Peugeot 406 2.0 Hdi 110hp
  • Peugeot 406 2.0 Hdi 110hp
    I have a 09/1999 Peugeot 406 Hdi 110hp with almost full extras, it has electric seats, electrocromatic rear view mirror, electraly rebatible left and right exterior mirrors automatic wippers and a lot of extras.
    I want to know if the sensor in the top of the dashboard, a litle bump with two wires attached, is the auto lights sensor, and if it is possible to activate this sensor?
    Is possible to activate the emergency lights on a emergency brake?
    Is possible to activate the automatic door locks?
    Best regards.
    The auto lights sensor is located on top of the windscreen (back of the inside central mirror), visible on the outside (obviously)
    The autolights is activated by a long push on the end of the lights stick (a message on the screen appears: automatic lighting active)
    To disactivate, push again - hear a beep (no message on the screen)
    If your car has auto wippers, you'll have "auto" written on the wippers stick.
    To activate, move the stick on any position and back on "auto" position. Message on the screen (automatic wipping active)
    It disactivates itself when you switch off the engine.
    The automatic door lock can be made only with the car alarm.
    Luck!
