Problema eroare Peugeot 406
    Posibil releu defect.
    Causes
    Possible causes of OBD code P0485
    - Fan control relay harness - Fan control relay connector - Fan control relay - Cooling Fan The Error code is generally activated on detection of the following conditions: The P0485 code is detected when the PCM detects that the commanded state of the driver and the actual state of the control circuit do not match.
    Possible Solutions
    - Replace the malfunctioning fan control relay - Replaced cooling fan
      Deci solutii ar fi inlocuire releu sau ventilator.
        Am incercat si cu releu si cu ventilator, tot la fel face: cand pun contactul porneste electroventilatorul la turatie maxima chiar daca AC-ul este oprit. N-a mai avut chiar nimeni problema asta?
          Pune un tester pe ea .
          trebuie monitorizati niste parametrii cei de temperaturi si presiune AC. Erorile de pe display sunt pur orienntative.
            Pe tester mi-a dat P0485, de monitorizat cred ca nu a stiut ala ce sa monitorizeze ca era cam afon.
