Mai sa fie... Stiam ca distanta de franare se MARESTE cu ABS-ul. ABS-ul in schimb ajuta la pastrarea controlabilitatii masinii. Uite, daca vrei, facem un test: franam de la 50km/h cu ABS ON, si inca o data cu ABS OFF pe masina mea. Ai sa vezi ca distanta de franare creste destul de mult, cam cu 20-30%!
Chestii legate de frane (ABS+EBD+EBA)
http://www.brennanlaw.com/lemonlaw/absjury.htm
The biggest misconception that they have is that the car [with ABS] is capable of stopping in a shorter distance. On slippery surfaces ABS is usually advantageous. In wet weather it is advantageous. But a few systems, even on dry asphalt, if you energize the ABS is takes longer to stop. Usually it doesn’t stop you faster and that’s the big misconception.
And the second biggest misconception is, somehow they think they’ll always have control of the car. Even with the best of antilock brake systems there can be irregularities in the road surface and the vehicle can go into a violent spin.
si inca un articol interesant:
http://www.abs-education.org/faqs/faqindex.htm
Do cars with ABS stop more quickly than cars without it? Not always. Although the stopping distance with ABS is shorter under most road conditions, drivers should always keep a safe distance behind the vehicle in front of them and maintain a speed consistent with the road conditions. While a vehicle with ABS maintains its steering capability in a sudden stop, it may not turn as quickly on a slippery road as it would on dry pavement.
In what circumstances might conventional brakes have an advantage over ABS? There are some conditions where stopping distance may be shorter without ABS. For example, in cases where the road is covered with loose gravel or freshly fallen snow, the locked wheels of a non-ABS car build up a wedge of gravel or snow, which can contribute to a shortening of the braking distance.
la ce folosesc sistemele de securitate: ABS, trasction control si sistemele inteligente de control al stabilitatii
http://www.abs-education.org/ishs/newtechca.html
PS: cred ca ar trebui facut un topic separat :wink:
ABS. Un sistem de antiblocare a rotilor, care actioneaza cu ajutorul unor senzori inductivi. Calculatorul ABS inregistreaza viteza de rotatie a rotilor si, daca o roata tinde sa se blocheze, forta de franare va fi scazuta pana cand alunecarea va fi anihilata.
Inventat, in 1974, de Bosch
Acest dispozitiv de supraveghere si de control al comportamentului automobilelor are o istorie veche. Actuala tehnologie ABS asigura, electronic, o distributie uniforma a presiunii din instalatia de franare, in functie de "plaja" de aderenta a fiecarei roti, concomitent cu impiedicarea patinajului acestora.
Istoria ABS a inceput in anii '70, iar inventatoarea acestui sistem este cunoscuta firma germana Bosch. In 1974, nemtii au testat aceasta noua "gaselnita" pe un BMW 3.0 CSL, dar sistemul a intrat oficial pe piata abia in 1978. Automobilele Mercedes 350 SE-Klasse si BMW 733i au fost primele dotate cu dispozitivul inventat de Bosch. ABS a "trecut" Atlanticul in 1985, nord-americanii fiind incantati de inventia germanilor. Un an mai tarziu, in intreaga lume existau peste un milion de automobile dotate cu ABS, iar in 1999 numarul acestora a depasit 50 de milioane. In primii 27 de ani de existenta, peste 120 de milioane de automobile au fost dotate cu acest sistem.
Dacia face opinie separata
O alta statistica releva ca 60% din masinile produse in anul 2000 aveau in dotare sistemul ABS. Interesant este ca sistemul din 1978 (ABS 2) avea 6,3 kilograme, in timp ce actualul ABS 8 are doar 1,6 kilograme.
Federatia europeana a producatorilor auto (ACEA) a stabilit ca toate autovehiculele fabricate dupa 2004 sa aiba in dotarea standard sistemul ABS. Desi este afiliata la aceasta organizatie, Dacia se eschiveaza cand vine vorba de a dota cu ABS toate masinile care se fabrica la Colibasi. Exista doar o singura varianta de Logan cu ABS, cea mai scumpa, de 8.750 de euro. Renault, in schimb, respecta ACEA si comercializeaza in Occident doar Loganuri echipate standard cu ABS.
Salut! Ce bine ca la masinuta mea,mi-am comandat si ABS.La vremea achizitionarii ei,18 decembrie 2004,ABS-ul intra la "optionale".L-am comandat fara ezitare si ce bine este astazi cand "micutul" este dotat si cu E4 si AC+ airbag-uri laterale si cortina.
Am testat ABS-ul zilele astea chiar in fata blocului la mine pe alee unde era o portiune acoperita cu zapada batatorita si gheata.Raspunde foarte bine la comanda,nu blocheaza rotile masina ramanand "pe traiectorie".Stiti reactia pedalei de frana...este azvarlita inapoi ritmic.
In concluzie este foarte bine venita iarna prezenta ABS-ului.
Cu stima,Mares Cosmin
LA MULTI ANI!NU E TREN PRECUM METROUL,PLACERE CA LIBIDOUL SI MASINA CA PEJO-UL!:thumbup:
Nu inteleg de ce se obinuieste sa se faca legatura intre ABS si distanta de franare mai scurta... cand defapt in cele mai multe cazuri e chiar invers....!!! Dacia avea pur si simplu frane mai slabe sau sofer care a franat mai tarziu... la distanta de franare de cela mai multe ori ABS-ul incurca... nicidecum nu scade distanta de franare...Originally posted by mjustinazi am vazut un leut(206) care a reusit sa franeze in scurt si a evitat un audi dar cel cu dacia din spate(datorita ABS???)nu a mai reusit sa franeze si l-a lovit pe leut!
morala: pacat de leut ca are frane bune si poate fi lovit din spate
ABS-ul are cu totu si cu totu alte roluri care nu privesc distanta de franare.......
Cred ca s-a mai discutat: ABS-ul mareste distanta de franare, mai ales iarna.Resoftari, chiptuning, dpf fix Peugeot si Citroen | Preturi incepand de la 250 lei. Detalii la 0751.194.100.
dar in acelasi timp, functie de aderenta o poate micsora(o arata si testele de specialitate)
daca franezi si datorita blocarii rotilor te duci sanie(lipsa ABS)=distanta mai mare pana la oprirea efectiva iar cand actioneaza ABS(care impiedica blocarea rotilor) este o franare ce pare mai in lung dar fara efectul de "sanie"sigpic
Forta maxima de frecare si implicit forta de frinare este la limita blocarii rotilor. ABS-ul care functioneaza corect incearca tocmai acest lucru:sa mentina rotile la limita blocarii cind forta de frecare si implicit frinarea sint maxime. Foarte evident pe gheata de exemplu, cu rorile blocate aproape ca masina accelereaza. Deci scuze dar cred ca te contrsazic,Originally posted by AlexGNu inteleg de ce se obinuieste sa se faca legatura intre ABS si distanta de franare mai scurta... cand defapt in cele mai multe cazuri e chiar invers....!!! Dacia avea pur si simplu frane mai slabe sau sofer care a franat mai tarziu... la distanta de franare de cela mai multe ori ABS-ul incurca... nicidecum nu scade distanta de franare...
ABS-ul are cu totu si cu totu alte roluri care nu privesc distanta de franare.......-DISCOUNT orice piese ORIGINALE Peugeot sau AM , accesorii PHILIPS, VALEO, BOSCH
da... discutia imi aduce aminte de fizica de liceu: forta de frecare statica, indicele de frecare miu care se calculeaza in functie de unghiul la care obiectul incepe sa alunece pe suprafata...
initial eu credeam ca sistemul ABS este atit de destept incit sa mentina rotile in miscare astfel incit sa nu se blocheze si implicit sa rupa aderenta. asta e de fapt idealul, dar ce s-a realizat este un ciclu blocare - deblocare suficient de rapid astfel incit sa nu rupa aderenta, dar distanta de frinare se pierde in pauza dintre blocari...
cred ca exista mai multe tipuri de ABS, unele mai eficiente ca altele, iar idealul, cum am mai spus, este net superior frinarii prin blocare. ca si la plecarea de pe loc, unde controlul tractiunii ajuta la un demaraj mai eficient decit frecarea pe loc a cauciulurilor (desi aici incape o discutie legata de viteza de rotatie care... dar divaghez si va plictisesc
Forta maxima de frinare este la limita dinaintea blocarii rotilor. Cu cit ABS-ul este mai performant adica slabeste cu ciot trebuie si cu frecventa care trebuie presiunea in cilindrii de frina cu atit rezultatele sint mai bune. Oricum pe gheata, zapada distanta de frinare este NET inferioarea cu ABS decit fara ca sa nu ma vorbim de pastrarea directiei de deplasare datorita evitarii blocarii neuniforme a rotilor cind masina vireaza ca un tanc.-DISCOUNT orice piese ORIGINALE Peugeot sau AM , accesorii PHILIPS, VALEO, BOSCH
