANTENA ANTENA SCURTA PAVILION
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE
ORNAMENT DE ROATA (STIL) STIL COLUMBIA 6 FANTE 15 INCI
LUMINA DE MERS INAPOI CU 1 LUMINA PENTRU MERS INAPOI
ETANSEITATE AERODINAMICA FARA GARNITURA DE CAPOTA MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
BARA DE PROTECTIE BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
RETROVIZOR EXTERIOR (PARTEA CONDUCATORULUI) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
RETROVIZOR EXTERIOR (PARTEA PASAGERULUI) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
ACCESORII EXTERIOARE MANER EXTERIOR + ORNAMENT CAPAC + RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI
SPALARE LUNETA MECANISM DE SPALARE LUNETA
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
GEAM (ASPECT) COLORATA
GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + GEAMURI LATERALE & SPATE SECURIT
Echipament interior
TETIERA SPATE TETIERA SPATE REGLABILA
TETIERA FATA TETIERA FATA REGLABILA
SCAUN SUPLIMENTAR FARA PERNA DE SCAUN SUPLIMENTARA
COTIERA DE SCAUN SPATE FARA COTIERA SPATE
BAGHETA PLANSEU DE INCARCARE CU BAGHETA DE PLANSEU DE INCARCARE
MASCARE BAGAJE CU PANOU DE MASCARE BAGAJE
CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
AMBALARE SISTEM AUDIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + FATADA ALUMINIU ARGINT VIU
VARIATIE DE ECHIPARE INTERIOARA ECHIPARE INTERIOARA STANDARD
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR FARA SUPORTURI LOMBARE SI LATERALE CONDUCATOR
REGLARE SCAUN FATA DE PASAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATERE SCAUN FATA DE CONDUCATOR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
COTIERA DE SCAUN FATA MONTARE FARA COTIERA FATA
INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
CD FARA MONTARE COMPACT DISC
CASETA DE DEPOZITARE CU COMPARTIMENT DE DEPOZITARE
ACTIONARE GEAM SPATE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
ACTIONARE GEAM DE CONDUCATOR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
AFISAJ AFISAJ (RADIO + CEAS + SI SAU T°, CD) FARA MEMORIE
OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR CU CAPAC + OGLINDA PARASOLAR PASAGER FARA CAPAC PARA LUMINA
INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
CALCULATOR DE BORD CU CALCULATOR DE BORD
PACHET ECHIPAMENT FARA PACHET ECHIPAMENT
RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
COMANDA INTERIOARA DE USA (ASPECT) COMANDA INTERIOARA USA ASPECT ARGINT VIU
PROTECTIE POST FATA FARA PROTECTIE POST FATA
DEPOZITARE (POST DE CONDUCERE) FARA COMPARTIMENT DE DEPOZITARE IN CONSOLA FATA DE PAVILION
RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
REFRIGERARE SISTEM DE REFRIGERARE SIMPLA
INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
TUNER-RADIO CU UN SINGUR TUNER RADIO
DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
ADAPTARE GARNITURA MANER MANETA DE VITEZA CU INSERTIE CROMATA
COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT CU SPUMA CU 3 BRATE
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L2 400
DEMAROR DEMAROR CLASA 5
ILUMINAT DEOSEBIT FARA ILUMINAT SPECIAL
MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE LCDV CREAT PENTRU INITIALIZAREA VERSIUNII 16
CONECTOR DE ASCULTARE SISTEM AUDIO FARA PRIZA PENTRU ACCESORII
SOC LATERAL USA CARE NU ESTE INTARITA
ADAPTARE TARA FARA ADAPTARE DE TARA
RULARE DRUM CORECT
MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI COMM 2003
Leave a comment:
Leave a comment:
Originally posted by nutu View PostSalut, rog pe un coleg sa îmi decodeze un vin. Mulțumesc.
Vf3wb9hzc33852671
Linie de produs 207
Nr. APV/PR 11127 82 1 0135
Data de Inceput de Garantie 18.06.2007
NRE e2*2001/116*0340*06
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
LIGNE DE PRODUIT 207
SILHOUETTE COUPE CABRIOLETA 2 USI
FINITION COUPE CABRIOLET SPORT 2
MOTEUR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE KTH - VOPSEA GRI THORIUM
TYPE D’HABILLAGE INTÉRIEUR ACCESORIU PLASA PAYERNE + OMNI "SJ"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
MOTEUR (TYPE) MOTOR TIP DV
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME FARA MONOGRAMA
COUPLE TACHYMÈTRE FARA C T
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
CATALYSEUR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR CU 2 TURATII 140W AERO CU PALETA
RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
FILTRE RÉSERVOIR FARA FILTRU REZERVOR
COUPLE RAPPORT CP 19 X 72
STYLE ROUE ROATA HOCKENHEIM 17 INCI
DIFFÉRENTIEL (BOITE) DIFERENTIAL 84
JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/45 R17 88W RANFORSAT
ROUES MONTÉES ROATA 7 INCI
ROUE (TYPE) MONTARE ROATA CU JANTA DIN ALIAJ
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
ANTIBLOCAGE ANTIBLOCARE ROATA
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22
FREIN TYPE DISCURI FATA VENTILATE / DISCURI SPATE
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 144
SUSPENSION SUSPENSIE NORMALA
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
VARIANTE ASSOCIÉE FREIN ABS TEVES MK60 O
PÉDALIER (TYPE) PEDALIER ALUMINIU
AVERTISSEURS SISTEM DE AVERTIZARE STANDARD
ANTENNE ANTENA INTEGRATA
TOIT OUVRANT (ASPECT) FARA TRAPA DE PLAFON
DÉCORATION (ADHÉSIVE) FARA DECORATIUNE ADEZIVA
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTARE FARA DEFLECTOR SPATE
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATÉRAL (DIMENSION) TREAPTA CULOARE ALUMINIU
ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
PROTECTION SOUS CAISSE ELEMENT DE PROTECTIE DIN MATERIAL PLASTIC + ELEMENT DIN SPUMA SUB MOTOR
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT CU ORNAMENT LA IESIRE ESAPAMENT
INSONORISATION COTÉ MOTEUR ELEMENT DE IZOLARE CAPOTA + ELEMENT DE PROTECTIE TERMICA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
ESSUIE-VITRE ARRIÈRE (FONCTIONNEMENT) FARA MECANISM DE STERGERE LUNETA
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
SONDE TEMPÉRATURE EXTÉRIEURE CU SONDA DE TEMPERATURA EXTERIOARA
PARE-CHOCS BARA DE PROTECTIE FATA/SPATE SPORT ALUMINIU/CULOARE CAROSERIE
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROIECTOR CU PARABOLA DUBLA
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
ROUE DE SECOURS ROATA TIP ROLA
ACCESSOIRES EXTÉRIEURS MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TOIT OUVRANT TRAPA DE PLAFON ESCAMOTABILA
ENJOLIVEMENT PARE-CHOCS BARA DE PROTECTIE FARA BANDOU
VITRE (ASPECT) FUMURIU + FUMURIU INCHIS
VITRE CUSTODE (NATURE) GEAM LATERAL SPATE CARE POATE COBORI
VITRE (TYPE) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
APPUI-TÊTE ARRIÈRE FARA TETIERA SPATE
APPUI-TÊTE AVANT TETIERA FATA ARTICULATA
ASSISE ARRIÈRE BANCHETA SPATE PERNA MONOBLOC SPATARE SEPARATE CARE NU SE RABATEAZA
CACHE-BAGAGES FARA PANOU DE MASCARE BAGAJE
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 2 RETRACTOARE 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CEINTURE DE SÉCURITÉ AVANT ALARMA CUPLARE CENTURA CONDUCATOR + PASAGER
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA TEMPERATA
CONDAMNATION ENFANT FARA SISTEM DE BLOCARE USA PENTRU COPIL
GRADUATION VITESSES GRADATIE IN KM/H
COMMODITÉS (POIGNÉES) FARA MANERE
CONDITIONNEMENT RADIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
COMMANDE À DISTANCE MONTAJ COMANDA LA DISTANTA
ECLAIRAGE RANGEMENT ILUMINAT TORPEDOU
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD SOFT CU DECORATIUNE GRINIUM
FEUX INT. DIVERS LAMPA DE CITIT HARTA
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 220 KM/H 140 M/H FUNDAL ALB CU CHENAR CROMAT
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 5KG + PERETE PROTECTIE POST + PERETE DESPARTITOR DINTRE HABITACLU SI COMPARTIMENT MOTOR + PEDALIER
REHAUSSE ASSISE AVANT PASSAGER SISTEM DE INALTARE PERNA SCAUN PASAGER FATA REGLARE PARALELA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RÉGLAGE ASSISE AVANT CONDUCTEUR SUSTINERE LATERALA FIXA CONDUCATOR
RÉGLAGE ASSISE AVANT PASSAGER SUPORT DE SUSTINERE LATERALA FIXA PENTRU PASAGER
ACCOUDOIR ASSISE AVANT MONTARE FARA COTIERA FATA
CONSOLE PLAFOND FARA CONSOLA PLAFON
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE GEAM SPATE CU COMANDA ELECTRICA
LÈVE-VITRE AVANT CONDUCTEUR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE FARA TETIERE SPATE
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG DUBLU LATERAL FATA
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
ORDINATEUR DE BORD CU CALCULATOR DE BORD
PACK ÉQUIPEMENT FARA PACHET ECHIPAMENT
RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA USA ASPECT CROMAT
PLAFONNIER COMANDA LA DISTANTA A USILOR + PLAFONIEREI FATA
PROJECTEUR DIRECTIONNEL CU PROIECTOR DIRECTIONAL
PROTECTION POSTE AVANT FARA GRILA DE SEPARARE
RANGEMENT (POSTE CONDUITE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE INCHIS CU CHEIE + REFRIGERAT
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RANGEMENT (AUTRES) BUZUNARE PENTRU HARTA PE SPATARELE SCAUNELOR FATA
SURTAPIS (ASPECT) COVORAS SUPLIMENTAR MOCHETA 1
SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
PROTECTION INTÉRIEURE FARA PROTECTIE INTERIOARA
INDICATEUR DE TEMPÉRATURE EXTÉRIEURE (GRADUATION) INDICATOR TEMPERATURA EXTERIOARA CELSIUS
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
ADAPTATION GARNITURE MANER MANETA DE VITEZE ALUMINIU + BURDUF PIELE
SURTAPIS CU COVORAS SUPLIMENTAR
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VERROUILLAGE RANGEMENT COMPARTIMENTE DEPOZITARE OBIECTE MARUNTE CU SISTEM DE INCUIERE
PACK AMBIANCE PACHET AMBIANTA FATA
SAC GONFLABLE GENOUX CONDUCTEUR AIRBAG ZONA GENUNCHI CONDUCATOR
PRIZA AUXILIARA PACK AUDIO FARA PRIZA AUXILIARA PACHET AUDIO
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE BATERIE L2 640
DÉMARREUR DEMAROR CLASA 5
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
PRISE D’ÉCOUTE RADIO FARA PRIZA PENTRU ACCESORII
COTÉ CIRCULATION CIRCULARE PE DREAPTA
JEUX DE CLÉS 2 CHEI TELECOMANDA DE INALTA FRECVENTA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
SURVEILLANCE VITESSE FARA SISTEM DE MONITORIZARE VITEZA
BOÎTIER SERVITUDE BSI + COM 2005 INEL CU 4 POZITII
Leave a comment:
Vf3wb9hzc33852671
Leave a comment:
Multumesc,dar mai doresc si codul oem ,garret si renault pentru turbina.
Cu stima.
Gigi.
Leave a comment:
Motor 2.0 Turbo Diesel cu FAP - Cod motor: RHT ; Tip motor: DW10ATED4 ; Cutie de viteze manuala in 5 trepte - model ML5C ; Cod CV: 20LM05 (mai poti gasi si notatiile 20LM24 sau 20LMB4, care reprezinta acelasi tip/model de cutie)
Originally posted by gigibincheci View PostVa rog sa-mi spuneti ce tip de motor si de cutie de viteze are acest Peugeot 807.
Fluiera in treapta a 2 a.
VIN VF3EBRHTB13058703.
Sunt din Brasov,cand treceti prin zona va astept la o cafea.
Cu stima.
GIGI.0729 982 877
Leave a comment:
Cu stima.
GIGI.0729 982 877
Leave a comment:
Se putea face cândva cu istoric si km,acuma doar dotări,nivel de echipare si altele😉
Pentru ce vrei tu exista reprezentanta Pejo,se merge acolo si ceri ce te interesează insa greu de obținut😏 asta daca exista vreo urma de interventie si esti proprietar in acte😉
Inviato tramite Tapatalk per Windows Phone
Leave a comment:
Salut. Daca se poate istoricul pt VF30E9HD8CS276830 ? Sau macar nr de km? Multumesc anticipat
Leave a comment:
Leave a comment:
