Peugeot 508 sedan, motorizare 2.0HDi FAP 140CP, euro 5, 162.xxx km.
Stiu ca nu e foarte usor de citit, insa pentru a nu exista discutii de genul, aia are sau aia nu are, mai jos e lista completa de dotari pe baza VIN-ului: VF38DRHF8BL040082
Caracteristicile vehiculului
Linie de produs 508
Nr. APV/PR 12597 CJ 1 0061
Data de Inceput de Garantie 29.05.2011
NRE e2*2007/46*0080*00
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
LIGNE DE PRODUIT 508
SILHOUETTE BERLINA 4 USI
FINITION INALTA JOASA
MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE METALIZATA LACUITA
COULEUR DE CAISSE EEH - VOPSEA GRI HARIA2
TYPE D’HABILLAGE INTÉRIEUR TEATURA SI URZEALA COCHER "3D"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
Caracteristici vehicul
DIRECTION SISTEM DE DIRECTIE ASISTATA
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA CALITATE DA/DE/DE+
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO5 (MOTOR)
ECHAPPEMENT TOBA DE ESAPAMENT LONGITUDINALA
CYLINDRÉE 2000 CM3
CATALYSEUR CATALIZATOR IMPREGNAT SUB 10PPM
REFROIDISSEMENT D’HUILE SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO5
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE DELPHI
LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze - Transmisie
COUPLE RAPPORT RAPORT PUNTE 6 X 65
STYLE ROUE STIL 04 17 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R17 94W NERANFORSAT
ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE ML6C
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 20
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 23
SUSPENSION SUSPENSIE NORMALA
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
ENJOLIVEMENT LATÉRAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT OBTURATOR INFERIOR PANOU FRONTAL
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PARE-CHOCS BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
PARE-BOUE (BAVETTE) FARA APARATORI DE ROTI SPATE
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ROUE DE SECOURS ROATA ALIAJ + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BARA DE PROTECTIE CU INSERTIE CROMATA
VITRE (ASPECT) GEAM FUMURIU
VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ASSISE ARRIÈRE BANCHETA SEPARATA RABATABILA
DETECTION ANGLEMORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COMMANDE DE VITESSES COMANDA DE VITEZE LA PODEA
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE SATIN ARGINTAT
FEUX INT. DIVERS LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
GARNISSAGE VOLUME CHARGEMENT COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
GARNISSAGE DE PORTE DECOR TESATURA
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 4 KG
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RÉGLAGE ASSISE AVANT CONDUCTEUR SUPORT LOMBAR CU REGLARE CONDUCATOR
RÉGLAGE ASSISE AVANT PASSAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFFICHEUR AFISAJ NIVEL C ECRAN MONOCROM
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
RÉCEPTEUR RADIO RD5/MP3 RADIO PT CD - AFISAJ DEPLASAT
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
STORES LATÉRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
SAC GONFLABLE GENOUX CONDUCTEUR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
ECRAN VIDÉO ARRIÈRE FARA ECRAN VIDEO IN SPATE
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE L3 720 EF
DÉMARREUR DEMAROR CLASA 5
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
ALLUMAGE FEUX APRINDERE LUMINI MANUALA
BOITIER TELEMATIQUE FARA MODUL TELEMATIC
Marci echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
ETIQUETTE FARA ETICHETA
PRISE D’ÉCOUTE RADIO PRIZA ACCESORII TRIPLA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
BOÎTIER SERVITUDE BSI EVOLUTION
TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
Optional: set de jante de tabla 16" originale + anvelope de iarna + prezoane originale = 200 Euro
Pret: 9200 Euro
Contact: PM, 0742993467, 0742698378
"Am citit regulile comerciale si le voi urma cu strictete"
Linie de produs 508
Informatii generale
Alimentare motor
CYLINDRÉE 2000 CM3
Echipament interior
Electricitate
BATTERIE L3 720 EF
Marci echipamente
Diverse
ROULAGE DRUM CORECT
Pret: 9200 Euro
