a3a-i norocoasa
  • a3a-i norocoasa
    Binecunoscuta eroare "antipolution system" se instalese si la mine de 2 x.Prima oara a fost din cauza benzinei de kko,am completat cu efix pana la full si a disparut.A2a oara a fost din cauza mersului subturat,am condus o zii mai turat si a disparut.dar cum se stie si in mitologia popula cifra numarul 3 este cu puteri mistice si nebanuite.Asa ca uite ...a venit si a3a oara si cum era de astepta cu ceva in plus,pe langa acel "antipolution system fault" acum apare si nou inscrisul la competite "antipolution system inoperative".Daca imi zic aia la peugeot vreun scor d-ala cum le place lor oare merita sa ii dau foc direct sau nu?
    Nu vreau sa traiesc mult,doar cat sa prind apocalipsa.
    Nu bag mana in foc dar:
    The ecu permanently monitors the elements essential for checking emissions : .
    a) Petrol :
    *misfiring
    *the efficiency of the catalytic converter
    *the condition of the oxygen sensors
    *any component or system, the failure of which can cause the tolerated *emission limits to be exceeded (air injection, egr, automatic gearbox)
    *the continuity of the canister purge solenoid valve circuit
    LIGHTING OF THE ENGINE DIAGNOSTICS WARNING LIGHT (EOBD)
    The engine diagnostics warning light indicates the failure of a component or a system relating to emissions, when this failure involves an increase in emissions with a level exceeding the legislative limits .
    Misfiring threatening to damage the catalytic converter cause the engine diagnostics warning light to flash .
    The engine diagnostics warning light is only used where there is a risk of damage to the engine or a safety risk for the occupants of the vehicle .
    The light comes on at the end of 3 consecutive driving cycles (one driving cycle comprises starting the engine, a driving phase during which any malfunction would be detected, and switching off the engine) .
    The diagnostics warning light goes out after 3 consecutive driving cycles, during which the monitoring system responsible for activation no longer detects any malfunction; the fault changes to intermittent .
    The ecu can then clear the intermittent fault if, during 40 heating cycles, this fault has not reappeared .
    A heating cycle is a period of vehicle operation which is sufficient for the engine temperature to increase by at least 22 ° from starting the engine, and for it to reach a minimum temperature of 70 ° .
    Intermittent faults can also be cleared using the diagnostic equipment DIAG 2000
      S-a intamplat la 1 km dupa ce am alimentat.Probabil vreun injector satul de benzina romaneasca de calitate "superioara",fiindca nu merge "rotund" motorul decat foarte rar.
        doar regenerare fap scapi sub 3 milioane...
          Scapa scapa, dar el are benzinar...
          VIATA E GREA, DA' TRECE...:)
            Bobina de inductie de pe cilindrul nr.3.Fuse,fuse si se duse.Cred ca imi iau un tester de peugeot,sa dau 180 ron in loc de 480 pt o bobina amarata.
              Bobina Bosch?
                Bobina era Sagem.......Made in France....
                  Eheheee,tocmai mi-a mai cazut inca o bibina,pana acum am schimbat 4 asta-i a5a si a6a cred ca o sa pice cat de curand.
                    Nu-mi vine sa cred asa ceva! Imi pare rau si sper ca cele schimbate sa tina de 10 ori mai mult indiferent ca mai dai sau nu masina
                    App unde le-ai schimbat pana la urma? Ai scapat mai ieftin sau tot cu cat mi-ai zis ultima data?
                      pai prima oara la pejo mi-au luat aproape 10 mil,dintre care 1,5 diagnosticarea si 1,5 mil / bucata fara tva si am skimbat 3.Apoi am dat 4,5 mil pt diagnosticare si 1 bobina iar bobina m-a costat mult mai mult ca la pejo.Oricum hotarasem sa o schimb chiar eu pe aceasta fiindca nu e nici o inginerie dar....azi dimineata cand am plecat cu ea toate bune si frumoase )
                        La mai multe zile ca cea de azi
                          Mane tu ai masina inmatriculata cu numere de anglia?
                            Da. X-ul reprezinta anul(2000)
                              Vazusem la stiri pe unu cu un leutz ca al tau facuse accident destul de urat si avea numere de Irlanda ,fara ornamente si volan pe stanga si eram plecat de acasa iar telefonul acasa..k d-aia e weekend
