Rezultate Euro NCAP Peugeot 607 ****
  • Rezultate Euro NCAP Peugeot 607 ****
    While the 607 earned its four stars, it did not perform as well as some other large cars have done. The driver's sill and the door pillar were found to be unstable after the frontal impact and the door no longer fitted its opening. The loads acting on the driver's chest in both tests were high and the areas his knees might strike were unforgiving. Meanwhile, its performance in the side impact was good, but not among the best. Both children ran the risk of chest injury, and protection for pedestrians was poor.
    Impact Protection
    Frontal Impact The driver and passenger were reasonably well protected. Impact forces fed into the passenger compartment caused its sill to buckle and the door pillar to rotate outwards. Afterwards, the door could not be opened by hand. The driver's head and neck were well protected but the forces affecting his chest were high for a large car. Also, loads were fed into his shin below the knee, which can cause disabling injuries. The centre rear belt was of a three-point type that gives better protection than a lap-only belt.
    Side Impact The 607's head-curtain and thorax airbags suggest it is capable of giving excellent protection but while it achieved a good standard, other similar large cars have done better. That said, the airbag curtain provided good head protection for those in the front and rear.
    Child Protection There is a manual switch to turn off the passenger's airbag. There are labels to indicate this, they could peel off, and did not warn of the danger of death or serious injury if a rear-facing restraint was put on the front passenger's seat with the airbag active. There is just one set of ISOFIX anchorages provided; so only one of the seats could use it although both were approved to do so. The seats were also approved to use a top tether with the ISOFIX anchorage but the car is not fitted with the necessary attachment. Both seats performed patchily and the children risked chest injury from the frontal impact.
    Pedestrian Protection Peugeot says it built protection into the 607 at the design stage. But its results did not impress.
    Model History & Safety Equipment of Car Tested The 607 was launched during 2000. The '02 model is fitted with a driver and passenger frontal airbags, side airbags, head-protecting (curtain) airbags, front belt pre-tensioners and load limiters, ABS and ASP as standard.
    Film: Crash-test 607
    http://www.euroncap.com/tests/peugeot_607_2002/119.aspx
    Pare mult cand vezi 4 stele din 5.. dar cand urmaresti filmuletul.. pare dezastruos!! Imi imaginam ca un elefant cum e 607 poate mai mult..
    Oricum sa ne fereasca Dumnezeu pe toti de aceste necazuri!
      pai ce ai vazut se datoreaza unui simplu fapt,fiindca francezul merge pe ideea cum ca masina ar trebui sa absoarba forta impactului astfel incat soferus sa fie bruscat cat mai putin,Asa ca masina se face pilaf pt a absoarbe cat mai multa energie in urma impactului.Daca ai fost atent ai fii observat ca masina se deterioreaza pana la 10-20 cm fata de parbriz unde incepe cocpitul iar de acolo brusc nu se mai misca nimic astfel incat sa nu te trezesti cu bujiile in gura.
      Nu vreau sa traiesc mult,doar cat sa prind apocalipsa.
        Aaaaaa Oricum nu vreau sa patesc asa ceva vreodata... Cand vad masina imi da impresia ca se deformeaza ff greu!!
          nimeni nu vrea..dar se intampla din pacate si nu se stie cine,cand si cum.De aceea inca platesc casco aproape 2000 euro pe an la asiban,fiindca la un impact frontal cu 100 la ora pun pariu ca numai ramane nimic de reparat la ea
            Da asa e sa ne fereasca Dumnezeu de asemenea intamplari
