How to set off the seatbelt beep?
  • [How To] How to set off the seatbelt beep?
    When you don't wear your seatbelt and you drive faster than 15km/h you hear a warning sound, the seatbelt beep. The seatbelt beep will sound softly for 30 seconds and very loud for 90 seconds after that the beep will stop. A lot of CityBug user don't like the seatbelt beep and there is a option to set the seatbelt beep off.
    After this modification the seatbelt beep is set OFF and you will no longer hear the seatbelt beep again.
    I want to remind you that the seatbelt beep can be set ON again at any time.
    Just use the instruction and reverse the setting of the seatbelt beep.
    Disconnecting the battery of the car will also set the seatbelt beep ON again.
    When you set OFF the seatbelt beep and you drive without your seatbelt on, the beep will not sound but the red indicator on your display will still flash like it does normally. Setting the seatbelt beep OFF will not affect or change anything to the other safety systems in your car.
    Although this modification is completely save, I can't take any responsibility for it.
    When you make use of the instruction, it's at your own risk.
    Instruction to set OFF the seatbelt beep:
    • first set the ignition ON
    • set the distance counter to ODO by pressing the distance counter knob
    • set the ignition OFF
    • set the ignition ON again
    • press the distance counter knob again for 10 seconds
    • close the seatbelt and keep the distance counter knob pressed in
    • the display of the distance counter will show the tekst: "b - on"
    • release the distance counter knob again
    • press the distance counter knob again shortly to switch between:
    "b - on" and "b - off" and set it to: "b - off"
    • set the ignition OFF again
    • modification done!!
    REFZ aka The CityBug | 107XS Modified & Ziptuned | © 2006-2009
    This feature is not available for cars sold in Romania before 2008.
    Nu exista aceasta optiune pentru masinile vandute in Romania, cel putin pana in 2008.
    Peugeot 107 1.0E Rosu
