Consum 206 Diesel
  • #91
    Originally posted by Doc &#064; Dec 19 2005, 18&#58
    Quoted post
    Par ar fi cazul sa iei un diesel care merge 3 zile pe rosu. :harhar: Aaa era sa uit, mai porneste si la prima cheie iarna&#33;
    LOLHAI NU VA MAI STRESATI INTRE VOI&#092;&#33;&#33;1&#33;
    :clapping: :clapping:
    TREABA LA A MEA 206 HDI 1.4 ESTE CA SCHIMB VITEZELE LA 2000 ,2100 RPM&#33;&#33;&#33;EEE MAI SAR PESTE RPM DAR IN MAJORITATEA CAZURILOR MERG CU EA SUBTURATA...SI SCHIMB SUB 2000&#33;&#33;&#33;&#33;
    ADEVARAT ESTE CA PE DIESEL MERGI DUPA CE SE APRINDE BECUL DE REZERVA/...MERGI&#33;&#33;&#33;&#33;
    AM OBSV SI LA DRUM LUNG CA DACA SARI PESTE 2500 DE RPM INCEPE SA CONSUME MULT&#33;&#33;&#33;&#33;
    CONSUM : ORAS TOTAL IARNA+VARA 6 LITRI.......80-100 KM....&#33;&#33;&#33;&#33;CATEODATA SI FORJATA&#33;&#33;&#33;MAI ALES ACUMA CU ZAPEZILE SI GHETUSUL ASTA FORJATA TARE CA SA MA INVART SI EU CU MASINA....NU? :bigyellowgrin: :bigyellowgrin:
    • #92
      Originally posted by cici7fcnb7 &#064; Feb 7 2006, 13&#58
      Quoted post
      mersul subturat genereaza un consum mult marit decat mersul la turatia optima... si schimbatul vitezelor la turatia optima.. care la benzina... din cate stiu eu e intre 2500-3000rpm
      • #93
        Originally posted by AlexG &#064; Feb 7 2006, 14&#58
        Quoted post
        fiind pe diesel nu cred ca subturatul face un consum mai mare&#33;&#33;&#33;&#33;
        cred...
        • #94
          doar iti buleste EGR....fa-ti un bine si exploateaza masina la parametrii dati de constructor. schimba viteza la peste 2500rpm
          • #95
            Originally posted by 75NOR &#064; Feb 7 2006, 17&#58
            Quoted post
            ce este EGR?
            nu stiu ...pls ....explika-mi
            si vitezele stiu ca se schimba la 2100 rpm&#33;&#33;&#33;&#33;
            asa mi-a spus inginerul sef de la pgu
            gandeste diesel....benzina poate 2500-3000
            :naughty:
            • #96
              POFTIM: lectura de vacanta obligatorie pt dizelisti :wink:
              Exhaust Gas Recirculating Valves
              What are they? What do they do? How do they fail??
              EGR Valves have been around for a long time. Way back in 1972 GM used them in an attempt to reduce emissions of oxides of nitrogen (NOx) which were a major cause of air pollution, mainly photochemical smog, that kind of smog which is formed when strong sunlight shines down on the exhaust gasses we puke out of our tailpipes by the billions of cubic feet a day.
              A short chemistry lesson is in order here. It was discovered way back when, that high combustion chamber peak temperatures (the really short duration high temperatures near the end of the combustion process) caused oxygen and nitrogen to combine chemically and form these oxides of nitrogen mentioned above. Most of the anti-pollution devices of the day did a pretty good job of reducing the other bad by-products of combustion, namely excessive hydrocarbons and carbon monoxide, however they tended to induce the formation of oxides of nitrogen. Something had to be done else we would all die of smog diseases.
              The automotive engineers figured that they needed to do something to lower the peak combustion temperatures which only occurred under certain high load driving conditions. They figured they could do so at the expense of power and fuel economy but what the heck, ya can&#39;t have everything&#33; If they could only add something to the combustion chamber that would act like sort of a fire extinguisher to cool the combustion temperatures that would do it.
              So they invented a way to allow some very inert gas to get back into the combustion chamber only when needed. They needed a source of this gas - it wasn&#39;t air, cuz that contains oxygen and nitrogen which caused the problem in the first place. So they chose carbon dioxide. Where to get a supply of carbon dioxide . . . ??? Hmmmm, how about the exhaust system? That is mainly carbon dioxide and water (plus a zillion other noxious chemicals) Suppose we allow some of the exhaust gas to get back into the intake manifold under strict control and only when we need it? That would cool the combustion chamber and prevent the formation of the NoX. Maybe we should call it recirculated exhaust gas (REG??). But a guy named Reginald voted no cuz he didn&#39;t want his name associated with a car part, so they called it exhaust gas recirculation (EGR) since there was nobody around with that name.
              Now we understand why it is there. And we understand what it does. So what can go wrong with it and what are the symptoms??
              It&#39;s really pretty simple - it can be open when it isn&#39;t supposed to be, or it can be closed when it is supposed to be open. Not rocket science, but it is science. If it is open when it is not supposed to be open, at idle for instance, It will act like one monster vacuum leak and the engine will not idle or will idle really roughly. If it doesn&#39;t open when it is supposed to open you will probably experience a symptom of "pinging" or "knocking" since the combustion chamber temperature will be higher than normal (one of the main causes of pinging in an engine).
              There are a zillion different types of EGR valves some of which work strictly on vacuum, and some which work on a combination of vacuum and pressure. Some have electronic controls, some have mechanical controls. I won&#39;t go into detail here about all the different types but suffice it to say that most can be checked by looking inside to see if the plunger shaft is stuck open or doesn&#39;t move when the engine is revved up (after it is warmed up). Replacement is probably the easiest part since most are held in by two small bolts and have a vacuum line connected to it. The hard part is whipping out your Visa card to pay for it since most of them will drain your reserves in a hurry&#33;&#33;
              ideea e sa schimbi la 2500 - 3000 ca nu ai nici o problema. se impaca foarte bine hdi cu 3000rpm.
              la benzina schimbi la 4000 -5000 rpm
              • #97
                hm...ms de documentatie....
                dar...
                atunci de ce mi-a spus ala de pgu asa...?
                si eu pe cine mai stiu ci diesel si nu nuami pguuri toti schimba asa la 2000-2100&#33;&#33;&#33;&#33;&#33;
                dc?
                • #98
                  si cat este in manual cuplul p[tr 206 hd 1.4?
                  • #99
                    in fine treaba este ca eu la cum schimb acuma vitezele adik 2000-2100,cred ca este bine.deoarece se simte ca nu este nici supraturat ,nici subturat motorul...parerea mea :biggrin:
                    • La mine in carte (versiunea in franceza), pentru 1.4hdi scrie: 160 Nm la 1750 rot/min.
                      Cand treci intr-o treapta superioara 2-3, 3-4 etc, in momentul imediat urmator schimbarii in treapta superioara, nu ar trebui sa fi sub 1750 rot/min (sau nu cu prea mult).
                      Acuma ca mai intervini mici erori de aproximatie a turatiei la care se schimba, nu cred ca influenteaza prea mult.
                      Important este sa nu se faca o regula din a merge sub 1750.
                      De ex eu am observat ca daca schimb 2-3 la aprox 2300-2400 in treapta a 3-a motorul va avea aprox 1750.
                      Cand schimb 3-4, schim pe la 2100-2250 si cade tot in jur de 1750, iar la 4-5 pot chiar sa schimb la 2000-2100 (daca ma misc repede)
                      Cutia de viteze (rapoartele) ""iti spun"" si ele oarecum cum sa schimbi, dupa ce te obisnuiesti putin cu masina.
                      Daca vei schimba in acest mod, consumul va scadea, deoarece in treapta superioara nu vei mai chinui motorul sa se ridice la turatia de cuplul maxim (de la 1400 la 1750 tre&#39; sa apesi zdravan pe pedala)
                      Mult succes.
                      • Weekend la Bran (380 km). Sambata bara la bara Comarnic-Azuga si duminica bara la bara Predeal-Poiana Tapului si la Comarnic. 4 persoane, portbagaj full 7,2l/100 km.
                        Consum acceptabil pt aceste conditii...
                        • Originally posted by dogg &#064; Oct 21 2005, 15&#58
                          Quoted post
                          pai daca omu&#39; si-a facut socoteala si asa i-a dat?&#33;
                          Numai ca mie nu prea-mi da: Bucuresti-Praga=909 km via Arad. In cazul in care consumul este de 4% inseamna aprox. 37 lt. motorina adica vreo 36 de euroi.
                          La banii astia inseamna ca are consum de 8%.
                          Mihai, sa stii ca nu sunt 900 km pana la Praga. Fac acest drum dus intors aproape la 2 luni, numai prin Arad. Locuiesc fix in centrul Pragai si in Bucuresti la Piata Sudului. Distanta o masor mereu si este de 1350km +/- 50km.
                          Poti masura aceasta distanta si cu un Autoroute sau cu un alt program la fel.
                          Oricum intre timp mi-am mai schimbat parerea despre consum. Daca in aceea perioada aveam un consum de 4% la viteza medie de 110-120km/h acum cred ca am un consum ce sare de 6% si asta datorita faptului ca merg pe la 150-160km//h Praga-Arad. Oricum treaba asta nu ma deranjeaza asa tare, singura teama pe care o am este numai legata de uzura motorului. Am fost la Eurial Pitesti la toate verificarile si am intrebat mereu despre uzura motorului si mereu am primit acelasi raspuns, ca motorul se afla in parametrii normali dpdv al uzurii.
                          Am masina din Mai 2005 si am pana acum 21.000 km, 19.000 din ei fiind in afara localitatii iar din astia 19.000 cam 14.000 numai pe autostrazile europene la viteza medie de 140-150km/h.
                          Nu am reusit sa ma lamuresc inca daca fac rau ca merg cu turatii numai pe 3500 rot/min. Parerile sunt f impartite.
                          As dori si parerile voastre.
                          Pug 206 1.4 HDi
                          • am un 1.4HDi/2005 si consuma cam 6-7 in oras si afara 3-4 la viteza sub 130 Km/h, la 170 se vedea pe bord cum se duce motorina :bigyellowgrin: , asa ca merita sa o ti cam la 130 consum super bun :thumbsup:
                            • Iarna asta mi-a iesit cam 8,5 in oras, dar mers in 90% din timp doar distante scurte:6,5 km de acasa la servici. Nu apuca sa se incalzeasca decat pe la 70 de grade. Acum am fost la Semenic, si pe 280 de km mi-a consumat cam 6,7%. Dar a fost zapada mare, si am urcat greu...totusi mi se pare ca e un consum cam mare fata de ce scriu ei in datele tehnice. M-as duce la Peugeot sa se uite daca nu e vreo problema, dar mi-e frica sa nu consume dupa aia cu galeata Mai bine astept sa se incalzeasca sa vad cum se comporta.
                              206 2.0 HDI 90CP
                              • Originally posted by pitbul79 &#064; Mar 14 2006, 12&#58
                                Quoted post
                                Nu am inteles exact, cum adica "se vedea pe bord"? este vorba de un computer de bord sau e ceva metaforic?
                                Pug 206 1.4 HDi
