Deci sa inteleg ca pretul nu este foarte mare si ca daca mecanicul nu gaseste alte "bube" masina merita! Nu o iau ca sa fac raliu cu ea ci doar sa o folosesc pt nevoile personale...deci cei 70 CP nu cred ca vor fi "lenesi".
1.9 D
Parerea mea e ca merita cel mai bine intretinut pe care il gasesti dintre astea. 206 nu sint prea multe de vinzare la SH (oare de ce??????? ), am urmarit citeva luni piata si din Ro si D....Dar intre 1,9 D si 1.1i sau 1.4i care ar merita mai mult? Care este mai fiabil?
Si sa aiba macar AC....206 1,4 HDI X-design
et voila....
1998 Peugeot 206 1.9 D - Technical specifications
bodywork
Type 4/5S HBK
Designer
Number of doors 3
dimensions & weights
Wheelbase 2442 mm 96.1 in
Track front 1425 mm 56.1 in
rear 1416 mm 55.7 in
Length 3835 mm 151 in
Width 1652 mm 65 in
Height 1432 mm 56.4 in
Ground clearance 110 mm 4.3 in
Kerb weight 1010 kg 2227 lb
Weight distribution
(Front) 65.20 %
Fuel capacity 50
litres 11
UK Gal 13.2
US Gal
aerodynamics
Drag coefficient 0.320
Frontal Area 1.97 m2
Cx 0.63
engine
Code DW8
Manufacturer Peugeot
Type S-4
SOHC
8 valves total
2 valves per cylinder
Main bearings 5
Construction
Bore × stroke 82.20mm × 88.00mm
3.24 in × 3.46 in
Bore/Stroke ratio 0.93
Displacement 1868 cc
(113.992 cu in)
Unitary capacity 467 cc/cylinder
Compression ratio 23.00:1
Fuel system Bosch diesel injection pump
Aspiration Normal D.
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output
(DIN) 71 PS (70.0 bhp) (52.2 kW)
@4600 rpm
Max. torque
(DIN) 125.0 Nm (92 lbft) (12.7 kgm)
@2500 rpm
Maximum rpm
Coolant Water
Specific output 37.5 bhp/litre
0.61 bhp/cu in
Specific torque 66.92 Nm/litre
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph
0-100km/h 16.10s
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile 19.90s
0-Kilometre 37.10s
Top speed 161 km/h
Fuel Consumption
CO2 Emissions
Power-to-weight 69.31 bhp/ton
chassis
Engine location Front
Engine alignment Transverse
Steering rack & pinion PAS
Turns
lock-to-lock 3.300
Turning circle 10.20 m
Suspension Front I.MS.
Rear I.TB.
Wheels F/R /
Tyres F 175/65 R 14T
Tyres R 175/65 R 14T
Brakes F/R VeDi/Dr-S
Brake ∅ F/R / mm
Braked area
Transmission 5M
Drive FWD
Top gear ratio 0.75
Final drive ratio 3.59
Sper sa-ti fie de folos.... :!:Give me fuel, give me fire, give me that which I desire... :gunsmilie:
cu placere.
cei de pe "www.carfolio.com" de unde am luat info, nu au dat si consumul...
valorile trecute de tine aici sunt aproape identice cu ce scoate varul meu...7.5 oras si sub 5 in afara la 120 constantGive me fuel, give me fire, give me that which I desire... :gunsmilie:
Deci se pare ca e un consum foarte bun pt acest motor si masinutza chiar este buna! Abia astept sa vad ce zice mecanicul si sper sa intru si eu in randul posesorilor de "pejo"!
Eu zic ca 7,5 in oras e un "scor" foarte bun iar sub 5 afara este foarte bine!
O sa ma uit si eu pe "www.carfolio.com" sa vad si alte date despre Clio Bicorp 1,2i 75CP, pt ca oscilam foarte mult intre pejo 206 si reno clio bicorp...
Pai decat un clio cu 1.2i mai bine un 206 cu 1.9D si nu spun asta pentru ca esti pe forumul nostru, dar dieselul fara turbo costa mai putin la intretinere. Motorul diesel este mult mai rezistent decat cel de 1.2i, ce nu are un consum foarte mic de benzina, si pentru oras este perfect.Resoftari, chiptuning, dpf fix Peugeot si Citroen | Preturi incepand de la 250 lei. Detalii la 0751.194.100.
Motorul de clio bicorp 1,2i 75CP consuma undeva in jur de 7l/100 km in oras, deci tot cam cat Peugeotul, dar si eu prefer Peugeotul 1,9D datorita faptului ca motorul se pare din ce am aflat de aici si din ceea ce mai stiam ca este mai bun decat cel de la Clio, asa ca sper sa zica ok mecanicul si sa il cumpar. :smile2: si o sa va anunt daca intru sau nu in clubul "pejo-istilor" – eu sper sa intru :biggrin:.
Mai aveam ca optiune si Opelul Corsa indiferent de motorizare, dar parca tot 206 arata mai bine si e mai elegant...:smile2:
daca vrei sa vezi ce inseamna o masina cu mii de probleme enervante si sacaitoare ia-ti renault si vei regreta in fiecare zi aceasta alegere...dupa ce ti se vor rupe din seninprimele 3 cabluri de acceleratie o sa intelegi ce vreau sa spun...Give me fuel, give me fire, give me that which I desire... :gunsmilie:
Doar cablurile de acceleratie??? Nu ai uitat pompele de benzina, rampa, etc???
Las-o balta, sper sa nu jignesc pe nimeni, dar Reno nu e masina!!! E un magnet pentru "atras" service-uri!
Opel Corsa.... Ahem, motorul si articulatiile fata dupa 1,5 ani sunt kaput.Nea Enzo Ferrari a lucrat la Alfa inainte ca el sa-si faca firma Ferrari si el a afirmat: "Cand vad o Alfa imi scot palaria"
Eu inteleg ca aici e forum despre peugeot, dar oameni buni, nu exista doar Peugeot pe lumea asta!! Si Opel e masina buna si Renault.
Daca le criticati in asa hal, atunci ce sa mai zic de alte masini mai slabe?
Daca e intretinuta si nu iti bati joc de ea, orice masina poate da un randament bun si poate avea o intretinere acceptabila dpdv al costurilor!
