Masini chinezesti
  • Byd S6 - SUV chinezesc
    • R8 şi Enzo cu motor de 1,6 litri
      • Si 5 trepte. ))
        • Extraordinar ma baiatule, astia se opresc vreodata? Pui un pis de motor pe 'supersportul asta'?) De ce draq nu pun un motor de scuter de 250 cmc sa dea bine la taxe. Cand vezi unu de asta la semafor, te astepti sa te faca praf si cand colo il fac cu o dacia 1410 1.4 intretinuta.:biker::blush:
          • SAIC, un cunoscut producator de masini chinezesti, anunta debutul marcii Roewe in Polonia. Acest lucru e programat pentru 2010.
            Articol: Roewe Cars in Europe Starting in 2010
            However, in order to comply with European regulations, Chinese models must pass a series of tests but, according to gasgoo.com, this is only a matter of time. Two models, internally known as 550 and 750, are in the process of snatching the official go-ahead to be sold in Europe.
            According to the aforementioned source, the two models are currently quite attractive for Chinese buyers, as they are both equipped with top-notch safety features, above the competition. Pricing for the 550 models will start at 60000 PLN (this is around 21,000 US dollars). Engine lineup will most likely include a 1.8T gasoline engine developing 160 horsepower, but a turbo unit might be offered as well, with maximum output going around 133 horsepower.
            In the meantime, BAIC is also looking at ways to start production in Europe. A new plant in Lithuania is currently in talks, country officials revealed in August.
            • Daca incepem sa cumparam si masini chinezesti...ne-am dus pe copca. Pe bune ! Cocurenta in mediul academic este acerba, nivelul de pregatire creste in continuu si deja in cativa ani va fi prima economie mondiala. Abia atunci vom vedea ce inseamna acest lucru cu adevarat , si va spun de acum :nivelulnostru de trai va scade in continuu . Europa si SUA nu vor mai fi lideri in lume, sunt chiar in declin accelerat. Bogatii se scot, saracii vor plati din greu.
