Peugeot 607 v6 2.7l 150kw cutie automată 6 trepte
    Exact, e durata medie de folosinta a cutiei. Cind intra in avarie nu mai treci de treapta a 3 a.
    Cea mai nasoala e prima, P0741, care e posibil sa fie cauza tuturor relelor. Asta iti spune ca nu se poate bloca convertizorul pentru priza directa, adica cu eficienta 100%. Cu alte cuvinte PATINEAZA. In convertizor sta cea mai mare parte a uleiului, de aici si incalzirea exagerata.
    Generic OBD Error Code Details for P0741
    Torque Converter Clutch Circuit Performance or Stuck Off
    What does this mean?
    OBD Code P0741refers to
    The torque converter clutch solenoid valve is activated, with the gear in D4, by the Transmission Control Module (***) in response to signals sent from the vehicle speed and the Engine Control Module (ECM). Lock-up piston operation will then be controlled. When the torque converter clutch solenoid valve is activated, the torque converter lockup clutch will engage creating a 1 to 1 RPM ratio between the transmission input shaft and the rotational speed of the torque converter. Lock-up operation, however, is prohibited when A/T fluid temperature is too low. When the accelerator pedal is depressed (less than 2/8) in lock-up condition, the engine speed should not change abruptly. If there is a big jump in engine speed, there is no lock-up.
    Symptoms
    Possible sumptoms of OBD code P0741
    - Engine Light ON (or Service Engine Soon Warning Light)
    Causes
    Possible causes of OBD code P0741
    - Low transmission fluid level - Dirty transmission fluid - Faulty torque converter clutch solenoid valve - Torque converter clutch solenoid valve harness or connectors - Torque converter clutch solenoid valve circuit is open or shorted - Transmission internal mechanical problem The Error code is generally activated on detection of the following conditions: Lock-up does not occur when driving in lock-up range or lockup remains ON in lock-up OFF range
    De obicei erorile legate de "remote wake-up, trigger, start/stop bla..bla" (U2000,U2001,U1118...) au legatura cu uitatul interfetei in portul OBD si intreruperea contactului. Nu prezinta interes decit daca reapar cu obstinenta dupa stergere.
    Eroarea P1445 banuiesc ca e legata de aditivul FAP, asta am inteles eu la traducere .
      Mulțumesc salex. Cu alte cuvinte asa cum merg eu pe distante scurte de cāțiva km/ sau zeci de km ma tine. Nu are unde sa se īncingă cutia. Mă tem sa vin cu ea 2000 de km īn țară... Ce spui?!
      Am tot uitat sa te īntreb. Īn foto a ta de la profil e mașina ta? Arata īntr-un fel mașinuța aia
      Asta de la care am luat-o i-a schimbat uleiul la Peugeot. A vrut inițial s-o cumpere pt el și după tester s-a răzgāndit s-o mai īnscrie. Iar eu nu sunt asa priceput la germană și a profitat de asta. Am găsit hārtiile de la tester īn facturile de īntreținere a mașinii. Nu le-am observat inițial. El a sperat ca schimbul de ulei remediază problema.. Mă gāndesc serios sa caut o cutie mai tānără la dezmembrări pe o caroserie nelovita..
        -Nu stiu ce sa zic. 2000km sint destui iar daca te lasa pe undeva, nici macar tractata nu merge ca o distrugi de tot; maxim 50km/h. Doar auto-platforme pentru cutiile automate ...
        -Poza aia e o varianta prototip (Elixir 6 Cylinder 2.7 L HDi Tiptronic) http://www.youtube.com/watch?v=p3BjigI53x8 Vezi si decapotabila cu plafon rigid (Macarena) https://www.youtube.com/watch?v=H7Bv13eiRUA
        -Incearca sa te duci tintit la un service Peugeot. Ii iei la sigur, le spui de problema convertizorului si le ceri imperativ sa verifice solenoidul (bobina) si valva. Poate scapi ieftin. Cumpararea cutiei SH e loterie. Nu stii ce cumperi, poate fi mai problematica ca a ta. Sau poate ai noroc si din doua faci una buna.
          Asta am sa fac. Varianta cu service-ul propusă de tine aici. Mulțumesc tare mult.
          Interpretarea diverselor coduri de eroare este la fel de accesibilă nespecialistilor precum am īnvățat de la tine despre piese și manuale(unde am citit și eu treaba cu tractatul) ? (servicebox)?
            De cāt īnveți și știi mai multe, cu atāt īți dai seama de fapt cāt de puțin știi.. (Einstein parcă...)
