Sfaturi achizitionare Peugeot 307
  • Pai in momentul in care fostul proprietar a cumparat masina (2005 sa zicem) el nu a platit la vremea aia taxa de inmatriculare ? Daca nu ma insel si atunci s-a platit, doar ca multe din firmele auto le dadeau "cadou" sau cel putin asa stiu eu.
    Peugeot 307 2.0E 136CP (T5)
    Peugeot 307 1.6HDI 110CP (T6)
    • stii tu ceva dar legea e clara, pt masinile inamtriculate inainte de iulie 2007 se platestes taxa de catre cumparator,vor fi multi naivi care o vor lua teapa,asta e statul de respectaa!
      • Doamne in ce tara traim, mi-e sila, mi-e scarba... In cazul asta m-am ars si eu si cred ca multi altii. Personal mi se pare un abuz si probabil multor romani posesori de masini si sper ca legea sa nu ramana asa.
        • Vehicle characteristics
          Vehicle family 307
          Build code 09088 88 1 0536
          Warranty Start Date 23/01/2002
          Engine serial number 10 DYHV 3005975
          Gearbox serial number 20 DL50 3736008
          BER e2*98/14*0245*00
          General information
          PRODUCT TYPE CAR
          COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
          VEHICLE FAMILY 307
          SILHOUETTE 5 DOOR SALOON
          TRIM LEVEL XR PACK
          ENGINE TURBO DIESEL DW10TD
          TRANSMISSION BVM5
          PAINT TYPE NON-METALLIC PAINT
          BODY COLOUR EWP - BANQUISE WHITE PAINT
          INTERIOR TRIM TYPE APIACA CLOTH + "MT" EFKA
          UPHOLSTERY COLOUR "FZ"
          GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
          ENGINE (TYPE) EW/DW
          OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
          BADGE HDI
          TRIM LEVEL XR PACK
          STEERING VARIABLE POWER STEERING
          SPEEDOMETER DRIVE W/O TACHO TORQUE
          Fuel supply-Engine
          DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
          CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON
          FUEL DIESEL FUEL
          EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
          ENGINE (TYPE) EW/DW
          OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
          CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
          EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
          DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
          VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
          PARTICLE FILTER WITHOUT PARTICLE FILTER
          FAN 1 FAN 2 SPEEDS IMPROVED 400W
          FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
          INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
          HYBRID ENGINE WITHOUT ALTERNATOR-STARTER
          TANK FILTER RESERVOIR FILTER INTERIOR
          THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
          Gearbox Transmission
          TRANSMISSION BVM5
          FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 75
          GEARBOX TYPE (TYPE APPROVAL) GEARBOX BE4/5 L TYPE
          DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84
          TYRE (SIZE, TYPE) 195X65X15 H TYRES
          WHEELS FITTED 6" RIM ROAD WHEELS
          WHEEL (TYPE) STEEL WHEELS
          GEARBOX TYPE GEARBOX BE4R
          Suspension-Steering-Brakes
          ABS WITH ABS BRAKES
          REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 26
          FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
          BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
          SUSPENSION NORMAL SUSPENSION
          DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
          BRAKE ASSOCIATED VARIANT ABS BOSCH 5 3
          Body fittings
          TOWBAR WITHOUT TOWBAR
          HORNS HORNS-HARMONY
          AERIAL SHORT ROOF AERIAL
          WHEEL EMBELLISHER (STYLE) 15 INCH OCEAN STYLE WITH 8 OPENINGS
          REVERSING LAMPS WITH 1 REVERSING LAMP
          ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
          EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
          EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
          WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
          REAR SCREEN WIPER REAR SCREEN WIPER
          HEADLAMP WIPER W/O HEADLAMP WIPER
          FRONT PANEL BLANK WITH RH BLANK (SHORT)
          ROOF GLASS WITHOUT ROOF WINDOW
          BUMPER BODY COLOUR STANDARD FRONT/REAR BUMPER
          MUDFLAP WITHOUT REAR MUDGUARD
          FRONT FOGLAMP NO FRONT FOG LIGHTS
          EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
          EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO
          SPARE WHEEL STEEL WHEEL + STANDARD TYRE
          REAR SCREEN WASH REAR SCREEN WASH
          SUN ROOF FIXED ROOF
          BUMPER TRIM DYED BUMPER STRIP
          GLASS (APPEARANCE) TINTED
          REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
          WINDOW (TYPE) NON-ACOUSTIC WINDSCREEN
          Interior fittings
          ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
          REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
          FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
          REAR SEAT SEPARATE FOLD BACK BENCH SEAT
          SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
          REAR SEAT ARMREST WITHOUT REAR ARMREST
          LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
          LUGGAGE COVER WITH LUGGAGE COVER
          REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
          FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
          CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
          SPEED GRADUATIONS GRADUATION KMS/H
          RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
          DRIVING POSITION LEFT HAND DRIVE
          ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
          DASHBOARD EQUIPMENT STANDARD DASHBOARD + FACIA QUIKSILVER
          INT. TRIM AND EQUIPMENT VARIATION STANDARD INTERIOR EQUIPMENT DRESSING
          RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
          SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
          FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
          DRIVER SEAT ADJUSTMENT WITHOUT DRIVER’S LUMBER AND SIDE SUPPORTS
          FRONT PASSENGER SEAT ADJUSTMENT WITHOUT PASSENGER’S SIDE AND LUMBAR SUPPORTS
          DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
          FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
          FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
          EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
          COMPACT DISC WITHOUT COMPACT DISC
          STOWAGE BIN WITHOUT SETTING BOX
          SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
          REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
          DRIVER’S WINDOW LIFT NON SEQUENTIAL DRIVER’S ELECTRIC WINDOW
          PASSENGER’S WINDOW LIFT NON SEQUENTIAL FRONT PASSENGER’S ELECTRIC WINDOW
          DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
          COURTESY MIRROR DRIVER’S CONCEALABLE+PASS NON CONCEALABLE NO LIGHT
          OIL GAUGE STD OIL LEVEL INDICATOR
          FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
          HEATING ELEMENT NON HEATED SEAT
          FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
          PASSENGER AIRBAG PASSENGER AIRBAG
          ELECTRIC WINDOW (OPERATION) WITHOUT AUTO STOP ELECTRIC WINDOWS
          ON-BOARD COMPUTER NO COMPUTER
          EQUIPMENT PACK W/O EQUIPMENT PACK
          EXTERIOR REAR VIEW MIRROR (HEATED) NON HEATED DOOR MIRROR
          AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
          INTERIOR DOOR CONTROL (APPEARANCE) BLACK EFFECT INTERIOR DOOR HANDLE
          FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
          STORAGE (DRIVING POSITION) WITHOUT ROOF FRONT CONSOLE STORAGE
          RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
          REFRIGERATION SINGLE AIR CONDITIONING
          CRUISE CONTROL WITHOUT SPEED CONTROL
          DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
          INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
          DRIVER AIRBAG DRIVERS AIR BAG
          LOAD SPACE STORAGE WITH BOOT TIDY
          OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
          TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
          FLOOR MAT W/O CARPETMAT
          LOCKING CONTROL SIMPLE CENTRAL LOCKING
          STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
          RADIO-INFORMATION-COMMUNICATION PACK RADIO CD / INFO 2
          DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
          Electrical
          ALTERNATOR ALTERNATOR 150 AMP
          HORNS HORNS-HARMONY
          BATTERY BATTERY L2 400
          STARTER MOTOR STARTER MOTOR CL 5
          SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
          Component manufacturers
          Miscellaneous
          SPECIAL SPECIFICATION STANDARD
          ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
          RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
          TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
          SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
          SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
          EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
          SURFACE CONDITIONS GOOD TERRAIN
          SPEED MONITORING WITHOUT SPEED CHECK
          • salut
            nu ai acees la istoric ....PM daca se poaTE
            • Salut, din pacate eu nu am acces pentru ca n-am cont platit (e 2000euro+ pe an) dar poti verifica cu ajutorul reprezentantei.
              • Salutare,
                De mult nu am ami dat pe aici.... In cele din urma am ales un Citroen C4 2.0 HDI 136 caluti din 2006, cu 120.000 KM la bord, masina super doatara variata VTR+, jante originale cu cauciucuri iarna/vara.... ce mai interiorul ala era bestial am fost super multumit de masina pentru....2 zile!! In 23 seara m-am intors de la BM cu ea (Omul care mi-a vandut-o CIpri... mare om, masina a fost exact cum mi-a spus ca va fi), iar in seara zilei de 25 decembrie in timp ce ma intorceam spre Cluj dinspre Alba (spre un mega chef ), intr0o localitate cu un drum cu 2 benzi pe sens, luminat totul, vizibilitate ce mia conditii perfecte de drum..... un bou cu un logan (fara macar ABS) pentru a evita o masina oprita pe banda 2 spre a schimba directia de mers a franat brusc a intrat in derapaj, pe contrasens...de unde venea una bucata Citroen luat de 2 zile cu mine il el fluierand cu prietena si circul;and (surpinzator de regulamentar vreo 55 km/h). Impactul a frontal masina mea este dauna totala... airbaguri....batai....politie.... martori.... cretinul fara RCA.....CRACIUN FERICIT SI LUI II DORESC!!!!!
                Partea materiala o rezolv pana la urma cu FPVS (aviz colegilor care trec prin ce am trecut eu) exista ceva total rupt din tara asta adica un fond de protectie al victimelor strazii care despagubeste pagubitii asemenea cazului meu. Deci exista speranta....
                Ideea este ca in 2 saptamani cand primesc banutii inapoi ma reapuc de cautat masini!! Un lucru stiu si eu si prietena mea ne-am dat jos din masina la fel cum ne-am urcat.... 5 Stras Euroncap MATTERS! Asa ca urmatoarea masina pe asta o sa se bazeze.
                Multa bafta la cumparare la toata lumea.
                Every new day is the first day of the rest of you're life!! So act like it!!!!!
                • Pacat Horea, pacat, era frumoasa. Dar tot raul inspre bine, poate te alegi cu ceva mai multi banuti si urmatoare masina sa fie si mai buna. Cat pentru loganist, o bicicleta si o casa la munte sa dispara de pe sosele.
                  • Pfai frate... imi pare rau pentru ce ai patit, Doamne fereste, bine ca ai reusit sa scapi cu bine si tu si prietena si ai circulat cu o viteza cat de cat ok si presupun ca aveai si centura. Legat de bani nu stiu cum ai sa rezolvi... poti sa-l dai in judecata sau ce poti face pentru recuperarea pagubelor avand in vedere ca dobitocul nu avea RCA?
                    • A mentionat ca a reusit cu FPVS.Fondul de Protectie al Victimelor Strazii.Despagubesc in caz de accident,in cazul in care vinovatul nu are RCA.Cum recupereaza ei banii de la paftas,habar nu am.
                      • De asta mi-e frica cel mai tare...sa dea peste mine un bou fara RCA. Imi pare rau de ghinionul tau...Dar tot raul spre mai bine
                        • Daca impactul este frontal masina mai poate fi reparata chiar daca la ochi pare rau. Problema intervine ca o sa coste ceva.
                          • Dar la un al doilea impact frontal va conta ceva mai mult.
                            • Depinde de impact, din ce observ eu impactul a fost absorbit de protectia fata (bara de metal/aluminiu din fata) dar e posibil sa ma insel, nu pot sa-mi dau seama dintr-o poza cu siguranta. In mod normal o parte din energia impactului se transmite si in caroserie, astfel daca gasesti tabla, stalpul sau alte elemente din caroserie strambe/deformate atunci poti sa te intrebi daca e sigur. Un mecanic/tinichigiu/ cineva de la rar poate sa-ti raspunda concret.
                              • Urat moment.Bine ca ati scapat fara nici o lovitura!
                                Iar pe voi astia cu "tot raul spre bine" chiar ca nu va inteleg...omu` nici n=a apucat sa se bucure de masina, si de unde stiti voi ca o sa primeasca mai multi bani decat a dat pe ea la o adica?
                                Oricum,bine ca n-a patit nimeni nimic,asta conteaza cel mai mult.
