Cum sa resetam "service interval" Peugeot 206
  • Cum sa resetam "service interval" Peugeot 206
    FOLOSITI CU ATENTIE
    Peugeot 206 Service Indicator Information
    Service Indicator
    This informs you when the next service is due, according to the manufacturer's servicing schedule.
    Operation
    As soon as the ignition is switched on, and for 2 seconds (if the next service is due after more than 1000 miles) or 5 seconds (if the next service is due within 1000 miles) the spanner symbolising " service due" is lit: the trip recorder display shows you the distance remaining (in round figures) before the next service.
    If the distance remaining before the next service is less than 500 miles, then the Spanner symbol will remain lit after 5 seconds. This indicates that a service should be carried out.
    To change the Service Interval
    * Switch off the ignition
    * Press and Hold the daytrip meter button situated to the right/bottom of the Rev counter
    * Switch on the ignition
    * The display will begin a 10 second countdown.
    * Release the button before the countdown finishes
    * The service interval is displayed
    * Each brief press of the button alternates the setting
    * When the required service interval is displayed, press the button for 10 seconds to confirm.
    Zero Reset (Remove "Spanner" symbol)
    Your Peugeot dealer will carry out this operation after each service. However, if you carry out the service yourself, the reset procedure is as follows.
    * Press and hold the daytrip meter button situated to the right/bottom of the Rev counter
    * Switch on the ignition (the display begins a 10 second countdown.)
    * Keep the Button pressed for 10 seconds.
    The display shows [=0] and the service indicator (spanner) disappears[/align:572958b41d] :?:
    dlliviu
    Gold Lion
    <u>Pedal To The Metal</u>
    206 1,4 HDI - putin modificata
    DDDDDDDDD
    daca resetati counterul pt ulei?
    NU O SA PIERDETI GARANTIA.100%
    Oricum este o prostie mai ales la noi.
    DIn 100 de masini la 70 nu e setat corespunzator. In romania la mot diesel revizia nu e la 30000 ci la 15000 sau la 10000 iar la benzina nu 30000 ci 20000 sau 15000 (depinde de motorizare) O alta problema este ca nu o poti seta exact la 15000 ci sau la 14800 sau la 15200.Sa nu mai uitam ca intre revizii mai sunt si vizitele intermediare.Iar nivelul de ulei este cea mai mare tampenie creat de PSA. Niciodata nu arata exact.
    Daca vreti sa resetati counterul este simplu.Iei contactul, apesi pe butonul dreapta din bord, pui contact si o sa vezi ca incepe numaratoarea inversa de la 10 pana la 0, cand apare (=0) lasati butonul, luati contactul, il puneti inca odata si GATA.
    V-am explicat ca cateodata mai uita mecanicul care schimba uleiul sau e murdar mana si nu o reseteaza. DD
      IR
      I: Dar chestia cu resetatul intervalului de revizie pana la urma este valabila? Este si indicata?
      R: E valabila si afiseaza 2 chei in bord la contact cad crede ca mai are <1000 km pana la urmatoare revizie.
      E indicat pt 'uituci'
      Km in bord raman la fel (asa ca nu poti fenta garantia!)
      I: Pot sa setez intervalul la 8000 km!
      R: Nu vei putea seta la 8000km. Sa fii tu fericit daca ai posibilitatea de a alege 10.000. Eu personal nu am decat 30k,25k,20k,15k
      dlliviu
      Gold Lion
      Subsemnatul
      GL-57-SIM
        Readuc in actualitate thread-ul de mai sus, cu o mica precizare. La MUX din 2004 1.4e nu merge .
        Daca aveti ceva solutii dedicate, va rog, nu va sfiiti.
        Uni omeni nu stie citi....
        Contact: 0723 199959
