Rezultate Euro NCAP Peugeot 307 **** - Anul 2001
  • Rezultate Euro NCAP Peugeot 307 **** - Anul 2001
    The 307’s strong safety cell for passengers remained intact in the tests. The driver’s door opened normally after the frontal impact and the footwell retained its shape. During the impact, the driver’s chest hit the steering wheel and the passenger’s head struck the facia. Both events increased the injury risk to vulnerable body areas. The results for the side impact test were very good, however. The passenger’s frontal airbag can be de-activated via a switch so that a rear-facing child restraint can be installed on the front passenger’s seat. A second key could be used to deactivate the airbag while the engine is running. Even so, the warning given on the instrument panel remained correct.
    Impact Protection
    Frontal Impact The body proved very strong after the impact and showed no distortion of its screen pillars. The footwell remained virtually undisturbed, too. However, structures behind the fascia increased the risks for the driver. The centre rear seat was fitted with a three-point belt that provides superior protection to that of a lap belt. The front belts had reel-mounted pre-tensioners and were load limited, reducing the risk of injury for occupants.
    Side Impact All-round protection was provided, including a head curtain airbag. Full marks were achieved, which is impressive for a car of this size.
    Child Protection Peugeot-branded Kiddy Reboard restraints were chosen for testing, facing forwards for the older child and rearwards for the younger. Each used ISOFIX mountings. The children’s heads were protected in the frontal impact but exposed in the side impact. The passenger airbag could be turned off using a key-operated switch. A pictogram and text label on the end of the fascia and on the stowed passenger’s sun visor mentioned the switch, but neither warned that injury or death could result from using a rear-facing restraint opposite a 'live' airbag.
    Pedestrian Protection The car provided reasonable protection where an adult’s or child’s head might strike, but the bumper and the leading edge of the bonnet were uncompromising.
    Model History & Safety Equipment of Car Tested The 307 was launched in Europe during March 2001. Equipment on the 2001 model (car tested) includes dual (smart) frontal airbags, side airbags (thorax) , head protection airbag (curtain), front belt pre-tensioners and load limiters, three-point centre rear belt, ABS, brake assist emergency braking and auto warning as standard. ESP is optional.
    Film: Crash-test 307
    http://www.euroncap.com/tests/peugeot_307_2001/107.aspx
    oricum, pt. o batranica lansata in 2001 (deci gandita candva in mileniul trecut) peugeot 307 se comporta mai bine la testul EURONCAP decat unele masini mai noi si cu mari pretentii: a se vedea Skoda Octavia 2 si Seat Leon, precum si noul Honda Civic care are rezultate destul de slabe pt generatia sa
    eu zic ca sta bine, asteptam 308 sa vedem ce iese
      Daca mai puneau toate punctele pentru piuitori la alarma sau mai stiu eu ce, poate ar fi luat si 307 5 stele. Oricum, pentru mine doar impactul lateral si cel frontal conteaza (si stabilitatea).
        stabilitatea dupa mine e super marfa ... eu sunt f multumit ...
          Dat fiind ca aceste teste sunt realizate de "o societate privata" pun la indoiala orice rezultate...
          Stelele astea vin si ele direct proportional cu "datul din urechi" al unora si altora...
          Peugeot-ul oricum este foarte prigonit in media din pricina vanzarilor destul de incomode, inclusiv pe piata germana...
          In alta oridne de idei, nu stiu pentru ce se fac aceste teste, in conditiile in care la masinile nemtesti de exemplu, este foarte clar specificat ca ei nu mai au nicio responsabilitate in cazul depasirii vitezei de "90 km la ora"!!!
          Deci...
            De regula testele se fac la o viteza de 50 km/h. Aceasta o spun ca fost angajat al unei societati care produce sisteme de siguranta pentru automobile. In automobil se introduc manechine numite "OSCAR" iar automobilul in momentul impactului are o viteza de 50 km/h. Aceste manechine sunt "dotate" cu tot felul de senzori care legati la un computer arata fortele rezultate in urma impactului in diverse parti ale corpului uman.
              eu stiam ca euroncap le face la 64 km /h,tu de ce sustii ca la 50 km?mi se pare super putin !!!
                Da, asa e se fac si la 64 km/h (40mile/h), dar de regula pentu a testa centurile de siguranta si alte lemente de securitate ale autovehiculelor cat si pentru a lua in considerare posibilele accidente in orase unde viteza este limitata la 50 km/h se fac teste si pentru 50km/h.
                Spre exemplu alti producatori de elemente de siguranta pentru industria auto fac crash teste la o viteza de 55 km/h.
                Asa este, EuroNCAP fac teste la 64km/h cat si la 50 km/h.
                Oricum vitezele difera si in functie de felul testului. Pentru lovitura frontala 64km/h; pentru lovitura din lateral 50km/h.
                  la EuroNcap nu au mai bagat si T6-le pentru ca structura sasiului si in general a masinii a ramas nemodificata. Chiar si la reprezentanta Peugeot cand mi-a dat pliantul oficial de prezentare pentru 307 T6, sus in colt erau trecute 4 stele. Asa ca eu zic ca aia stiu cel mai bine si la cat de atenti sunt la detalii, daca avea 5 stele ii puneau ei 5 nu doar 4
                  Man that lives by the pistol dies by the smoke of gun ! :evillook:
