Salutare tuturor! Am posibilitatea sa cumpar de la o cunostina un 206, 1.4 benzina, din 2003, 200 si putin mii de km, cu pretul de 1100. Ca defecte, ar fi amortizoarele pe fata si lipsa freon. A avut puntea spate schimbata, evacuare noua, suspensii spate la fel. Ce spuneti? Ceva de verificat?
Sfaturi achizitionare 206
Caracteristicile vehiculului
Linie de produs 206
Nr. APV/PR 10745 83 1 0310
Data de Inceput de Garantie 11.05.2006
NRE e2*2001/116*0310*02
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
LINIE DE PRODUS 206
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE XS LINE
MOTOR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA5
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
TIP ECHIPARE INTERIOARA ACCESORIU PLASA KATLA + SOFIS MONOTON "N7"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA FARA MONOGRAMA SUPLIMENTARA
MONOGRAMA COMPLEMENTARA, DIVERSE SW
MONOGRAMA JBL
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
Alimentare motor
BUSON DE CARBURANT BUSON CARBURANT ALUMINIU
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO 4 (MOTOR)
PREFILTRU ECHIPARE FARA PREGATIRE PENTRU FILTRU
CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
OPTIMIZAREA CONSUMULUI VEHICULULUI FARA OPTIMIZARE DE CONSUM CARBURANT
MOTOR RACIRE RADIATOR EP:19 21 DM2 ALUMINIU BRAZAT PA 1,2
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
TAIERE ALIMENTARE CU CARBURANT CU SISTEM DE INTRERUPERE A ALIMENTARII CU CARBURANT
REOSTAT CU REOSTAT
AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" CU ACCELEROMETRU
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 2 TURATII 140W AERO FARA PRIZA DE AER
RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
MODUL CLAPETA (ADMISIE AER MOTOR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze - Transmisie
CUPLU RAPORT RAPORT PUNTE 17 X 61
STIL ROATA (JANTA) ROATA SIROCCO 15 INCI
BLOCARE DE SIGURANTA CUTIE DE VITEZE FARA BLOCARE DE SIGURANTA BV
TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP BE4/5 L
DIFERENTIAL (CUTIE) DIFERENTIAL 77
PNEURI (DIMENSIUNI, TIP) PNEU 195/55 R15 85H NERANFORSAT
ROTI MONTATE ROATA 6 INCI
ROATA (TIP) MONTARE ROATA CU JANTA DIN ALIAJ
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
ANTIBLOCARE ANTIBLOCARE ROATA
ANTIFURT ANTIFURT STANDARD
FRANA PRINCIPALA REPARTITIE ELECTRONICA DE FRANARE
FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII FARA SISTEM ESP
VARIANTA ASOCIATA FRANA ABS TEVES MK70
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
PEDALIER (TIP) PEDALIER ALUMINIU
Caroserie Echipamente
AVERTIZOARE SISTEM DE AVERTIZARE STANDARD
ANTENA ANTENA SCURTA PAVILION
DECORATIUNE (ADEZIVA) ORNAMENT SPATE DE INCADRARE NEGRU MAT
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE + TREAPTA PEUGEOT
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORIZARE PE MOTOR ELEMENTE DE IZOLARE FONICA TABLIER + CAPOTA MOTOR + GRUP MOTOPROPULSOR
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE FATA SPORT IN CULOAREA CAROSERIEI + INEL - SPATE STANDARD IN CULOAREA CAROSERIEI
APARATOARE DE NOROI (BAVETA) APARATOARE DE NOROI IN FATA ROTII SPATE
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
PROIECTOR SPECIAL (OPTICA DUBLA) PROIECTOR CU PARABOLA DUBLA
RETROVIZOR EXTERIOR (PARTEA CONDUCATORULUI) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
RETROVIZOR EXTERIOR (PARTEA PASAGERULUI) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
ROATA DE REZERVA ROATA TIP ROLA
ACCESORII EXTERIOARE RETROVIZOARE EXTERIOARE VOPSITE MANERE EXTERIOARE FATA VOPSITE SPATE NEUTRE
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA ASFERICA RETROVIZOR EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
GEAM SPATE (GEN) LUNETA CU INCALZIRE
GEAM (ASPECT) FUMURIU + FUMURIU INCHIS IN SPATE
GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
GEAM (TIP) PARBRIZ CARE NU ESTE IZOLAT TERMIC
Echipament interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
BRICHETA BRICHETA FATA
TETIERA SPATE TETIERA SPATE REGLABILA
TETIERA FATA TETIERA FATA ARTICULATA
SCAUN SPATE BANCHETA SEPARATA RABATABILA
MASCARE BAGAJE FARA PANOU DE MASCARE BAGAJE
CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GRADARE VITEZE GRADATIE IN KM/H
ACCESORII (MANERE) MANER PASAGER FATA + SPATE + INCHIZATOARE
TUROMETRU TUROMETRU CU AC
AMBALARE SISTEM AUDIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
CONSOLA CONSOLA CU SISTEM DE INCALZIRE SPATE
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
COMANDA LA DISTANTA MONTAJ COMANDA LA DISTANTA CU RAZA DE ACTIUNE IMBUNATATITA
INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
ILUMINAT COMPARTIMENT DEPOZITARE LUMINA IN COMPARTIMENTUL DE DEPOZITARE OBIECTE MARUNTE
ILUMINAT DE PORTBAGAJ VOLUM INCARCARE COMANDA AUTOMATA PENTRU ILUMINAT PORTBAGAJ SAU VOLUM DE INCARCARE
ECHIPAMENT PLANSA DE BORD PANOU FRONTAL ASPECT METAL STRALUCITOR SOFT + BUTON ALUMINIU
LUMINI INTERIOARE DIVERSE FARA LAMPA INTERIOARA DIVERSE
TABLOU DE BORD (CARACTERISTICI) GRADATIE 220 KM/H SAU 135 M/H FUNDAL NEGRU CONTUR CROMAT
TUROMETRU (PRIZA DE INFORMATII) TUROMETRU INFO CALCULATOR
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
HUSA DE PROTECTIE CU HUSA DE PROTECTIE BATERIE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUSTINERE LATERALA FIXA CONDUCATOR
REGLARE SCAUN FATA DE PASAGER SUPORT DE SUSTINERE LATERALA FIXA PENTRU PASAGER
RABATERE SCAUN FATA DE CONDUCATOR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
ELMENTE DE GARNITURA INTERIOARA JERSEU PAVILION PH2 + MONTANT PH2
INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
CD FARA MONTARE COMPACT DISC
CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
ACTIONARE GEAM SPATE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
ACTIONARE GEAM DE CONDUCATOR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA ELECTRICA
AFISAJ AFISAJ (RADIO + CEAS + SI SAU T°,CD)
CEAS FARA CEAS
INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
CALCULATOR DE BORD CU CALCULATOR DE BORD
PACHET ECHIPAMENT FARA PACHET ECHIPAMENT
RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
COMANDA INTERIOARA DE USA (ASPECT) PALETA USA CROMATA + ORNAMENT NEUTRU
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROTECTIE POST FATA FARA PROTECTIE POST FATA
PARASOLAR FATA PE PARTEA CONDUCATORULUI + PASAGERULUI (FARA INSCRIPTIONARE)
DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE + PALETA CROMATA
RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD3"
REFRIGERARE SISTEM DE REFRIGERARE SIMPLA
REGULATOR DE VITEZA FARA SISTEM DE REGULARIZARE VITEZA
INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
REOSTAT CU REOSTAT
DEPOZITARE (ALTELE) COMPARTIMENTE DEPOZITARE OBIECTE MARUNTE IN USILE FATA + SPATE + BUZUNAR PE SPATARUL SCAUNULUI
COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
COVORADS DE PODEA MOCHETA TESUTA DILOUR F550
TEMPORIZATOR DE ILUMINAT TEMPORIZATOR FIX
CONTACT TRANSPONDER
ADAPTARE GARNITURA MANER CROMAT + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
INCUIERE COMPARTIMENT DEPOZITARE COMPARTIMENT DEPOZITARE OBIECTE MARUNTE FARA SISTEM DE INCUIERE
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L2 400
DEMAROR DEMAROR CLASA 6
ILUMINAT DEOSEBIT FARA ILUMINAT SPECIAL
MULTIPLEXARE MONTARE MULTIPLEXATA
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA GERMANIA
ATMOSFERA ATMOSFERA NORMALA
CASETA DE PRIM AJUTOR AMBALARE/ECHIPARE TRUSA DE PRIM AJUTOR
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII
SOC LATERAL USA CARE NU ESTE INTARITA
SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
RULARE DRUM CORECT
MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
TRIUNGHI DE PRESEMNALIZARE PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
Multumesc din suflet,dar tot nu m-am lamurit daca filtrul de particule are acel REZERVOR de ULEI ADITIVAT!M-am uitat sub masina dar nu dau de el nicicum.In rest are tot ce scrie in VIN!Multumesc inca o data !Originally posted by dezkreator View PostCaracteristicile vehiculului
Linie de produs 206
Informatii generale
LINIE DE PRODUS 206
MONOGRAMA JBL
Alimentare motor
CARBURANT MOTORINA
REOSTAT CU REOSTAT
Echipament interior
CEAS FARA CEAS
REOSTAT CU REOSTAT
CONTACT TRANSPONDER
Electricitate
Marci echipamente
Diverse
RULARE DRUM CORECT
