tip de motor dupa cod
  • tip de motor dupa cod
    Buna,
    Am gasit la un auto-schrot un motor cu codul PSA LFY 10 KJER cu bloc de aluminiu. cum pot afla cilindreea, cursa, alezaj ,an fabricatie ,etc. Cei de acolo nu stiu nimic despre motor, nici de pe ce masina e ,dar ei cred ca de pe un 306.
    Daca ma poate lamuri cineva astept un bip la 0723004747 sau pe forum
    Multumesc.
    Sendy
    Salut. Se pare că motoarele LFY sunt de fapt 1.8 L 16v XU7JP4 (LFY/L4).
    The PSA-borrowed engine is XU7JP4 (code LFY, known as L4 in Iran) 1.8 L DOHC with 4 hydraulically-adjusted valves per cylinder capable of producing a maximum power of 109.0 bhp (81.3 kW / 110.5 PS) @ 5500 RPM and a maximum torque of 155.0 N·m (15.8 kgf·m / 114 ft·lbf) @ 4250 RPM which is controlled by Bosch Motronic MP 7.3 ECU. The same engine was already in use in the PSA's Peugeot 406 LX 1.8i 16v, Citroën Xantia SX 1.8i 16v, and Citroën Xsara VTS 1.8i 16v.
    The XU7 had a displacement of 1.8 L (1761 cc), with a bore of 83 mm (3.3 in) and a stroke of 81.4 mm (3.2 in). All XU7 engines used fuel injection, with a 16-valve DOHC version, the XU7 JP4, also produced. Output ranged from 90–112 PS (89–110 hp/66–82 kW).
    Deci cilindrii cu diametru de 83 mm, cursa de 81.4 mm. 16 valve.
      Mercy mult.
      Daca mai stie careva ceva,astept cu nerabdare
      Sendy
