1,4hdi
  • 1,4hdi
    Sunt motoare pe 207 de 1,4 hdi cu 55 cp? Sau numai cu 70cp.Se comporta bine cele de 55cp la greutatea masinii?Stie cineva?
    Nu cred ca exista vreun motor pe 207 care sa aiba 55cp.
      Am vazut pe forumurile de vanzari auto multe 1,4hdi 55cp. De aia mi se apre curios. Chiar toti au gresit cand au postat anuntul|?
      bobovis
      Supermoderator
        Nu exista motor de 55 cai, are 68 sau 70 motorul de 1.4, nu mai tin minte exact
          Sunt 55 kW probabil...ceea ce se transforma si ajung la vreo 75 Cp. Probabil au incurcat cand au scris la kw, in loc de cp.
          Felina mea
            La asta m-am gandit si eu. Mi se apreau prea lenese la 55cp. Ca la dacia 1300.
            bobovis
            Supermoderator
              Sunt/au fost motoare de 1.4hdi de 50 cp (daca retin bine) instalate pe peugeot partner.
                doar pe 107 este 1,4 hdi de 54 cp ...
                DLD-414
                The Duratorq DLD-414 (or DV4) is a 1.4 L (1398 cc/85 cu in) straight-4 turbo-Diesel. Output is 50 kW (67 hp) at 4500 rpm and 160 N·m (117 ft·lbf) at 2000 rpm.
                The DV4 is available in two versions:
                One, an 8-valve design, uses a Borg-Warner KP35 turbocharger but no intercooler. This is the same turbocharger as the Renault K9K Diesel. It is Euro 3 compliant, but will receive a Diesel particulate filter from 2006 to make it Euro 4 compliant. In Ford, most Citroen and Mazda applications it uses a Siemens SID804 or SID802 common rail injection system, in Peugeot and some Citroen a Bosch common rail system is used.
                A second version uses a DOHC 16-valve design, with an intercooled variable geometry turbocharger. This derivation will no longer be built from 2006, as it will not be able to comply with the EURO4 regulations. This engine uses Delphi Corp.'s DCR1400 common-rail injection system
                Applications:
                8-valve non-intercooled, 55 PS (54 hp/40 kW) and 96 ft·lbf (130 N·m)
                2005–present Citroën C1/Peugeot 107/Toyota Aygo 1.4 HDi
                8-valve non-intercooled, 68 PS (67 hp/50 kW) and 111 ft·lbf (150 N·m)
                2003–present Citroën C2 1.4 HDi
                8-valve non-intercooled, 68 PS (67 hp/50 kW) and 118 ft·lbf (160 N·m)
                2002–present Citroën C3 1.4 HDi
                2002–present Ford Fiesta 1.4 TDCi
                2002–present Ford Fusion (European) 1.4 TDCi
                2002–present Peugeot 206 1.4 HDi
                2005–present Peugeot 1007 1.4 HDi
                2002–2007 Mazda 2/Demio 1.4D
                2008–present Mazda 2/Demio 1.4D
                2007–present Ford (India) 1.4 TDCi Fiesta, also marketed as the Ikon in South Africa.
                2008–present Ford Bantam TDCi commercial vehicle in South Africa.
                16-valve intercooled, 90 PS (89 hp/66 kW) and 147 ft·lbf (200 N·m)
                2001–2005 Citroën C3 1.4 HDi 16V
                2002–2005 Suzuki Liana 1.4 DDiS
                Model Output Notes
                DV4 TD 70 PS (69 hp/51 kW) turbo-Diesel
                DV4 TED4 92 PS (90 hp/67 kW) turbo-Diesel 16-valve
                '' by google
                "Great Minds Discuss Ideas, Medium Minds Discuss Events, Small Minds Discuss People."
                  Eu am 1.4 si are 90 de cai...cineva spunea ca are 70 maxim...
                    Aici este vorba de 1.4 HDI, tu ai 1.4 benzina care este si de 70CP.
                      salut
                      nu.am avzut niste anunturi de vanzari 207 1,4 hdi 55cp si m-am mirat pai 55cp avea dacia si mi s-a parut un motor slab la asa greutate.era o cruiozitate
                        cauciucuri de iarna
                        Salutare,
                        Sunt Daniel ,posesorul unui Peugeot 207 Active ,1.4hdi ,70cp ,gri alluminium ,achizitionat in 03.09.2010 si am o intrebare pentru ceilalti posesori ,anume de care cauciucuri de iarna ,marca folositi ? Eu am 185 / 65 R15 GoodYear.Ms.
                          Uite aici un topic dedicat pentru cauciucuri de iarna. http://www.peugeotclubromania.ro/for...elope-de-iarna
                          Personal iarna trecuta am folosit Dunlop SP Winter Sport 3D (SH) de care am fost super multumit, si anul acesta tot cu acest model o sa merg.
                            Eu am de iarna trecuta Nokian w de care sunt foarte multumit.Acum am achizitionat 2 Nokian w+ pentru fata si pe celelalte le pun pe spate.
                            , GRI ALUMINIU , 2007.
                              Noul motor 1.4 HDI FAP E5.
