Rezultate Euro NCAP Peugeot 206 ****
  • Rezultate Euro NCAP Peugeot 206 ****
    The 206 is a small car that gives an all-round performance protecting the adult occupants. The structure provided a safety cage with the driver’s door frame showed only minor distortion. There are safety concerns over the fitting of a manual switch to turn off the passenger’s airbag. However the 3 year-old’s child restraint failed to contain the child’s head in both front and side impact. Also the 1½-half-year old’s restraint was forward facing and did not protect the child’s neck in the frontal test.
    Impact Protection
    Frontal Impact The 206 maintains the occupant’s survival space in the frontal crash. The front seat belts are fitted with pretensioners which are designed to limit forward movement in the event of a crash. Load limiters are also fitted but despite this the passenger’s chest loading was a little high. Only a simple two point static belt was fitted in the centre rear seat, which can cause severe spinal and abdominal injuries. The knee impact area had hard areas which would give higher loads than those experienced in the test if knees impacted directly onto them. There was some padding which will help to spread the loads, although this was not sufficient to remove all worries of damaging knees and upper legs. The extent of the movement of the brake pedal rearwards gives rise to an increased risk of injury to the driver’s feet.
    Side Impact For a car without side-impact airbags the 206 is well designed and has done well to give a low risk of injury for all the body regions. The dummy’s head contacted the front edge of the central door pillar as well as the bottom edge of the window, but without sufficient force to cause concern over serious injury. The abdomen had some loading from the arm rest and the pelvis was contacted by a foam block in the door trim.
    Child Protection A passenger airbag is standard and Peugeot have addressed the risk to children in rear facing child restraints in the front by fitting a switch so that the airbag can be turned off with the ignition key. The consequence of not setting the switch correctly could be fatal and the warning of this condition was not foolproof. The removable warning labels had no text to explain the risk of serious injury or death to a child in a rear facing restraint. The child restraints were both forward facing and provided protection in the frontal test, except that for the 1½-half-year old the neck loads were high which is a common failing for forward facing seats. In the side impact the seats were also good performers, except that the 3-year-old’s seat did not keep the child’s head contained within the seat wings.
    Pedestrian Protection The pedestrian protection score come almost entirely from the adult and child impact assessments which is the same as most of the cars we have tested in this class. However two of the leg impact sites were also graded as giving weak protection.
    Model History & Safety Equipment of Car Tested The 206 was introduced in Sept 1998. The 2000 model year car features dual frontal airbags, front safety belt pretensioners and load limiters & ISOFIX anchorages on the front passenger seat as standard. Optional equipment: side airbags (head & thorax) and ABS.
    Film: Crash-test 206
    http://www.euroncap.com/tests/peugeot_206_2000/72.aspx
    deci in concluzie...e destul de sigura...
      Sa te fereasca Dumnezeu mai bine! la cat e de mare masina...... numa de stele sa nu ai nevoie. Era un post mai vechi cu un accident cu un 206 care la accident frontal cu 30km/h a luat dauna totala pe ea! Daca intra cu 50h cred ca omul avea sansa 50% sa ajunga la urgenta unde lucreaza nevasta-mea!!
      Nu zic ca e un lucru rau, sa fim intelesi. Dar tot e mai bine ca-n altele dar sa nu ne AMAGIM cu apa rece.....
      PS
      eu am un 206
      www.fanmusic.ro & www.pravaliacucarti.ro
        Paranoia, stai linistit ca e destul de sigura pentru varsta si clasa ei. Nu trebuie sa te dai zmeu, dar tot e mai sigura decat jumate din masinile de pe strada. Putine masini sunt cu adevarat sigure, si nu ma refer la NCAP.
          Off topic: am vazut crash-testul pentru nu stiu ce masina chinezeasca.. tragic .. la 206 spatiul pasagerilor are sanse foarte mari sa ramana nedeformat.. absoarbe impactul partea motorului (..ref. la dauna totala)
            uitativa aici un pug 206,accident frontal la 40km/h!!precizez ca nu a lovit un zid ci a lovit o masina!!.. un Santa Fe...!!
              Sifonat bine...probabil pentru protectia pietonilor ... cred... sa preia socul sa nu-l omoare pe nenea pietenol... Daca sa s-a nimerit sa fie in loc de pieton un santa fe... asta este ... macar santa fe-ul a fost protejat.... Doamne fereste! Nu doresc la nimeni asa ceva!
                Este evident ca daca lovea un zid impactul ar fi avut o forta mult mai mica.
                Ce viteza avea Santa Fe-ul? Presupun ca pe aproape de atat. Si aia e o masina de 1600 de kile.
                Mi se pare cat se poate de rezonabil cum arata masina.
                  da cum ai vrea sa arate un 206 lovit de un Santa Fe?... Vorba lui SonyAD ...aia are 1600kg... arata chiar bine as putea zice ....Acum sa fim seriosi .. la impactul frontal sunt mai multi factori care pot stabili gradul de avarie a masinii ... nu doar viteza ... conteaza daca ai intrat pe perioada de franare ... daca "te-ai dus ca bou" fara sa pisti frana ... daca ai "norocu" sa dai intr-un H3 nu se compara cu un impact frontal cu o masina de aceeasi clasa cu 206.... ca una e sa intri cu 40 intr-un Hummer... una e sa intri intr-una mai mica.... OPTIM E SA TE FEREASCA DUMNEZEU DE AMBELE SITUATII!
                    Originally posted by esku View Post
                    da cum ai vrea sa arate un 206 lovit de un Santa Fe?... .... OPTIM E SA TE FEREASCA DUMNEZEU DE AMBELE SITUATII!
                    Mai sincer ... as vrea ca 206-le sa arate chiar mai bine decat arata cand era nou , sa fie polishat, tunat, sa aibe eleron si eventual si jante de 16inch ... dupa un impact cu un santa-fe, santa claus... sau chiar h3... Da cum ai spus si tu ... OPTIM E SA TE FEREASCA DUMNEZEU DE AMBELE SITUATII!
                      si santa feu cit avea?
                        Nu doar viteza. Şi masele vehiculelor. Frānele contează doar īntr-atāt īncāt afectează viteza finală.
                        Şi, desigur, construcţia vehiculelor.
                          mama are la peugeot 206 , 6 airbaguri astea sunt toate care se pot pune ??
                          http://img252.imageshack.us/img252/2936/1928rj4.png
                            sincer cre ca da...
                              Arata foarte bine avand in vedere ca santa-fe-ul are 2 tone fara cateva zeci de kg, cu tot cu sofer...(1850 kg gol)
                              mod edit: Vezi in Regulament, 2.Reguli si recomandari pct.2
