Rezultate Euro NCAP Peugeot 407 *****
  • Rezultate Euro NCAP Peugeot 407 *****
    The 407 has a very strong and stable passenger safety cage. It scored close to the maximum number of available points in the frontal impact. The restraint systems and airbags, including a knee airbag for the driver, protected occupants and kept the driver’s chest and head away from the steering wheel.
    Side impact protection includes side airbags and a curtain airbag. Child protection was good but pedestrian protection proved to be average, with no protection given where an adult’s head would most likely strike.
    Impact Protection
    Frontal Impact Dual stage non-tethered airbags for the driver and front passenger and belt pre-tensioners plus load limiters worked well. The driver’s knee airbag was also very effective.
    The body showed minimal deformation at its sill and screen pillar and only minor footwell intrusion. Rear seats each had three-point belts with load limiters.
    Side Impact The seat-mounted thorax and pelvis airbag and head curtain airbag worked efficiently; the curtain also protected those sat in the rear.
    However, the 407 was penalised in this section of the tests because forces transferred in an unrealistic manner to the test dummy’s spine, so reducing the level of forces recorded by instrumentation in its chest.
    Child Protection The recommended restraints were forward-facing Britax Romer Duo Plus, which were fitted to the car using ISOFix mountings.
    Both children were protected in the frontal and side impact although the older child’s chest load in the frontal impact was just a little on the high side.
    The 407 has a manual on/off switch for the passenger frontal airbag. Instructions for using it were given in a non-permanent pictogram and a written label on the passenger’s end of the fascia
    Permanent labels fitted to both sides of the passenger’s sun visor warned against placing a child in a rear-facing seat opposite an airbag.
    Pedestrian Protection The bonnet’s leading edge and, though less, the bumper gave protection. Limited protection is available where a child’s head might strike, but none was evident for an adult.
    Model History & Safety Equipment of Car Tested Standard equipment on the 407 includes driver and passenger frontal airbags, side airbags, head protection curtain airbag, driver’s knee airbag, front safety belt pre-tensioners and load limiters, rear belt load limiters, driver and passenger seat belt reminders, ISOFix, BA, ASR, ESP, ABS, and tyre pressure monitoring.
    Film: Crash-test 407
    http://www.euroncap.com/tests/peugeot_407_2004/189.aspx
    Citat din Top Gear ... daca vrei sa protejezi pietoni ... atunci calca-i cu un 407 ...
    :naughty: Fost proprietar de 407 SR Confort - 1.6HDi, 110 CP, ... Actual posesor de Skoda Superb 1.9 TDI - nu se compara cu 1,6HDi care este splendid ... Viitor posesor de ... tot 407, dar poate coupe!
      cred ca era ceva de genul "daca vrei sa fii calcat de o masina atunci aceasta trebuie sa fie".
        asa e dadu ... am revazut emisiunea aseara! ... imi cer scuze!
          Mie mi se pare bestial ca botul poate fi atat de sigur pentru pietoni fara compromisuri la design....
            e..nu e chiar asa.....sunt sigur ca nu scapa daca dai in pietoni cu 407..ar trebui facut un experimeint..poate vom vedea la o intalnire daca scapa pietonu )
            Peugeot 407 SW,2.7HDi V6,204 CP,GRI,PANORAMIC,DUBLUCLIAMTRONIC,XENON
            Peugeot 206 RC,177 CP,jenti 16,piele,DVD,Climatronic,NEOANE ALBASTRE,Xenon doar pe scurta+proiectoare;)..curand si pe lunga!
              Daca il calci pe pieton cu 407 sigur nu mai scapa la cat de grea este masina. Poate doar daca il lovesti frontal deoarece capota este extraordinar de flexibila si motorul este asezat foarte jos.
                E clar: nu ai cum sa-l calci pe..piton(la cat de joasa ,abia calci un soarece),unghiul inclinat il..culca pe capota,si il prelinge usor intr-o parte,deci singurul pericol pt pieton e sa fie calcat de o alta masina..) in rest scapa ieftin cu vreo doua picioare rupte...=))
                I love this Car !;)
                  sau la cat de joasa e cu adibaosi rupti)
                    eu am lovit o baba care traversa ca gloaba prin mijlocu intersectiei... si sa detaliez momentu care mi'a ramas intiparit .... a aruncat'o pe capota ... capota s'a indoit si apoi a revenit impingand'o pe baba ca o prastie ... dupa care a cazut pe asfalt ... urmare.. baba n'a avut nimic serios decat o vanataie sau doua... capota indoita si zgariata de la cosu ei de rachita ... apoi si'a revenit probabil de la soare ramanand doar zgarieturi'le ...
                    2005 407 ST Executive 2.0 hdi 136cp
